      Wuschl @Armilar last edited by
      @armilar super danke. Jetzt bleibt nur noch das übrig
      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
      16.11.2022, 21:22:50.314	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
      • Armilar
        Armilar Most Active Forum Testing last edited by
        @armilar
        Würde mir ein klein wenig von deiner Seite helfen, wenn du sehen würdest, was im Screensaver aktuell nicht läuft 😉
          @armilar das hier fehlt, das finde ich nirgends.
           //Subpage 2 von Subpages_2
                  let NSPanel_Einstellungen: PageEntities =
                      'type': 'cardEntities',
                      'heading': 'Screensaver',
                      'useColor': true,
                      'subPage': true,
                      'parent': Service,
                      'items': [
                          <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                          <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                          <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                          <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
          • Armilar
            Armilar Most Active Forum Testing @Armilar last edited by Armilar
            @armilar
            on({id: [].concat(['0_userdata.0.NSPanel.1.Relay.1']).concat(['0_userdata.0.NSPanel.1.Relay.2']), change: "ne"}, async function (obj) {
                console.log(obj.id);
                console.log((obj.common ? obj.common.name : ""));
                console.log((obj.common ? obj.common.desc : ""));
                console.log(obj.channelId);
                console.log(obj.channelName);
                console.log(obj.deviceName);
                console.log((obj.state ? obj.state.val : ""));
                console.log((obj.state ? obj.state.ts : ""));
                console.log((obj.state ? obj.state.q : ""));
                console.log((obj.state ? obj.state.from : ""));
            Pass mal die beiden Datenpunkte im Trigger an deine an. Dann Trigger mal beide Datenpunkte (true/false) und sende das Log zurück.
            --> Als neues Test-Script anlegen
            Ich denke wir werden mit einem Spit über die obj.id gehen. Die ist eindeutig
            Peoples 1 Reply Last reply Reply Quote 0
            • Armilar
              Armilar Most Active Forum Testing @Peoples last edited by
              @peoples
              Habe es auf die obj.id umgeschrieben. Tausche mal die Zeilen im TS-Script aus...
              //switch Relays 1 + 2 with DP's
              async function Init_Relays() {
                  if (existsState(NSPanel_Path + 'Relay.1') == false ||
                      existsState(NSPanel_Path + 'Relay.2') == false) {
                      await createStateAsync(NSPanel_Path + 'Relay.1', true, { type: 'boolean' });
                      await createStateAsync(NSPanel_Path + 'Relay.2', true, { type: 'boolean' });
              Init_Relays();
              on({id: [].concat(String(NSPanel_Path) + 'Relay.1').concat(String(NSPanel_Path) + 'Relay.2'), change: "ne"}, async function (obj) {
                  try {
                      let Button = obj.id.split('.');
                      console.log(((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))));
                      require("request")((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))).on("error", function (err) {console.error(err.message);});
                  } catch (err) {
                      console.warn(err.message);
              on({id: [].concat(config.mrIcon1ScreensaverEntity.ScreensaverEntity).concat(config.mrIcon2ScreensaverEntity.ScreensaverEntity), change: "ne"}, async function (obj) {
                  if (obj.id.substring(0,4) == 'mqtt') {
                      if (getState(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6)).val != obj.state.val) {
                          await setStateAsync(NSPanel_Path + 'Relay.' + Button[Button.length - 1].substring(5,6), obj.state.val == 'ON' ? true : false);
              • Armilar
                Armilar Most Active Forum Testing @Wuschl last edited by
                @wuschl
                Oh ich dachte mehr wenn du direkt auf den Screensaver vom NSPanel siehst. Ist da alles okay, oder fehlt etwas?
                • Armilar
                  @wuschl sagte in SONOFF NSPanel mit Lovelace UI:
                  Sehe soeben das pages-Array. Da ist auch ein Fehler drin. Es fehlen die Kommas - hab sie mal eingebaut.
                  pages: [
                             Garagen,
                             WLAN,
                             Service             //Auto-Alias Service Page
                    @armilar da ist alles da.
                    Nur die Screensaver Einstellungen fehlen.
                    • Armilar
                      @wuschl
                      Den Post darüber mal geändert?
                        @armilar ja, Kommas eingebaut, aber ändert nichts.
                        • Armilar
                          Armilar Most Active Forum Testing @Wuschl last edited by Armilar
                          @wuschl
                          Poste nochmal die Config, bitte
                          und die aktuellen Logs.
                            @armilar
                            export const config: Config = {
                                panelRecvTopic: 'mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT',       // anpassen
                                panelSendTopic: 'mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend',   // anpassen
                                firstScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Hourly.h0.PrecipitationProbability', ScreensaverEntityIcon: 'weather-pouring', ScreensaverEntityText: 'Regen', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
                                secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
                                thirdScreensaverEntity: { ScreensaverEntity: "shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3", ScreensaverEntityIcon: "pool-thermometer", ScreensaverEntityText: "Pool", ScreensaverEntityUnitText: "°C", ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 40} },
                                fourthScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity', ScreensaverEntityIcon: 'water-percent', ScreensaverEntityText: 'Luft', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
                                alternativeScreensaverLayout: false,
                                autoWeatherColorScreensaverLayout: true,
                                mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
                                mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
                                timeoutScreensaver: 20,
                                dimmode: 20,
                                active: 100, //Standard-Brightness TFT
                                screenSaverDoubleClick: true,
                                locale: 'de-DE',                                // en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
                                timeFormat: '%H:%M',                            // currently not used
                                dateFormat: '%A, %d. %B %Y',                    // currently not used
                                weatherEntity: 'alias.0.Wetter.Gerät_1',                // Dieser Alias muss erstellt werden, damit die 4 kleineren Icons (Wetter oder DP) angezeigt werden können --> oder autoCreateAlias auf true
                                defaultOffColor: Off,
                                defaultOnColor: On,
                                defaultColor: Off,
                                defaultBackgroundColor: Black,    //New Parameter
                                temperatureUnit: '°C',
                                pages: [
                                        Garagen,
                                        WLAN,
                                subPages: [
                                            NSPanel_Infos,              //Auto-Alias Service Page
                                            NSPanel_Einstellungen,      //Auto-Alias Service Page
                                            NSPanel_Firmware_Info       //Auto-Alias Service Page
                                button1Page: null,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
                                button2Page: null    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
                            16.11.2022, 22:14:57.478	[info ]: javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                            16.11.2022, 22:15:01.129	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                            16.11.2022, 22:15:01.900	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                            16.11.2022, 22:15:01.983	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                            16.11.2022, 22:15:02.043	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                            16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                            16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                            16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                            16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)```
                            code_text
                            • Peoples
                              Peoples @Armilar last edited by Peoples
                              @armilar
                              bitteschön
                              2022-11-16 22:26:07.923 - info: javascript.0 (400696) script.js.test: 0_userdata.0.NSPanel.Fitness.Relay.1
                              2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: 0_userdata.0.NSPanel.Fitness.Relay.1
                              2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: undefined
                              2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: Relay
                              2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: Fitness
                              2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: true
                              2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: 1668633967917
                              2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: 0
                              Armilar 1 Reply Last reply Reply Quote 1
                              • Armilar
                                @peoples
                                Okay, hatte ich mir schon gedacht.
                                Nimm mal den Code aus diesen Post (vor ein paar Minuten):
                                https://forum.iobroker.net/post/893216
                                Ich habe die obj.id zerlegt und nehme den Teil nach dem Punkt. Dann sollte es passen.
                                • Armilar
                                  Armilar Most Active Forum Testing last edited by Armilar
                                  @wuschl
                                  hmm, dachte ich hätte eben geantwortet. Aber dann sah ich meine Frage nicht mehr 😵
                                  Ich kann keine Fehler finden in der Config. Sende mal den kompletten oberen Teil (Code in einem Spoiler)
                                  erst
                                  dann außen noch
                                  Muss ich mir komplett ansehen. Irgendwo ist noch ein Fehlerchen in dem Teil. Kann aber bis morgen dauern.
                                  • Peoples
                                    @armilar
                                    Ja mit der Änderung funktioniert es
                                    • Armilar
                                      @peoples 👍
                                        @armilar
                                        let vwIconColor = [];
                                        //-- Anfang der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ----------------
                                        var Garagen: PageEntities =
                                            "type": "cardEntities",
                                            "heading": "Garagen",
                                            "useColor": true,
                                            "subPage": false,
                                            "parent": undefined,
                                            "items": [
                                                <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Audi", offColor: MSGreen, onColor: MSRed, name: "Garage Audi", icon: "garage-variant", icon2: "garage-open-variant"},
                                                <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Polo", offColor: MSGreen, onColor: MSRed, name: "Garage Polo", icon: "garage-variant", icon2: "garage-open-variant"},
                                                <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Fahrräder", offColor: MSGreen, onColor: MSRed, name: "Garage Fahrräder", icon: "garage-variant", icon2: "garage-open-variant"},
                                        var WLAN: PageQR =
                                            "type": "cardQR",
                                            "heading": "Gäste WLAN",
                                            "useColor": true,
                                            "subPage": true,
                                            "items": [<PageItem>{ id: "alias.0.NsPanelGarage.WLAN" }]
                                        //-- ENDE der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ------------------
                                        //Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt)
                                        let Service: PageEntities =
                                            "heading": "NSPanel Service",
                                            "useColor": true,
                                            "subPage": false,
                                            "items": [
                                                <PageItem>{ id: AliasPath + 'autoUpdate', name: "Auto-Updates" ,icon: "update", offColor: MSRed, onColor: MSGreen},
                                                <PageItem>{ navigate: true, id: "NSPanel_Infos", icon: "information-outline", onColor: White, name: "NSPanel Infos"},
                                                <PageItem>{ navigate: true, id: "NSPanel_Firmware_Info", icon: "update", onColor: White, name: "Firmware Infos"},
                                                <PageItem>{ navigate: true, id: "NSPanel_Einstellungen", icon: "wrench-outline", onColor: White, name: "Screensaver"}
                                                //Subpage 1 von Subpages_2
                                                let NSPanel_Infos: PageEntities =
                                                    "heading": "NSPanel Infos",
                                                    "useColor": true,
                                                    "subPage": true,
                                                    "parent": Service,
                                                    "items": [
                                                        <PageItem>{ id: AliasPath + 'Tasmota.Hardware', name: 'Hardware', icon: 'memory', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                                        <PageItem>{ id: AliasPath + 'Sensor.ESP32.Temperature', name: "ESP Temperatur", icon: "thermometer", unit: "°C", offColor: MSYellow, onColor: MSYellow, useColor: true},
                                                        <PageItem>{ id: AliasPath + 'Tasmota.Uptime', name: "Uptime", icon: "timeline-clock-outline", offColor: MSYellow, onColor: MSYellow, useColor: true},
                                                        <PageItem>{ id: AliasPath + 'Tasmota.Wifi.RSSI', name: "Wifi-Signal", icon: "signal-distance-variant", unit: "dBm", offColor: MSYellow, onColor: MSYellow, useColor: true}
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'parent': Service,
                                                    'items': [
                                                //Subpage 3 von Subpages_2
                                                let NSPanel_Firmware_Info: PageEntities =
                                                    'heading': 'Firmware-Updates',
                                                    'useColor': true,
                                                    'subPage': true,
                                                    'parent': Service,
                                                    'items': [
                                                        <PageItem>{ id: AliasPath + 'Tasmota.Version', name: 'Tasmota Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                                        <PageItem>{ id: AliasPath + 'Display.TFTVersion', name: 'TFT-Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                                        <PageItem>{ id: AliasPath + 'Display.BerryDriver', name: 'Berry-Treiber', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                                        <PageItem>{ id: AliasPath + 'Display.Model', name: 'NSPanel Version', offColor: MSYellow, onColor: MSYellow, useColor: true}
                                            dimmode: 20,
                                            defaultOnColor: On,
                                            defaultColor: Off,
                                            pages: [
                                                    Garagen,
                                                    WLAN,
                                            subPages: [
                                        [s=]
                                        [/s]
                                        Armilar T 2 Replies Last reply Reply Quote 0
                                        • Armilar
                                          var WLAN: PageQR =
                                          "type": "cardQR",
                                          "useColor": true,
                                          "subPage": true,
                                          Du hast eine SubPage unter die Pages gehängt
                                          Setze mal subPage auf false.
                                          var WLAN: PageQR =
                                              "type": "cardQR",
                                              "useColor": true,
                                              "subPage": false,
                                            @armilar das wars auch nicht
                                            17.11.2022, 14:43:01.211	[info ]: javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                                            17.11.2022, 14:43:05.999	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                                            17.11.2022, 14:43:06.786	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                                            17.11.2022, 14:43:06.843	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                                            17.11.2022, 14:43:06.869	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                            17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                                            17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                                            17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                                            17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
                                            1.0k
                                            lovelace ui nspanel sonoff
                                            270
                                            7695
                                            6532996
