    • Armilar
      Armilar Most Active Forum Testing @Wuschl last edited by Armilar
      @wuschl
      Sende mal deine Config. Ich denke es liegt an einem Parameter. Entweder der Relay-Status oder eine ScreensaverEntity
      Die Fehlermeldung ist ja mal wieder Gold wert 😉
        TT-Tom @Armilar last edited by
        @armilar
        ja das habe ich dann auch gecheckt, darum Fehlpost 😖
          Wuschl @Armilar last edited by Wuschl
          @armilar
          export const config: Config = {
             panelRecvTopic: 'mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT',       // anpassen
             panelSendTopic: 'mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend',   // anpassen
             firstScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Hourly.h0.PrecipitationProbability', ScreensaverEntityIcon: 'weather-pouring', ScreensaverEntityText: 'Regen', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
             secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
             thirdScreensaverEntity: { ScreensaverEntity: "shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3", ScreensaverEntityIcon: "pool-thermometer", ScreensaverEntityText: "Pool", ScreensaverEntityUnitText: "°C", ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 40} },
             fourthScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity', ScreensaverEntityIcon: 'water-percent', ScreensaverEntityText: 'Luft', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
             alternativeScreensaverLayout: false,
             autoWeatherColorScreensaverLayout: true,
             mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.tasmota_0E3BFC.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
             mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.tasmota_0E3BFC.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
             timeoutScreensaver: 20,
             dimmode: 20,
             active: 100, //Standard-Brightness TFT
             screenSaverDoubleClick: true,
             locale: 'de-DE',                                // en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
             timeFormat: '%H:%M',                            // currently not used
             dateFormat: '%A, %d. %B %Y',                    // currently not used
             weatherEntity: 'alias.0.Wetter.Gerät_1',                // Dieser Alias muss erstellt werden, damit die 4 kleineren Icons (Wetter oder DP) angezeigt werden können --> oder autoCreateAlias auf true
             defaultOffColor: Off,
             defaultOnColor: On,
             defaultColor: Off,
             defaultBackgroundColor: Black,    //New Parameter
             temperatureUnit: '°C',
             pages: [
                     Garagen
                     WLAN
                     Service             //Auto-Alias Service Page
             subPages: [
                         NSPanel_Infos,              //Auto-Alias Service Page
                         NSPanel_Einstellungen,      //Auto-Alias Service Page
                         NSPanel_Firmware_Info       //Auto-Alias Service Page
             button1Page: null,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
             button2Page: null    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
          Armilar Meister-x 4 Replies Last reply Reply Quote 0
          • Armilar
            @wuschl sagte in SONOFF NSPanel mit Lovelace UI:
            Setzte mal die da ``` in die Spalte darunter und ganz nach vorne. Dann wird es besser lesbar
            • Peoples
              Peoples @Armilar last edited by
              @armilar
              Wenn du mir sagst wie ich den Common Name Abfrage Versuche ich's Mal.
              Node ist die 16.18.1
              Armilar 2 Replies Last reply Reply Quote 0
              • Meister-x
                Meister-x @Wuschl last edited by
                @wuschl
                wo müsste ich meie Meldung Bwegungsmelder dazu einfügen?
                • Armilar
                  Da ist doch schon etwas...
                  Dein Tele läuft auf:
                  dein Stat läuft auf:
                  und ist irgendwie ein völlig anderes Gerät
                  Versuche es mal mit:
                  mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
                  mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
                  • Armilar
                    Armilar Most Active Forum Testing @Meister-x last edited by
                    @meister-x
                    ich muss es erstmal einbauen. Wird in die nächste Version kommen.
                    Meister-x 2 Replies Last reply Reply Quote 0
                    • Meister-x
                      Meister-x @Armilar last edited by
                      @armilar
                      super -vielen Dank !!!!!!
                      • Armilar
                        Armilar Most Active Forum Testing @Peoples last edited by Armilar
                        @peoples
                        Warte - ich klicke mal schnell ein paar Zeilen zusammen...
                        16.18.1 passt. Schon vorbildlich 😊
                          @armilar super danke. Jetzt bleibt nur noch das übrig
                          16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                          16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                          16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                          16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
                          • Armilar
                            Armilar Most Active Forum Testing last edited by
                            @armilar
                            Würde mir ein klein wenig von deiner Seite helfen, wenn du sehen würdest, was im Screensaver aktuell nicht läuft 😉
                              @armilar das hier fehlt, das finde ich nirgends.
                               //Subpage 2 von Subpages_2
                                      let NSPanel_Einstellungen: PageEntities =
                                          'type': 'cardEntities',
                                          'heading': 'Screensaver',
                                          'useColor': true,
                                          'subPage': true,
                                          'parent': Service,
                                          'items': [
                                              <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                                              <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                                              <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                                              <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
                              • Armilar
                                Armilar Most Active Forum Testing @Armilar last edited by Armilar
                                @armilar
                                on({id: [].concat(['0_userdata.0.NSPanel.1.Relay.1']).concat(['0_userdata.0.NSPanel.1.Relay.2']), change: "ne"}, async function (obj) {
                                    console.log(obj.id);
                                    console.log((obj.common ? obj.common.name : ""));
                                    console.log((obj.common ? obj.common.desc : ""));
                                    console.log(obj.channelId);
                                    console.log(obj.channelName);
                                    console.log(obj.deviceName);
                                    console.log((obj.state ? obj.state.val : ""));
                                    console.log((obj.state ? obj.state.ts : ""));
                                    console.log((obj.state ? obj.state.q : ""));
                                    console.log((obj.state ? obj.state.from : ""));
                                Pass mal die beiden Datenpunkte im Trigger an deine an. Dann Trigger mal beide Datenpunkte (true/false) und sende das Log zurück.
                                --> Als neues Test-Script anlegen
                                Ich denke wir werden mit einem Spit über die obj.id gehen. Die ist eindeutig
                                Peoples 1 Reply Last reply Reply Quote 0
                                • Armilar
                                  @peoples
                                  Habe es auf die obj.id umgeschrieben. Tausche mal die Zeilen im TS-Script aus...
                                  //switch Relays 1 + 2 with DP's
                                  async function Init_Relays() {
                                      if (existsState(NSPanel_Path + 'Relay.1') == false ||
                                          existsState(NSPanel_Path + 'Relay.2') == false) {
                                          await createStateAsync(NSPanel_Path + 'Relay.1', true, { type: 'boolean' });
                                          await createStateAsync(NSPanel_Path + 'Relay.2', true, { type: 'boolean' });
                                  Init_Relays();
                                  on({id: [].concat(String(NSPanel_Path) + 'Relay.1').concat(String(NSPanel_Path) + 'Relay.2'), change: "ne"}, async function (obj) {
                                      try {
                                          let Button = obj.id.split('.');
                                          console.log(((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))));
                                          require("request")((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))).on("error", function (err) {console.error(err.message);});
                                      } catch (err) {
                                          console.warn(err.message);
                                  on({id: [].concat(config.mrIcon1ScreensaverEntity.ScreensaverEntity).concat(config.mrIcon2ScreensaverEntity.ScreensaverEntity), change: "ne"}, async function (obj) {
                                      if (obj.id.substring(0,4) == 'mqtt') {
                                          if (getState(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6)).val != obj.state.val) {
                                              await setStateAsync(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6), obj.state.val == 'ON' ? true : false);
                                  • Armilar
                                    @wuschl
                                    Oh ich dachte mehr wenn du direkt auf den Screensaver vom NSPanel siehst. Ist da alles okay, oder fehlt etwas?
                                    • Armilar
                                      Sehe soeben das pages-Array. Da ist auch ein Fehler drin. Es fehlen die Kommas - hab sie mal eingebaut.
                                      pages: [
                                                 Garagen,
                                                 WLAN,
                                        @armilar da ist alles da.
                                        Nur die Screensaver Einstellungen fehlen.
                                        • Armilar
                                          @wuschl
                                          Den Post darüber mal geändert?
                                            @armilar ja, Kommas eingebaut, aber ändert nichts.
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6242332
