    4. Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert
      A Former User @Thomas Braun last edited by A Former User
      @thomas-braun sagte in Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
      sudo apt update
      pi@pi-Slave1:/ $ sudo apt-get update
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Err:2 http://deb.debian.org/debian bullseye InRelease
        Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [196 kB]
      Get:7 http://security.debian.org/debian-security bullseye-security/main armhf Packages [197 kB]
      Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [130 kB]
      Err:5 https://deb.nodesource.com/node_16.x bullseye InRelease
        Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
      Fetched 571 kB in 3s (182 kB/s)
      Reading package lists... Error!
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bullseye InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
      W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease into data and signature failed
      W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f16.x_dists_bullseye_InRelease into data and signature failed
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      E: Splitting of clearsigned file /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_InRelease failed as it doesn't contain all expected parts
      E: The package lists or status file could not be parsed or opened.
      pi@pi-Slave1:/ $ sudo apt update
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      pi@pi-Slave1:/ $
      sudo apt full-upgrade
      Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye InRelease
      Err:2 https://deb.nodesource.com/node_16.x bullseye InRelease
      Err:3 http://deb.debian.org/debian bullseye InRelease
      Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
      pi@pi-Slave1:~ $
      pi@pi-Slave1:/etc/network $ sudo systemctl status dhcpcd
      ● dhcpcd.service - DHCP Client Daemon
           Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset>
           Active: active (running) since Wed 2022-11-16 17:39:53 CET; 18h ago
             Docs: man:dhcpcd(8)
          Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCES>
         Main PID: 469 (dhcpcd)
            Tasks: 2 (limit: 779)
              CPU: 14.446s
           CGroup: /system.slice/dhcpcd.service
                   ├─469 /usr/sbin/dhcpcd -b -q
                   └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf >
      Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3e>
      lines 1-22/22 (END)
           Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
             Docs: man:dhcpcd(8)
          Process: 411 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCESS)
              CPU: 14.446s
                   └─548 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
      Nov 17 11:34:35 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 11:34:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 11:34:43 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 11:36:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 11:45:36 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 11:51:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 11:52:39 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 11:57:00 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 12:06:24 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      Nov 17 12:06:27 pi-Slave1 dhcpcd[469]: eth0: Router Advertisement from fe80::3ea6:2fff:fee0:916e
      auf meinen Raspi, Hier stell ich doch keinen DHCP ein oder? wo schau ich das nach?
        @marcel-drzal
        Nee, da sind deine Repos falsch. Kann das aber im Moment nicht gut nachvollziehen, da am Handy unterwegs.
          A Former User @Guest last edited by
          sudo rm /var/lib/apt/lists/* dann ging es
            Thomas Braun Most Active @Guest last edited by Thomas Braun
            @marcel-drzal
            Dann lass jetzt mal ein
            sudo apt update
            sehen. Und bitte auch
            df -h
            ? 2 Replies Last reply Reply Quote 0
              sudo apt update
              bei Rasperry Pi-Slave
              pi@pi-Slave1:~ $ sudo apt update
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://deb.debian.org/debian bullseye InRelease
              Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
              Reading package lists... Done
              Building dependency tree... Done
              All packages are up to date.
              pi@pi-Slave1:~ $ df -h
              Filesystem      Size  Used Avail Use% Mounted on
              /dev/root        29G  4.0G   24G  15% /
              devtmpfs        325M     0  325M   0% /dev
              tmpfs           455M     0  455M   0% /dev/shm
              tmpfs           182M  1.1M  181M   1% /run
              tmpfs           5.0M  4.0K  5.0M   1% /run/lock
              /dev/mmcblk0p1  255M   31M  225M  12% /boot
              tmpfs            91M   20K   91M   1% /run/user/1000
              bei Rasperry pi-Test
              pi@pi-Test:~ $ sudo apt update
              OK:1 http://archive.raspberrypi.org/debian buster InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
              Alle Pakete sind aktuell.
              pi@pi-Test:~ $ df -h
              Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
              /dev/root        30G    4,5G   24G   17% /
              devtmpfs        430M       0  430M    0% /dev
              tmpfs           462M       0  462M    0% /dev/shm
              tmpfs           462M     12M  450M    3% /run
              tmpfs           5,0M    4,0K  5,0M    1% /run/lock
              tmpfs           462M       0  462M    0% /sys/fs/cgroup
              /dev/mmcblk0p1  253M     49M  204M   20% /boot
              tmpfs            93M       0   93M    0% /run/user/1000
              pi@pi-Test:~ $
                @marcel-drzal sagte in Geöst Alexa2 Fehler nach Pi-Hole DHCP Server geändert:
                Auf pi-Test stimmt die nodesource-Quelle nicht, wenn da als OS buster läuft. Die release names sollen übereinstimmen.
                Und auf dem dritten System schaut es wie aus?
                  sudo nano /etc/apt/sources.list
                  vom Pik-Slave
                  deb http://deb.debian.org/debian bullseye main contrib non-free
                  deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                  deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                  # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                  #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                  #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                  #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                  vom Pi-Test
                  deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                  # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                  #deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
                    @marcel-drzal
                    Was ist das für eine Datei?
                    ? 3 Replies Last reply Reply Quote 0
                        @thomas-braun Gibt es einen unterschied zwischen
                        apt
                        apt-get?
                          @marcel-drzal
                          Möglich.
                          Und die /etc/apt/sources.list.d/nodesource.list auf pi-Test?
                            apt
                            apt-get?
                            Ja, gibt es. apt ist neuer und tickt etwas anders als apt-get.
                            Das ist wiederum stabiler und für skripte besser geeignet.
                              Pi Test
                              #deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main
                              #deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster$
                              deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye ma$
                              deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullsey$
                                @marcel-drzal
                                Auf dem Host läuft aber buster
                                Dann muss auch in die .list-Files buster rein.
                                Die Datei ist offenbar mal falsch von Hand editiert worden. Die auskommentierten Zeilen zu nodejs@14 sind richtig.
                                    aber ich habe doch alles auf das neue Bulseye geändert
                                    Master host Iobroker
                                    #deb http://ftp.debian.org/debian buster main contrib
                                    #deb http://ftp.debian.org/debian buster-updates main contrib
                                    #deb http://security.debian.org buster/updates main contrib
                                      @marcel-drzal
                                      Das wird mehr als unübersichtlich hier.
                                      Auf allen drei Systemen:
                                      echo $HOSTNAME && cat /etc/debian_version
                                        jetzt passt es oder?
                                        Master:
                                        marcel@iobroker:~$ df -h
                                        /dev/mapper/pve-vm--100--disk--0   25G  6.8G   17G  30% /
                                        none                              492K  4.0K  488K   1% /dev
                                        udev                               16G     0   16G   0% /dev/tty
                                        tmpfs                              16G     0   16G   0% /dev/shm
                                        tmpfs                             6.3G   92K  6.3G   1% /run
                                        tmpfs                             5.0M     0  5.0M   0% /run/lock
                                        tmpfs                             3.2G     0  3.2G   0% /run/user/1001
                                        marcel@iobroker:~$
                                        Slave
                                        Test Pi
                                        pi@pi-Test:~ $
                                        auf dem Test Pi stimmt was nicht ist noch Buster drin
                                        pi@pi-Test:~ $ sudo apt-get update
                                        Holen:1 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
                                        Holen:2 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages [781 B]
                                        Holen:3 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                        Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
                                        Holen:5 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                        Holen:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                                        Holen:7 http://raspbian.raspberrypi.org/raspbian buster/contrib armhf Packages [58,8 kB]
                                        Holen:8 http://raspbian.raspberrypi.org/raspbian buster/non-free armhf Packages [104 kB]
                                        Holen:9 http://raspbian.raspberrypi.org/raspbian buster/rpi armhf Packages [1.360 B]
                                        Es wurden 13,6 MB in 13 s geholt (1.036 kB/s).
                                          Master
                                          marcel@iobroker:~$ echo $HOSTNAME && cat /etc/debian_version
                                          iobroker
                                          11.5
                                          Slave
                                          pi@pi-Slave1:~ $ echo $HOSTNAME && cat /etc/debian_version
                                          pi-Slave1
                                          11.5
                                          Test
                                          pi@pi-Test:~ $ echo $HOSTNAME && cat /etc/debian_version
                                          pi-Test
                                          10.13
                                            Der pi-Test läuft also noch auf buster.
                                            Dann müssen auch die .list-Files auf buster lauten. Inkl. der nodesource.list.
                                            Bei den anderen beiden Systemen halt entsprechend auf bullseye.
                                            1392
