    4. Lay-Z-Spa Wifi Control
    • Agria4800
      Agria4800 @Agria4800 last edited by
      @agria4800
      Hiermit bekommt man die Zeiten ausgelesen:
      var Souce_other, Source, RSSI, Times, Chlortime, Filtertime, Uptime, Pumptime, Heating, Airtime, Hydrojet_Time, Costs, Verbrauch;
      on({id: [].concat(['mqtt.0.layzspa.other']), change: "ne"}, async function (obj) {
       var value = obj.state.val;
       Souce_other = getState("mqtt.0.layzspa.other").val;
       await wait(100);
       RSSI = getAttr(Souce_other, 'RSSI');
       setState("0_userdata.0.LazySpa.RSSI-Wifi"/*RSSI-Wifi*/, parseFloat(RSSI), true);
      on({id: [].concat(['mqtt.0.layzspa.times']), change: "ne"}, async function (obj) {
       Source = getState("mqtt.0.layzspa.times").val;
       await wait(100);
       Times = getAttr(Source, 'TIME');
       setState("0_userdata.0.LazySpa.Times.Time"/*Time*/, parseFloat(Times), true);
       Chlortime = getAttr(Source, 'CLTIME');
       setState("0_userdata.0.LazySpa.Times.Chlor_Time"/*Chlor_Time*/, Chlortime, true);
       Filtertime = getAttr(Source, 'FTIME');
       setState("0_userdata.0.LazySpa.Times.Filter_Time"/*Filter_Time*/, parseFloat(Filtertime), true);
       Uptime = getAttr(Source, 'UPTIME');
       setState("0_userdata.0.LazySpa.Times.Up_Time"/*Up_Time*/, parseFloat(Uptime), true);
       Pumptime = getAttr(Source, 'PUMPTIME');
       setState("0_userdata.0.LazySpa.Times.Pump_Time"/*Pump_Time*/, parseFloat(Pumptime), true);
       Heating = getAttr(Source, 'HEATINGTIME');
       setState("0_userdata.0.LazySpa.Times.Heating_Time"/*Heating Time*/, parseFloat(Heating), true);
       Airtime = getAttr(Source, 'AIRTIME');
       setState("0_userdata.0.LazySpa.Times.Air_Time"/*Air_Time*/, parseFloat(Airtime), true);
       Hydrojet_Time = getAttr(Source, 'JETTIME');
       setState("0_userdata.0.LazySpa.Times.Hydrojet_Time"/*Hydrojet_Time*/, parseFloat(Hydrojet_Time), true);
       Costs = getAttr(Source, 'COST');
       setState("0_userdata.0.LazySpa.Times.Cost"/*Cost*/, parseFloat(Costs), true);
       Verbrauch = getAttr(Source, 'KWH');
       setState("0_userdata.0.LazySpa.Times.Verbrauch"/*Verbrauch*/, parseFloat(Verbrauch), true);
      und hiermit werden sie umgeschrieben analog !Bildschirmfoto 2022-08-12 um 21.15.48.png
      var Dauer, tage, std, min, sec;
      // https://forum.iobroker.net/topic/13488/vorlage-blockly-umrechnung-von-sekunden-in-stunden-minuten-und-sekunden/11
      on({id: "0_userdata.0.LazySpa.Times.Up_Time"/*Up_Time*/, change: "ne"}, async function (obj) {
       Dauer = getState("0_userdata.0.LazySpa.Times.Up_Time").val;
       tage = Math.floor(parseFloat(Dauer) / 86400);
       Dauer = parseFloat(Dauer) - parseFloat(tage) * 86400;
       std = Math.floor(parseFloat(Dauer) / 3600);
       Dauer = parseFloat(Dauer) - parseFloat(std) * 3600;
       min = Math.floor(parseFloat(Dauer) / 60);
       Dauer = parseFloat(Dauer) - parseFloat(min) * 60;
       sec = Math.floor(parseFloat(Dauer) / 1);
       setState("0_userdata.0.LazySpa.Times.Format-Up-Time"/*Format-Up-Time*/, ([tage,'D -  ',std,'h:',min,'min:',sec,'sec'].join('')));
      on({id: "0_userdata.0.LazySpa.Times.Air_Time"/*Air_Time*/, change: "ne"}, async function (obj) {
       Dauer = getState("0_userdata.0.LazySpa.Times.Air_Time").val;
       setState("0_userdata.0.LazySpa.Times.Format-Air-Time"/*Format-Air-Time*/, ([tage,'D -  ',std,'h:',min,'min:',sec,'sec'].join('')));
      on({id: "0_userdata.0.LazySpa.Times.Heating_Time"/*Heating Time*/, change: "ne"}, async function (obj) {
       Dauer = getState("0_userdata.0.LazySpa.Times.Heating_Time").val;
       setState("0_userdata.0.LazySpa.Times.Format-Heating-Time"/*Format-Heating-Time*/, ([tage,'D -  ',std,'h:',min,'min:',sec,'sec'].join('')));
      on({id: "0_userdata.0.LazySpa.Times.Pump_Time"/*Pump_Time*/, change: "ne"}, async function (obj) {
       Dauer = getState("0_userdata.0.LazySpa.Times.Pump_Time").val;
       setState("0_userdata.0.LazySpa.Times.Format-Pump-Time"/*Format-Pump-Time*/, ([tage,'D -  ',std,'h:',min,'min:',sec,'sec'].join('')));
      on({id: "0_userdata.0.LazySpa.Times.Hydrojet_Time"/*Hydrojet_Time*/, change: "ne"}, async function (obj) {
       Dauer = getState("0_userdata.0.LazySpa.Times.Hydrojet_Time").val;
       setState("0_userdata.0.LazySpa.Times.Format-Hydrojet-Time"/*Format-Hydrojet-Time*/, ([tage,'D -  ',std,'h:',min,'min:',sec,'sec'].join('')));
      Z 1 Reply Last reply Reply Quote 1
        anderl last edited by
        Hallo zusammen, hat irgendjemand noch eine Platine abzugeben? Leider unbedarft, trotzdem neue Herausforderung gesucht 😀 Danke und Grüße Andy
        • Bjoern Weiss
          Bjoern Weiss last edited by
          ich habe ein kleines Problem. Hat jemand eine Idee, warum mir in dem Anzeigefeld keine Temperatur angezeigt wird?
          Wenn es einen Fehler wie beispielsweise E02 etc gibt, wird dieser dort aber angezeigt.
          Ist ein Vegas (54112), allerdings mit 4-adrigen Verkabelung statt wie angegeben 6 Adern.
          Hab übrigends noch Platinen übrig wenn jemand noch eine benötigt.
            Rickman @anderl last edited by
            @anderl
            Ich habe gestern die PCB v2 bestellt. Wollte für den Winter auch schon mal was zum basteln haben.
            Sobald die da sind, kann ich Dir Bescheid geben.
            Falls noch jemand welche benötigt - habe dann immer noch 3 übrig. 😉
            Gruß,
            Richy
            allesautomatisch 1 Reply Last reply Reply Quote 0
            • allesautomatisch
              allesautomatisch @Rickman last edited by
              @rickman
              Ich würde Dir ein v2 PCB abnehmen.
              Vielen Dank und Gruß,
              Michael
                Rickman @allesautomatisch last edited by
                @allesautomatisch
                Hast ne Chatnachricht... 🙂
                • Chris685
                  Chris685 last edited by
                  Ich habe noch 4 Platinen V1 da und einen Satz mit 6 poligen JST-SM. Wenn Interesse besteht bitte PN.
                    Rickman last edited by Rickman
                    Also... Ich hätte dann noch 2 fertige Boards für das Model S100101, St. Lucia/Rio.
                    Im Moment drucke ich noch die passenden Gehäuse dafür, die wunderbar in die zwei freien Bohrungen neben der Heizung passen.
                    Bei eBay werden die für 83,- Euro vertickt, hier für 35,- plus Versand.
                    Falls es nicht klappen sollte, weil doch wieder was anders in der Elektronik der Pumpe ist, nehme ich den selbstverständlich wieder zurück. Bei Interesse gerne eine PN an mich.
                    EDIT:
                    Keiner mehr da...
                    Gruß,
                    Richy
                      MezzoDO last edited by
                      Guten Abend zusammen!
                      Gibt's hier fachkundige Leute zu diesem Projekt, die mir bei meinem Problem helfen könnten?
                      Ich hab die PCB V1 Platine und wollte einen BAHAMAS mit der Pumpe S100101 mit dem Modul ausstatten.
                      Zusammengebaut mit dem blauen Level Converter, der laut Instructions bestätigt funktionieren soll. Zudem habe ich in meiner Verzweiflung auch versucht die 560 Ohm Widerstände an die Datenleitungen 3,4 & 5 zum Display zu löten.
                      Laut GitProject soll das Modell MIAMI2021 gewählt werden, was ich auch eingestellt und hochgeladen habe (PlatformIO Upload, Build Filesystem und Upload Filesystem).
                      Die WebUI lässt sich soweit auch aufrufen und konfigurieren, allerdings bleibt das Display der Pumpe dunkel und Bedienung ist weder Am Display noch per WebUI möglich.
                      Alles was ich sehe ist die (vermeintlich korrekte) Temperatur per WebUI.
                      Habe alles gemäß Anleitung mehr als fünf mal gecheckt. Vielleicht findet sich jemand, der mir helfen kann 😞
                      R tvtotal R 3 Replies Last reply Reply Quote 0
                        Rickman @MezzoDO last edited by
                        @mezzodo
                        Schau Dir mal die Bilder bei mir an. Hast Du die Kabel so verlötet? Also in der Reihenfolge am Ein- und Ausgang?
                        Du hast zwar eine V1- Platine, aber das selbe Pumpenmodell... Vielleicht klappts ja.
                        Bei mir hat die Standardbelegung nämlich auch nicht funktioniert. 😉
                          MezzoDO @Rickman last edited by
                          @rickman
                          Danke für den Tipp, die Belegung hab ich tatsächlich schonmal gesehen aber nicht berücksichtigt. Ich teste das mal.
                          LG
                            MezzoDO @MezzoDO last edited by
                            @mezzodo said in Lay-Z-Spa Wifi Control:
                            @rickman
                            LG
                            Umverdrahtet, selber Effekt...
                            Allerdings habe ich aus Gründen mal einen neuen Level Converter bestellt und jetzt spielt zumindest die Melodie beim starten, dennoch wie vorher bleibt das Display tot. Ich denke ich werde es nun nochmal mit der 1:1 Verdrahtung versuchen und melde mich erneut #justupdating
                              Smokey @Agria4800 last edited by
                              @agria4800 sagte in Lay-Z-Spa Wifi Control:
                              😞 ich hab den ganzen Threat jetzt x mal gelesen, raffe aber einfach nicht, wie ich per VIS die entsprechenden Kommandos absetzen kann, wie es oben im Bild zu sehen ist. Das sind doch keine direkten Datenpunkte, die einen Wert oder ein true/false erwarten. Ich sehe im Objekt-Baum hinter den Datenpunkten nur JASON files oder scripts. Was hab ich denn übersehen?
                              • Lord Byron
                                Lord Byron last edited by Lord Byron
                                Sehr geiles Projekt. Genau das was mir noch fehlt für meinen Maldives Pool. Ich habe fünf v2 PCB bestellt. Falls sich hier auch Schweizer tummeln, die noch eines bräuchten, gerne PM an mich 😉
                                Edit:
                                Hab bereits alles Material bekommen und soweit mal installiert und konfiguriert. Ich benutze zwar kein ioBroker, sondern Mosquitto in HA, aber vielleicht kann mir ja trotzdem jemand hier einen Tip geben. Ich haben den Maldives mit Hydrojet, Verbindung zu Mosquitto steht und wird auch alles wunderbar in HA angezeigt... ...ausser die Hydrojet Düsen. Meiner Meinung nach müsste dies doch im neusten Release mit integriert sein?
                                  MiPl @Agria4800 last edited by
                                  @agria4800
                                  Hallo, danke für die Screenshots zur Einrichtung von mqtt - Es klappt bei mir aber trotzdem nicht. Derzeit benutze ich den mqtt-Adapter 4.07. Habe die Einstellungen exakt so gemacht wie von Dir dargegestellt und unzählige Male versucht. Geht nicht. Auch ein Reset der Poolsteuerung und des ioBroker brachten keinen Erfolg. Beim Log bekomme ich auch keine Hilfe.
                                  Ich habe in einem anderen Thread gelesen, dass der Adapter so lange auf Gelb bleibt, bis sich ein Device anmeldet/einwählt. Aber wie kann ich die Poolsteuerung sich aktiv einwählen lassen?
                                  Ich checks nicht.
                                  Danke für jede Hilfe.
                                    MiPl last edited by
                                    @mipl
                                    ich habe zu meiner Frage einen neuen Beitrag aufgemacht: Keine Verbindung zu mqtt-Server/Broker
                                      @agria4800
                                      Hallo Agria4800,
                                      ich habe das Script erfolgreich in Betrieb nehmen können (vielen Dank an die Ersteller). Ich bekomme derzeit alle ca. 4 Sekunden einen Eintrag im Log und eine entsprechende Aktualisierung der Daten, da sich z. B. die (virtuelle) Temperatur minimal ändert. Könnte man hier nicht auf Zentel-Grad Genauigkeit reduzieren, um die Rechnerlast ein wenig runterzufahren? Ich habe von Java Null Check, daher kann ich es nicht machen. Habe mir übergangsweise so geholfen und den Logeintrag auskommentiert. Aber das ist ja nicht Sinn der Sache.
                                      Danke im Voraus.
                                        johobo @Meistertr last edited by
                                        Hi, Ich habe gerade Platinen bestellt. falls also jemand interesse hat gerne melden.
                                        M J 2 Replies Last reply Reply Quote 0
                                          johobo @Rickman last edited by
                                          @rickman
                                          würdest du die Dateien für das Gehäuse zur Verfügung stellen? Oder kann ich sie irgendwie auf Thingiverse finden? Danke & Viele Grüße! JoHo
                                            mistral0806 last edited by
                                            @johobo Hi, ich habe Interesse. Ist noch eine Platine übrig?
                                            211
                                            49690
