    4. Test Adapter Energiefluss v3.6.x GitHub/Latest
      Maxtor62 @BananaJoe last edited by Maxtor62
      @bananajoe sagte in Test Adapter Energiefluss v2.0.x GitHub/Latest:
      rgb(255,255,255,0)
      Hi, danke für die Idee, aber das geht schon in der Instanzeinstellung schief. RGB mag er scheinbar nicht.
        Maxtor62 @heinzie last edited by Maxtor62
        @heinzie
        Hi, das kannst Du auch mit dem VIS Inventwo Universal Widget realisieren, falls Du VIS benutzt.
        Einfach einen transparenten Schalter darüber legen(z-index beachten) und die Werte für +grün und -rot eingeben, die Ränder den gewünschten Farbton einstellen. Größe an Deine Energiefluss Grafik anpassen und gut.
        Hab Dir mal so ein Widget angehängt.
        [{"tpl":"i-vis-universal","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iUniversalWidgetType":"Background","iValueType":"boolean","iStateResponseTime":"0","iNavWait":"10","iButtonCol":"","iButtonActive":"","iOpacityBack":"1","iCornerRadiusUL":"0","iCornerRadiusUR":"0","iCornerRadiusLR":"0","iCornerRadiusLL":"0","iContentFlexDirection":"vertical","iContentVertAlign":"iSpace-between","iContentOrder":"orderTextImg","iOpacityCtn":"1","iTextColor":"{vis-inventwo.0.CSS.Text}","iTextSize":"16","iTextAlign":"iCenter","iTextSpaceTop":"0","iTextSpaceBottom":"0","iTextSpaceLeft":"0","iTextSpaceRight":"0","iIconSize":"50","iImgAlign":"iCenter","iImgSpaceTop":"20","iImgSpaceBottom":"0","iImgSpaceLeft":"0","iImgSpaceRight":"0","iImgRotation":"0","iImgBlinkFalse":"0","iImgBlinkTrue":"0","iShadowXOffset":"0","iShadowYOffset":"0","iShadowBlur":"0","iShadowSpread":"0","iShadowColor":"#111111","iShadowColorActive":"#111111","iShadowInnerXOffset":"0","iShadowInnerYOffset":"0","iShadowInnerBlur":"0","iShadowInnerSpread":"0","iShadowInnerColor":"","iShadowInnerColorActive":"","iBorderSize":"1","iBorderStyle":"solid","iBorderColor":"#12e802","iBorderColorActive":"#cb3438","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"shelly.0.SHSW-PM#E89F6D848CBF#1.Relay0.Switch","iValueFalse":"","iValueTrue":"3","iTextFalse":"","iTextTrue":"","iImageFalse":"","iImageTrue":"","iInvertImageCol":true,"iFlipImage":false,"nav_view":"PV","iStateResetValueTime":"0","views":["Alarm","Alexa","Anrufmonitor","Corona","Drucker","ECharts","FB_Checkpresence","Gartenbewässerung","Geschirrspüler","Licht","Meteoalarm","Multimedia","Netzwerk","Pegelalarm","Sprinkle_Control","Status","Time","View_Gross","Wetter","Yamaha"],"iImgColorFalse":"#ffffff","iImgColorTrue":"#ffffff","iImgColorFalseFilter":"filter: invert(100%) sepia(0%) saturate(2%) hue-rotate(168deg) brightness(104%) contrast(101%);","iImgColorTrueFilter":"filter: invert(100%) sepia(94%) saturate(0%) hue-rotate(248deg) brightness(106%) contrast(106%);","name":"Klima Schalter","filterkey":"EcoFlow","iValueComparison":"greater","iButtonColHover":"","iShadowColorHover":"","iShadowInnerColorHover":"","iBorderColorHover":"","iPopUpBackground":"","iPopUpPreventClickOutside":"","iPopUpShowTitle":"true","iPopUpTitle":"","iPopUpTitleColor":"","iPopUpCloseBtnColor":"#dc2e2e","iPopUpWidth":"800px","iPopUpHeight":"500px","iPopUpHeightTitle":"50","iPopUpTitleSize":"28","iPopUpPosition":"center","iPopUpPositionX":"0","iPopUpPositionY":"0","iPopUpCloseAfterSeconds":"0","iPopUpCornerRadiusUL":"12","iPopUpCornerRadiusUR":"0","iPopUpCornerRadiusLR":"12","iPopUpCornerRadiusLL":"0","iPopUpShadowXOffset":"2","iPopUpShadowYOffset":"2","iPopUpShadowBlur":"2","iPopUpShadowSpread":"1","iPopUpShadowColor":"#111111","iContentType":"image","iImgClockFace":"001","iImgClockHands":"001","iImgClockShowBorder":"1","iImgColorClockFace":"#ffffff","iImgColorHands":"#ffffff","iImgColorHandSecond":"#ff0000","iClockShowSeconds":"","iClockTimezone":"Europe/Berlin","iHtmlTextFieldFalse":"","iHtmlTextFieldTrue":"","iShadowTextXOffset":"0","iShadowTextYOffset":"0","iShadowTextBlur":"0","iShadowTextColor":"","iShadowTextColorActive":"","iHttpType":"iSend","iTextColorActive":"#f6b831","iTextDecoration":"none"},"style":{"left":"645px","top":"156px","z-index":"4","width":"110px","height":"110px"},"widgetSet":"vis-inventwo"}]
        • SKB
          SKB Developer Most Active @Maxtor62 last edited by
          @maxtor62 ah, ok. Die Farbe schaue ich mir dann nochmal an.
          Die Grafik ist insgesamt so groß, wie der Frame, den du einstellst, worin sie geladen ist.
            Maxtor62 @SKB last edited by
            @skb
            kann ich so nicht bestätigen. Wenn ich den iFrame um 50px kleiner stelle, wird die Grafik abgeschnitten. aber der Rand ist immer noch da und braucht unnötig Platz. Egal ob rechts oder unten.
            • SKB
              @maxtor62 Ich kann dir das so bestätigen. Du musst dem iframe das "Scroll-Attribut" auf "no" oder "false" geben. Dann gehen die Scrollbalken weg.
              Wie du hier an den verschiedenen Auflösungen sehen kannst:
              2022-11-13 20_39_16-test-iframe.html.png 2022-11-13 20_38_59-test-iframe.html.png 2022-11-13 20_39_33-test-iframe.html.png
                Maxtor62 @SKB last edited by Maxtor62
                @skb
                das gleiche Problem hatte wendy2702 am 29.09.2022 auch schon mal erklärt.
                iFrame ist so eingestellt.
                • SKB
                  @maxtor62 wenn VIS das nicht richtig umsetzt, kann ich da leider nicht helfen, da ich VIS nicht nutze bzw in JarVIS dies richtig dargestellt wird und alles HTML konform ist.
                    @skb
                    ok danke. Dann ist der Adapter für mich nicht brauchbar. Wünsche Dir trotzdem viel Erfolg bei Deiner Entwicklung.
                    • SKB
                      @maxtor62 Danke, ich habe eine Lösung gefunden 🙂
                      Bitte nochmal die Version installieren. Ich habe eine Datei angepasst. Damit sollte es nun problemlos gehen.
                        ManfredHi last edited by
                        Hallo. Ich habe das Problem, dass wenn ich das Frame kleiner mache, immer rechts ein Teil abgeschnitten wird.
                        Da ich keine Batterie habe, habe ich natürlich nicht den linken Bereich. Kann man das irgendwie anders einstellen, dass ich das Frame trotzdem verkleinern kann?
                        • Crazy32
                          Crazy32 last edited by
                          Moin allerseits. Ich bekomme (hoffentlich) dieses Jahr noch meine PV-Anlage mit Speicher und bin auf der Suche nach einem Widget für meine VIS über diesen Adapter gestolpert. Sieht echt gut aus! Aber irgendwie passt da was nicht. Ich habe den Adapter ohne Fehler installiert, aber ich finde den bei den Instanzen nicht. In Objekten ist ein Ordner Energiefluss vorhanden, aber der ist komplett leer.
                          Und ja, ich weiß, die Anlage ist noch nicht da, aber ich bin neugierig und wollte mir den Adapter einfach schon mal anschauen 🙂
                          Hat da jemand eine Idee?
                          SKB da_Woody 2 Replies Last reply Reply Quote 0
                          • SKB
                            SKB Developer Most Active @Crazy32 last edited by
                            @crazy32 Wie bei allen Adaptern, die du über Github installierst, musst Du die Instanz selbst hinzufügen. Dann passts!
                            Crazy32 1 Reply Last reply Reply Quote 0
                            • SKB
                              SKB Developer Most Active @ManfredHi last edited by
                              @manfredh-1 Lass mich raten - auch VIS?
                              • da_Woody
                                da_Woody @Crazy32 last edited by
                                • Crazy32
                                  Crazy32 @SKB last edited by
                                  @skb sagte in Test Adapter Energiefluss v2.0.x GitHub/Latest:
                                  @da_woody sagte in Test Adapter Energiefluss v2.0.x GitHub/Latest:
                                  Danke euch beiden!
                                  • da_Woody
                                    da_Woody @SKB last edited by da_Woody
                                    @skb die neue version ist echt super! 👍
                                    was ich nur ein bisschen schade finde, daß das auto fest vernietet ist. kannst du das eventuell zuordenbar machen?
                                    z.b. auto wird pos 7 zugeordnet? ich hab keine e-karre und würde die position gern für etwas anderes verwenden. dann hätte ich wenigstens 4 positionen.
                                    hintergrund, wenn ich in iQontrol die kachel auf 3x3 einstelle, kann ich die rechten positionen nicht benützen. klar, ich kann bildschirmgrösse verwenden, dann ist das am handy aber unleserlich.
                                    • SKB
                                      SKB Developer Most Active @da_Woody last edited by
                                      @da_woody Vielleicht nochmal die Version drüber installieren. Ich hatte eine Datei geändert, die vielleicht auch @Maxtor62 hilft.
                                      M da_Woody 2 Replies Last reply Reply Quote 1
                                        @skb
                                        yep, hat geholfen. Der Abstand zum Rand ist jetzt kleiner.
                                        • SKB
                                          @maxtor62 Und die Scrollbalken sind weg, wie ich sehe.
                                          Ich hatte schon befürchtet, ein treuer User weicht auf die vielen anderen verfügbaren Flow Adapter aus 😉
                                          • da_Woody
                                            @skb nope, hilft bei iQontrol nix. abgesehn davon, die vernietete auto-position bleibt ja tropsdem da dort.
                                            ich kann nur versuchen das in iQ zu skalieren wegen dem rechten rand.
                                            ich zeck ja nicht gern rum, aber warum muss die batterie als einziges soweit links sein?
                                            tropsdem thnx für das ding! es ist, wie es ist. neues teil, jeder hat dann so seine ideas. verbesserungen sind sicher möglich, eierlegende wollmilchsau gibts nicht!
                                            energiefluss vis visualisierung visualization
                                            149
                                            2366
                                            1183108
