    4. [gelöst] VIS: funktioniert nicht
      toste @Thomas Braun last edited by
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@8.19.2
      2 info using node@v16.18.0
      3 timing npm:load:whichnode Completed in 1ms
      4 timing config:load:defaults Completed in 5ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
      6 timing config:load:builtin Completed in 3ms
      7 timing config:load:cli Completed in 6ms
      8 timing config:load:env Completed in 0ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
      10 timing config:load:project Completed in 6ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:validate Completed in 1ms
      16 timing config:load:credentials Completed in 3ms
      17 timing config:load:setEnvs Completed in 3ms
      18 timing config:load Completed in 31ms
      19 timing npm:load:configload Completed in 32ms
      20 timing npm:load:mkdirpcache Completed in 3ms
      21 timing npm:load:mkdirplogs Completed in 1ms
      22 verbose title npm install iobroker.vis@1.4.10
      23 verbose argv "install" "--save-exact" "iobroker.vis@1.4.10"
      24 timing npm:load:setTitle Completed in 4ms
      25 timing config:load:flatten Completed in 9ms
      26 timing npm:load:display Completed in 12ms
      27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
      28 verbose logfile /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
      29 timing npm:load:logFile Completed in 15ms
      30 timing npm:load:timers Completed in 1ms
      31 timing npm:load:configScope Completed in 0ms
      32 timing npm:load Completed in 70ms
      33 timing arborist:ctor Completed in 2ms
      34 silly logfile start cleaning logs, removing 2 files
      35 silly logfile done cleaning log files
      36 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      37 timing idealTree:init Completed in 2113ms
      38 timing idealTree:userRequests Completed in 15ms
      39 silly idealTree buildDeps
      40 silly fetch manifest iobroker.vis@1.4.10
      41 http fetch GET 200 https://registry.npmjs.org/iobroker.vis 1804ms (cache hit)
      42 silly placeDep ROOT iobroker.vis@1.4.10 OK for: iobroker.inst@3.0.0 want: 1.4.10
      43 silly fetch manifest axios@^0.24.0
      44 http fetch GET 200 https://registry.npmjs.org/axios 701ms (cache revalidated)
      45 timing idealTree:#root Completed in 2547ms
      46 silly placeDep node_modules/iobroker.vis axios@0.24.0 OK for: iobroker.vis@1.4.10 want: ^0.24.0
      47 timing idealTree:node_modules/iobroker.vis Completed in 7ms
      48 timing idealTree:node_modules/iobroker.vis/node_modules/axios Completed in 0ms
      49 timing idealTree:buildDeps Completed in 2556ms
      50 timing idealTree:fixDepFlags Completed in 19ms
      51 timing idealTree Completed in 4736ms
      52 timing reify:loadTrees Completed in 4739ms
      53 timing reify:diffTrees Completed in 55ms
      54 silly reify moves {}
      55 timing reify:retireShallow Completed in 3ms
      56 timing reify:createSparse Completed in 25ms
      57 timing reify:loadBundles Completed in 0ms
      58 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
      59 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
      60 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto
      61 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto' ]
      62 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/nan
      63 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/nan' ]
      64 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install
      65 silly reify mark deleted [
      65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/prebuild-install',
      65 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/prebuild-install'
      65 silly reify ]
      66 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc
      67 silly reify mark deleted [
      67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/detect-libc',
      67 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/detect-libc'
      67 silly reify ]
      68 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi
      69 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/node-abi' ]
      70 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog
      71 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/npmlog' ]
      72 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/semver
      73 silly reify mark deleted [
      73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/semver',
      73 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/.bin/semver'
      73 silly reify ]
      74 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet
      75 silly reify mark deleted [
      75 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/are-we-there-yet'
      75 silly reify ]
      76 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge
      77 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/gauge' ]
      78 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream
      79 silly reify mark deleted [
      79 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/readable-stream'
      79 silly reify ]
      80 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba
      81 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/aproba' ]
      82 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width
      83 silly reify mark deleted [
      83 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string-width'
      83 silly reify ]
      84 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi
      85 silly reify mark deleted [
      85 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/strip-ansi'
      85 silly reify ]
      86 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray
      87 silly reify mark deleted [ '/opt/iobroker/node_modules/node-aead-crypto/node_modules/isarray' ]
      88 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder
      89 silly reify mark deleted [
      89 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/string_decoder'
      89 silly reify ]
      90 verbose reify failed optional dependency /opt/iobroker/node_modules/code-point-at
      91 silly reify mark deleted [ '/opt/iobroker/node_modules/code-point-at' ]
      92 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point
      93 silly reify mark deleted [
      93 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point'
      93 silly reify ]
      94 verbose reify failed optional dependency /opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex
      95 silly reify mark deleted [
      95 silly reify   '/opt/iobroker/node_modules/node-aead-crypto/node_modules/ansi-regex'
      95 silly reify ]
      96 verbose reify failed optional dependency /opt/iobroker/node_modules/number-is-nan
      97 silly reify mark deleted [ '/opt/iobroker/node_modules/number-is-nan' ]
      98 timing reifyNode:node_modules/osx-temperature-sensor Completed in 30ms
      99 timing reifyNode:node_modules/node-aead-crypto Completed in 30ms
      100 silly tarball no local data for iobroker.vis@https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz. Extracting by manifest.
      101 timing reifyNode:node_modules/number-is-nan Completed in 296ms
      102 timing reifyNode:node_modules/code-point-at Completed in 291ms
      103 timing reifyNode:node_modules/node-aead-crypto/node_modules/strip-ansi Completed in 296ms
      104 timing reifyNode:node_modules/node-aead-crypto/node_modules/string-width Completed in 297ms
      105 timing reifyNode:node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point Completed in 297ms
      106 timing reifyNode:node_modules/node-aead-crypto/node_modules/aproba Completed in 299ms
      107 timing reifyNode:node_modules/node-aead-crypto/node_modules/ansi-regex Completed in 300ms
      108 timing reifyNode:node_modules/node-aead-crypto/node_modules/string_decoder Completed in 313ms
      109 timing reifyNode:node_modules/node-aead-crypto/node_modules/npmlog Completed in 314ms
      110 timing reifyNode:node_modules/node-aead-crypto/node_modules/isarray Completed in 318ms
      111 timing reifyNode:node_modules/node-aead-crypto/node_modules/detect-libc Completed in 324ms
      112 timing reifyNode:node_modules/node-aead-crypto/node_modules/are-we-there-yet Completed in 325ms
      113 timing reifyNode:node_modules/node-aead-crypto/node_modules/semver Completed in 327ms
      114 timing reifyNode:node_modules/node-aead-crypto/node_modules/prebuild-install Completed in 344ms
      115 timing reifyNode:node_modules/node-aead-crypto/node_modules/node-abi Completed in 344ms
      116 timing reifyNode:node_modules/node-aead-crypto/node_modules/gauge Completed in 361ms
      117 timing reifyNode:node_modules/node-aead-crypto/node_modules/readable-stream Completed in 379ms
      118 timing reifyNode:node_modules/iobroker.vis/node_modules/axios Completed in 420ms
      119 timing reifyNode:node_modules/node-aead-crypto/node_modules/nan Completed in 418ms
      120 http fetch GET 200 https://registry.npmjs.org/iobroker.vis/-/iobroker.vis-1.4.10.tgz 2386ms (cache miss)
      121 timing reifyNode:node_modules/iobroker.vis Completed in 2461ms
      122 timing reify:unpack Completed in 2462ms
      123 timing reify:unretire Completed in 0ms
      124 timing build:queue Completed in 5ms
      125 timing build:link Completed in 0ms
      126 info run iobroker.vis@1.4.10 install node_modules/iobroker.vis node main.js --install
      127 info run iobroker.vis@1.4.10 install { code: 6, signal: null }
      128 timing reify:rollback:createSparse Completed in 212ms
      129 timing reify:rollback:retireShallow Completed in 0ms
      130 timing command:install Completed in 10629ms
      131 verbose stack Error: command failed
      131 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
      131 verbose stack     at ChildProcess.emit (node:events:513:28)
      131 verbose stack     at maybeClose (node:internal/child_process:1100:16)
      131 verbose stack     at Socket.<anonymous> (node:internal/child_process:458:11)
      131 verbose stack     at Socket.emit (node:events:513:28)
      131 verbose stack     at Pipe.<anonymous> (node:net:301:12)
      132 verbose pkgid iobroker.vis@1.4.10
      133 verbose cwd /opt/iobroker
      134 verbose Linux 5.10.103-v7l+
      135 verbose node v16.18.0
      136 verbose npm  v8.19.2
      137 error code 6
      138 error path /opt/iobroker/node_modules/iobroker.vis
      139 error command failed
      140 error command sh -c -- node main.js --install
      141 verbose exit 6
      142 timing npm Completed in 10985ms
      143 verbose unfinished npm timer reify 1666357655886
      144 verbose unfinished npm timer reify:build 1666357663196
      145 verbose unfinished npm timer build 1666357663198
      146 verbose unfinished npm timer build:deps 1666357663198
      147 verbose unfinished npm timer build:run:install 1666357663205
      148 verbose unfinished npm timer build:run:install:node_modules/iobroker.vis 1666357663206
      149 verbose code 6
      150 error A complete log of this run can be found in:
      150 error     /home/iobroker/.npm/_logs/2022-10-21T13_07_35_535Z-debug-0.log
        Thomas Braun Most Active @toste last edited by
        @toste sagte in VIS: funktioniert nicht:
        iob install vis@1.4.5
        T metaxa 2 Replies Last reply Reply Quote 2
          OK, das sieht anders aus und läuft wieder:
          pi@raspberrypi:/home/iobroker $ iob install vis@1.4.5
          NPM version: 8.19.2
          Installing iobroker.vis@1.4.5... (System call)
          added 1 package in 22s
          60 packages are looking for funding
            run `npm fund` for details
          host.raspberrypi install adapter vis@1.4.5
          upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
          upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
          upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
          upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
          Adapter "system.adapter.vis.0" restarted.
          upload [322] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
          upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/cancel.png icon/cancel.png image/png
          upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulb_on.png img/bulb_on.png image/png
          upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/128/mp3.png js/fm/icon/mine/128/mp3.png image/png
          upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
          upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/signals/motionColor.png signals/motionColor.png image/png
          upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_BulbOnOffCtrl.png widgets/basic/img/Prev_BulbOnOffCtrl.png image/png
          upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ScreenResolution.png widgets/basic/img/Prev_ScreenResolution.png image/png
          upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueBoolCtrl.png widgets/basic/img/Prev_ValueBoolCtrl.png image/png
          upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_ValueListHtml8.png widgets/basic/img/Prev_ValueListHtml8.png image/png
          upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/micDetected.svg widgets/basic/img/micDetected.svg image/svg+xml
          upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/info/js/info.js widgets/info/js/info.js application/javascript
          upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialog.png widgets/jqui/img/Prev_ContainerDialog.png image/png
          upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Carousel.png widgets/swipe/img/Prev_Carousel.png image/png
          upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/Prev_Swipe.png widgets/swipe/img/Prev_Swipe.png image/png
          upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
          upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
          upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
          upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
          upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
          upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
          upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
          upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
          upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
          upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
          upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
          upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
          upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
          upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
          upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
          upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
          upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
          upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
          upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
          host.raspberrypi object system.adapter.vis created/updated
          Update "system.adapter.vis.0"
          Jetzt bietet er mir wieder das Update auf 1.4.15 an. Soll ich das probieren?
            @toste
            sudo ln -s /usr/bin/node /usr/bin/nodejs
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            iob update
            sagt? Wenn das sauber ist kannst du das upgrade auf die aktuelle vis wagen.
              pi@raspberrypi:/home/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
              ln: failed to create symbolic link '/usr/bin/nodejs': File exists
              pi@raspberrypi:/home/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.0
              v16.18.0
              8.19.2
              4.0.23
              pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              /home/iobroker
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
              Hit:4 https://www.pivccu.de/piVCCU stable InRelease
              Reading package lists... Done
              Building dependency tree
              All packages are up to date.
              nodejs:
                Installed: 16.18.0-deb-1nodesource1
                Candidate: 16.18.0-deb-1nodesource1
                Version table:
               *** 16.18.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                      100 /var/lib/dpkg/status
                   10.24.0~dfsg-1~deb10u2 500
              pi@raspberrypi:/home/iobroker $ iob update
              Used repository: Stable (default)
              Adapter    "admin"        : 6.2.22   , installed 6.2.22
              Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
              Adapter    "backitup"     : 2.4.12   , installed 2.4.12
              Adapter    "daswetter"    : 3.1.3    , installed 3.1.3
              Adapter    "discovery"    : 3.0.5    , installed 3.0.5
              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
              Adapter    "flot"         : 1.11.0   , installed 1.11.0
              Adapter    "history"      : 2.2.0    , installed 2.2.0
              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
              Adapter    "info"         : 1.9.19   , installed 1.9.19
              Adapter    "iot"          : 1.11.9   , installed 1.11.9
              Adapter    "javascript"   : 6.0.3    , installed 6.0.3
              Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
              Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
              Adapter    "ping"         : 1.5.3    , installed 1.5.3
              Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
              Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
              Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
              Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
              Adapter    "tuya"         : 3.6.15   , installed 3.6.15
              Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
                @toste
                Das sieht gut aus. Bring das mal auf die aktuelle vis.
                  Prima, auch das hat funktioniert. Vielen lieben Dank !!
                  Aber warum das jetzt nicht direkt ging, wissen wir nicht?
                    Ich vermute, das hat mit der Lizenz zu tun. Bei den alten Versionen wurde das anders gehandhabt, soweit ich weiß.
                      Schmunzi57 last edited by
                      Guten Morgen, auch ich hatte genau dieses Problem und es konnte, wie hier auch gelöst werden.
                      Nun bin ich wieder HAPPY 😋
                      Recht herzlichen Dank an alle die hier helfen und für uns "weniger wissende" da sind.
                      Mein besonderer Dank gilt in diesem Fall @Thomas-Braun, denn ohne dieses spezifische Wissen ist man halt aufgeschmissen.
                      In diesem Sinne nochmal mein Danke und macht bitte weiter so.
                      Tschüs
                      • metaxa
                        metaxa @Thomas Braun last edited by
                        @thomas-braun sagte in [gelöst] VIS: funktioniert nicht:
                        Auch von meiner Seite, danke!
                        2300
