      Wuschl @Armilar last edited by Wuschl
      @armilar
      export const config: Config = {
         panelRecvTopic: 'mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT',       // anpassen
         panelSendTopic: 'mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend',   // anpassen
         firstScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Hourly.h0.PrecipitationProbability', ScreensaverEntityIcon: 'weather-pouring', ScreensaverEntityText: 'Regen', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
         secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
         thirdScreensaverEntity: { ScreensaverEntity: "shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3", ScreensaverEntityIcon: "pool-thermometer", ScreensaverEntityText: "Pool", ScreensaverEntityUnitText: "°C", ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 40} },
         fourthScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity', ScreensaverEntityIcon: 'water-percent', ScreensaverEntityText: 'Luft', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
         alternativeScreensaverLayout: false,
         autoWeatherColorScreensaverLayout: true,
         mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.tasmota_0E3BFC.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
         mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.tasmota_0E3BFC.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
         timeoutScreensaver: 20,
         dimmode: 20,
         active: 100, //Standard-Brightness TFT
         screenSaverDoubleClick: true,
         locale: 'de-DE',                                // en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
         timeFormat: '%H:%M',                            // currently not used
         dateFormat: '%A, %d. %B %Y',                    // currently not used
         weatherEntity: 'alias.0.Wetter.Gerät_1',                // Dieser Alias muss erstellt werden, damit die 4 kleineren Icons (Wetter oder DP) angezeigt werden können --> oder autoCreateAlias auf true
         defaultOffColor: Off,
         defaultOnColor: On,
         defaultColor: Off,
         defaultBackgroundColor: Black,    //New Parameter
         temperatureUnit: '°C',
         pages: [
                 Garagen
                 WLAN
                 Service             //Auto-Alias Service Page
         subPages: [
                     NSPanel_Infos,              //Auto-Alias Service Page
                     NSPanel_Einstellungen,      //Auto-Alias Service Page
                     NSPanel_Firmware_Info       //Auto-Alias Service Page
         button1Page: null,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
         button2Page: null    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
      Armilar Meister-x 4 Replies Last reply Reply Quote 0
      • Armilar
        Armilar Most Active Forum Testing @Wuschl last edited by
        @wuschl sagte in SONOFF NSPanel mit Lovelace UI:
        Setzte mal die da ``` in die Spalte darunter und ganz nach vorne. Dann wird es besser lesbar
        • Peoples
          Peoples @Armilar last edited by
          @armilar
          Wenn du mir sagst wie ich den Common Name Abfrage Versuche ich's Mal.
          Node ist die 16.18.1
          Armilar 2 Replies Last reply Reply Quote 0
          • Meister-x
            Meister-x @Wuschl last edited by
            @wuschl
            wo müsste ich meie Meldung Bwegungsmelder dazu einfügen?
            • Armilar
              Da ist doch schon etwas...
              Dein Tele läuft auf:
              dein Stat läuft auf:
              und ist irgendwie ein völlig anderes Gerät
              Versuche es mal mit:
              mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
              mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
              • Armilar
                Armilar Most Active Forum Testing @Meister-x last edited by
                @meister-x
                ich muss es erstmal einbauen. Wird in die nächste Version kommen.
                Meister-x 2 Replies Last reply Reply Quote 0
                • Meister-x
                  Meister-x @Armilar last edited by
                  @armilar
                  super -vielen Dank !!!!!!
                  • Armilar
                    Armilar Most Active Forum Testing @Peoples last edited by Armilar
                    @peoples
                    Warte - ich klicke mal schnell ein paar Zeilen zusammen...
                    16.18.1 passt. Schon vorbildlich 😊
                      @armilar super danke. Jetzt bleibt nur noch das übrig
                      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
                      • Armilar
                        Armilar Most Active Forum Testing last edited by
                        @armilar
                        Würde mir ein klein wenig von deiner Seite helfen, wenn du sehen würdest, was im Screensaver aktuell nicht läuft 😉
                          @armilar das hier fehlt, das finde ich nirgends.
                           //Subpage 2 von Subpages_2
                                  let NSPanel_Einstellungen: PageEntities =
                                      'type': 'cardEntities',
                                      'heading': 'Screensaver',
                                      'useColor': true,
                                      'subPage': true,
                                      'parent': Service,
                                      'items': [
                                          <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                                          <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                                          <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                                          <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
                          • Armilar
                            Armilar Most Active Forum Testing @Armilar last edited by Armilar
                            @armilar
                            on({id: [].concat(['0_userdata.0.NSPanel.1.Relay.1']).concat(['0_userdata.0.NSPanel.1.Relay.2']), change: "ne"}, async function (obj) {
                                console.log(obj.id);
                                console.log((obj.common ? obj.common.name : ""));
                                console.log((obj.common ? obj.common.desc : ""));
                                console.log(obj.channelId);
                                console.log(obj.channelName);
                                console.log(obj.deviceName);
                                console.log((obj.state ? obj.state.val : ""));
                                console.log((obj.state ? obj.state.ts : ""));
                                console.log((obj.state ? obj.state.q : ""));
                                console.log((obj.state ? obj.state.from : ""));
                            Pass mal die beiden Datenpunkte im Trigger an deine an. Dann Trigger mal beide Datenpunkte (true/false) und sende das Log zurück.
                            --> Als neues Test-Script anlegen
                            Ich denke wir werden mit einem Spit über die obj.id gehen. Die ist eindeutig
                            Peoples 1 Reply Last reply Reply Quote 0
                            • Armilar
                              @peoples
                              Habe es auf die obj.id umgeschrieben. Tausche mal die Zeilen im TS-Script aus...
                              //switch Relays 1 + 2 with DP's
                              async function Init_Relays() {
                                  if (existsState(NSPanel_Path + 'Relay.1') == false ||
                                      existsState(NSPanel_Path + 'Relay.2') == false) {
                                      await createStateAsync(NSPanel_Path + 'Relay.1', true, { type: 'boolean' });
                                      await createStateAsync(NSPanel_Path + 'Relay.2', true, { type: 'boolean' });
                              Init_Relays();
                              on({id: [].concat(String(NSPanel_Path) + 'Relay.1').concat(String(NSPanel_Path) + 'Relay.2'), change: "ne"}, async function (obj) {
                                  try {
                                      let Button = obj.id.split('.');
                                      console.log(((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))));
                                      require("request")((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))).on("error", function (err) {console.error(err.message);});
                                  } catch (err) {
                                      console.warn(err.message);
                              on({id: [].concat(config.mrIcon1ScreensaverEntity.ScreensaverEntity).concat(config.mrIcon2ScreensaverEntity.ScreensaverEntity), change: "ne"}, async function (obj) {
                                  if (obj.id.substring(0,4) == 'mqtt') {
                                      if (getState(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6)).val != obj.state.val) {
                                          await setStateAsync(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6), obj.state.val == 'ON' ? true : false);
                              • Armilar
                                @wuschl
                                Oh ich dachte mehr wenn du direkt auf den Screensaver vom NSPanel siehst. Ist da alles okay, oder fehlt etwas?
                                • Armilar
                                  Sehe soeben das pages-Array. Da ist auch ein Fehler drin. Es fehlen die Kommas - hab sie mal eingebaut.
                                  pages: [
                                             Garagen,
                                             WLAN,
                                    @armilar da ist alles da.
                                    Nur die Screensaver Einstellungen fehlen.
                                    • Armilar
                                      @wuschl
                                      Den Post darüber mal geändert?
                                        @armilar ja, Kommas eingebaut, aber ändert nichts.
                                        • Armilar
                                          Armilar Most Active Forum Testing @Wuschl last edited by Armilar
                                          @wuschl
                                          Poste nochmal die Config, bitte
                                          und die aktuellen Logs.
                                            @armilar
                                                dimmode: 20,
                                                defaultOnColor: On,
                                                defaultColor: Off,
                                                pages: [
                                                        Garagen,
                                                        WLAN,
                                                subPages: [
                                            16.11.2022, 22:14:57.478	[info ]: javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                                            16.11.2022, 22:15:01.129	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                                            16.11.2022, 22:15:01.900	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                                            16.11.2022, 22:15:01.983	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                                            16.11.2022, 22:15:02.043	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                            16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                                            16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                                            16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                                            16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)```
                                            code_text
                                            lovelace ui nspanel sonoff
                                            270
                                            7630
                                            6254853
