    4. Fehlermeldungen bei Installation mac
      thoduh last edited by
      Also, hab schon einiges Versucht, jetzt nochmal von Anfang an, genau nach Anleitung, kommt dieser Fehler:
      Last login: Tue Jul 25 15:41:48 on ttys001
      MacMini-LAN:~ MacMini$ cd /Users/MacMini/Documents/ioBroker
      MacMini-LAN:ioBroker MacMini$ npm install iobroker --unsafe-perm
      npm ERR! code ENOSELF
      npm ERR! Refusing to install package with name "iobroker" under a package
      npm ERR! also called "iobroker". Did you name your project the same
      npm ERR! as the dependency you're installing?
      npm ERR!
      npm ERR! For more information, see:
      npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
      npm ERR!     /Users/MacMini/.npm/_logs/2017-07-25T13_44_45_150Z-debug.log
      MacMini-LAN:ioBroker MacMini$</https:>
      Logfile:
      0 info it worked if it ends with ok
      1 verbose cli [ '/usr/local/bin/node',
      1 verbose cli   '/usr/local/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'iobroker',
      1 verbose cli   '--unsafe-perm' ]
      2 info using npm@5.3.0
      3 info using node@v8.2.1
      4 verbose npm-session 8862e681e9efcc76
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 http fetch GET 304 https://registry.npmjs.org/iobroker 253ms (from cache)
      8 silly pacote tag manifest for iobroker@latest fetched in 272ms
      9 silly install loadIdealTree
      10 silly install cloneCurrentTreeToIdealTree
      11 silly install loadShrinkwrap
      12 silly install loadAllDepsIntoIdealTree
      13 verbose stack Error: Refusing to install package with name "iobroker" under a package
      13 verbose stack also called "iobroker". Did you name your project the same
      13 verbose stack as the dependency you're installing?
      13 verbose stack
      13 verbose stack For more information, see:
      13 verbose stack     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">
      13 verbose stack     at checkSelf (/usr/local/lib/node_modules/npm/lib/install/validate-args.js:64:14)
      13 verbose stack     at Array. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
      13 verbose stack     at LOOP (/usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:15:14)
      13 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:18:7
      13 verbose stack     at hasMinimumFields (/usr/local/lib/node_modules/npm/lib/install/validate-args.js:30:12)
      13 verbose stack     at chain (/usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:20:5)
      13 verbose stack     at /usr/local/lib/node_modules/npm/lib/install/validate-args.js:16:5
      13 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:35
      13 verbose stack     at Array.forEach (native)
      13 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:11
      13 verbose stack     at asyncMap (/usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:51:8)
      13 verbose stack     at module.exports (/usr/local/lib/node_modules/npm/lib/install/validate-args.js:15:3)
      14 verbose cwd /Users/MacMini/Documents/ioBroker
      15 verbose Darwin 16.7.0
      16 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker" "--unsafe-perm"
      17 verbose node v8.2.1
      18 verbose npm  v5.3.0
      19 error code ENOSELF
      20 error Refusing to install package with name "iobroker" under a package
      20 error also called "iobroker". Did you name your project the same
      20 error as the dependency you're installing?
      20 error
      20 error For more information, see:
      20 error     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">
      21 verbose exit [ 1, true ]</https:></anonymous></anonymous></anonymous></https:>
      • BuZZy
        BuZZy last edited by
        Was hast du runtergeladen?
        https://github.com/ioBroker/ioBroker.js-controller
        oder
        https://github.com/ioBroker/ioBroker ???
        Sieht für mich aus als hättest du https://github.com/ioBroker/ioBroker runtergeladen..
        In der Docu ist der falsche Link drin.
        Versuch bitte mal:
        Alles löschen was du runtergeladen hast, dann "npm clean" ausführen, dann https://github.com/ioBroker/ioBroker.js … master.zip runterladen. ( NICHT https://github.com/ioBroker/ioBroker/archive/master.zip!!!! )
        Dann weiter wie in der Docu:
        ` > einen Ordner „iobroker“ an einem beliebigen Ort erstellen (z.B. unter /User/Dokumente)
        das .zip-file in diesen Ordner kopieren
        Im Terminal in den soeben erstellten Ordner (z.B. „ioBroker“) gehen "cd /iobroker".
        Tipp: Im Terminal cd eintippen und eben erstellten Ordner mir der Maus ins Terminalfenster ziehen.
        Dann Return drücken.
        ioBroker installieren "npm install iobroker –unsafe-perm"
        im Terminal in das Unterverzeichnis iobroker.js-controller wechseln "cd node_modules/iobroker.js-controller"
        Die Datei iobroker ausführbar machen "chmod +x iobroker"
        Den Controller starten "node controller.js"
        Nach der Installation den Browser öffnen und in der Adressleiste http://localhost:8081 eingeben `
          @BuZZy:
          In der Docu ist der falsche Link drin. `
          Sorry, das kommt davon, wenn man mal eben in einem unbekannten Tutorial einen Link einfügt. :oops: :oops: :oops:
          Habe korrigiert.
          Hoffentlich korrekt.
          Rainer
            OK, jetzt kommt folgendes:
            > iobroker@1.0.0 install /Users/MacMini/Documents/ioBroker/node_modules/iobroker
            > node lib/setup.js
            npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/ioBroker
            node-pre-gyp info it worked if it ends with ok
            node-pre-gyp verb cli [ '/usr/local/bin/node',
            node-pre-gyp verb cli   '/Users/MacMini/Documents/ioBroker/node_modules/serialport/node_modules/.bin/node-pre-gyp',
            node-pre-gyp verb cli   'install',
            node-pre-gyp verb cli   '--fallback-to-build' ]
            node-pre-gyp info using node-pre-gyp@0.6.32
            node-pre-gyp info using node@8.2.1 | darwin | x64
            node-pre-gyp verb command install []
            node-pre-gyp info check checked for "/Users/MacMini/Documents/ioBroker/node_modules/serialport/build/Release/serialport.node" (not found)
            node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
            node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
            node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
            node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.2.1 (node-v57 ABI) (falling back to source compile with node-gyp)
            node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
            node-pre-gyp verb command build [ 'rebuild' ]
            ../src/serialport.cpp:90:44: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
              return getValueFromObject(options, key)->ToInt32()->Int32Value();
            /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9336:21: note: 'ToInt32' has been explicitly marked deprecated here
            Local <int32>Value::ToInt32() const {
            ../src/serialport.cpp:102:44: warning: 'ToNumber' is deprecated [-Wdeprecated-declarations]
              return getValueFromObject(options, key)->ToNumber()->NumberValue();
            /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9300:22: note: 'ToNumber' has been explicitly marked deprecated here
            Local <number>Value::ToNumber() const {
            ../src/serialport.cpp:174:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                int fd = argv[1]->ToInt32()->Int32Value();
            ../src/serialport.cpp:193:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
              int fd = info[0]->ToInt32()->Int32Value();
            ../src/serialport.cpp:217:108: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
              baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
            ../src/serialport.cpp:252:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:369:24: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
              baton->fd = info[0]->ToInt32()->Int32Value();
            ../src/serialport.cpp:480:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:528:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
            ../src/serialport.cpp:585:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
            10 warnings generated.
            ../src/serialport_unix.cpp:44:101: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
              result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
            ../src/serialport_unix.cpp:45:103: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
              result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
            2 warnings generated.
            ../src/serialport_poller.cpp:86:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
              obj->fd_ = info[0]->ToInt32()->Int32Value();
            1 warning generated.
            node-pre-gyp info ok
            npm notice created a lockfile as package-lock.json. You should commit this file.
            npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBroker
            shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
            path.js:1163
                      cwd = process.cwd();
            Error: ENOENT: no such file or directory, uv_cwd
                at Object.resolve (path.js:1163:25)
                at Function.Module._resolveLookupPaths (module.js:408:17)
                at Function.Module._resolveFilename (module.js:480:22)
                at Function.Module._load (module.js:437:25)
                at Module.require (module.js:513:17)
                at require (internal/module.js:11:18)
                at /usr/local/lib/node_modules/npm/bin/npm-cli.js:19:21
                at Object. <anonymous>(/usr/local/lib/node_modules/npm/bin/npm-cli.js:92:3)
                at Module._compile (module.js:569:30)
                at Object.Module._extensions..js (module.js:580:10)
            Cannot install as normal user. Try sudo...
            sudo npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBroker
            Password:
            Password:Sorry, try again.
            path.js:1163
            npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBroker
            path.js:1163
            sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBroker
            path.js:1163
            Could not find "/Users/MacMini/Documents/ioBroker/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
            Non-critical error: ENOENT: no such file or directory, mkdir '/Users/MacMini/Documents/ioBroker/node_modules/iobroker/lib/../../../log'
            + iobroker@1.0.0
            added 46 packages in 89.892s
            MacMini-LAN:ioBroker MacMini$</anonymous></anonymous></anonymous></anonymous></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
            Logfile:
            1 verbose cli   'iobroker.js-controller',
            1 verbose cli   '--production',
            1 verbose cli   '--prefix',
            1 verbose cli   '/Users/MacMini/Documents/ioBroker' ]
            4 verbose npm-session 5c87be63f17774e9
            7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 396ms (from cache)
            8 silly pacote tag manifest for iobroker.js-controller@latest fetched in 432ms
            13 verbose stack Error: Refusing to install package with name "iobroker.js-controller" under a package
            13 verbose stack also called "iobroker.js-controller". Did you name your project the same
            13 verbose stack
            14 verbose cwd /Users/MacMini/Documents/ioBroker/node_modules/iobroker
            16 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/Users/MacMini/Documents/ioBroker"
            20 error Refusing to install package with name "iobroker.js-controller" under a package
            20 error also called "iobroker.js-controller". Did you name your project the same
            20 error
            • BuZZy
              Da scheint auf Github etwas nicht mehr vorhanden zu sein. Siehe 404 Fehler in deinem Log.
                Das Verzeichnis existiert nicht:
                MacMini-LAN:ioBroker MacMini$ cd node_modules/iobroker.js-controlle
                -bash: cd: node_modules/iobroker.js-controlle: No such file or directory
                  Diese 404 (zumindest die die ich auf die schnelle gefunden habe) sind "normal".
                  Beim serial port wird zuerst versucht ein fertiges Paket zu installieren. Dieses wird für Darwin nicht gefunden (also 404) dann geht die Installation in den build über und bastelt sich das Paket selber.
                  Also don't panic.
                  Aber während ich dies tippe kommt mir noch eine Idee, die kann ich aber nur in den Raum stellen, da ich mich mit Äpfeln gar nicht auskenne:
                  Bei RasPi et al. benötigt die Installation des serialports Root-Rechte. wie wird das Paket unter OS X installiert?
                  gibt es da auch so etwas wie root oder Administrator-Rechte?
                  Rainer
                    Das wird versucht mit "sudo", wenn ich das richtig sehe:
                    • BuZZy
                      Versuch eine Ebene höher zu wechseln "cd .." dann wieder rein in das Verzeichnis mit "cd iobroker"
                      Dann nochmal die Installation versuchen (eventuell mit sudo)?
                      Wie oben gesagt:
                      Der Eintrag "error retrieving current directory: getcwd: cannot access parent directories: No such file or directory"
                      sagt eigentlich dass das Script nicht weiß wo es gerade ist..
                      Also raus aus dem Ordner und nochmal rein im gleichen Terminalfenster und dann nochmal die Installation versuchen.
                        Leider auch nicht:
                        MacMini-LAN:ioBroker MacMini$ cd ..
                        MacMini-LAN:Documents MacMini$ cd iobroker
                        MacMini-LAN:iobroker MacMini$ sudo npm install iobroker --unsafe-perm
                        Password:
                        > node lib/setup.js
                        npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
                        npm ERR! also called "iobroker.js-controller". Did you name your project the same
                        npm ERR!
                        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-25T17_31_42_595Z-debug.log
                        npm ERR!
                        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-25T17_31_45_952Z-debug.log
                        Write "./iobroker start" to start the ioBroker
                        Cannot set permissions of /Users/MacMini/Documents/ioBroker/node_modules/iobroker.js-controller/iobroker
                        You can still manually copy
                        Cannot create file /usr/bin/iobroker!. Non critical
                        You can manually copy file into /usr/bin/. Just write:
                            sudo cp /Users/MacMini/Documents/ioBroker/node_modules/iobroker/install/iobroker /usr/bin/
                            sudo chmod 777 /usr/bin/iobroker
                        + iobroker@1.0.0
                        added 46 packages and removed 167 packages in 92.075s
                        MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controller
                        -bash: cd: node_modules/iobroker.js-controller: No such file or directory
                        MacMini-LAN:iobroker MacMini$</https:></https:></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
                        • BuZZy
                          Okay, ändere mal den Ordnernamen "/Users/MacMini/Documents/ioBroker/" in "/Users/MacMini/Documents/ioBrokermac/" also den ioBroker ordner in ioBrokermac umbennen.
                          Dann die installation nochmal versuchen. Gibts wieder einen Fehler?
                          Dann:
                          Existiert der Ordner iobroker.js-controller in dem neu umbenannten ioBrokermac Ordner?
                          Wenn ja, diesen auch umbenennen in iobrokermac.js-controller, dann in diesen Ordner reinwechseln und dort "sudo npm install iobroker.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac"
                          oder eventuell
                          "sudo npm install iobrokermac.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac"
                          oder eventuell
                          "sudo npm install iobroker.js-controller --production"
                          oder eventuell
                          "sudo npm install iobrokermac.js-controller --production" ... 😄 Versuch macht kluch.. Oder wie heißt es so schön? 😄
                            Es kann sich hier auch um Zugriffsrechte handeln.
                            Bei der ioBroker Installation auf Linux muss der Ordner iobroker ALLE Rechte (777) haben.
                            Rainer
                            • BuZZy
                              Momentan sehe ich keine Probleme außer
                              ` > npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
                              npm ERR! as the dependency you're installing? `
                              npm macht manchmal Probleme wenn der Ordnername der gleiche ist wie der von dem Paket welches installiert werden soll. Deswegen bitte nochmal meine Tipps von http://forum.iobroker.net/viewtopic.php?f=17&t=7343#p76997 ausprobieren und dann nochmal hier berichten wie es aussieht - wobei es natürlich nie schadet die Rechte auf 777 zu setzen. 😄
                                Erst mal Danke für deine Bemühungen 😉
                                Ordner umbenannt in iobrokermac, installation mit sudo npm install iobroker –unsafe-perm
                                MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker --unsafe-perm
                                Password:
                                > iobroker@1.0.0 install /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker
                                > node lib/setup.js
                                npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/ioBrokermac
                                node-pre-gyp verb cli   '/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/node_modules/.bin/node-pre-gyp',
                                node-pre-gyp info check checked for "/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/build/Release/serialport.node" (not found)
                                npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBrokermac
                                npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                                npm ERR!
                                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_40_371Z-debug.log
                                sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                                npm ERR!
                                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_42_345Z-debug.log
                                Could not find "/Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
                                Cannot set permissions of /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker.js-controller/iobroker
                                    sudo cp /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/install/iobroker /usr/bin/
                                + iobroker@1.0.0
                                removed 329 packages and updated 1 package in 86.429s
                                MacMini-LAN:ioBrokermac MacMini$</https:></https:></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
                                installation mit sudo npm install iobrokermac.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac
                                MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobrokermac.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                                npm ERR! code E404
                                npm ERR! 404 Not Found: iobrokermac.js-controller@latest
                                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_02_24_890Z-debug.log
                                installation mit sudo npm install iobroker.js-controller –production
                                MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker.js-controller --production
                                npm ERR!
                                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_03_43_461Z-debug.log
                                npm ERR! code E404
                                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_05_40_972Z-debug.log
                                • BuZZy
                                  Dann benenne den Ordner iobroker.js-controller um in iobrokermac.js-controller dann in den Ordner iobrokermac.js-controller rein gehen
                                  und versuchen zu installieren mit
                                  sudo npm install iobroker.js-controller –production (ohne das Mac im Namen)
                                  Welche Ausgabe bekommst du dann? Ich denke wir nähern uns bald dem Ziel.. Eine paar Ideen hätte ich noch wenn das auch nicht klappt. 😄
                                  Von unterwegs gesendet
                                    Also jetzt hast du mich abgehängt, den Ordner iobroker.js-controller gibt es doch eben gar nicht :?:
                                    • BuZZy
                                      Existiert der Ordner /Users/MacMini/Documents/ioBrokermac/node_modules/ ??
                                      Eventuell befindet sich der Ordner node_modules auch in irgend einem von den übergeordneten Ordnern?
                                        ja, den Ordner gibt es.
                                        • BuZZy
                                          und welche Ordner sind in diesem node_modules Ordner enthalten?
                                            welches nodejs hast du eigentlich installiert?
                                            Rainer
                                            13532
