Adapter Hyundai (Bluelink) oder KIA (UVO)
@ilovegym installier mal meine version
https://github.com/arteck/ioBroker.bluelink
und mach nochmal.. dann log schauen nach -->
Hello, gemacht, Adapter zeigt Version 2.2.3 an.
Steuern der Clima geht nicht, wenn ich auf start clima druecke, kommt ein undefined. Ein Lock/Unlock funktioniert, der vorige Fehler von Version 2.2.6 ist weg.ilovegym@VMC123-iobroker /opt/iobroker $ iob logs --watch | grep bluelink.0 2022-11-17 08:32:13.914 - info: host.VMC123-iobroker iobroker Update "system.adapter.bluelink.0" 2022-11-17 08:32:13.922 - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 (force=false, process=true) 2022-11-17 08:32:13.923 - info: bluelink.0 (635883) Got terminate signal TERMINATE_YOURSELF 2022-11-17 08:32:13.924 - info: bluelink.0 (635883) Adapter bluelink cleaned up everything... 2022-11-17 08:32:13.924 - info: bluelink.0 (635883) terminating 2022-11-17 08:32:13.924 - info: bluelink.0 (635883) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2022-11-17 08:32:13.925 - info: host.VMC123-iobroker stopInstance system.adapter.bluelink.0 send kill signal 2022-11-17 08:32:14.723 - info: host.VMC123-iobroker instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2022-11-17 08:32:17.191 - info: host.VMC123-iobroker instance system.adapter.bluelink.0 started with pid 687175 2022-11-17 08:32:18.289 - info: bluelink.0 (687175) starting. Version 2.2.3 (non-npm: arteck/ioBroker.bluelink#f3613b00ef64bb48fe5c5568a146f79bfbc18c81) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.18.1, js-controller: 4.0.23 2022-11-17 08:32:18.302 - info: bluelink.0 (687175) Login to api 2022-11-17 08:32:23.123 - info: bluelink.0 (687175) 1 Vehicles found 2022-11-17 08:34:00.504 - info: bluelink.0 (687175) Starting clima for vehicle 2022-11-17 08:34:00.506 - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl 2022-11-17 08:34:00.506 - info: bluelink.0 (687175) --> airTemp KMHKR81AFNU0.control.set.airTemp 2022-11-17 08:34:00.507 - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost 2022-11-17 08:34:00.507 - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating 2022-11-17 08:34:00.639 - error: bluelink.0 (687175) undefined 2022-11-17 08:35:34.601 - info: bluelink.0 (687175) Starting unlock for vehicle 2022-11-17 08:35:34.763 - info: bluelink.0 (687175) Unlock successful 2022-11-17 08:35:54.255 - info: bluelink.0 (687175) Starting lock for vehicle 2022-11-17 08:35:54.395 - info: bluelink.0 (687175) Lock successful 2022-11-17 08:36:02.288 - info: bluelink.0 (687175) Starting clima for vehicle 2022-11-17 08:36:02.290 - info: bluelink.0 (687175) --> airCtrl KMHKR81AFNU0.control.set.airCtrl 2022-11-17 08:36:02.290 - info: bluelink.0 (687175) --> airTemp KMHKR81AFN.control.set.airTemp 2022-11-17 08:36:02.290 - info: bluelink.0 (687175) --> defrost KMHKR81AFNU0.control.set.defrost 2022-11-17 08:36:02.290 - info: bluelink.0 (687175) --> heating KMHKR81AFNU0.control.set.heating 2022-11-17 08:36:02.414 - error: bluelink.0 (687175) undefinedEin komplettes Debuglog kann ich dir gerne per Mail senden...??
same here
2022-11-17 08:43:04.526 - info: bluelink.0 (2076917) Starting clima for vehicle 2022-11-17 08:43:04.534 - info: bluelink.0 (2076917) --> airCtrl KMHKR81XXXXXXXXX.control.set.airCtrl 2022-11-17 08:43:04.535 - info: bluelink.0 (2076917) --> airTemp KMHKR81XXXXXXXXX.control.set.airTemp 2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> defrost KMHKR81XXXXXXXXX.control.set.defrost 2022-11-17 08:43:04.536 - info: bluelink.0 (2076917) --> heating KMHKR81XXXXXXXXX.control.set.heating 2022-11-17 08:43:04.982 - error: bluelink.0 (2076917) undefined
man sollte nix neben bei machen
installiert nochmal..ich will mal schauen ob die zahlen richtig übernommen werden
da kommt jetzt:
2022-11-17 10:10:59.095 - debug: bluelink.0 (823776) New Event for state: {"val":true,"ack":false,"ts":1668676259094,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1667470001835} 2022-11-17 10:10:59.095 - debug: bluelink.0 (823776) ID: "bluelink.0.KMHKR.control.start" 2022-11-17 10:10:59.095 - info: bluelink.0 (823776) Starting clima for vehicle 2022-11-17 10:10:59.097 - info: bluelink.0 (823776) --> [object Object] 2022-11-17 10:10:59.098 - info: bluelink.0 (823776) --> [object Object] 2022-11-17 10:10:59.098 - info: bluelink.0 (823776) --> [object Object] 2022-11-17 10:10:59.098 - info: bluelink.0 (823776) --> [object Object] 2022-11-17 10:10:59.238 - error: bluelink.0 (823776) {"source":{"name":"HTTPError","hostname":"prd.eu-ccapi.hyundai.com","method":und zum schluss im text wieder Service temporary unavalable... ist anscheinend die allgemeine Fehlermeldung, wenn sonst nix passt... ??
@ilovegym installier nochmal..bitää
@arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
BINGO !! das wars
super!2022-11-17 10:34:33.463 - debug: bluelink.0 (867157) New Event for state: {"val":true,"ack":false,"ts":1668677673462,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1667470001835} 2022-11-17 10:34:33.463 - debug: bluelink.0 (867157) ID: "bluelink.0.KMHKR81AFNU.control.start" 2022-11-17 10:34:33.463 - info: bluelink.0 (867157) Starting clima for vehicle 2022-11-17 10:34:33.465 - info: bluelink.0 (867157) --> airCtrl true 2022-11-17 10:34:33.465 - info: bluelink.0 (867157) --> airTemp 25 2022-11-17 10:34:33.465 - info: bluelink.0 (867157) --> defrost 25 2022-11-17 10:34:33.466 - info: bluelink.0 (867157) --> heating trueKeine Fehler, Klima ist aktiv im Auto und alles was ich eingestellt habe! Super!! Keinen kalten Arsch mehr hehe..
ich kann die Funktion jetzt auch bestätigen, danke
aktuell lässt sich dadurch die Temepraur + Aircon + Defrost Windscreen aktivieren.
Besteht ggf. noch de chance auch die Werte für Steering wheel warme + Rear Window + die Mirror zu editieren/aktivieren?
@williwilliwilli
Stimmt, die gehen nicht an, wobei das auch an der aktuellen Temp liegen kann? Hyundai programmiert da ja teilweise seltsame Sachen..
Ich schau morgen frueh nochmal, wenns richtig kalt ist.. -
@williwilliwilli sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
weiss ich nicht.. müsste ich mir anschauen was da ider der API möglich ist ..oder weiss du @Newan das vielleicht ??
Nach meiner bisherigen Erfahrung ist die Aktivierung davon abhängig, welche der drei Boxen ich in der App checke:
wenn die drei aktiv sind, dann starten alle fünf Optionen:
Wie das bei der API aussieht, das weiß ich leider nicht.
Eine Abhängigkeit von Wetter/Temperatur etc. konnte ich bisher nicht feststellen. -
Wie lange braucht das denn so bis ein fertiger Update auf Github bei ioBroker als Aktualisierung auftaucht?
Ich würde ungern mit der Installation aus anderen Quellen beginnen.
@wolpertinger solange bis @Newan es implementiert hat, getestet und hochgeladen.
In der Vorweihnachtszeit neben den Hauptberuflichen Dingen steht das an…
Warten, und geduldig sein, ist dann die Devise.
@ilovegym Ja, schon klar. Aber ist es nicht bereits implementiert gemäß Github Repo?
@wolpertinger probiers aus
Ich hab seit dem Fix von @arteck seinen Fork drauf, der funktioniert zuverlaessig. -
@arteck Danke, hast mich wieder auf den richtigen Pfad gebracht
funktioinert! -
Re: Adapter Hyundai (Bluelink) oder KIA (UVO)
Aktuelle Test Version 2.2.6 Veröffentlichungsdatum 04.11.2022 Github Link https://github.com/Newan/ioBroker.bluelink Ich weiß nicht, ob das API dies hergibt, aber sollte es möglich sein, wäre es schön, alle Ladevorgänge protokolliert zu haben.
@zisco gegenfrage kann ich die in der App sehen ??
