    4. Test Adapter HeatingControl v2.12.x
    • Rene_HM
      Rene_HM Developer @TurboSasch last edited by
      @turbosasch Kannst du die Konsole des browser öffnen (Strg +Umschalt +J auf Windows) und das consolen log anschauen (oder mir zukommen lassen)?
        TurboSasch @Rene_HM last edited by
        @rene_hm ja, ich habe einen Log für Dich:
        metro-bootstrap.css:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        iconFont.min.css:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        metro.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        fritzdect.js:46 Version fritzdect: 0.0.2
        conn.js:305 2022-11-05T08:44:35.394Z Connected => authenticate
        conn.js:326 2022-11-05T08:44:35.830Z Authenticated: true
        DevTools failed to load source map: Could not load content for http://192.168.178.36:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.lnav_fixed_width
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.primary_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.abar_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.tnav_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.bnav_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.lnav_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.secondary_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.content_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color1
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color1_dark
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color2
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color2_dark
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color3
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.color3_dark
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.config_view
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.card_title
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.card_title_color
        vis.js:3543 Create inner vis object 0_userdata.0.mdui.vis.card_title_bg
        vis.js:3543 Create inner vis object deconz.0.Sensors.21.temperature
        vis.js:3543 Create inner vis object deconz.0.Sensors.17.on
        vis.js:3543 Create inner vis object hm-rpc.0.PEQ1315641.0.RSSI_PEER
        vis.js:3543 Create inner vis object hm-rpc.0.PEQ1315641.4.SET_TEMPERATURE
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Ankleide.ResetManual
        vis.js:3543 Create inner vis object hm-rpc.0.info.connection
        vis.js:3543 Create inner vis object deconz.0.Sensors.8.valve
        vis.js:3543 Create inner vis object deconz.0.Sensors.16.temperature
        vis.js:3543 Create inner vis object deconz.0.Sensors.12.on
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Badezimmer.ResetManual
        vis.js:3543 Create inner vis object deconz.0.Sensors.5.valve
        vis.js:3543 Create inner vis object deconz.0.Sensors.11.temperature
        vis.js:3543 Create inner vis object deconz.0.Sensors.21.on
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.GaesteWC.StatusLog
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.GaesteWC.ResetManual
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.GaesteWC.State
        vis.js:3543 Create inner vis object deconz.0.Sensors.4.valve
        vis.js:3543 Create inner vis object wid
        vis.js:3543 Create inner vis object deconz.0.Sensors.13.temperature
        vis.js:3543 Create inner vis object deconz.0.Sensors.23.on
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kinderzimmer.ResetManual
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kinderzimmer.State
        vis.js:3543 Create inner vis object deconz.0.Sensors.6.valve
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kinderzimmer.StatusLog
        vis.js:3543 Create inner vis object deconz.0.Sensors.14.temperature
        vis.js:3543 Create inner vis object deconz.0.Sensors.20.on
        vis.js:3543 Create inner vis object hm-rpc.0.PEQ1315641.4.ACTUAL_TEMPERATURE
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.StatusLog
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.WindowIsOpen
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.ResetManual
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Kueche.State
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.0.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.0.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Bad.ActiveTimeSlot
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.0.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.0.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-So.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-Su.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sa-Su.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Fr.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mo-Su.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sun.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.5.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.4.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.3.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.3.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.2.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.2.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.1.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.1.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.4.Temperature
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.Periods.5.time
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Mon.CopyPeriods
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Tue.CopyPeriods
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Wed.CopyPeriods
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Thu.CopyPeriods
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Fri.CopyPeriods
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.Sat.CopyPeriods
        vis.js:3543 Create inner vis object deconz.0.Sensors.15.temperature
        vis.js:3543 Create inner vis object deconz.0.Sensors.15.on
        vis.js:3543 Create inner vis object heatingcontrol.0.Rooms.Schlafzimmer.ResetManual
        vis.js:3543 Create inner vis object deconz.0.Sensors.7.valve
        vis.js:3543 Create inner vis object ham.0.Wohnzimmer-.000000BC.Current-Temperature
        vis.js:3543 Create inner vis object deconz.0.Sensors.2.valve
        vis.js:3543 Create inner vis object heatingcontrol_card_title
        vis.js:3543 Create inner vis object myhome_card_title_color
        vis.js:3543 Create inner vis object heatingcontrol.0.vis.ProfileTypes.CopyProfile
        translate.js:20 "Use background": {"en": "Use background", "de": "Use background", "ru": "Use background"},
        message_socket_on.png:1 GET http://192.168.178.36:8082/vis/widgets/jqui-mfd/img/message_socket_on.png 404 (Not Found)
        Image (async)
        buildFragment @ jquery-1.11.2.min.js:3
        domManip @ jquery-1.11.2.min.js:3
        t.fn.domManip @ can.custom.min.js:28
        append @ jquery-1.11.2.min.js:3
        (anonymous) @ visEdit.js:2430
        each @ jquery-1.11.2.min.js:2
        editInitWidgetPreview @ visEdit.js:2415
        editInitNext @ visEdit.js:2940
        initNext @ vis.js:715
        (anonymous) @ vis.js:610
        loadWidgetSets @ vis.js:575
        init @ vis.js:609
        (anonymous) @ vis.js:3609
        (anonymous) @ conn.js:1350
        r.onack @ socket.io.js:8
        r.onpacket @ socket.io.js:8
        (anonymous) @ socket.io.js:8
        r.emit @ socket.io.js:6
        r.ondecoded @ socket.io.js:6
        a.add @ socket.io.js:6
        r.ondata @ socket.io.js:6
        r.onPacket @ socket.io.js:6
        (anonymous) @ socket.io.js:6
        r.onPacket @ socket.io.js:7
        r.onData @ socket.io.js:7
        ws.onmessage @ socket.io.js:8
        2conn.js:81 No connection!
        conn.js:157 Trying connect...
        conn.js:281 was offline for 10.042s
        conn.js:305 2022-11-05T08:44:55.569Z Connected => authenticate
        conn.js:326 2022-11-05T08:44:55.730Z Authenticated: true
        translate.js:20 "Änderungen": {"en": "Änderungen", "de": "Änderungen", "ru": "Änderungen"},`
        • Rene_HM
          @turbosasch ja, deine Vis verliert die Verbindung und baut sie neu auf. Die Ursache dazu sehe ich hier leider nicht. Wie hast du den restore gemacht? Fehlt da vielleicht noch etwas?
            TurboSasch @Rene_HM last edited by TurboSasch
            @rene_hm Ich habe ein Backup genommen, welches ich jeden Tag erstelle. Ich habe Vis auch einmal deinstalliert und wieder installiert. Leider ohne irgendwelche Änderung. Und ich habe alle paar Monate das Projekt gesichert. Separat auf PC natürlich.
            • Rene_HM
              @turbosasch nutzt du die vis von pittini?
              T Dominik F. P B 5 Replies Last reply Reply Quote 0
                @rene_hm ja! Kann ich Dir das Backup mal schicken vom Heating Control? Oder kann ich das hier irgendwie anhängen?
                • Dominik F.
                  Dominik F. @Rene_HM last edited by Dominik F.
                  kann gelöscht werden
                    Phinix @Rene_HM last edited by Phinix
                    Kann mir bitte jemand die Offset-Berechnung erklären, das ist mir noch etwas schleierhaft.
                    Folgende Werte habe ich:
                    Ziel-Temperatur: 22 C°
                    IST-Thermostat: 20.9 C°
                    IST-ext. Sensor: 21,23 C°
                    Berechneter Offset -1,5 C°. Die Berechnung finde ich auch im Log.
                    Nur verstehe ich nicht woher die Werte "TempOffset calc -45.33 / 31 = -1.5" kommen.
                    heatingcontrol.0 2022-11-05 16:25:00.295	debug	(avg) TempOffset -1.5
                    heatingcontrol.0 2022-11-05 16:25:00.295	debug	tempDiff -0.33000000000000185
                    heatingcontrol.0 2022-11-05 16:25:00.294	debug	Ist-Temperatur am zusätzl. Sensor 21.23
                    heatingcontrol.0 2022-11-05 16:25:00.294	debug	(avg) Ist-Temperatur am Thermostat 20.9
                    heatingcontrol.0 2022-11-05 16:25:00.294	debug	TempOffset Arbeitszimmer
                    heatingcontrol.0 2022-11-05 16:25:00.288	debug	TempOffset calc -45.33 / 31 = -1.5
                    heatingcontrol.0 2022-11-05 16:25:00.288	debug	tempdiff: 20.9 - 21.23 = -0.33000000000000185
                    heatingcontrol.0 2022-11-05 16:25:00.288	debug	use value
                    heatingcontrol.0 2022-11-05 16:25:00.287	debug	time diff 6.0508
                    heatingcontrol.0 2022-11-05 16:25:00.287	debug	got 20.9 from hm-rpc.0.00201D89BC45B0.1.ACTUAL_TEMPERATURE LastUpdate 05.11.2022 16:18:57
                    heatingcontrol.0 2022-11-05 16:25:00.267	debug	got 21.23 from ext_Sensor LastUpdate 05.11.2022 16:25:00
                    V Rene_HM 2 Replies Last reply Reply Quote 0
                      Moin zusammen,
                      Nach langen hin und her, habe ich es endlich geschafft, das Heating Control läuft.
                      Nun fiel mir auf, das die Zeit nicht stimmt. Es ist um eine Stunde versetzt. Schaltung also auf 6 Uhr eingestellt und um 7 Uhr (reale Zeit ) geht die erst an. Wo kann man das umstellen?
                      Dominik F. 1 Reply Last reply Reply Quote 0
                      • Dominik F.
                        Dominik F. @TurboSasch last edited by
                        @turbosasch
                        In den Haupteinstellungen unter allgemeine Einstellungen kannst du die Zeitzone einstellen
                          Berlon @Rene_HM last edited by
                          @rene_hm
                          habe den aktuellen Adapter installiert.
                          Wenn ich nun in der Vis von Pittini änderungen mache bekomme ich folgende Fehler:
                          heatingcontrol.0
                          2022-11-21 16:31:01.595	error	!!ChangeStatus not implemented yet MinimumTemperature DH_Andreas value 12
                          heatingcontrol.0
                          2022-11-21 16:30:17.844	error	copy from vis
                          heatingcontrol.0
                          2022-11-21 16:30:16.214	error	copy from vis
                          heatingcontrol.0
                          2022-11-21 16:30:13.610	error	copy from vis
                          heatingcontrol.0
                          2022-11-21 16:30:12.631	error	copy from vis
                          heatingcontrol.0
                          2022-11-21 16:30:10.636	error	copy from vis
                            Daniel D. last edited by
                            ich habe nach dem Update 2.9.3 ein Problem mit den Fenstersensoren (Zigbee).
                            Die Schalten die ID WindowsIsOpen auf true aber die Thermostate (Homematic) werden nicht auf Fenster Offen geschaltet.
                            In der VIS wird auch Fenster Geöffnet angezeigt
                            Die ID State vom Thermostat bleibt auf Auto und wird nicht auf Manual geschaltet.
                            Im Adapter ist auch unter Fenstersensor-Einstellung der Haken bei Sensoren verwendet gesetzt.
                            Ein Downgrade hat auch keine Besserung gebracht.
                            Falls ich noch was an INFO vergessen haben sollte bitte nicht steinigen .
                              Berlon last edited by
                              @rene_hm
                              heatingcontrol.0
                              2022-11-21 19:52:53.045	error	ChangeStatusCmdList is longer then 60 entries, no new entry allowed -> skipped Computer Thermostats_Current [object Object]
                              Rene, ich benötige mehr Einträge!!!!!!!!!!!!!!!!!
                              Geschuldet durch die Tatsache das ich eine hybride Heizungsanlage (Gas und Splitklimageräte die nie zusammen laufen und das mein Sohn ein 3Schichtsystem hat.)
                              So sind bei mir alle Räume 3x (3Schichtsystem) vorhanden (1x Gas, 1x Split heizen und 1x Split kühlen)
                              Habe 9 Profile in denen
                              Profil 1-3 Gas steuert, Profile 4-9 sind runter geregelt.
                              Profil 4-6 Klima heizen, 1-3 und 7-9 sind runter geregelt
                              Profil 7-9 Klima kühlen, 1-6 sind runter geregelt.
                              Nach meiner Berechnung sind das bei 36 Räumen und 5 Perioden Mo-Fr + Sa und So.
                              360 Einträge!!!!
                              Kannst du das bitte anpassen?
                              Meine Version der Heizungsanlage wird aufgrund der aktuellen Gegebenheiten immer öfters erscheinen.
                              • Dominik F.
                                Dominik F. @Daniel D. last edited by
                                @daniel-d sagte in Test Adapter HeatingControl v2.9.x:
                                Was meinst du hier genau? Wird die Temperatur nicht angepasst?
                                Das Thermostat sollte ja sowieso auf Manual stehen bzw. von dir eingstellt werden, sonst funktioniert Heatingcontrol nicht richtig^^
                                Der State von Heatingcontrol bei Fenster offen sollte AutoWindowOpen sein.
                                  Daniel D. @Dominik F. last edited by
                                  @dominik-f
                                  Ja die Temperatur wird nich angepasst
                                  Die Thermosate werden Automatisch beim Starten von Heatingcontrol Adapter auf Auto gestellt auch wenn sie vorher auf Manual standen.
                                  Ich habe AutoWindowOpen bei mir in Heatingcontrol nicht. Nur WindowsIsOpen und das ändert auch von fals auf true wenn ich das Fenster öffne.
                                  Weiß gerade echt nicht weiter 😞
                                  E Rene_HM 2 Replies Last reply Reply Quote 0
                                    ElCriminale @Daniel D. last edited by
                                    ich setze den Adapter in v2.9.3 ein mit drei HmIP-eTRV-2, dazu Fensterkontakte von Aqara. Das funktioniert auch gut. Nun möchte ich noch Aqara Temperatursensoren mit einbinden, welche ich im Adapter unter zusätzliche Temperatursensoren hinzugefügt habe. Die zusätzlichen Temperatursensoren sind angehakt, offset steht auf 2.
                                    Bleibt der Datenpunkt "Objekt-ID aktuelle Temperatur" weiterhin das Thermostat oder dann der zusätzliche Temperatursensor? Aktuell ist noch das Thermostat hinterlegt. Ist das also alles so richtig?
                                    Bedeutet offset die Differenz zwischen den beiden Temperaturmesspunkten und diese darf dann nicht größer sein, als der eingestellte Wert?
                                    Danke und Gruß Ingo
                                      ManfredHi last edited by
                                      Hallo.
                                      Habe eine Frage zu den Zeitperioden.
                                      Ich habe an und für sich 4 Perioden eingestellt. Wenn ich bei einzelnen Räumen dann jedoch nur zwei Perioden benötige, genügt es nur diese beiden dann einzutragen und den Rest leer zu lassen, oder muss ich zusätzlich zwei Zeiten mit den gleichen Temperaturwerten angeben?
                                      • Rene_HM
                                        Rene_HM Developer @ManfredHi last edited by
                                        @manfredh-1 sagte in Test Adapter HeatingControl v2.9.x:
                                        Du musst alle vier Perioden eintragen. Wenn du nur zwei benötigst musst du trotzdem vier unterschiedliche Zeiten aber dann mit gleichen Temperaturen eintragen...
                                        • Rene_HM
                                          Rene_HM Developer @ElCriminale last edited by
                                          @elcriminale sagte in Test Adapter HeatingControl v2.9.x:
                                          Einfach die Temperatursensoren zusätzlich eintragen, alles andere bleibt gleich...
                                          • Rene_HM
                                            Rene_HM Developer @Daniel D. last edited by
                                            Zeige doch mal mit ein paar Bildern, was du meinst. Ich denke, wir verstehen dein Problem noch nicht so recht...
                                            Der Adapter stellt keine Thermostate auf "auto", aber evtl. meinst du ja ganz etwas anderes....
                                            heating
                                            236
                                            3158
                                            1820424
