    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      Thomas Braun Most Active @nhet last edited by
      @nhet
      iob upgrade bluelink --debug
      Damit sollte man mehr sehen.
      • N
        nhet @Thomas Braun last edited by
        leider nein
        pi@raspberrypi:~ $ iob upgrade bluelink --debug
        This upgrade of "bluelink" will at least introduce the following changes:
        -> 2.2.6:
        fix / extend clima & errorcounter
        Would you like to upgrade bluelink from @2.2.5 to @2.2.6 now? [(y)es, (n)o]: y
        Update bluelink from @2.2.5 to @2.2.6
        NPM version: 8.19.2
        Installing iobroker.bluelink@2.2.6... (System call)
        up to date in 11s
        152 packages are looking for funding
          run `npm fund` for details
        upload [5] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/admin.d.ts admin.d.ts video/mp2t
        upload [4] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
        upload [3] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink_old.png bluelink_old.png image/png
        upload [2] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/index_m.html index_m.html text/html
        upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/style.css style.css text/css
        upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/words.js words.js application/javascript
        pi@raspberrypi:~ $ iob update
        Used repository: Beta (latest)
        Adapter    "admin"        : 6.2.23   , installed 6.2.23
        Adapter    "backitup"     : 2.5.5    , installed 2.5.5
        Adapter    "bluelink"     : 2.2.6    , installed 2.2.5  [Updatable]
        arteck Meister Mopper 2 Replies Last reply Reply Quote 0
          arteck Developer Most Active @nhet last edited by
          @nhet ja da ist im npm was fratze bei dir..
          install den adapter mal von GIT..einmalig
          • Meister Mopper
            Meister Mopper @nhet last edited by
            @nhet
            Ich vermute mal, Du hast das npm 8 Problem und kannst gar keine Adapter aktualisieren.
            Mittlerweile ist das hier im Forum mehrfach dokumentiert. Da liegen irgendwelche Geisterverzeichnisse im System.
            Thomas Braun N 2 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @Meister Mopper last edited by
              @meister-mopper
              Das müsste sich aber bei --debug dann anders darstellen.
              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
              Würde die aber ausspucken.
              • Meister Mopper
                Meister Mopper @Thomas Braun last edited by
                Tatsächlich hatte ich mit --debug auch keine Auffälligkeiten, trotzdem wurde kein Adapter angehoben.
                • N
                  nhet @Meister Mopper last edited by
                  @meister-mopper, ich sag mal: alle anderen Adapter werden korrekt geupdatet.
                  Thomas Braun Meister Mopper 4 Replies Last reply Reply Quote 0
                    @nhet
                    Check es mit der Befehlszeile von oben.
                    • Meister Mopper
                      @nhet
                      Okay, dann muss es etwas anderes sein. Bei mir ließ sich nichts aktualisieren.
                        @nhet
                        Schau mal node/npm an:
                        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          Thomas Braun Most Active @nhet last edited by Thomas Braun
                          @nhet
                          Da stimmt was in den release-Dateien nicht.
                          Auf meinem System:
                          2022-11-14 18:58:44.556  - info: host.chet iobroker Installing iobroker.bluelink@2.2.6... (System call)
                          2022-11-14 18:59:00.352  - info: host.chet iobroker npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          2022-11-14 18:59:04.288  - info: host.chet iobroker added 44 packages, removed 1018 packages, and changed 1 package in 19s
                          2022-11-14 18:59:04.294  - info: host.chet iobroker
                          2022-11-14 18:59:04.295  - info: host.chet iobroker 88 packages are looking for funding  run `npm fund` for details
                          2022-11-14 18:59:04.370  - info: host.chet iobroker host.chet install adapter bluelink
                          Aber sofort wird der Adapter zum Update vorgeschlagen:
                          echad@chet:~ $ iobroker update -u
                          Used repository: beta
                          Und oh wunder...
                          https://github.com/Newan/ioBroker.bluelink/issues/59
                          eric2905 created this issue in Newan/ioBroker.bluelink
                          closed Update 2.2.5 ==> 2.2.6 endless #59
                            @thomas-braun hab ich doch schon oben geschrieben
                              A Former User @Guest last edited by A Former User
                              @ilovegym @arteck
                              ich habe es auch mal mit meinem IONIQ 5 getestet in der Version 2.2.6 und ich habe das gleiche Problem wie @ilovegym . (Weil ich mir die Funktionserweiterung beim Fernklimatisieren auch sehr Wünsche)
                              2022-11-16 10:54:33.825 - info: bluelink.0 (2012726) Login to api
                              2022-11-16 10:54:38.340 - info: bluelink.0 (2012726) 1 Vehicles found
                              2022-11-16 10:54:52.136 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
                              2022-11-16 10:54:52.183 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
                              2022-11-16 10:54:52.189 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
                              2022-11-16 10:54:52.196 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
                              2022-11-16 10:54:52.261 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
                              2022-11-16 10:54:57.137 - info: bluelink.0 (2012726) Starting clima for vehicle
                              2022-11-16 10:54:57.292 - error: bluelink.0 (2012726) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              2022-11-16 10:54:57.293 - error: bluelink.0 (2012726) unhandled promise rejection: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
                              2022-11-16 10:54:57.295 - error: bluelink.0 (2012726) ManagedBluelinkyError: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
                              at U (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:11700)
                              at G. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:16700)
                              at Generator.throw ()
                              at a (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
                              at runMicrotasks ()
                              at processTicksAndRejections (internal/process/task_queues.js:95:5)
                              2022-11-16 10:54:57.297 - error: bluelink.0 (2012726) @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
                              2022-11-16 10:54:57.310 - info: bluelink.0 (2012726) Adapter bluelink cleaned up everything...
                              2022-11-16 10:54:57.312 - info: bluelink.0 (2012726) terminating
                              2022-11-16 10:54:57.315 - warn: bluelink.0 (2012726) Terminated (UNCAUGHT_EXCEPTION): Without reason
                              In Version 2.2.3., die ich davor (und auch nach dem Test wieder) genutzt habe, habe ich das Problem nicht.
                                arteck Developer Most Active @Guest last edited by
                                @williwilliwilli sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                im ernst...
                                  A Former User @arteck last edited by
                                  @arteck ja, denn der Fehler kommt immer! hab ich auch. In der App funktionierts ja.
                                  Mit der vorigen Version des Adapters gehts. ( halt ohne die Temp zu setzen etc.)
                                    arteck Developer Most Active @Guest last edited by arteck
                                    @ilovegym installier mal meine version
                                    https://github.com/arteck/ioBroker.bluelink
                                    und mach nochmal.. dann log schauen nach -->
                                    ? ? 2 Replies Last reply Reply Quote 0
                                      @arteck
                                      Hello, gemacht, Adapter zeigt Version 2.2.3 an.
                                      Steuern der Clima geht nicht, wenn ich auf start clima druecke, kommt ein undefined. Ein Lock/Unlock funktioniert, der vorige Fehler von Version 2.2.6 ist weg.
                                      ilovegym@VMC123-iobroker /opt/iobroker $ iob logs --watch | grep bluelink.0
                                      2022-11-17 08:32:13.914  - info: host.VMC123-iobroker iobroker Update "system.adapter.bluelink.0"
                                      2022-11-17 08:32:13.922  - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 (force=false, process=true)
                                      2022-11-17 08:32:13.923  - info: bluelink.0 (635883) Got terminate signal TERMINATE_YOURSELF
                                      2022-11-17 08:32:13.924  - info: bluelink.0 (635883) Adapter bluelink cleaned up everything...
                                      2022-11-17 08:32:13.924  - info: bluelink.0 (635883) terminating
                                      2022-11-17 08:32:13.924  - info: bluelink.0 (635883) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2022-11-17 08:32:13.925  - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 send kill signal
                                      2022-11-17 08:32:14.723  - info: host.VMC123-iobroker instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2022-11-17 08:32:17.191  - info: host.VMC123-iobroker instance system.adapter.bluelink.0 started with pid 687175
                                      2022-11-17 08:32:18.289  - info: bluelink.0 (687175) starting. Version 2.2.3 (non-npm: arteck/ioBroker.bluelink#f3613b00ef64bb48fe5c5568a146f79bfbc18c81) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.18.1, js-controller: 4.0.23
                                      2022-11-17 08:32:18.302  - info: bluelink.0 (687175) Login to api
                                      2022-11-17 08:32:23.123  - info: bluelink.0 (687175) 1 Vehicles found
                                      2022-11-17 08:34:00.504  - info: bluelink.0 (687175) Starting clima for vehicle
                                      2022-11-17 08:34:00.506  - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl
                                      2022-11-17 08:34:00.506  - info: bluelink.0 (687175) --> airTemp KMHKR81AFNU0.control.set.airTemp
                                      2022-11-17 08:34:00.507  - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost
                                      2022-11-17 08:34:00.507  - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating
                                      2022-11-17 08:34:00.639  - error: bluelink.0 (687175) undefined
                                      2022-11-17 08:35:34.601  - info: bluelink.0 (687175) Starting unlock for vehicle
                                      2022-11-17 08:35:34.763  - info: bluelink.0 (687175) Unlock successful
                                      2022-11-17 08:35:54.255  - info: bluelink.0 (687175) Starting lock for vehicle
                                      2022-11-17 08:35:54.395  - info: bluelink.0 (687175) Lock successful
                                      2022-11-17 08:36:02.288  - info: bluelink.0 (687175) Starting clima for vehicle
                                      2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl
                                      2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> airTemp KMHKR81AFN.control.set.airTemp
                                      2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost
                                      2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating
                                      2022-11-17 08:36:02.414  - error: bluelink.0 (687175) undefined
                                      Ein komplettes Debuglog kann ich dir gerne per Mail senden...??
                                        @arteck
                                        same here
                                        2022-11-17 08:43:04.526 - info: bluelink.0 (2076917) Starting clima for vehicle
                                        2022-11-17 08:43:04.534 - info: bluelink.0 (2076917) --> airCtrl KMHKR81XXXXXXXXX.control.set.airCtrl
                                        2022-11-17 08:43:04.535 - info: bluelink.0 (2076917) --> airTemp KMHKR81XXXXXXXXX.control.set.airTemp
                                        2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> defrost KMHKR81XXXXXXXXX.control.set.defrost
                                        2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> heating KMHKR81XXXXXXXXX.control.set.heating
                                        2022-11-17 08:43:04.982 - error: bluelink.0 (2076917) undefined
                                          man sollte nix neben bei machen
                                          installiert nochmal..ich will mal schauen ob die zahlen richtig übernommen werden
                                            @arteck
                                            da kommt jetzt:
                                            2022-11-17 10:10:59.095  - debug: bluelink.0 (823776) New Event for state: {"val":true,"ack":false,"ts":1668676259094,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1667470001835}
                                            2022-11-17 10:10:59.095  - debug: bluelink.0 (823776) ID: "bluelink.0.KMHKR.control.start"
                                            2022-11-17 10:10:59.095  - info: bluelink.0 (823776) Starting clima for vehicle
                                            2022-11-17 10:10:59.097  - info: bluelink.0 (823776) --> [object Object]
                                            2022-11-17 10:10:59.098  - info: bluelink.0 (823776) --> [object Object]
                                            2022-11-17 10:10:59.238  - error: bluelink.0 (823776) {"source":{"name":"HTTPError","hostname":"prd.eu-ccapi.hyundai.com","method":
                                            und zum schluss im text wieder Service temporary unavalable... ist anscheinend die allgemeine Fehlermeldung, wenn sonst nix passt... ??
                                            81.1k
                                            2270
                                            849620
