    4. Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert
      @codierknecht
      marcel@iobroker:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      x86_64
      Kein Docker
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      8.15.0
      4.0.23
      marcel
      marcel sudo iobroker
      tty
      /opt/iobroker
      Err:1 http://deb.debian.org/debian bullseye InRelease
        Temporary failure resolving 'deb.debian.org'
      Err:2 http://security.debian.org/debian-security bullseye-security InRelease
        Temporary failure resolving 'security.debian.org'
      Err:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        Temporary failure resolving 'deb.nodesource.com'
      Err:4 https://dl.yarnpkg.com/debian stable InRelease
        Temporary failure resolving 'dl.yarnpkg.com'
      Err:5 https://repos.influxdata.com/debian buster InRelease
        Temporary failure resolving 'repos.influxdata.com'
      Err:6 http://deb.debian.org/debian bullseye-updates InRelease
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
      W: Failed to fetch http://security.debian.org/debian-security/dists/bullseye-security/InRelease  Temporary failure resolving 'security.debian.org'
      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  Temporary failure resolving 'repos.influxdata.com'
      W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Temporary failure resolving 'deb.nodesource.com'
      W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  Temporary failure resolving 'dl.yarnpkg.com'
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      nodejs:
        Installed: 16.17.1-deb-1nodesource1
        Candidate: 16.17.1-deb-1nodesource1
        Version table:
       *** 16.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
        Thomas Braun Most Active @Guest last edited by Thomas Braun
        @marcel-drzal
        Du hast kein Problem mit dem apexa2-Adapter, da ist grundsätzlich der Wurm in deinem Netzwerk-Setup.
        Dein influx-Repo läuft auf Buster, der Rest auf Bullseye
        Pass das an.
          A Former User @Thomas Braun last edited by
          @thomas-braun was kann ich machen?
            @marcel-drzal
            Den Netzwerk richtig einstellen.
            Bin aber kein Netzwerk -Guru.
            Codierknecht ? 2 Replies Last reply Reply Quote 0
            • Codierknecht
              Codierknecht Developer Most Active @Thomas Braun last edited by
              @thomas-braun sagte in Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
              Ich auch nicht 😞
              Aber sowas wie
              failure resolving 'xxx'
              Klingt nach Problemen mit der Namensauflösung und DNS.
                @thomas-braun ich habe den DNS Server neu installiert und ne neue DNS eingestellt
                Soll ich mal Fix
                  A Former User @Codierknecht last edited by
                  @codierknecht ja habe den DNS Server eine IP gegeben im Router
                    @marcel-drzal
                    Ich weiß nicht was du da genau wie und wo eingestellt hast.
                    War aber offenbar falsch und die Namensauflösung funktioniert nicht mehr.
                      was kann ich da machen? Habe schon Fix versucht. geht auch nicht
                      marcel@iobroker:/opt/iobroker$ iob upgrade self
                      Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
                      Host    "iobroker"       is up to date.
                      marcel@iobroker:/opt/iobroker$ iob start
                      marcel@iobroker:/opt/iobroker$ sudo apt update
                      [sudo] password for marcel:
                      Err:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Err:2 https://repos.influxdata.com/debian buster InRelease
                      Err:5 http://deb.debian.org/debian bullseye InRelease
                      marcel@iobroker:/opt/iobroker$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      x86_64
                      Kein Docker
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.1
                      v16.17.1
                      8.15.0
                      4.0.23
                      marcel
                      tty
                      /opt/iobroker
                      Err:4 http://deb.debian.org/debian bullseye InRelease
                      Err:5 https://dl.yarnpkg.com/debian stable InRelease
                      nodejs:
                        Version table:
                        Thomas Braun Most Active last edited by
                        @marcel-drzal
                        Mit dem iobroker hat das nichts zu tun, das ist ein Knoten im Netzwerk-Setup.
                        • Codierknecht
                          Codierknecht Developer Most Active @Guest last edited by
                          @marcel-drzal sagte in Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                          Ich kann da nicht ganz folgen.
                          Du hast dem DNS Deiner Proxmox gesagt, dass der Router die Namen auflöst?
                          Kann ja nicht - Dein Router löst doch keine öffentlichen Domainnamen in IP's auf.
                          Ich kenne Proxmox nicht.
                          Hat das 'nen eigenen DNS? Kannst Du dem sagen, dass der Primary "1.1.1.1" und der Secondary "8.8.8.8" sein soll?
                          Das Netzwerkproblem kann der ioBroker auch nicht lösen 😉
                            Danke noch mal
                            DNS Server in Proxmox nicht umgestellt.
                            es kann so einfach sein
                            noch eine Frage, die Version v16.17.1 ist die richtige? da ich auf dem Rasperry die v16.17.0 habe?
                            Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                            • Codierknecht
                              Codierknecht Developer Most Active @Guest last edited by Codierknecht
                              Meine sind jedenfalls neuer:
                              Update schadet nicht - gibt sonst wieder Mecker vom Chef 😉
                                @marcel-drzal
                                Spiel halt Updates regelmäßig per üblichem Vorgehen ein.
                                sudo apt update
                                sudo apt full-upgrade
                                Schwupps, schon ist sie Kiste auf aktuellem Stand.
                                  A Former User @Thomas Braun last edited by A Former User
                                  @thomas-braun sagte in Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                                  sudo apt update
                                  pi@pi-Slave1:/ $ sudo apt-get update
                                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                                  Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                  Err:2 http://deb.debian.org/debian bullseye InRelease
                                    Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                                  Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [196 kB]
                                  Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [197 kB]
                                  Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [130 kB]
                                  Err:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                                  Fetched 571 kB in 3s (182 kB/s)
                                  Reading package lists... Error!
                                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bullseye InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                                  W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                                  W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
                                  W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
                                  E: Splitting of clearsigned file /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease failed as it doesn't contain all expected parts
                                  E: The package lists or status file could not be parsed or opened.
                                  pi@pi-Slave1:/ $ sudo apt update
                                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                  pi@pi-Slave1:/ $
                                  Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Hit:3 http://deb.debian.org/debian bullseye InRelease
                                  Err:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  Err:3 http://deb.debian.org/debian bullseye InRelease
                                  Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                                  pi@pi-Slave1:~ $
                                  pi@pi-Slave1:/etc/network $ sudo systemctl status dhcpcd
                                  ● dhcpcd.service - DHCP Client Daemon
                                       Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset>
                                       Active: active (running) since Wed 2022-11-16 17:39:53 CET; 18h ago
                                         Docs: man:dhcpcd(8)
                                      Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCES>
                                     Main PID: 469 (dhcpcd)
                                        Tasks: 2 (limit: 779)
                                          CPU: 14.446s
                                       CGroup: /system.slice/dhcpcd.service
                                               ├─469 /usr/sbin/dhcpcd -b -q
                                               └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf >
                                  Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
                                  lines 1-22/22 (END)
                                       Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
                                         Docs: man:dhcpcd(8)
                                      Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCESS)
                                          CPU: 14.446s
                                               └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
                                  Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
                                  auf meinen Raspi, Hier stell ich doch keinen DHCP ein oder? wo schau ich das nach?
                                    @marcel-drzal
                                    Nee, da sind deine Repos falsch. Kann das aber im Moment nicht gut nachvollziehen, da am Handy unterwegs.
                                      A Former User @Guest last edited by
                                      sudo rm /var/lib/apt/lists/* dann ging es
                                        @marcel-drzal
                                        Dann lass jetzt mal ein
                                        sudo apt update
                                        sehen. Und bitte auch
                                        df -h
                                          sudo apt update
                                          bei Rasperry Pi-Slave
                                          pi@pi-Slave1:~ $ sudo apt update
                                          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:4 http://deb.debian.org/debian bullseye InRelease
                                          Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
                                          pi@pi-Slave1:~ $ df -h
                                          Filesystem      Size  Used Avail Use% Mounted on
                                          /dev/root        29G  4.0G   24G  15% /
                                          devtmpfs        325M     0  325M   0% /dev
                                          tmpfs           455M     0  455M   0% /dev/shm
                                          tmpfs           182M  1.1M  181M   1% /run
                                          tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                                          /dev/mmcblk0p1  255M   31M  225M  12% /boot
                                          tmpfs            91M   20K   91M   1% /run/user/1000
                                          bei Rasperry pi-Test
                                          pi@pi-Test:~ $ sudo apt update
                                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          Alle Pakete sind aktuell.
                                          pi@pi-Test:~ $ df -h
                                          Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
                                          /dev/root        30G    4,5G   24G   17% /
                                          devtmpfs        430M       0  430M    0% /dev
                                          tmpfs           462M       0  462M    0% /dev/shm
                                          tmpfs           462M     12M  450M    3% /run
                                          tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                                          tmpfs           462M       0  462M    0% /sys/fs/cgroup
                                          /dev/mmcblk0p1  253M     49M  204M   20% /boot
                                          tmpfs            93M       0   93M    0% /run/user/1000
                                          pi@pi-Test:~ $
                                            @marcel-drzal sagte in Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                                            Auf pi-Test stimmt die nodesource-Quelle nicht, wenn da als OS buster läuft. Die release names sollen übereinstimmen.
                                            Und auf dem dritten System schaut es wie aus?
                                            1392
