    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      Thomas Braun Most Active @nhet last edited by Thomas Braun
      @nhet
      Da stimmt was in den release-Dateien nicht.
      Auf meinem System:
      2022-11-14 18:58:44.556  - info: host.chet iobroker Installing iobroker.bluelink@2.2.6... (System call)
      2022-11-14 18:59:00.352  - info: host.chet iobroker npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      2022-11-14 18:59:04.288  - info: host.chet iobroker added 44 packages, removed 1018 packages, and changed 1 package in 19s
      2022-11-14 18:59:04.294  - info: host.chet iobroker
      2022-11-14 18:59:04.295  - info: host.chet iobroker 88 packages are looking for funding  run `npm fund` for details
      2022-11-14 18:59:04.370  - info: host.chet iobroker host.chet install adapter bluelink
      Aber sofort wird der Adapter zum Update vorgeschlagen:
      echad@chet:~ $ iobroker update -u
      Used repository: beta
      Adapter    "bluelink"     : 2.2.6    , installed 2.2.5  [Updatable]
      Und oh wunder...
      https://github.com/Newan/ioBroker.bluelink/issues/59
      eric2905 created this issue in Newan/ioBroker.bluelink
      closed Update 2.2.5 ==> 2.2.6 endless #59
        @thomas-braun hab ich doch schon oben geschrieben
          A Former User @Guest last edited by A Former User
          @ilovegym @arteck
          ich habe es auch mal mit meinem IONIQ 5 getestet in der Version 2.2.6 und ich habe das gleiche Problem wie @ilovegym . (Weil ich mir die Funktionserweiterung beim Fernklimatisieren auch sehr Wünsche)
          2022-11-16 10:54:33.825 - info: bluelink.0 (2012726) Login to api
          2022-11-16 10:54:38.340 - info: bluelink.0 (2012726) 1 Vehicles found
          2022-11-16 10:54:52.136 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
          2022-11-16 10:54:52.183 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
          2022-11-16 10:54:52.189 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
          2022-11-16 10:54:52.196 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
          2022-11-16 10:54:52.261 - info: bluelink.0 (2012726) State value to set for "bluelink.0.KMHKRXXXXXXXXXXXX.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
          2022-11-16 10:54:57.137 - info: bluelink.0 (2012726) Starting clima for vehicle
          2022-11-16 10:54:57.292 - error: bluelink.0 (2012726) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2022-11-16 10:54:57.293 - error: bluelink.0 (2012726) unhandled promise rejection: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
          2022-11-16 10:54:57.295 - error: bluelink.0 (2012726) ManagedBluelinkyError: @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
          at U (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:11700)
          at G. (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:16700)
          at Generator.throw ()
          at a (/opt/iobroker/node_modules/bluelinky/dist/index.js:17:136)
          at runMicrotasks ()
          at processTicksAndRejections (internal/process/task_queues.js:95:5)
          2022-11-16 10:54:57.297 - error: bluelink.0 (2012726) @EuropeVehicle.start: [503] Service Unavailable on [POST] https://prd.eu-ccapi.hyundai.com:8080/api/v2/spa/vehicles/27972170-3287-4d84-aa30-4847f048e162/control/temperature - {"retCode":"F","resCode":"5031","resMsg":"Unavailable remote control - Service Temporary Unavailable","msgId":"65f58c5a-653c-4358-aa68-567a43b4662d"}
          2022-11-16 10:54:57.310 - info: bluelink.0 (2012726) Adapter bluelink cleaned up everything...
          2022-11-16 10:54:57.312 - info: bluelink.0 (2012726) terminating
          2022-11-16 10:54:57.315 - warn: bluelink.0 (2012726) Terminated (UNCAUGHT_EXCEPTION): Without reason
          In Version 2.2.3., die ich davor (und auch nach dem Test wieder) genutzt habe, habe ich das Problem nicht.
            arteck Developer Most Active @Guest last edited by
            @williwilliwilli sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
            im ernst...
              A Former User @arteck last edited by
              @arteck ja, denn der Fehler kommt immer! hab ich auch. In der App funktionierts ja.
              Mit der vorigen Version des Adapters gehts. ( halt ohne die Temp zu setzen etc.)
                arteck Developer Most Active @Guest last edited by arteck
                @ilovegym installier mal meine version
                https://github.com/arteck/ioBroker.bluelink
                und mach nochmal.. dann log schauen nach -->
                ? ? 2 Replies Last reply Reply Quote 0
                  @arteck
                  Hello, gemacht, Adapter zeigt Version 2.2.3 an.
                  Steuern der Clima geht nicht, wenn ich auf start clima druecke, kommt ein undefined. Ein Lock/Unlock funktioniert, der vorige Fehler von Version 2.2.6 ist weg.
                  ilovegym@VMC123-iobroker /opt/iobroker $ iob logs --watch | grep bluelink.0
                  2022-11-17 08:32:13.914  - info: host.VMC123-iobroker iobroker Update "system.adapter.bluelink.0"
                  2022-11-17 08:32:13.922  - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 (force=false, process=true)
                  2022-11-17 08:32:13.923  - info: bluelink.0 (635883) Got terminate signal TERMINATE_YOURSELF
                  2022-11-17 08:32:13.924  - info: bluelink.0 (635883) Adapter bluelink cleaned up everything...
                  2022-11-17 08:32:13.924  - info: bluelink.0 (635883) terminating
                  2022-11-17 08:32:13.924  - info: bluelink.0 (635883) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-11-17 08:32:13.925  - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 send kill signal
                  2022-11-17 08:32:14.723  - info: host.VMC123-iobroker instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-11-17 08:32:17.191  - info: host.VMC123-iobroker instance system.adapter.bluelink.0 started with pid 687175
                  2022-11-17 08:32:18.289  - info: bluelink.0 (687175) starting. Version 2.2.3 (non-npm: arteck/ioBroker.bluelink#f3613b00ef64bb48fe5c5568a146f79bfbc18c81) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.18.1, js-controller: 4.0.23
                  2022-11-17 08:32:18.302  - info: bluelink.0 (687175) Login to api
                  2022-11-17 08:32:23.123  - info: bluelink.0 (687175) 1 Vehicles found
                  2022-11-17 08:34:00.504  - info: bluelink.0 (687175) Starting clima for vehicle
                  2022-11-17 08:34:00.506  - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl
                  2022-11-17 08:34:00.506  - info: bluelink.0 (687175) --> airTemp KMHKR81AFNU0.control.set.airTemp
                  2022-11-17 08:34:00.507  - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost
                  2022-11-17 08:34:00.507  - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating
                  2022-11-17 08:34:00.639  - error: bluelink.0 (687175) undefined
                  2022-11-17 08:35:34.601  - info: bluelink.0 (687175) Starting unlock for vehicle
                  2022-11-17 08:35:34.763  - info: bluelink.0 (687175) Unlock successful
                  2022-11-17 08:35:54.255  - info: bluelink.0 (687175) Starting lock for vehicle
                  2022-11-17 08:35:54.395  - info: bluelink.0 (687175) Lock successful
                  2022-11-17 08:36:02.288  - info: bluelink.0 (687175) Starting clima for vehicle
                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl
                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> airTemp KMHKR81AFN.control.set.airTemp
                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost
                  2022-11-17 08:36:02.290  - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating
                  2022-11-17 08:36:02.414  - error: bluelink.0 (687175) undefined
                  Ein komplettes Debuglog kann ich dir gerne per Mail senden...??
                    @arteck
                    same here
                    2022-11-17 08:43:04.526 - info: bluelink.0 (2076917) Starting clima for vehicle
                    2022-11-17 08:43:04.534 - info: bluelink.0 (2076917) --> airCtrl KMHKR81XXXXXXXXX.control.set.airCtrl
                    2022-11-17 08:43:04.535 - info: bluelink.0 (2076917) --> airTemp KMHKR81XXXXXXXXX.control.set.airTemp
                    2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> defrost KMHKR81XXXXXXXXX.control.set.defrost
                    2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> heating KMHKR81XXXXXXXXX.control.set.heating
                    2022-11-17 08:43:04.982 - error: bluelink.0 (2076917) undefined
                      man sollte nix neben bei machen
                      installiert nochmal..ich will mal schauen ob die zahlen richtig übernommen werden
                        @arteck
                        da kommt jetzt:
                        2022-11-17 10:10:59.095  - debug: bluelink.0 (823776) New Event for state: {"val":true,"ack":false,"ts":1668676259094,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1667470001835}
                        2022-11-17 10:10:59.095  - debug: bluelink.0 (823776) ID: "bluelink.0.KMHKR.control.start"
                        2022-11-17 10:10:59.095  - info: bluelink.0 (823776) Starting clima for vehicle
                        2022-11-17 10:10:59.097  - info: bluelink.0 (823776) --> [object Object]
                        2022-11-17 10:10:59.098  - info: bluelink.0 (823776) --> [object Object]
                        2022-11-17 10:10:59.238  - error: bluelink.0 (823776) {"source":{"name":"HTTPError","hostname":"prd.eu-ccapi.hyundai.com","method":
                        und zum schluss im text wieder Service temporary unavalable... ist anscheinend die allgemeine Fehlermeldung, wenn sonst nix passt... ??
                          @ilovegym installier nochmal..bitää
                            @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                            BINGO !! das wars 🙂 super!
                            2022-11-17 10:34:33.463  - debug: bluelink.0 (867157) New Event for state: {"val":true,"ack":false,"ts":1668677673462,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1667470001835}
                            2022-11-17 10:34:33.463  - debug: bluelink.0 (867157) ID: "bluelink.0.KMHKR81AFNU.control.start"
                            2022-11-17 10:34:33.463  - info: bluelink.0 (867157) Starting clima for vehicle
                            2022-11-17 10:34:33.465  - info: bluelink.0 (867157) --> airCtrl true
                            2022-11-17 10:34:33.465  - info: bluelink.0 (867157) --> airTemp 25
                            2022-11-17 10:34:33.465  - info: bluelink.0 (867157) --> defrost 25
                            2022-11-17 10:34:33.466  - info: bluelink.0 (867157) --> heating true
                            Keine Fehler, Klima ist aktiv im Auto und alles was ich eingestellt habe! Super!! Keinen kalten Arsch mehr hehe.. 😄
                              @ilovegym ok dann mach ich für den @Newan ein pr.. Danke fürs testen
                                @arteck
                                ich kann die Funktion jetzt auch bestätigen, danke
                                aktuell lässt sich dadurch die Temepraur + Aircon + Defrost Windscreen aktivieren.
                                Besteht ggf. noch de chance auch die Werte für Steering wheel warme + Rear Window + die Mirror zu editieren/aktivieren?
                                ? arteck 2 Replies Last reply Reply Quote 0
                                  @williwilliwilli
                                  Stimmt, die gehen nicht an, wobei das auch an der aktuellen Temp liegen kann? Hyundai programmiert da ja teilweise seltsame Sachen..
                                  Ich schau morgen frueh nochmal, wenns richtig kalt ist..
                                    weiss ich nicht.. müsste ich mir anschauen was da ider der API möglich ist ..oder weiss du @Newan das vielleicht ??
                                      @ilovegym
                                      Nach meiner bisherigen Erfahrung ist die Aktivierung davon abhängig, welche der drei Boxen ich in der App checke:
                                      wenn die drei aktiv sind, dann starten alle fünf Optionen:
                                      Wie das bei der API aussieht, das weiß ich leider nicht.
                                      Eine Abhängigkeit von Wetter/Temperatur etc. konnte ich bisher nicht feststellen.
                                      W F 2 Replies Last reply Reply Quote 0
                                        Wolpertinger @Guest last edited by
                                        Wie lange braucht das denn so bis ein fertiger Update auf Github bei ioBroker als Aktualisierung auftaucht?
                                        Ich würde ungern mit der Installation aus anderen Quellen beginnen.
                                          A Former User last edited by
                                          @wolpertinger solange bis @Newan es implementiert hat, getestet und hochgeladen.
                                          In der Vorweihnachtszeit neben den Hauptberuflichen Dingen steht das an…
                                          Warten, und geduldig sein, ist dann die Devise.
                                            @ilovegym Ja, schon klar. Aber ist es nicht bereits implementiert gemäß Github Repo?
                                            81.1k
                                            2269
                                            848751
