    3. Entwicklung
    4. [Neuer Adapter] Reolink Kamera
    • da_Woody
      da_Woody @da_Woody last edited by
      @da_woody hab nochmal den adapter instance0 gestartet mit debug
      host.ioBroker
      2022-10-28 14:41:06.173	info	instance system.adapter.reolink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.ioBroker
      2022-10-28 14:41:05.072	info	stopInstance system.adapter.reolink.0 send kill signal
      reolink.0
      2022-10-28 14:41:05.029	info	State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "string"
      reolink.0
      2022-10-28 14:41:04.737	debug	Error or not supported getMailNotification
      reolink.0
      2022-10-28 14:41:04.614	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      reolink.0
      2022-10-28 14:41:04.614	info	terminating
      reolink.0
      2022-10-28 14:41:04.614	debug	refreshStateTimeout: UNLOAD
      reolink.0
      2022-10-28 14:41:04.613	info	Got terminate signal TERMINATE_YOURSELF
      host.ioBroker
      2022-10-28 14:41:03.755	info	stopInstance system.adapter.reolink.0 (force=false, process=true)
      host.ioBroker
      2022-10-28 14:41:03.754	info	"system.adapter.reolink.0" disabled
      reolink.0
      2022-10-28 14:41:03.719	debug	mailValue 200: [{"cmd":"Unknown","code":1,"error":{"detail":"not support","rspCode":-9}}]
      reolink.0
      2022-10-28 14:41:03.647	error	Value not supported!
      reolink.0
      2022-10-28 14:41:03.647	info	Changed state: EmailNotification
      reolink.0
      2022-10-28 14:41:03.646	debug	state reolink.0.settings.EmailNotification changed: Error or not supported (ack = true)
      reolink.0
      2022-10-28 14:41:03.596	info	State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "string"
      reolink.0
      2022-10-28 14:41:03.560	debug	Error or not supported getMailNotification
      reolink.0
      2022-10-28 14:41:03.520	debug	mailValue 200: [{"cmd":"Unknown","code":1,"error":{"detail":"not support","rspCode":-9}}]
      reolink.0
      2022-10-28 14:41:03.428	error	Value not supported!
      • Wszene
        Wszene last edited by Wszene
        @Andy-Grundt
        Hallo Zusammen,
        Ich habe 2x die Reolink RLC-510A
        Ich bekomme auch die Datenpunkte
        Habe da aber mal eine Frage zur Bewegungserkennung
        Sollte sich der DP "reolink.0.sensor.motion" bei Erkennung auf "1" ändern?
        Wenn Ja dann funktioniert das nicht
        Ich habe mal zum Testen in der App die Push-Mitteilung angeschalten Diese springt an
        Danke im Voraus
        Marcel
          msauer last edited by
          Hallo Zusammen,
          ich würde gerne in Blockly mit einem Trigger des Objekts reolink.0.sensor.motion ein Bild per pushover verschicken. Nun ist in dem Beispiel zwar die Javascript Prozedur vorgeschlagen, wie aber setzte ich das in Blockly um. Hat das schon jemand gemacht und mag es mit uns teilen?
          Mark
            Mutze last edited by
            Guten Abend,
            vorweg, es ist toll was diese Community auf die Beine stellt. Das ist ein Grund warum ich heute meine Reolink Kameras bekommen habe.
            Dank dieses neuen Adapters habe ich auch bereits die erste Kamera in ioBroker einbinden können. Bei der Kamera handelt es sich um eine Reolink TrackMix PoE.
            Soweit ich das bisher beurteilen kann, funktioniert die Einbindung. Die Kamera einschl. der hier bereits diskutierten Parameter werden erkannt.
            Ein kleiner Hinweis.
            Nach dem Anlegen der ersten Instanz und das Einbinden der Kamera ist der Start des Adapters gescheitert. Der Adpater blieb auf der gelben Statusmeldung hängen und im Logfile stand etwas wie "type undefined".
            Dann erinnerte ich mich, dass ich Sonderzeichen für das Passwort der Kamera verwendet habe. Mit diesen Sonderzeichen hatte ich bereits bei einem anderen Adapter mal Probleme. Nach dem Ändern des Passwortes ohne die Sonderzeichen konnte die Verbindung problemlos aufgebaut werde.
            Ich weiß nicht ob die Entwickler mit dem Hinweis etwas anfangen können und ggf. in einem nächsten Release eine Änderung berücksichtigen.
            Ich werde in den kommenden Tagen gerne weiter testen und berichten.
            Folgende 2 weitere Kameratypen habe ich heute auch noch bekommen und werde diese auch testen.
            Reolink RCL-823A
            Reolink Duo 2 PoE
            Werden im Laufe der Woche auch eingebunden und ich berichte.
            Nochmals vielen Dank an die Entwickler und die Community.
            Gruss Mutze
              meerkat @Wolfi last edited by
              Hi @wolfi
              Ich habe auch eine E1 Outdoor gekauft und wollte nun auch den preset nutzen. Bei mir steht nur Null im datenpunkt und wenn ich bspw. 1 eintrage, dann passiert nichts.
              Presets sind natürlich in der Kamera angelegt und über die App bzw. Website kann ich diese auch ansteuern.
              Hast du nich spezielle Einstellungen gemacht?
                Wolfi @meerkat last edited by Wolfi
                @meerkat
                Stimmt geht bei mir via Adapter auch nicht mehr.
                Was ist eigentlich die aktuelle Version? Suche den Link zur Installation?
                geht zur not auch so via blockly
                https://forum.iobroker.net/post/853217
                  Hi @wolfi,
                  Teste ich nachher mal. Hast du den im Post genannten link auch noch? Würde mal schauen, was ich dann noch einbaue
                  Meerkat
                    @meerkat
                    Finde gerade den link nicht mehr suche mal nach " Reolink API CGI commands
                    OK habe jetzt die Version 0.1.1 installiert bekommen.
                    PLZPreset geht aber nicht!
                    Kann das sonst noch jemand bestätigen? (E1 Outdoor)
                      RoaBo @Wolfi last edited by
                      @wolfi Nabend. Ich habe eine TrackMix Wifi und auch da leider nicht. Auch klappt es nicht mit dem curl Befehl. In Blocky reagiert nichts und per ssh gibt er "please login first" aus.
                        meerkat @RoaBo last edited by
                        Hi @roabo @Wolfi
                        Habe gestern Abend auch noch lange probiert. Beim curl musste ich in der Adresse den Bereich cgi-bin weglassen und alles mit Token senden. Dafür gibt es ne eigenen aufruf. Teste heute abend noch weiter und gebe dann mal Rückmeldung
                          @meerkat
                          Hier mein blockly zum Importieren. (IP mit port und PW anpassen.)
                          Zeitgesteuert für Pos 4 und 5
                          Gruss
                          Reolink_PLZ.txt
                            @wolfi Super! Das funktioniert. Vielen Dank!
                              Wolfi last edited by Wolfi
                              Kann bitte jemand sagen ob das PLZPreset mit dem Aktuellen
                              Version des Adapters funktionieren sollte??
                              Jemand der eine E1 Outdoor hatte.
                              Ich meinte in einer früheren Version hat es mal funktioniert.
                              Gruss
                              oelison 1 Reply Last reply Reply Quote 0
                              • oelison
                                oelison @Wolfi last edited by
                                @wolfi Nein, geht nicht. Hatte auf meinem produktiv System noch eine alte (0.0.3), bei der hat das funktioniert. Dann update gemacht auf das aktuelle repository (0.1.1) und es geht nicht mehr.
                                  Wolfi @oelison last edited by
                                  @oelison
                                  Danke für die Klärung
                                  Gruss
                                    romestylez last edited by romestylez
                                    Danke für den Adapter habe diesen installiert. Nutze zwei 820A.
                                    Ist es möglich das Bild/Stream nur anzuzeigen wenn die Motion Detection etwas erkennt ? Falls ja wie ? Ich speichere bei Motion Detection das Video auf mein NAS. Wäre halt schön wenn der Livestream im ioBroker startet wenn Bewegung erkannt wird.
                                    • BananaJoe
                                      BananaJoe Most Active @romestylez last edited by
                                      @romestylez das ist jetzt nicht direkt das was du lesen willst, aber ich hatte schon vor einiger Zeit das Problem das ich einen Stream nur laufen lassen wollte wenn die View überhaupt sichtbar ist.
                                      Mit der gleichen Methode könnte man natürlich auch bei einer statischen View arbeiten:
                                      https://forum.iobroker.net/topic/36345/gelöst-vis-video-stream-nur-starten-wenn-view-sichtbar-ist?_=1668785812268
                                      Ich nutze inzwischen aber nur noch Standbilder die alle 60 Sekunden aktualisiert werden.
                                      Passiert etwas (z.B. Klingel) setze ich das hoch auf alle 1 bis 2 Sekunden, nach 60 Sekunden wieder auf den normalen Intervall
                                      Das nutze ich das Bild Widget und habe bei Refresh ein Datenpunkt-Binding eingegeben
                                        @bananajoe said in [Neuer Adapter] Reolink Kamera:
                                        Danke für den Hinweis es gibt da leider ein paar kleine Probleme. Die Reolink kann per http nur ein Bild liefern keinen Stream (zumindest meine RCL-820).
                                        Wenn man das Camera Widget nimmt um das Bild anzuzeigen dann wird nicht geupdated da etwas an die URL hinten angehangen wird und der Pfad dann nicht gefunden werden kann auf der Kamera das war irgendwas mit "refts" oder so am Ende die Option nix an die URL anzuhängen gibts leider bei diesem Camera Snapshot Widget nicht.
                                        Ich habe nun ein iFrame was sich alle 2 Sekunden updated gemacht mit dem Link zum Bild. Nun müsste ich damit halt prüfen ob es vorne Bewegung gibt. Leider wird aber das Objekt "reolink.0.sensor.motion" nicht gefüllt wenn Bewegung erkannt wird und die App mir diese meldet. Wahrscheinlich weil ich auf ein NAS aufzeichne per FTP und nicht auf eine SD-Karte.
                                        Ich werde mir deine Methode aber auf jeden Fall merken kann man sicher für andere Sachen übernehmen 😉
                                          ahennies last edited by
                                          Moin, ich habe eine RCL-820A, die leider nicht mit dem Adapter sprechen möchte. Was funktioniert ist das Einbinden der Kamera über motioneye rmtp, aber mein RPi 3 kann das nicht wirklich leisten. Da bekomme ich nur ein graues Fenster. Alles andere was hier bereits beschrieben wurde tut leider nicht.
                                          Also wenn jemand eine RCL-820A hat und vielleicht etwas rausgefunden hat, dann würde ich mich über den einen oder anderen Tipp freuen.
                                          Mein Ziel ist es, die Kamera, wie auch immer, in den iobroker zu bringen.
                                          Da ich aber noch zwei Kameras benötige, wäre es natürlich auch interessant zu erfahren, welche Kameras mit der neuesten Version funktionieren.
                                          Achim
                                          R H 2 Replies Last reply Reply Quote 0
                                            romestylez @ahennies last edited by
                                            @ahennies said in [Neuer Adapter] Reolink Kamera:
                                            Achim
                                            Ich habe auch eine RCL-820A. Ich habe den Adapter installiert und dann die Kamera hinzugefügt. Aber mir bringt der Adapter leider nichts weil die Motion Detection nicht funktioniert. Ich kann das Bild also nicht abgreifen.
                                            Ich habe jetzt folgendes Widget "gebaut":
                                            [{"tpl":"tplMfdCamSnapshot","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"interval":"2000","dialog_width":"896","dialog_height":"512","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"url":"http://IPDERKAMERA/cgi-bin/api.cgi?cmd=Snap&channel=0&user=USERNAME&password=USER&width=640&height=480","modal":false,"autoclose":"20000","overflowX":"initial","overflowY":"initial","noHeader":true,"title":"Kamera vorne","iconColor":"#fff","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":"1198px","top":"17px","width":"","z-index":"1"},"widgetSet":"jqui-mfd"}]
                                            Damit bekomme ich das Bild der Kamera welches sich alle 2 Sekunden aktualisiert. Nach 20 Sekunden schließt sich das Pop-Up mit dem Kamera Bild automatisch.
                                            Wie gesagt es ist sehr schade das der Adapter nicht funktioniert. Ich hätte ihn gerne genutzt.
                                            P A 2 Replies Last reply Reply Quote 0
                                            kamera neuer adapter reolink testen
                                            157
                                            1074
                                            450375
