    4. Test Adapter mihome-cloud
      tombox @Guest last edited by
      @hannnes Ich habe eine neue Funktion integriert das Geräte via Spec versucht werden abzurufen und nicht nur via Plugin.
      Einfach alle Objekte von mihome-cloud löschen und dann neuinstallierten und schauen was unter status und remote kommt bzw ob man was via remote steuern kann
      Thomas Braun ? 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @tombox last edited by
        @tombox
        Dafür sind jetzt meine Kaffeearten wieder futsch.
        Und viele Errors:
        2022-11-13 19:40:05.722  - error: mihome-cloud.0 (76460) TypeError: service.properties is not iterable
        2022-11-13 19:40:05.725  - error: mihome-cloud.0 (76460) TypeError: service.properties is not iterable
            at MihomeCloud.extractRemotesFromSpec (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:422:38)
            at async /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:267:15
            at async MihomeCloud.getDeviceList (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:204:5)
            at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:94:7)
        2022-11-13 19:40:07.897  - info: tuya.0 (1233) 012003832c3ae840bc99: Error on Reconnect: connection timed out
        2022-11-13 19:40:08.584  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0002228321
        2022-11-13 19:40:08.585  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
            at JSON.parse (<anonymous>)
            at MihomeCloud.parseResponse (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:859:19)
            at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:757:37
            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            at async MihomeCloud.updateDevices (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:732:9)
            at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:96:7)
        2022-11-13 19:40:10.275  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0002791f32
        2022-11-13 19:40:10.275  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:10.276  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:11.602  - info: mihome-cloud.0 (76460) Error getting Status of the device via Plugin for Klima WZ (blt.3.rauh1qas4400) with {"id":0,"method":"nnerF","accessKey":"IOS00026747c5acafc2","params":[]}
        2022-11-13 19:40:11.602  - info: mihome-cloud.0 (76460) {"code":-1,"message":"bluetooth device does not support sending rpc"}
        2022-11-13 19:40:13.047  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001c0ff0a
        2022-11-13 19:40:13.048  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:14.767  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000201afb5
        2022-11-13 19:40:14.768  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:16.460  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000210a8ce
        2022-11-13 19:40:16.461  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:17.932  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d00021126f7
        2022-11-13 19:40:17.932  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:17.933  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:21.307  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001ad43b1
        2022-11-13 19:40:21.307  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:21.308  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:22.783  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001c1e912
        2022-11-13 19:40:22.784  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:22.785  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:24.465  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0002150d0a
        2022-11-13 19:40:24.465  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:24.466  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:26.137  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000289edfa
        2022-11-13 19:40:26.137  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:26.138  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:31.673  - error: mihome-cloud.0 (76460) /home/rpc/63722155
        2022-11-13 19:40:31.673  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:31.674  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:33.025  - info: mihome-cloud.0 (76460) Error getting Status of the device via Plugin for Klima SZ (blt.3.raujllfo4000) with {"id":0,"method":"nnerF","accessKey":"IOS00026747c5acafc2","params":[]}
        2022-11-13 19:40:33.025  - info: mihome-cloud.0 (76460) {"code":-1,"message":"bluetooth device does not support sending rpc"}
        2022-11-13 19:40:34.750  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001dbbcf1
        2022-11-13 19:40:34.751  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:34.752  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:36.253  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000289ebbe
        2022-11-13 19:40:36.253  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:36.254  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:37.961  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d000289ebbe
        2022-11-13 19:40:37.962  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:39.626  - error: mihome-cloud.0 (76460) /home/rpc/78328901
        2022-11-13 19:40:39.626  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:39.627  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:41.397  - error: mihome-cloud.0 (76460) /home/rpc/90211825
        2022-11-13 19:40:41.398  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:41.399  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:43.109  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001bb4d1d
        2022-11-13 19:40:43.109  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:43.110  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:44.766  - error: mihome-cloud.0 (76460) /home/rpc/lumi.158d0001bb5435
        2022-11-13 19:40:44.766  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
        2022-11-13 19:40:44.767  - error: mihome-cloud.0 (76460) SyntaxError: "[object Object]" is not valid JSON
          tombox @Thomas Braun last edited by
          @thomas-braun Ok habe noch Fehler handling eingebaut
          Thomas Braun T 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @tombox last edited by Thomas Braun
            @tombox
            Fehler weg, Kaffeesorten wieder da. 🙂
            An- und Ausschlten geht sogar schon.
            Dann kann ich demnächst der Alexa ja sagen, sie soll Kaffee kochen.
              Tschaeens @tombox last edited by
              @tombox
              vielen Dank für den Adapter
              Airpurifier 2s lässt sich ebenfalls steuern!
              Fanlevel funzt auch
              der Wert
              mihome-cloud.0.132101241.remote.on -> Air Purifier Switch Status
              springt immer wieder auf false zurück. Setze ich diesen auf true geht der Ventilator an aber kurze Zeit später geht er wieder auf false. Ein erneutes false schaltet Gerät aus.
              Zur Info.
              T T 2 Replies Last reply Reply Quote 0
                tombox @Tschaeens last edited by
                @tschaeens Kannst du noch ein screenshot machen mit aufgeklappten remote remotePlugin status und statusPlugin
                  @tombox
                  Langt dir dieser Screenshot?
                  Lg
                    @tschaeens passt kann man unter remoteplugin was steuern?
                    Warum ist der filter hours auf null siehst du da mehr in der app?
                    was kann man noch unter pm2 sehen?
                      @tombox
                      unter remoteplugin kann man nichts steuern. Dort steht schon immer null. In der App ist die Lebensdauer vom Filter enthalten. Unter pm2 ist der Staubsensor. Der funzt auch. Ich kann nur unter remote schalten.
                        A Former User @tombox last edited by A Former User
                        @tombox Hammer!! Es funktioniert*. Ich bin beeindruckt.
                        *ich kann die Ventilatoren bedienen. Wozu sind die kryptischen Dinge in dem Feld, wo man den Wert setzt? wie z.B der Qualitätscode...
                          A Former User last edited by
                          Gerade im log entdeckt:
                          mihome-cloud.0
                          2022-11-15 16:39:54.478	error	Error: Client network socket disconnected before secure TLS connection was established at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/dist/node/axios.cjs:725:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/dist/node/axios.cjs:2467:25) at RedirectableRequest.emit (node:events:513:28) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:513:28) at ClientRequest.req.emit (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/http-cookie-agent/dist/http/create_cookie_agent.js:109:16) at TLSSocket.socketErrorListener (node:_http_client:494:9) at TLSSocket.emit (node:events:513:28) at emitErrorNT (node:internal/streams/destroy:157:8) at emitErrorCloseNT (node:internal/streams/destroy:122:3)
                          mihome-cloud.0
                          2022-11-15 16:39:54.477	error	Error: Client network socket disconnected before secure TLS connection was established
                          mihome-cloud.0
                          2022-11-15 16:39:54.477	error	/miotspec/action
                          • JackDaniel
                            JackDaniel last edited by
                            hier kommt das im log
                            mihome-cloud.0
                            2022-11-15 18:48:33.791	error	TypeError: service.properties is not iterable
                            mihome-cloud.0
                            2022-11-15 18:48:31.119	warn	Please report this url to the developer: https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip
                            mihome-cloud.0
                            2022-11-15 18:48:31.118	warn	Remote commmands too long for roborock.vacuum.s5
                            mihome-cloud.0
                            2022-11-15 18:47:50.056	error	Please set username and password in the instance settings
                              thoml last edited by
                              @tombox Mein Dreame L10S Ultra wird auch erkannt, nur werden sehr wenige Datenpunkte befüllt. Die befüllten Datenpunkte lassen sich aber auch steuern und werden auch sofort in der App aktualisiert.
                              Es ist auch noch ein Wasserkocher hinterlegt.
                              Falls du Zugriff auf die Geräte brauchst, gib eben bescheid.
                                tombox @thoml last edited by
                                @thoml Ja Zugriff hilft immer beim debuggen
                                tombox2020@gmail.com
                                  Mein Netzwerk ist mehrmals zusammengebrochen. Ich habe dann den Schuldigen gefunden. Es ist ioBroker mit der Abfrage nach de.api.io.mi.com
                                  Da kommt doch der Verdacht auf, dass das mit dem Abtauchen des Adapters zusammenhängt.
                                  Der meldet:
                                    @hannnes Was sagt der log gibt es da ein fehler
                                      @tombox
                                      dazu muss erwähnt werden, dass ich gerade AdGuard mit vielen neuen blacklisten ausgestattet habe.
                                      ![94938bc2-5ed7-4085-8aa5-87326685dca7-image.png](/assets/uploads/files/1668719436239-94938bc2-5ed7-4085-8aa5-87326685dca7-image-resized.png)
                                      ```2022-11-17 19:06:58.327 - error: host.HomeServer01 Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                                      2022-11-17 19:06:59.243 - error: info.0 (3798) info.0 already running
                                      2022-11-17 19:07:01.830 - error: host.HomeServer01 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2022-11-17 19:07:02.773 - info: javascript.0 (3744) received all states
                                      2022-11-17 19:07:04.202 - error: trashschedule.0 (3862) trashschedule.0 already running
                                      2022-11-17 19:07:04.209 - warn: trashschedule.0 (3862) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2022-11-17 19:07:05.361 - error: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript_test: ReferenceError: Init is not defined
                                      2022-11-17 19:07:05.364 - error: javascript.0 (3744) at script.js.Geraete-Skripts.Xiaomi-Skript_test:37:1
                                      2022-11-17 19:07:05.366 - error: javascript.0 (3744) at script.js.Geraete-Skripts.Xiaomi-Skript_test:484:3
                                      2022-11-17 19:07:05.367 - error: javascript.0 (3744) at Script.runInContext (node:vm:141:12)
                                      2022-11-17 19:07:08.717 - error: trashschedule.1 (3889) trashschedule.1 already running
                                      2022-11-17 19:07:09.598 - info: host.HomeServer01 instance system.adapter.mihome-cloud.0 started with pid 3941
                                      2022-11-17 19:07:10.109 - error: host.HomeServer01 instance system.adapter.trashschedule.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2022-11-17 19:07:10.309 - info: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: You are already logged in, login canceled
                                      2022-11-17 19:07:10.311 - info: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: Retrieving your in de registered MiHome Devices
                                      2022-11-17 19:07:10.329 - error: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: Error: Pls login before make any request
                                      2022-11-17 19:07:10.330 - error: javascript.0 (3744) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:67:13)
                                      2022-11-17 19:07:10.332 - error: javascript.0 (3744) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:29)
                                      2022-11-17 19:07:10.336 - error: javascript.0 (3744) at Init (script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2:874:50)
                                      2022-11-17 19:07:10.338 - error: javascript.0 (3744) at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                      2022-11-17 19:07:10.382 - error: web.0 (3923) web.0 already running
                                      2022-11-17 19:07:10.377 - info: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: You are already logged in, login canceled
                                      2022-11-17 19:07:10.378 - info: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: Retrieving your in de registered MiHome Devices
                                      2022-11-17 19:07:10.385 - error: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: Error: Pls login before make any request
                                      2022-11-17 19:07:10.386 - error: javascript.0 (3744) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:67:13)
                                      2022-11-17 19:07:10.386 - error: javascript.0 (3744) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:29)
                                      2022-11-17 19:07:10.387 - error: javascript.0 (3744) at Init (script.js.Geraete-Skripts.Xiaomi-Skript:874:50)
                                      2022-11-17 19:07:10.393 - error: javascript.0 (3744) at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                      2022-11-17 19:07:11.834 - error: host.HomeServer01 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2022-11-17 19:07:11.835 - info: host.HomeServer01 Restart adapter system.adapter.web.0 because enabled
                                      2022-11-17 19:07:15.632 - error: mihome-cloud.0 (3941) mihome-cloud.0 already running
                                      2022-11-17 19:07:15.663 - warn: mihome-cloud.0 (3941) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2022-11-17 19:07:16.385 - error: host.HomeServer01 instance system.adapter.mihome-cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2022-11-17 19:07:16.386 - info: host.HomeServer01 Restart adapter system.adapter.mihome-cloud.0 because enabled
                                      2022-11-17 19:07:54.479 - info: mihome-cloud.0 (4337) Login to MiHome Cloud
                                      2022-11-17 19:07:59.792 - error: mihome-cloud.0 (4337) Error: getaddrinfo EAI_AGAIN account.xiaomi.com
                                      2022-11-17 19:07:59.804 - error: mihome-cloud.0 (4337) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2022-11-17 19:07:59.810 - error: mihome-cloud.0 (4337) unhandled promise rejection: Cannot read properties of undefined (reading '_sign')
                                      2022-11-17 19:07:59.817 - error: mihome-cloud.0 (4337) TypeError: Cannot read properties of undefined (reading '_sign')
                                      at MihomeCloud.login (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:133:20)
                                      at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:91:5)
                                      2022-11-17 19:07:59.818 - error: mihome-cloud.0 (4337) Cannot read properties of undefined (reading '_sign')
                                      2022-11-17 19:07:59.844 - info: mihome-cloud.0 (4337) terminating
                                      2022-11-17 19:07:59.847 - warn: mihome-cloud.0 (4337) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2022-11-17 19:08:00.491 - error: host.HomeServer01 instance system.adapter.mihome-cloud.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      2022-11-17 19:08:00.492 - info: host.HomeServer01 Restart adapter system.adapter.mihome-cloud.0 because enabled
                                        @hannnes Ok das Problem ist abgefangen
                                          @tombox
                                          ich hab ne Verständnisfrage: Wie fängst Du das Problem ab ohne dass ich neu installieren muss? Oder soll ich neu installieren?
                                            @hannnes Ich habe es in der GitHub version abgefangen. Wenn du die Änderung haben möchtest musst du neuinstallierten
                                            225
                                            37512
