    3. Entwicklung
    4. [Neuer Adapter] Reolink Kamera
    • da_Woody
      da_Woody @Andy Grundt last edited by da_Woody
      @andy-grundt moin! 🙂 gerade noch mal drübergespielt, jetzt wurde reolink.0 grün. die beiden anderen instanzen gestartet, auch beide grün.
      log:
      reolink.2
      2022-10-26 06:16:19.517	warn	Read-only state "reolink.2.disc.mounted" has been written without ack-flag with value "false"
      reolink.2
      2022-10-26 06:16:19.471	warn	Read-only state "reolink.2.disc.free" has been written without ack-flag with value "0"
      reolink.2
      2022-10-26 06:16:19.424	warn	Read-only state "reolink.2.disc.formatted" has been written without ack-flag with value "false"
      reolink.2
      2022-10-26 06:16:19.413	warn	Read-only state "reolink.2.disc.capacity" has been written without ack-flag with value "0"
      reolink.1
      2022-10-26 06:16:12.548	warn	Read-only state "reolink.1.disc.mounted" has been written without ack-flag with value "false"
      reolink.1
      2022-10-26 06:16:12.492	warn	Read-only state "reolink.1.disc.free" has been written without ack-flag with value "0"
      reolink.1
      2022-10-26 06:16:12.435	warn	Read-only state "reolink.1.disc.formatted" has been written without ack-flag with value "false"
      reolink.1
      2022-10-26 06:16:12.386	warn	Read-only state "reolink.1.disc.capacity" has been written without ack-flag with value "0"
      reolink.0
      2022-10-26 06:15:45.925	warn	Read-only state "reolink.0.disc.mounted" has been written without ack-flag with value "false"
      reolink.0
      2022-10-26 06:15:45.878	warn	Read-only state "reolink.0.disc.free" has been written without ack-flag with value "0"
      reolink.0
      2022-10-26 06:15:45.833	warn	Read-only state "reolink.0.disc.formatted" has been written without ack-flag with value "false"
      reolink.0
      2022-10-26 06:15:45.784	warn	Read-only state "reolink.0.disc.capacity" has been written without ack-flag with value "0"
      hatte gestern auch bei Hosts eine fehlermeldung. da stand was von "restart loop endeckt" leider keinen screenshot gemacht.
      Andy Grundt 2 Replies Last reply Reply Quote 0
      • Andy Grundt
        Andy Grundt Developer @da_Woody last edited by
        @da_woody Danke...falls du noch was findest, sagt beschied.
        • da_Woody
          @andy-grundt gerne, wenn ich zeit habe und verschiedene dingens probiere. ich verwende die meisten adapter nur rudimentär, also ohne irgend welche benachrichtigungen. so gesehn verwende ich auch keine bewegundmeldungen und sonstiges.
          kann dir also nur berichten, ob eine neue version nicht tut... 🙂
          • I
            Idefix01 @da_Woody last edited by
            Hallöchen, ich habe es in der Vis mit folgendem Link eingefügt und es funktioniert einwandfrei.
            https://IP-der-Kamera/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG 7C&user=Benutzername&password=Password&width=1920&height=1080
            • Andy Grundt
              @da_woody
              Das schreiben der Datenpunkte ohne ack-flag wurde auch behoben. Sollte jetzt nicht mehr im log auftauchen.
              • da_Woody
                @andy-grundt hüstel... nach nem update über den link hats mächtig geraschelt. hab dann mal alle 3 instanzen, die grün waren gestoppt, log gelöscht, die 0 gestartet:
                reolink.0
                2022-10-28 13:54:54.672	error	DB closed
                reolink.0
                2022-10-28 13:54:54.671	error	Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40) at ReoLinkCam.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5880:35)
                reolink.0
                2022-10-28 13:54:54.670	error	unhandled promise rejection: DB closed
                reolink.0
                2022-10-28 13:54:54.670	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                reolink.0
                2022-10-28 13:54:54.670	warn	get state error: Connection is closed.
                reolink.0
                2022-10-28 13:54:54.553	warn	get state error: DB closed
                reolink.0
                2022-10-28 13:54:53.430	error	Value not supported!
                reolink.0
                2022-10-28 13:54:53.217	error	Value not supported!
                reolink.0
                2022-10-28 13:54:52.936	error	Value not supported!
                reolink.0
                2022-10-28 13:54:52.708	error	Value not supported!
                reolink.0
                2022-10-28 13:54:52.475	error	Value not supported!
                reolink.0
                2022-10-28 13:54:52.346	error	Value not supported!
                reolink.0
                2022-10-28 13:54:52.220	error	Value not supported!
                reolink.0
                2022-10-28 13:54:52.094	error	Value not supported!
                reolink.0
                2022-10-28 13:54:51.982	error	Value not supported!
                reolink.0
                2022-10-28 13:54:51.836	error	Value not supported!
                reolink.0
                2022-10-28 13:54:51.700	error	Value not supported!
                reolink.0
                2022-10-28 13:54:51.569	error	Value not supported!
                reolink.0
                2022-10-28 13:54:51.443	error	Value not supported!
                reolink.0
                2022-10-28 13:54:51.293	error	Value not supported!
                reolink.0
                2022-10-28 13:54:51.174	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.991	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.858	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.750	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.620	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.491	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.336	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.208	error	Value not supported!
                reolink.0
                2022-10-28 13:54:50.090	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.984	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.847	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.713	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.578	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.442	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.320	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.159	error	Value not supported!
                reolink.0
                2022-10-28 13:54:49.028	error	Value not supported!
                reolink.0
                2022-10-28 13:54:48.911	error	Value not supported!
                reolink.0
                2022-10-28 13:54:48.785	error	Value not supported!
                reolink.0
                2022-10-28 13:54:48.645	error	Value not supported!
                • da_Woody
                  da_Woody @da_Woody last edited by
                  @da_woody hab nochmal den adapter instance0 gestartet mit debug
                  host.ioBroker
                  2022-10-28 14:41:06.173	info	instance system.adapter.reolink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  host.ioBroker
                  2022-10-28 14:41:05.072	info	stopInstance system.adapter.reolink.0 send kill signal
                  reolink.0
                  2022-10-28 14:41:05.029	info	State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "string"
                  reolink.0
                  2022-10-28 14:41:04.737	debug	Error or not supported getMailNotification
                  reolink.0
                  2022-10-28 14:41:04.614	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  reolink.0
                  2022-10-28 14:41:04.614	info	terminating
                  reolink.0
                  2022-10-28 14:41:04.614	debug	refreshStateTimeout: UNLOAD
                  reolink.0
                  2022-10-28 14:41:04.613	info	Got terminate signal TERMINATE_YOURSELF
                  host.ioBroker
                  2022-10-28 14:41:03.755	info	stopInstance system.adapter.reolink.0 (force=false, process=true)
                  host.ioBroker
                  2022-10-28 14:41:03.754	info	"system.adapter.reolink.0" disabled
                  reolink.0
                  2022-10-28 14:41:03.719	debug	mailValue 200: [{"cmd":"Unknown","code":1,"error":{"detail":"not support","rspCode":-9}}]
                  reolink.0
                  2022-10-28 14:41:03.647	error	Value not supported!
                  reolink.0
                  2022-10-28 14:41:03.647	info	Changed state: EmailNotification
                  reolink.0
                  2022-10-28 14:41:03.646	debug	state reolink.0.settings.EmailNotification changed: Error or not supported (ack = true)
                  reolink.0
                  2022-10-28 14:41:03.596	info	State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "string"
                  reolink.0
                  2022-10-28 14:41:03.560	debug	Error or not supported getMailNotification
                  reolink.0
                  2022-10-28 14:41:03.520	debug	mailValue 200: [{"cmd":"Unknown","code":1,"error":{"detail":"not support","rspCode":-9}}]
                  reolink.0
                  2022-10-28 14:41:03.428	error	Value not supported!
                  • Wszene
                    Wszene last edited by Wszene
                    @Andy-Grundt
                    Hallo Zusammen,
                    Ich habe 2x die Reolink RLC-510A
                    Ich bekomme auch die Datenpunkte
                    Habe da aber mal eine Frage zur Bewegungserkennung
                    Sollte sich der DP "reolink.0.sensor.motion" bei Erkennung auf "1" ändern?
                    Wenn Ja dann funktioniert das nicht
                    Ich habe mal zum Testen in der App die Push-Mitteilung angeschalten Diese springt an
                    Danke im Voraus
                    Marcel
                      msauer last edited by
                      Hallo Zusammen,
                      ich würde gerne in Blockly mit einem Trigger des Objekts reolink.0.sensor.motion ein Bild per pushover verschicken. Nun ist in dem Beispiel zwar die Javascript Prozedur vorgeschlagen, wie aber setzte ich das in Blockly um. Hat das schon jemand gemacht und mag es mit uns teilen?
                      Mark
                        Mutze last edited by
                        Guten Abend,
                        vorweg, es ist toll was diese Community auf die Beine stellt. Das ist ein Grund warum ich heute meine Reolink Kameras bekommen habe.
                        Dank dieses neuen Adapters habe ich auch bereits die erste Kamera in ioBroker einbinden können. Bei der Kamera handelt es sich um eine Reolink TrackMix PoE.
                        Soweit ich das bisher beurteilen kann, funktioniert die Einbindung. Die Kamera einschl. der hier bereits diskutierten Parameter werden erkannt.
                        Ein kleiner Hinweis.
                        Nach dem Anlegen der ersten Instanz und das Einbinden der Kamera ist der Start des Adapters gescheitert. Der Adpater blieb auf der gelben Statusmeldung hängen und im Logfile stand etwas wie "type undefined".
                        Dann erinnerte ich mich, dass ich Sonderzeichen für das Passwort der Kamera verwendet habe. Mit diesen Sonderzeichen hatte ich bereits bei einem anderen Adapter mal Probleme. Nach dem Ändern des Passwortes ohne die Sonderzeichen konnte die Verbindung problemlos aufgebaut werde.
                        Ich weiß nicht ob die Entwickler mit dem Hinweis etwas anfangen können und ggf. in einem nächsten Release eine Änderung berücksichtigen.
                        Ich werde in den kommenden Tagen gerne weiter testen und berichten.
                        Folgende 2 weitere Kameratypen habe ich heute auch noch bekommen und werde diese auch testen.
                        Reolink RCL-823A
                        Reolink Duo 2 PoE
                        Werden im Laufe der Woche auch eingebunden und ich berichte.
                        Nochmals vielen Dank an die Entwickler und die Community.
                        Gruss Mutze
                          meerkat @Wolfi last edited by
                          Hi @wolfi
                          Ich habe auch eine E1 Outdoor gekauft und wollte nun auch den preset nutzen. Bei mir steht nur Null im datenpunkt und wenn ich bspw. 1 eintrage, dann passiert nichts.
                          Presets sind natürlich in der Kamera angelegt und über die App bzw. Website kann ich diese auch ansteuern.
                          Hast du nich spezielle Einstellungen gemacht?
                            Wolfi @meerkat last edited by Wolfi
                            @meerkat
                            Stimmt geht bei mir via Adapter auch nicht mehr.
                            Was ist eigentlich die aktuelle Version? Suche den Link zur Installation?
                            geht zur not auch so via blockly
                            https://forum.iobroker.net/post/853217
                              Hi @wolfi,
                              Teste ich nachher mal. Hast du den im Post genannten link auch noch? Würde mal schauen, was ich dann noch einbaue
                              Meerkat
                                @meerkat
                                Finde gerade den link nicht mehr suche mal nach " Reolink API CGI commands
                                OK habe jetzt die Version 0.1.1 installiert bekommen.
                                PLZPreset geht aber nicht!
                                Kann das sonst noch jemand bestätigen? (E1 Outdoor)
                                  RoaBo @Wolfi last edited by
                                  @wolfi Nabend. Ich habe eine TrackMix Wifi und auch da leider nicht. Auch klappt es nicht mit dem curl Befehl. In Blocky reagiert nichts und per ssh gibt er "please login first" aus.
                                    meerkat @RoaBo last edited by
                                    Hi @roabo @Wolfi
                                    Habe gestern Abend auch noch lange probiert. Beim curl musste ich in der Adresse den Bereich cgi-bin weglassen und alles mit Token senden. Dafür gibt es ne eigenen aufruf. Teste heute abend noch weiter und gebe dann mal Rückmeldung
                                      @meerkat
                                      Hier mein blockly zum Importieren. (IP mit port und PW anpassen.)
                                      Zeitgesteuert für Pos 4 und 5
                                      Gruss
                                      Reolink_PLZ.txt
                                        @wolfi Super! Das funktioniert. Vielen Dank!
                                          Wolfi last edited by Wolfi
                                          Kann bitte jemand sagen ob das PLZPreset mit dem Aktuellen
                                          Version des Adapters funktionieren sollte??
                                          Jemand der eine E1 Outdoor hatte.
                                          Ich meinte in einer früheren Version hat es mal funktioniert.
                                          Gruss
                                          oelison 1 Reply Last reply Reply Quote 0
                                          • oelison
                                            oelison @Wolfi last edited by
                                            @wolfi Nein, geht nicht. Hatte auf meinem produktiv System noch eine alte (0.0.3), bei der hat das funktioniert. Dann update gemacht auf das aktuelle repository (0.1.1) und es geht nicht mehr.
                                            1.2k
                                            kamera neuer adapter reolink testen
                                            157
                                            1074
                                            449252
