    4. Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert
    • Codierknecht
      Codierknecht Developer Most Active @Guest last edited by
      @marcel-drzal
      Du hast @Thomas-Braun falsch verstanden.
      Deinen "normalen" Text braucht Du nicht als Code posten.
      Nimm das was @Thomas-Braun zeigt und führe es in der Konsole aus.
      Das Ergebnis kopierst Du und postest es hier in Code-Tags, damit man das auch sinnvoll lesen kann.
        @codierknecht
        marcel@iobroker:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        x86_64
        Kein Docker
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.1
        v16.17.1
        8.15.0
        4.0.23
        marcel
        marcel sudo iobroker
        tty
        /opt/iobroker
        Err:1 http://deb.debian.org/debian bullseye InRelease
          Temporary failure resolving 'deb.debian.org'
        Err:2 http://security.debian.org/debian-security bullseye-security InRelease
          Temporary failure resolving 'security.debian.org'
        Err:3 https://deb.nodesource.com/node_16.x bullseye InRelease
          Temporary failure resolving 'deb.nodesource.com'
        Err:4 https://dl.yarnpkg.com/debian stable InRelease
          Temporary failure resolving 'dl.yarnpkg.com'
        Err:5 https://repos.influxdata.com/debian buster InRelease
          Temporary failure resolving 'repos.influxdata.com'
        Err:6 http://deb.debian.org/debian bullseye-updates InRelease
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
        W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
        W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  Temporary failure resolving 'repos.influxdata.com'
        W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Temporary failure resolving 'deb.nodesource.com'
        W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  Temporary failure resolving 'dl.yarnpkg.com'
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        nodejs:
          Installed: 16.17.1-deb-1nodesource1
          Candidate: 16.17.1-deb-1nodesource1
          Version table:
         *** 16.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u1 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.5~dfsg-2~11u1 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
          Thomas Braun Most Active @Guest last edited by Thomas Braun
          @marcel-drzal
          Du hast kein Problem mit dem apexa2-Adapter, da ist grundsätzlich der Wurm in deinem Netzwerk-Setup.
          Dein influx-Repo läuft auf Buster, der Rest auf Bullseye
          Pass das an.
            A Former User @Thomas Braun last edited by
            @thomas-braun was kann ich machen?
              @marcel-drzal
              Den Netzwerk richtig einstellen.
              Bin aber kein Netzwerk -Guru.
              Codierknecht ? 2 Replies Last reply Reply Quote 0
              • Codierknecht
                Codierknecht Developer Most Active @Thomas Braun last edited by
                @thomas-braun sagte in Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                Ich auch nicht 😞
                Aber sowas wie
                failure resolving 'xxx'
                Klingt nach Problemen mit der Namensauflösung und DNS.
                  @thomas-braun ich habe den DNS Server neu installiert und ne neue DNS eingestellt
                  Soll ich mal Fix
                    A Former User @Codierknecht last edited by
                    @codierknecht ja habe den DNS Server eine IP gegeben im Router
                      @marcel-drzal
                      Ich weiß nicht was du da genau wie und wo eingestellt hast.
                      War aber offenbar falsch und die Namensauflösung funktioniert nicht mehr.
                        was kann ich da machen? Habe schon Fix versucht. geht auch nicht
                        marcel@iobroker:/opt/iobroker$ iob upgrade self
                        Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
                        Host    "iobroker"       is up to date.
                        marcel@iobroker:/opt/iobroker$ iob start
                        marcel@iobroker:/opt/iobroker$ sudo apt update
                        [sudo] password for marcel:
                        Err:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Err:2 https://repos.influxdata.com/debian buster InRelease
                        Err:5 http://deb.debian.org/debian bullseye InRelease
                        marcel@iobroker:/opt/iobroker$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        x86_64
                        Kein Docker
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.17.1
                        v16.17.1
                        8.15.0
                        4.0.23
                        marcel
                        tty
                        /opt/iobroker
                        Err:4 http://deb.debian.org/debian bullseye InRelease
                        Err:5 https://dl.yarnpkg.com/debian stable InRelease
                        nodejs:
                          Version table:
                          Thomas Braun Most Active last edited by
                          @marcel-drzal
                          Mit dem iobroker hat das nichts zu tun, das ist ein Knoten im Netzwerk-Setup.
                          • Codierknecht
                            @marcel-drzal sagte in Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                            Ich kann da nicht ganz folgen.
                            Du hast dem DNS Deiner Proxmox gesagt, dass der Router die Namen auflöst?
                            Kann ja nicht - Dein Router löst doch keine öffentlichen Domainnamen in IP's auf.
                            Ich kenne Proxmox nicht.
                            Hat das 'nen eigenen DNS? Kannst Du dem sagen, dass der Primary "1.1.1.1" und der Secondary "8.8.8.8" sein soll?
                            Das Netzwerkproblem kann der ioBroker auch nicht lösen 😉
                              Danke noch mal
                              DNS Server in Proxmox nicht umgestellt.
                              es kann so einfach sein
                              noch eine Frage, die Version v16.17.1 ist die richtige? da ich auf dem Rasperry die v16.17.0 habe?
                              Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                              • Codierknecht
                                Codierknecht Developer Most Active @Guest last edited by Codierknecht
                                Meine sind jedenfalls neuer:
                                Update schadet nicht - gibt sonst wieder Mecker vom Chef 😉
                                  @marcel-drzal
                                  Spiel halt Updates regelmäßig per üblichem Vorgehen ein.
                                  sudo apt update
                                  sudo apt full-upgrade
                                  Schwupps, schon ist sie Kiste auf aktuellem Stand.
                                    A Former User @Thomas Braun last edited by A Former User
                                    @thomas-braun sagte in Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                                    sudo apt update
                                    pi@pi-Slave1:/ $ sudo apt-get update
                                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    Err:2 http://deb.debian.org/debian bullseye InRelease
                                      Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                                    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [196 kB]
                                    Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [197 kB]
                                    Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [130 kB]
                                    Err:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                                    Fetched 571 kB in 3s (182 kB/s)
                                    Reading package lists... Error!
                                    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bullseye InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                                    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                                    W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                                    W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                                    E: Splitting of clearsigned file /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease failed as it doesn't contain all expected parts
                                    E: The package lists or status file could not be parsed or opened.
                                    pi@pi-Slave1:/ $ sudo apt update
                                    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    pi@pi-Slave1:/ $
                                    Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Hit:3 http://deb.debian.org/debian bullseye InRelease
                                    Err:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Err:3 http://deb.debian.org/debian bullseye InRelease
                                    Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                                    pi@pi-Slave1:~ $
                                    pi@pi-Slave1:/etc/network $ sudo systemctl status dhcpcd
                                    ● dhcpcd.service - DHCP Client Daemon
                                         Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset>
                                         Active: active (running) since Wed 2022-11-16 17:39:53 CET; 18h ago
                                           Docs: man:dhcpcd(8)
                                        Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCES>
                                       Main PID: 469 (dhcpcd)
                                          Tasks: 2 (limit: 779)
                                            CPU: 14.446s
                                         CGroup: /system.slice/dhcpcd.service
                                                 ├─469 /usr/sbin/dhcpcd -b -q
                                                 └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf >
                                    Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                    lines 1-22/22 (END)
                                         Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
                                           Docs: man:dhcpcd(8)
                                        Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCESS)
                                            CPU: 14.446s
                                                 └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
                                    Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                    auf meinen Raspi, Hier stell ich doch keinen DHCP ein oder? wo schau ich das nach?
                                      @marcel-drzal
                                      Nee, da sind deine Repos falsch. Kann das aber im Moment nicht gut nachvollziehen, da am Handy unterwegs.
                                        A Former User @Guest last edited by
                                        sudo rm /var/lib/apt/lists/* dann ging es
                                          @marcel-drzal
                                          Dann lass jetzt mal ein
                                          sudo apt update
                                          sehen. Und bitte auch
                                          df -h
                                            sudo apt update
                                            bei Rasperry Pi-Slave
                                            pi@pi-Slave1:~ $ sudo apt update
                                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                            Hit:4 http://deb.debian.org/debian bullseye InRelease
                                            Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                                            pi@pi-Slave1:~ $ df -h
                                            Filesystem      Size  Used Avail Use% Mounted on
                                            /dev/root        29G  4.0G   24G  15% /
                                            devtmpfs        325M     0  325M   0% /dev
                                            tmpfs           455M     0  455M   0% /dev/shm
                                            tmpfs           182M  1.1M  181M   1% /run
                                            tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                                            /dev/mmcblk0p1  255M   31M  225M  12% /boot
                                            tmpfs            91M   20K   91M   1% /run/user/1000
                                            bei Rasperry pi-Test
                                            pi@pi-Test:~ $ sudo apt update
                                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                            OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                            Alle Pakete sind aktuell.
                                            pi@pi-Test:~ $ df -h
                                            Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                                            /dev/root        30G    4,5G   24G   17% /
                                            devtmpfs        430M       0  430M    0% /dev
                                            tmpfs           462M       0  462M    0% /dev/shm
                                            tmpfs           462M     12M  450M    3% /run
                                            tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                                            tmpfs           462M       0  462M    0% /sys/fs/cgroup
                                            /dev/mmcblk0p1  253M     49M  204M   20% /boot
                                            tmpfs            93M       0   93M    0% /run/user/1000
                                            pi@pi-Test:~ $
                                            1392
