    4. Fehlermeldungen bei Installation mac
      thoduh last edited by
      OK, jetzt kommt folgendes:
      MacMini-LAN:ioBroker MacMini$ npm install iobroker --unsafe-perm
      > iobroker@1.0.0 install /Users/MacMini/Documents/ioBroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/ioBroker
      node-pre-gyp info it worked if it ends with ok
      node-pre-gyp verb cli [ '/usr/local/bin/node',
      node-pre-gyp verb cli   '/Users/MacMini/Documents/ioBroker/node_modules/serialport/node_modules/.bin/node-pre-gyp',
      node-pre-gyp verb cli   'install',
      node-pre-gyp verb cli   '--fallback-to-build' ]
      node-pre-gyp info using node-pre-gyp@0.6.32
      node-pre-gyp info using node@8.2.1 | darwin | x64
      node-pre-gyp verb command install []
      node-pre-gyp info check checked for "/Users/MacMini/Documents/ioBroker/node_modules/serialport/build/Release/serialport.node" (not found)
      node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
      node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.2.1 (node-v57 ABI) (falling back to source compile with node-gyp)
      node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
      node-pre-gyp verb command build [ 'rebuild' ]
      ../src/serialport.cpp:90:44: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        return getValueFromObject(options, key)->ToInt32()->Int32Value();
      /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9336:21: note: 'ToInt32' has been explicitly marked deprecated here
      Local <int32>Value::ToInt32() const {
      ../src/serialport.cpp:102:44: warning: 'ToNumber' is deprecated [-Wdeprecated-declarations]
        return getValueFromObject(options, key)->ToNumber()->NumberValue();
      /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9300:22: note: 'ToNumber' has been explicitly marked deprecated here
      Local <number>Value::ToNumber() const {
      ../src/serialport.cpp:174:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          int fd = argv[1]->ToInt32()->Int32Value();
      ../src/serialport.cpp:193:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        int fd = info[0]->ToInt32()->Int32Value();
      ../src/serialport.cpp:217:108: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ../src/serialport.cpp:252:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp:369:24: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        baton->fd = info[0]->ToInt32()->Int32Value();
      ../src/serialport.cpp:480:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp:528:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp:585:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
      10 warnings generated.
      ../src/serialport_unix.cpp:44:101: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      ../src/serialport_unix.cpp:45:103: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
      2 warnings generated.
      ../src/serialport_poller.cpp:86:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        obj->fd_ = info[0]->ToInt32()->Int32Value();
      1 warning generated.
      node-pre-gyp info ok
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBroker
      shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
      path.js:1163
                cwd = process.cwd();
      Error: ENOENT: no such file or directory, uv_cwd
          at Object.resolve (path.js:1163:25)
          at Function.Module._resolveLookupPaths (module.js:408:17)
          at Function.Module._resolveFilename (module.js:480:22)
          at Function.Module._load (module.js:437:25)
          at Module.require (module.js:513:17)
          at require (internal/module.js:11:18)
          at /usr/local/lib/node_modules/npm/bin/npm-cli.js:19:21
          at Object. <anonymous>(/usr/local/lib/node_modules/npm/bin/npm-cli.js:92:3)
          at Module._compile (module.js:569:30)
          at Object.Module._extensions..js (module.js:580:10)
      Cannot install as normal user. Try sudo...
      sudo npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBroker
      Password:
      Password:Sorry, try again.
      path.js:1163
      npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBroker
      path.js:1163
      sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBroker
      path.js:1163
      Could not find "/Users/MacMini/Documents/ioBroker/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
      Non-critical error: ENOENT: no such file or directory, mkdir '/Users/MacMini/Documents/ioBroker/node_modules/iobroker/lib/../../../log'
      + iobroker@1.0.0
      added 46 packages in 89.892s
      MacMini-LAN:ioBroker MacMini$</anonymous></anonymous></anonymous></anonymous></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
      Logfile:
      0 info it worked if it ends with ok
      1 verbose cli [ '/usr/local/bin/node',
      1 verbose cli   '/usr/local/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'iobroker.js-controller',
      1 verbose cli   '--production',
      1 verbose cli   '--prefix',
      1 verbose cli   '/Users/MacMini/Documents/ioBroker' ]
      2 info using npm@5.3.0
      3 info using node@v8.2.1
      4 verbose npm-session 5c87be63f17774e9
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 396ms (from cache)
      8 silly pacote tag manifest for iobroker.js-controller@latest fetched in 432ms
      9 silly install loadIdealTree
      10 silly install cloneCurrentTreeToIdealTree
      11 silly install loadShrinkwrap
      12 silly install loadAllDepsIntoIdealTree
      13 verbose stack Error: Refusing to install package with name "iobroker.js-controller" under a package
      13 verbose stack also called "iobroker.js-controller". Did you name your project the same
      13 verbose stack as the dependency you're installing?
      13 verbose stack
      13 verbose stack For more information, see:
      13 verbose stack     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">
      13 verbose stack     at checkSelf (/usr/local/lib/node_modules/npm/lib/install/validate-args.js:64:14)
      13 verbose stack     at Array. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/slide/lib/bind-actor.js:15:8)
      13 verbose stack     at LOOP (/usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:15:14)
      13 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:18:7
      13 verbose stack     at hasMinimumFields (/usr/local/lib/node_modules/npm/lib/install/validate-args.js:30:12)
      13 verbose stack     at chain (/usr/local/lib/node_modules/npm/node_modules/slide/lib/chain.js:20:5)
      13 verbose stack     at /usr/local/lib/node_modules/npm/lib/install/validate-args.js:16:5
      13 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:35
      13 verbose stack     at Array.forEach (native)
      13 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:52:11
      13 verbose stack     at asyncMap (/usr/local/lib/node_modules/npm/node_modules/slide/lib/async-map.js:51:8)
      13 verbose stack     at module.exports (/usr/local/lib/node_modules/npm/lib/install/validate-args.js:15:3)
      14 verbose cwd /Users/MacMini/Documents/ioBroker/node_modules/iobroker
      15 verbose Darwin 16.7.0
      16 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production" "--prefix" "/Users/MacMini/Documents/ioBroker"
      17 verbose node v8.2.1
      18 verbose npm  v5.3.0
      19 error code ENOSELF
      20 error Refusing to install package with name "iobroker.js-controller" under a package
      20 error also called "iobroker.js-controller". Did you name your project the same
      20 error as the dependency you're installing?
      20 error
      20 error For more information, see:
      20 error     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">
      21 verbose exit [ 1, true ]</https:></anonymous></anonymous></anonymous></https:>
      • BuZZy
        BuZZy last edited by
        Da scheint auf Github etwas nicht mehr vorhanden zu sein. Siehe 404 Fehler in deinem Log.
          Das Verzeichnis existiert nicht:
          MacMini-LAN:ioBroker MacMini$ cd node_modules/iobroker.js-controlle
          -bash: cd: node_modules/iobroker.js-controlle: No such file or directory
            Diese 404 (zumindest die die ich auf die schnelle gefunden habe) sind "normal".
            Beim serial port wird zuerst versucht ein fertiges Paket zu installieren. Dieses wird für Darwin nicht gefunden (also 404) dann geht die Installation in den build über und bastelt sich das Paket selber.
            Also don't panic.
            Aber während ich dies tippe kommt mir noch eine Idee, die kann ich aber nur in den Raum stellen, da ich mich mit Äpfeln gar nicht auskenne:
            Bei RasPi et al. benötigt die Installation des serialports Root-Rechte. wie wird das Paket unter OS X installiert?
            gibt es da auch so etwas wie root oder Administrator-Rechte?
            Rainer
              Das wird versucht mit "sudo", wenn ich das richtig sehe:
              • BuZZy
                Versuch eine Ebene höher zu wechseln "cd .." dann wieder rein in das Verzeichnis mit "cd iobroker"
                Dann nochmal die Installation versuchen (eventuell mit sudo)?
                Wie oben gesagt:
                Der Eintrag "error retrieving current directory: getcwd: cannot access parent directories: No such file or directory"
                sagt eigentlich dass das Script nicht weiß wo es gerade ist..
                Also raus aus dem Ordner und nochmal rein im gleichen Terminalfenster und dann nochmal die Installation versuchen.
                  Leider auch nicht:
                  MacMini-LAN:ioBroker MacMini$ cd ..
                  MacMini-LAN:Documents MacMini$ cd iobroker
                  MacMini-LAN:iobroker MacMini$ sudo npm install iobroker --unsafe-perm
                  Password:
                  > node lib/setup.js
                  npm ERR! code ENOSELF
                  npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
                  npm ERR! also called "iobroker.js-controller". Did you name your project the same
                  npm ERR! as the dependency you're installing?
                  npm ERR!
                  npm ERR! For more information, see:
                  npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
                  npm ERR!     /Users/MacMini/.npm/_logs/2017-07-25T17_31_42_595Z-debug.log
                  npm ERR!
                  npm ERR!     /Users/MacMini/.npm/_logs/2017-07-25T17_31_45_952Z-debug.log
                  Write "./iobroker start" to start the ioBroker
                  Cannot set permissions of /Users/MacMini/Documents/ioBroker/node_modules/iobroker.js-controller/iobroker
                  You can still manually copy
                  Cannot create file /usr/bin/iobroker!. Non critical
                  You can manually copy file into /usr/bin/. Just write:
                      sudo cp /Users/MacMini/Documents/ioBroker/node_modules/iobroker/install/iobroker /usr/bin/
                      sudo chmod 777 /usr/bin/iobroker
                  + iobroker@1.0.0
                  added 46 packages and removed 167 packages in 92.075s
                  MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controller
                  -bash: cd: node_modules/iobroker.js-controller: No such file or directory
                  MacMini-LAN:iobroker MacMini$</https:></https:></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
                  • BuZZy
                    Okay, ändere mal den Ordnernamen "/Users/MacMini/Documents/ioBroker/" in "/Users/MacMini/Documents/ioBrokermac/" also den ioBroker ordner in ioBrokermac umbennen.
                    Dann die installation nochmal versuchen. Gibts wieder einen Fehler?
                    Dann:
                    Existiert der Ordner iobroker.js-controller in dem neu umbenannten ioBrokermac Ordner?
                    Wenn ja, diesen auch umbenennen in iobrokermac.js-controller, dann in diesen Ordner reinwechseln und dort "sudo npm install iobroker.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac"
                    oder eventuell
                    "sudo npm install iobrokermac.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac"
                    oder eventuell
                    "sudo npm install iobroker.js-controller --production"
                    oder eventuell
                    "sudo npm install iobrokermac.js-controller --production" ... 😄 Versuch macht kluch.. Oder wie heißt es so schön? 😄
                      Es kann sich hier auch um Zugriffsrechte handeln.
                      Bei der ioBroker Installation auf Linux muss der Ordner iobroker ALLE Rechte (777) haben.
                      Rainer
                      • BuZZy
                        Momentan sehe ich keine Probleme außer
                        ` > npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
                        npm ERR! as the dependency you're installing? `
                        npm macht manchmal Probleme wenn der Ordnername der gleiche ist wie der von dem Paket welches installiert werden soll. Deswegen bitte nochmal meine Tipps von http://forum.iobroker.net/viewtopic.php?f=17&t=7343#p76997 ausprobieren und dann nochmal hier berichten wie es aussieht - wobei es natürlich nie schadet die Rechte auf 777 zu setzen. 😄
                          Erst mal Danke für deine Bemühungen 😉
                          Ordner umbenannt in iobrokermac, installation mit sudo npm install iobroker –unsafe-perm
                          MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker --unsafe-perm
                          Password:
                          > iobroker@1.0.0 install /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker
                          > node lib/setup.js
                          npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/ioBrokermac
                          node-pre-gyp verb cli   '/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/node_modules/.bin/node-pre-gyp',
                          node-pre-gyp info check checked for "/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/build/Release/serialport.node" (not found)
                          npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBrokermac
                          npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                          npm ERR!
                          npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_40_371Z-debug.log
                          sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                          npm ERR!
                          npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_42_345Z-debug.log
                          Could not find "/Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
                          Cannot set permissions of /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker.js-controller/iobroker
                              sudo cp /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/install/iobroker /usr/bin/
                          + iobroker@1.0.0
                          removed 329 packages and updated 1 package in 86.429s
                          MacMini-LAN:ioBrokermac MacMini$</https:></https:></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
                          installation mit sudo npm install iobrokermac.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac
                          MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobrokermac.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                          npm ERR! code E404
                          npm ERR! 404 Not Found: iobrokermac.js-controller@latest
                          npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_02_24_890Z-debug.log
                          installation mit sudo npm install iobroker.js-controller –production
                          MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker.js-controller --production
                          npm ERR!
                          npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_03_43_461Z-debug.log
                          npm ERR! code E404
                          npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_05_40_972Z-debug.log
                          • BuZZy
                            Dann benenne den Ordner iobroker.js-controller um in iobrokermac.js-controller dann in den Ordner iobrokermac.js-controller rein gehen
                            und versuchen zu installieren mit
                            sudo npm install iobroker.js-controller –production (ohne das Mac im Namen)
                            Welche Ausgabe bekommst du dann? Ich denke wir nähern uns bald dem Ziel.. Eine paar Ideen hätte ich noch wenn das auch nicht klappt. 😄
                            Von unterwegs gesendet
                              Also jetzt hast du mich abgehängt, den Ordner iobroker.js-controller gibt es doch eben gar nicht :?:
                              • BuZZy
                                Existiert der Ordner /Users/MacMini/Documents/ioBrokermac/node_modules/ ??
                                Eventuell befindet sich der Ordner node_modules auch in irgend einem von den übergeordneten Ordnern?
                                  ja, den Ordner gibt es.
                                  • BuZZy
                                    und welche Ordner sind in diesem node_modules Ordner enthalten?
                                      welches nodejs hast du eigentlich installiert?
                                      Rainer
                                        @BuZZy:
                                        und welche Ordner sind in diesem node_modules Ordner enthalten? `
                                        • BuZZy
                                          https://github.com/ioBroker/ioBroker.js … master.zip runterladen, in den Ordner rein und dann in dem Ordner
                                            Die gezippte Datei in den nodes_modules Ordner?
                                            13532
