    4. Test Adapter zigbee2mqtt
    • Noosi
      Noosi last edited by
      wenn legacy des dimmers auf true gestellt wird, werden diese Ausgaben erzeugt :
      info 2022-11-05 13:51:24MQTT publish: topic 'zigbee2mqtt/Hue!Switch AG Schreibtisch', payload '{"battery":63.5,"counter":1,"last_seen":1667652685463,"linkquality":65,"update":{"state":"idle"}}'
      info 2022-11-05 13:51:24MQTT publish: topic 'zigbee2mqtt/Hue!Switch AG Schreibtisch', payload '{"battery":63.5,"counter":1,"last_seen":1667652685472,"linkquality":65,"update":{"state":"idle"}}'
      info 2022-11-05 13:51:25MQTT publish: topic 'zigbee2mqtt/Hue!Switch AG Schreibtisch', payload '{"action":"off-hold","battery":63.5,"counter":1,"duration":0.801,"last_seen":1667652686264,"linkquality":65,"update":{"state":"idle"}}'
      info 2022-11-05 13:51:26MQTT publish: topic 'zigbee2mqtt/Hue!Switch AG Schreibtisch', payload '{"action":"off-hold","battery":63.5,"counter":1,"duration":1.602,"last_seen":1667652687065,"linkquality":65,"update":{"state":"idle"}}'
      info 2022-11-05 13:51:27MQTT publish: topic 'zigbee2mqtt/Hue!Switch AG Schreibtisch', payload '{"action":"off-hold","battery":63.5,"counter":1,"duration":2.401,"last_seen":1667652687864,"linkquality":65,"update":{"state":"idle"}}'
      info 2022-11-05 13:51:28MQTT publish: topic 'zigbee2mqtt/Hue!Switch AG Schreibtisch', payload '{"action":"off-hold","battery":63.5,"counter":1,"duration":3.202,"last_seen":1667652688664,"linkquality":65,"update":{"state":"idle"}}'
      info 2022-11-05 13:51:28MQTT publish: topic 'zigbee2mqtt/Hue!Switch AG Schreibtisch', payload '{"action":"off-hold-release","battery":63.5,"counter":1,"duration":3.248,"last_seen":1667652688711,"linkquality":65,"update":{"state":"idle"}}'
      info 2022-11-05 13:52:33MQTT publish: topic 'zigbee2mqtt/Hue!GU10 AG Decke Links', payload '{"brightness":254,"color":{"x":0.3685,"y":0.369},"color_mode":"color_temp","color_temp":233,"last_seen":1667652753774,"linkquality":65,"state":"OFF","update":{"state":"idle"}}'
      Bis auf die linkquality aktuallisiert sich im IOBroker KEIN anderer Datenpunkt. Aktionen werden hier mit bindestrich gesendet.
      Legacy des dimmers auf false > Alle Datenpunkte aktuallisieren sich im IOBRoker, Aktionen werden mit unterstrich gesendet.
      Nur in diesem Fall bleibt das HOLD auf true.
      IdleBit 1 Reply Last reply Reply Quote 0
      • IdleBit
        IdleBit @Noosi last edited by IdleBit
        @noosi sagte in Test Adapter zigbee2mqtt:
        Hast du dir einmal die Docu angeschaut..
        legacy ist nicht unterstützt
        Wie ich schon mehrmals erwähnt erstelle doch ein issues, das hier ist nicht zielführend und verbrennt nur kostbare Zeit...
          crunchip Forum Testing Most Active last edited by crunchip
          hab das gestern auch mal installiert, läuft soweit prima Sache👍 , bis aufs Problem mit dem Admin in einem 2ten Browserfenster, wenn im anderen Browser das interne zigbee2mqtt offen ist, lässt sich nichts mehr bedienen und der Admin läd sich zu tote.
          Die eigentliche Frage die ich habe,
          mit aktivem
          availability: true
          werden mir ja die Geräte als erreichbar angezeigt, allerdings habe ich Saisonbedingt Geräte die aktuell nicht im Betrieb sind. (im zigbee Adapter konnte man die deaktivieren)
          wie funktioniert das hier bzw gibt es so eine Funktion, oder einfach überlesen?
          Habe testhalber diese mal auf die blacklist gesetzt, werden aber trotzdem weiter angepingt was ja alle 10 Min zur folgenden Meldung führt
          Failed to ping 'Christbaum' (attempt 1/1, Read 0x842e14fffe05ea44/1 genBasic(["zclVersion"], {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
          oder bleibt nur die Möglichkeit das Prüfen der Erreichbarkeit speziell für diese Geräte manuell in die .yaml einzutragen?
          yaml einzutragen, jedoch greift diese nicht
          EDIT:
          hab jetzt mal versucht eine availability-advanced-configuration in die .yaml mit einzufügen, diese greift aber nicht. könnte da wer mal behilflich sein?
          N mickym 2 Replies Last reply Reply Quote 0
          • N
            nox309 @crunchip last edited by
            @crunchip
            möge mich der @IdleBit verbessern, aber die Datenpunkte bleiben immer im ioBroker bestehen, heißt ich würde die Geräte einfach in Z2M löschen und bei Bedarf wieder einbinden.
            Die Datenpunkte von gelöschten Geräten bekommen den Namen "deleted" oder so, somit bleiben alle Skripte und sonstige Einstellungen im ioB Aktiv.
            Vielleicht ist das ja eine gangbare Lösung für dich.
            crunchip 1 Reply Last reply Reply Quote 2
              crunchip Forum Testing Most Active @nox309 last edited by
              @nox309 sagte in Test Adapter zigbee2mqtt:
              logisch, aber die Ping Prüfung kann doch durch diese Funktion deaktiviert werden.
              bleibt mir anderweitig aktuell nichts anderes übrig
                @crunchip wenn du den hier einträgst .. dann wird der auch nicht im object tree angezeigt
                crunchip 1 Reply Last reply Reply Quote 1
                • IdleBit
                  IdleBit last edited by
                  @crunchip die Ping Meldungen ist doch nur ein Warnung (wenn ich mich jetzt nicht täusche), du könntest einfach das Loglevel in Zigbee2mqtt auf error hochstellen.
                  arteck crunchip 2 Replies Last reply Reply Quote 0
                    arteck Developer Most Active @IdleBit last edited by
                    @idlebit jo auch
                      crunchip Forum Testing Most Active @arteck last edited by
                      @arteck da hatte ich sie schon testweise drin, trotzdem wird versucht diese anzupingen. Die Geräte waren ja im zigbee Adapter bereits deaktiv, beim Umzug der Datenbank auf zigbee2mqtt, wurden die Geräte ja in den Objekten mit angelegt, folglich können diese jetzt nicht angepingt werden, da aktuell nicht angeschlossen und wenn ich nachträglich die Geräte auf block setze greift nix und es kommt trotzdem die Failed to ping...., siehe oben
                        crunchip Forum Testing Most Active @IdleBit last edited by
                        @idlebit richtig, wäre auch eine Möglichkeit, trotzdem sollte aber das doch möglich sein?
                        IdleBit 2 Replies Last reply Reply Quote 0
                        • IdleBit
                          IdleBit @crunchip last edited by
                          @crunchip das ist meines Wissens von zigbee2mqtt nicht vorgesehen, da habe ich kein Einfluss darauf.
                          Du könntest noch mit den Datenpunkt logfilter die Logs filterten, mehr kann ich dir aktuell leider nicht anbieten.
                            @idlebit sagte in Test Adapter zigbee2mqtt:
                            na doch @crunchip mach ein isse auf zigbee2mqtt seite auf.. für Änderung
                            • IdleBit
                              IdleBit @crunchip last edited by IdleBit
                              @crunchip sagte in Test Adapter zigbee2mqtt:
                              Kann sein, ich habe das noch nicht Probiert da ich keine devices offline habe.
                              #Edit:
                              Hattest du nach der Änderung in der yaml zigbee2mqtt neu gestartet
                                crunchip Forum Testing Most Active @IdleBit last edited by crunchip
                                diesen Satz verstehe ich jetzt aber nicht,
                                das ist doch die Beschreibung von zigbee2mqtt
                                @arteck sagte in Test Adapter zigbee2mqtt:
                                du meinst hier?
                                ja
                                EDIT:
                                hab jetzt mal eines der Geräte aus dem zigbee2mqtt gelöscht,
                                in den Objekten bleibt es ja nach wie vor vorhanden und ping Meldung ist weg.
                                Bei Wiederanschluss sollte es sich ja automatisch wieder integrieren, muss dann wahrscheinlich nur entsprechend den Name wieder vergeben.
                                  mir ist gestern noch aufgefallen, dass 3 der Sensoren(xiaomi Türkontakt und Bewegungsmelder) nichts an iobroker übertragen. In den Objekten zwar vorhanden aber aktualisieren nicht.
                                  Im zigbee2mqtt funktionieren sie jedoch korrekt.
                                  was hab ich schon mehrmals probiert:
                                  • neu verbunden
                                  • Batterie getauscht
                                  • aus dem Netzwerk entfernt und neu angelernt, dabei auch aus iobroker gelöscht
                                  • zwischen den Aktionen Adapter und auch zigbee2mqtt neu gestartet.
                                  hat da wer eine Idee, @arteck @IdleBit?
                                    arteck Developer Most Active @crunchip last edited by
                                    @crunchip nö ich hab davon jede menge .. gehen immer.. ok ausser Betterie leer.
                                    welchen stand hat dein z2m ?? im converter gabs mal ein bug für xiaomi Geräte
                                      crunchip Forum Testing Most Active @arteck last edited by crunchip
                                      ich auch, nur das Problem bei den 3, andere mit mit gleicher Firmware funktionieren
                                      Zigbee2MQTT Version
                                          1.28.2-dev commit: a2f85348
                                      Coordinator-Typ
                                          zStack3x0
                                      Coordinator-Version
                                          20210120
                                      Coordinator IEEE Adresse
                                          0x00124b001ca5ea11
                                      Frontend Version
                                          0.6.115
                                      z.b
                                      Gerätename
                                          BWM Wohn/Esszimmer
                                      Beschreibung
                                      Zuletzt gesehen
                                          vor 6 Minuten
                                      Verfügbarkeit
                                      Geräte-Typ
                                          EndDevice
                                      Zigbee Modell
                                          lumi.sensor_motion.aq2
                                      Zigbee Hersteller
                                          LUMI
                                      Beschreibung
                                          Aqara human body movement and illuminance sensor
                                      Unterstützungsstatus
                                          Unterstützt
                                      IEEE Addresse
                                          0x00158d000236b3f9
                                      Netzwerk Adresse
                                          0x1EF0
                                      Firmware-Datum
                                          20170627
                                      Firmware-Version
                                          3000-0001
                                      Hersteller
                                          Xiaomi
                                      Modell
                                          RTCGQ11LM
                                      Spannungsversorgung
                                          Batterie 100%
                                      Interview erfolgreich
                                          Wahr
                                      EDIT:
                                      hab aktualisiert
                                      1.28.2-dev commit: 50cb421f
                                      keine Besserung
                                      arteck N 2 Replies Last reply Reply Quote 0
                                        @crunchip dann werden die wohl putt sein
                                        • N
                                          @crunchip
                                          den Fehler kenne ich in andere Form das gar nichts mehr geht.
                                          Ich gehe zwar davon aus, dass bei dir die Konfig stimmt, aber dennoch die Frage, du hast die richtigen Einstellungen in der Konfig von Z2M gemacht, die in der Adapater Doku steht, oder?
                                          Besonders den Punkt Output
                                          output: json
                                          https://github.com/o0shojo0o/ioBroker.zigbee2mqtt/blob/main/docs/DE/DE_get-started_move.md
                                            mit dem zigbee Adapter funktionierte ja alles, nach dem Umzug auf zigbee2mqtt kommt von zigbee2mqtt bei den 3 Sensoren in iobroker nichts mehr an, einmalig beim anlegen auch mit Werten und dann erfolgt keine Aktualisierung mehr in iobroker.
                                            Auf der z2m Seite wird mir das ja angezeigt, wenn ich den Sensor auslöse, warum sollte dann also der Sensor kaputt sein?
                                            zigbee zigbee 3.0 zigbee2mqtt
                                            52
                                            526
                                            93225
