    4. JavaScript
    5. Datenpunkt aus xml
    Datenpunkt aus xml
      Homoran Global Moderator Administrators @australien last edited by Homoran
      @australien wieso steht bei dir dp in Zeile 13.
      das ust nicht was Paul schrieb
      edit: ok, hatte das "original " nicht gesehen
        australien last edited by australien
        jetz kommt Leben ins Geschehen
        20:19:52.202	info	javascript.0 (6486) Stop script script.js.common.PV
        20:38:16.280	info	javascript.0 (6486) Stop script script.js.common.PV
        20:38:17.819	info	javascript.0 (6486) Start javascript script.js.common.PV
        20:38:17.856	info	javascript.0 (6486) script.js.common.PV: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
        20:39:07.644	info	javascript.0 (6486) script.js.common.PV: {'root':{'Device':[{'$':{'Name':'SF-WR-5503','Type':'Inverter','Serial':'752794AB005565810009','BusAddress':'1','NetBiosName':'INV005565810009','IpAddress':'10.68.0.85','DateTime':'2022-11-14T20:38:18'},'Measurements':[{'Measurement':[{'$':{'Value':'233.046','Unit':'V','Type':'AC_Voltage1'}},{'$':{'Value':'235.306','Unit':'V','Type':'AC_Voltage2'}},{'$':{'Value':'234.911','Unit':'V','Type':'AC_Voltage3'}},{'$':{'Value':'50.002','Unit':'Hz','Type':'AC_Frequency1'}},{'$':{'Value':'50.006','Unit':'Hz','Type':'AC_Frequency2'}},{'$':{'Value':'50.003','Unit':'Hz','Type':'AC_Frequency3'}},{'$':{'Value':'0.000','Unit':'V','Type':'DC_Voltage'}},{'$':{'Value':'21.260','Unit':'°C','Type':'Temp'}}]}]}]}}
        20:40:00.071	info	javascript.0 (6486) script.js.common.PV: {'root':{'Device':[{'$':{'Name':'SF-WR-5503','Type':'Inverter','Serial':'752794AB005565810009','BusAddress':'1','NetBiosName':'INV005565810009','IpAddress':'10.68.0.85','DateTime':'2022-11-14T20:39:10'},'Measurements':[{'Measurement':[{'$':{'Value':'233.334','Unit':'V','Type':'AC_Voltage1'}},{'$':{'Value':'235.452','Unit':'V','Type':'AC_Voltage2'}},{'$':{'Value':'235.217','Unit':'V','Type':'AC_Voltage3'}},{'$':{'Value':'50.015','Unit':'Hz','Type':'AC_Frequency1'}},{'$':{'Value':'50.024','Unit':'Hz','Type':'AC_Frequency2'}},{'$':{'Value':'50.008','Unit':'Hz','Type':'AC_Frequency3'}},{'$':{'Value':'0.000','Unit':'V','Type':'DC_Voltage'}},{'$':{'Value':'21.250','Unit':'°C','Type':'Temp'}}]}]}]}}
        nur wir teile ich die Daten nun Datenpunkten zu?
          paul53 @australien last edited by paul53
          @australien sagte in Datenpunkt aus xml:
          Ersetze log(obj) durch
          const messung = obj.root.Device[0].Measurements[0].Measurement;
          for(let obj of messung) {
              log(obj.$.Type + ': ' + parseFloat(obj.$.Value) + ' ' + obj.$.Unit);
              // setState('0_userdata.0.SolarFrontier.' + obj.$.Type, parseFloat(obj.$.Value), true);
          Erstelle vorher die 8 Datenpunkte vom Typ "number" unter "0_userdata.0".
          Log:
          20:59:41.099	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Voltage1: 233.046 V
          20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Voltage2: 235.306 V
          20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Voltage3: 234.911 V
          20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Frequency1: 50.002 Hz
          20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Frequency2: 50.006 Hz
          20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: AC_Frequency3: 50.003 Hz
          20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: DC_Voltage: 0 V
          20:59:41.100	info	javascript.1 (2579) script.js.common.Neuer_Test: Temp: 21.26 °C
            @paul53 wieso sind im obj nur 8 Werte?
            die xml enthält 17
              paul53 @Homoran last edited by paul53
              @homoran sagte: die xml enthält 17
              Dann müssen die übrigen wohl in einem anderen Array-Element enthalten sein. Ich schau mal.
                Homoran Global Moderator Administrators @paul53 last edited by Homoran
                alle in <Measurements>
                <root>
                <Device Name="SF-WR-5503" Type="Inverter" Serial="752794Axxxxxxx" BusAddress="1" NetBiosName="INV005565810009" IpAddress="10.68.0.85" DateTime="2022-11-14T14:34:49">
                <Measurements>
                <Measurement Value="232.511" Unit="V" Type="AC_Voltage1"/>
                <Measurement Value="234.392" Unit="V" Type="AC_Voltage2"/>
                <Measurement Value="234.739" Unit="V" Type="AC_Voltage3"/>
                <Measurement Value="0.188" Unit="A" Type="AC_Current1"/>
                <Measurement Value="0.186" Unit="A" Type="AC_Current2"/>
                <Measurement Value="0.182" Unit="A" Type="AC_Current3"/>
                <Measurement Value="83.355" Unit="W" Type="AC_Power"/>
                <Measurement Value="30.510" Unit="W" Type="AC_Power1"/>
                <Measurement Value="28.707" Unit="W" Type="AC_Power2"/>
                <Measurement Value="27.966" Unit="W" Type="AC_Power3"/>
                <Measurement Value="49.997" Unit="Hz" Type="AC_Frequency1"/>
                <Measurement Value="50.005" Unit="Hz" Type="AC_Frequency2"/>
                <Measurement Value="50.001" Unit="Hz" Type="AC_Frequency3"/>
                <Measurement Value="435.600" Unit="V" Type="DC_Voltage"/>
                <Measurement Value="0.195" Unit="A" Type="DC_Current"/>
                <Measurement Value="84.942" Unit="W" Type="DC_Power"/>
                <Measurement Value="39.610" Unit="°C" Type="Temp"/>
                </Measurements>
                </Device>
                </root>
                  Das Ergebnis (Log) von xml2js lieferte nur die 8 Werte.
                  A Homoran 2 Replies Last reply Reply Quote 0
                    australien @paul53 last edited by
                    super, danke euch beiden!
                      @paul53 das ist ja das Problem
                      ich habe so etwas auch bei meinem Kostal, allerdings muss ich da in derAPI due gewünschten Parameter abfragen. das ist anscheinend auf eine maximale Anzahl je Abfrage limitiert.
                      Vielleicht ist die Zeichenanzahl begrenzt
                      @australien wie bist du denn an das vollständige xml Dokument gekommen?
                        @australien
                        Kann es sein, dass nachts keine Stromstärke- und Leistungswerte geliefert werden?
                        Homoran 2 Replies Last reply Reply Quote 1
                          @paul53 guter Ansatz!
                            mit Nachts ist mir klar, ich werd mir das morgen unter Tags noch anschauen, falls kein Nebel ist 😉
                            Danke Euch beiden nochmals!!
                              @australien
                              was ist denn die DC Voltage, wenn nicht die Panel Spannung?
                              und
                              @homoran sagte in Datenpunkt aus xml:
                                Guten Morgen,
                                Nebel, aber liefert etwas, somit sind wieder alle 17 Datenpunkte vorhanden.
                                <Measurements>
                                <Measurement Value="234.225" Unit="V" Type="AC_Voltage1"/>
                                <Measurement Value="236.033" Unit="V" Type="AC_Voltage2"/>
                                <Measurement Value="235.065" Unit="V" Type="AC_Voltage3"/>
                                <Measurement Value="0.144" Unit="A" Type="AC_Current1"/>
                                <Measurement Value="0.155" Unit="A" Type="AC_Current2"/>
                                <Measurement Value="0.147" Unit="A" Type="AC_Current3"/>
                                <Measurement Value="6.654" Unit="W" Type="AC_Power"/>
                                <Measurement Value="6.163" Unit="W" Type="AC_Power1"/>
                                <Measurement Value="2.353" Unit="W" Type="AC_Power2"/>
                                <Measurement Value="2.135" Unit="W" Type="AC_Power3"/>
                                <Measurement Value="49.951" Unit="Hz" Type="AC_Frequency1"/>
                                <Measurement Value="49.957" Unit="Hz" Type="AC_Frequency2"/>
                                <Measurement Value="49.958" Unit="Hz" Type="AC_Frequency3"/>
                                <Measurement Value="382.300" Unit="V" Type="DC_Voltage"/>
                                <Measurement Value="0.017" Unit="A" Type="DC_Current"/>
                                <Measurement Value="6.499" Unit="W" Type="DC_Power"/>
                                <Measurement Value="36.550" Unit="°C" Type="Temp"/>
                                </Measurements>
                                @Homoran hatte ich vor 6 Jahren bei der Installation der Anlage erfragt. Es waren sogar 3 xml Seiten, nur die anderen beiden waren nicht brauchbar, weiß die auch nicht mehr.
                                  @australien sagte: alle 17 Datenpunkte vorhanden.
                                  Dann erstelle die restlichen Datenpunkte und erweitere um eine Abfrage.
                                  if(messung.length == 17) {
                                    Datenpunkte hab ich bereits erstellt und werden auch geschrieben - mit dem alten script.
                                    Worin besteht der unterschied?
                                      @australien sagte: Worin besteht der unterschied?
                                      Dass mit der zusätzlichen Abfrage nachts nichts geschrieben wird.
                                        Nachts sind die Werte der Leistung aber sowieso 0 und somit ist es doch auch egal.
                                          eben nicht!
                                          Nachts g7bt das xml gar nichts zum auswerten zurück
                                            @australien sagte: ist es doch auch egal.
                                            Ja, ist es, wenn die Werte nicht historisiert werden.
                                            1155
