      Wuschl @Armilar last edited by
      @armilar ja, Kommas eingebaut, aber ändert nichts.
      • Armilar
        Armilar Most Active Forum Testing @Wuschl last edited by Armilar
        @wuschl
        Poste nochmal die Config, bitte
        und die aktuellen Logs.
          @armilar
          export const config: Config = {
              panelRecvTopic: 'mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT',       // anpassen
              panelSendTopic: 'mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend',   // anpassen
              firstScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Hourly.h0.PrecipitationProbability', ScreensaverEntityIcon: 'weather-pouring', ScreensaverEntityText: 'Regen', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
              secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
              thirdScreensaverEntity: { ScreensaverEntity: "shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3", ScreensaverEntityIcon: "pool-thermometer", ScreensaverEntityText: "Pool", ScreensaverEntityUnitText: "°C", ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 40} },
              fourthScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity', ScreensaverEntityIcon: 'water-percent', ScreensaverEntityText: 'Luft', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
              alternativeScreensaverLayout: false,
              autoWeatherColorScreensaverLayout: true,
              mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
              mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
              timeoutScreensaver: 20,
              dimmode: 20,
              active: 100, //Standard-Brightness TFT
              screenSaverDoubleClick: true,
              locale: 'de-DE',                                // en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
              timeFormat: '%H:%M',                            // currently not used
              dateFormat: '%A, %d. %B %Y',                    // currently not used
              weatherEntity: 'alias.0.Wetter.Gerät_1',                // Dieser Alias muss erstellt werden, damit die 4 kleineren Icons (Wetter oder DP) angezeigt werden können --> oder autoCreateAlias auf true
              defaultOffColor: Off,
              defaultOnColor: On,
              defaultColor: Off,
              defaultBackgroundColor: Black,    //New Parameter
              temperatureUnit: '°C',
              pages: [
                      Garagen,
                      WLAN,
                      Service             //Auto-Alias Service Page
              subPages: [
                          NSPanel_Infos,              //Auto-Alias Service Page
                          NSPanel_Einstellungen,      //Auto-Alias Service Page
                          NSPanel_Firmware_Info       //Auto-Alias Service Page
              button1Page: null,   //Beispiel-Seite auf Button 1, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
              button2Page: null    //Beispiel-Seite auf Button 2, wenn Rule2 definiert - Wenn nicht definiert --> button1Page: null,
          16.11.2022, 22:14:57.478	[info ]: javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
          16.11.2022, 22:15:01.129	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
          16.11.2022, 22:15:01.900	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
          16.11.2022, 22:15:01.983	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
          16.11.2022, 22:15:02.043	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
          16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
          16.11.2022, 22:15:03.460	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
          16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
          16.11.2022, 22:15:03.461	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)```
          code_text
          • Peoples
            Peoples @Armilar last edited by Peoples
            @armilar
            bitteschön
            2022-11-16 22:26:07.923 - info: javascript.0 (400696) script.js.test: 0_userdata.0.NSPanel.Fitness.Relay.1
            2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: 0_userdata.0.NSPanel.Fitness.Relay.1
            2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: undefined
            2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: Relay
            2022-11-16 22:26:07.924 - info: javascript.0 (400696) script.js.test: Fitness
            2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: true
            2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: 1668633967917
            2022-11-16 22:26:07.925 - info: javascript.0 (400696) script.js.test: 0
            Armilar 1 Reply Last reply Reply Quote 1
            • Armilar
              Armilar Most Active Forum Testing @Peoples last edited by
              @peoples
              Okay, hatte ich mir schon gedacht.
              Nimm mal den Code aus diesen Post (vor ein paar Minuten):
              https://forum.iobroker.net/post/893216
              Ich habe die obj.id zerlegt und nehme den Teil nach dem Punkt. Dann sollte es passen.
              • Armilar
                Armilar Most Active Forum Testing last edited by Armilar
                @wuschl
                hmm, dachte ich hätte eben geantwortet. Aber dann sah ich meine Frage nicht mehr 😵
                Ich kann keine Fehler finden in der Config. Sende mal den kompletten oberen Teil (Code in einem Spoiler)
                erst
                dann außen noch
                Muss ich mir komplett ansehen. Irgendwo ist noch ein Fehlerchen in dem Teil. Kann aber bis morgen dauern.
                • Peoples
                  @armilar
                  Ja mit der Änderung funktioniert es
                  • Armilar
                    @peoples 👍
                      @armilar
                      let vwIconColor = [];
                      //-- Anfang der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ----------------
                      var Garagen: PageEntities =
                          "type": "cardEntities",
                          "heading": "Garagen",
                          "useColor": true,
                          "subPage": false,
                          "parent": undefined,
                          "items": [
                              <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Audi", offColor: MSGreen, onColor: MSRed, name: "Garage Audi", icon: "garage-variant", icon2: "garage-open-variant"},
                              <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Polo", offColor: MSGreen, onColor: MSRed, name: "Garage Polo", icon: "garage-variant", icon2: "garage-open-variant"},
                              <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Fahrräder", offColor: MSGreen, onColor: MSRed, name: "Garage Fahrräder", icon: "garage-variant", icon2: "garage-open-variant"},
                      var WLAN: PageQR =
                          "type": "cardQR",
                          "heading": "Gäste WLAN",
                          "useColor": true,
                          "subPage": true,
                          "items": [<PageItem>{ id: "alias.0.NsPanelGarage.WLAN" }]
                      //-- ENDE der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ------------------
                      //Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt)
                      let Service: PageEntities =
                          "heading": "NSPanel Service",
                          "useColor": true,
                          "subPage": false,
                          "items": [
                              <PageItem>{ id: AliasPath + 'autoUpdate', name: "Auto-Updates" ,icon: "update", offColor: MSRed, onColor: MSGreen},
                              <PageItem>{ navigate: true, id: "NSPanel_Infos", icon: "information-outline", onColor: White, name: "NSPanel Infos"},
                              <PageItem>{ navigate: true, id: "NSPanel_Firmware_Info", icon: "update", onColor: White, name: "Firmware Infos"},
                              <PageItem>{ navigate: true, id: "NSPanel_Einstellungen", icon: "wrench-outline", onColor: White, name: "Screensaver"}
                              //Subpage 1 von Subpages_2
                              let NSPanel_Infos: PageEntities =
                                  "heading": "NSPanel Infos",
                                  "useColor": true,
                                  "subPage": true,
                                  "parent": Service,
                                  "items": [
                                      <PageItem>{ id: AliasPath + 'Tasmota.Hardware', name: 'Hardware', icon: 'memory', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                      <PageItem>{ id: AliasPath + 'Sensor.ESP32.Temperature', name: "ESP Temperatur", icon: "thermometer", unit: "°C", offColor: MSYellow, onColor: MSYellow, useColor: true},
                                      <PageItem>{ id: AliasPath + 'Tasmota.Uptime', name: "Uptime", icon: "timeline-clock-outline", offColor: MSYellow, onColor: MSYellow, useColor: true},
                                      <PageItem>{ id: AliasPath + 'Tasmota.Wifi.RSSI', name: "Wifi-Signal", icon: "signal-distance-variant", unit: "dBm", offColor: MSYellow, onColor: MSYellow, useColor: true}
                              //Subpage 2 von Subpages_2
                              let NSPanel_Einstellungen: PageEntities =
                                  'type': 'cardEntities',
                                  'heading': 'Screensaver',
                                  'useColor': true,
                                  'subPage': true,
                                  'parent': Service,
                                  'items': [
                                      <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                                      <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                                      <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                                      <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
                              //Subpage 3 von Subpages_2
                              let NSPanel_Firmware_Info: PageEntities =
                                  'heading': 'Firmware-Updates',
                                  'useColor': true,
                                  'subPage': true,
                                  'parent': Service,
                                  'items': [
                                      <PageItem>{ id: AliasPath + 'Tasmota.Version', name: 'Tasmota Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                      <PageItem>{ id: AliasPath + 'Display.TFTVersion', name: 'TFT-Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                      <PageItem>{ id: AliasPath + 'Display.BerryDriver', name: 'Berry-Treiber', offColor: MSYellow, onColor: MSYellow, useColor: true},
                                      <PageItem>{ id: AliasPath + 'Display.Model', name: 'NSPanel Version', offColor: MSYellow, onColor: MSYellow, useColor: true}
                          dimmode: 20,
                          defaultOnColor: On,
                          defaultColor: Off,
                          pages: [
                                  Garagen,
                                  WLAN,
                          subPages: [
                      [s=]
                      [/s]
                      Armilar T 2 Replies Last reply Reply Quote 0
                      • Armilar
                        @wuschl sagte in SONOFF NSPanel mit Lovelace UI:
                        var WLAN: PageQR =
                        "type": "cardQR",
                        "useColor": true,
                        "subPage": true,
                        Du hast eine SubPage unter die Pages gehängt
                        Setze mal subPage auf false.
                        var WLAN: PageQR =
                            "type": "cardQR",
                            "useColor": true,
                            "subPage": false,
                          @armilar das wars auch nicht
                          17.11.2022, 14:43:01.211	[info ]: javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                          17.11.2022, 14:43:05.999	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                          17.11.2022, 14:43:06.786	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                          17.11.2022, 14:43:06.843	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                          17.11.2022, 14:43:06.869	[info ]: javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                          17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                          17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                          17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                          17.11.2022, 14:43:07.254	[warn ]: javascript.0 (806)     at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
                          • Armilar
                            @wuschl
                            Dann schalten wir mal etwas mehr Logging ein (oben rechts vom Script):
                            Dann Speichern und das Log senden in dem die Warnungen auftauchen.
                            Danach den Haken wieder raus und erneut speichern.
                              @armilar wie kann ich dir das senden? Der Text ist zu lange.
                              • Armilar
                                @wuschl
                                nicht alles, sondern nur die Zeilen ab ca. 10 vor den Warnungen und 10 nach den Warnungen. Sollte direkt nach dem Start des Scriptes kommen. Also max. 30 - 100 Zeilen.
                                Es geht mir nur um die Funktionen die zuvor aufgerufen werden und danach um die Position zu lokalisieren. Die Zeilen-Nummerierung gibt das nicht her. Sonst könnte man ja mit den Daten von dir arbeiten 😉
                                W 2 Replies Last reply Reply Quote 0
                                  @armilar
                                  18:50:59.370	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                                  18:51:00.731	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                                  18:51:00.819	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                                  18:51:00.821	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.PageNavi","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.824	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourDay, timerId=undefined) => {"val":7,"ack":true,"ts":1668327325121,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325121}
                                  18:51:00.824	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourNight, timerId=undefined) => {"val":22,"ack":true,"ts":1668327325607,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325607}
                                  18:51:00.824	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_brightnessDay, timerId=undefined) => {"val":8,"ack":true,"ts":1668327324911,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                                  18:51:00.825	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_brightnessNight, timerId=undefined) => {"val":1,"ack":true,"ts":1668327325318,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325318}
                                  18:51:00.825	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourDay, timerId=undefined) => {"val":7,"ack":true,"ts":1668327325121,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325121}
                                  18:51:00.829	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=[object Object])
                                  18:51:00.829	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Dimmode_hourNight, timerId=undefined) => {"val":22,"ack":true,"ts":1668327325607,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325607}
                                  18:51:00.830	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=[object Object])
                                  18:51:00.831	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"dimmode~8~100~0","ack":false,"ts":1668707460831,"q":0,"from":"system.adapter.javascript.0","lc":1668707460831,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:00.837	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=* * * * *)
                                  18:51:00.838	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.ScreensaverInfo.entityChangeTime, timerId=undefined) => {"val":60,"ack":true,"ts":1668327325175,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325175}
                                  18:51:00.841	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=*/60 * * * * *)
                                  18:51:00.842	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.843	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.843	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.ScreensaverInfo.weatherForecast","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.844	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=0 * * * *)
                                  18:51:00.847	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(cron=[object Object])
                                  18:51:00.847	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: schedule(wizard={"time":{"start":"00:00","end":"23:59","mode":"hours","interval":12},"period":{"days":1}})
                                  18:51:00.851	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"pageType~pageStartup","ack":false,"ts":1668707460851,"q":0,"from":"system.adapter.javascript.0","lc":1668707460851,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:00.852	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.tele.NS-Panel-Paps_0BED20.INFO2, timerId=undefined) => {"val":"{\"Info2\":{\"WebServerMode\":\"Admin\",\"Hostname\":\"NS-Panel-Paps-0BED20-3360\",\"IPAddress\":\"192.168.178.244\"}}","ack":true,"ts":1668692778130,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668270172355}
                                  18:51:00.855	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.currentVersion, timerId=undefined) => {"val":"12.2.0","ack":true,"ts":1668702873969,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327326108}
                                  18:51:00.856	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.onlineVersion, timerId=undefined) => {"val":"12.2.0","ack":true,"ts":1668702874500,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325585}
                                  18:51:00.856	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Berry_Driver.currentVersion, timerId=undefined) => {"val":"4","ack":true,"ts":1668702874147,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325585}
                                  18:51:00.856	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.Display_Firmware.currentVersion, timerId=undefined) => {"val":"43","ack":true,"ts":1668702874596,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325214}
                                  18:51:00.858	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.popupNotify.popupNotifyAction","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.858	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.858	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"accuweather.0.Hourly.h0.PrecipitationProbability","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"accuweather.0.Current.WindSpeed","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"accuweather.0.Current.RelativeHumidity","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.859	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.tele.NS-Panel-Paps_0BED20.RESULT","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.860	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Alarm.AlarmState","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.860	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"mqtt.0.tele.NS-Panel-Paps_0BED20.SENSOR","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:00.860	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                  18:51:00.909	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.autoUpdate, obj={"type":"channel","common":{"role":"socket","name":"AutoUpdate"},"native":{}})
                                  18:51:01.088	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.tele.NS-Panel-Paps_0BED20.INFO2, timerId=undefined) => {"val":"{\"Info2\":{\"WebServerMode\":\"Admin\",\"Hostname\":\"NS-Panel-Paps-0BED20-3360\",\"IPAddress\":\"192.168.178.244\"}}","ack":true,"ts":1668692778130,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668270172355}
                                  18:51:01.089	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.NSPanel_ipAddress, state={"val":"192.168.178.244","ack":true,"ts":1668707461089,"q":0,"from":"system.adapter.javascript.0","lc":1668327325124,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.091	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.ScreensaverInfo.popupNotifyHeading","change":"ne","ack":false,"q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:01.093	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.ScreensaverInfo.popupNotifyText","change":"ne","ack":false,"q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:01.094	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"0_userdata.0.NSPanel.Paps.popupNotify.popupNotifyInternalName","change":"ne","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:01.146	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.currentVersion, state={"val":"12.2.0","ack":true,"ts":1668707461145,"q":0,"from":"system.adapter.javascript.0","lc":1668327326108,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.165	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, state={"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"from":"system.adapter.javascript.0","lc":1668327324911,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.171	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.ipAddress, obj={"type":"channel","common":{"role":"info","name":"ipAddress"},"native":{}})
                                  18:51:01.182	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Uptime, state={"val":"0T04:04:50","ack":true,"ts":1668707461182,"q":0,"from":"system.adapter.javascript.0","lc":1668707461182,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.277	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Version, state={"val":"12.2.0(tasmota)","ack":true,"ts":1668707461277,"q":0,"from":"system.adapter.javascript.0","lc":1668327326125,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.318	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"date~Donnerstag, 17. November 2022","ack":false,"ts":1668707461318,"q":0,"from":"system.adapter.javascript.0","lc":1668707461318,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.319	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"time~18:51","ack":false,"ts":1668707461319,"q":0,"from":"system.adapter.javascript.0","lc":1668707461319,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.319	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"timeout~20","ack":false,"ts":1668707461319,"q":0,"from":"system.adapter.javascript.0","lc":1668707461319,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                  18:51:01.320	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_Version, timerId=undefined) => {"val":"eu","ack":true,"ts":1668702874935,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327325303}
                                  18:51:01.323	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getObject(id=alias.0.Garagen-Papa.Garage-Audi, enumName=undefined) => {"_id":"alias.0.Garagen-Papa.Garage-Audi","common":{"name":{"de":"Garage-Audi"},"role":"gate","icon":"","color":null},"native":{},"type":"channel","from":"system.adapter.admin.0","user":"system.user.admin","ts":1668611449973,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  18:51:01.324	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Garagen-Papa.Garage-Audi.SET, timerId=undefined) => {"val":false,"ack":true,"ts":1668621847691,"q":0,"from":"system.adapter.shelly.0","user":"system.user.admin","lc":1668620862733}
                                  18:51:01.324	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Audi.SET","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                  18:51:01.325	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Garagen-Papa.Garage-Audi.ACTUAL, timerId=undefined) => {"val":false,"ack":false,"ts":1668700336224,"q":0,"c":"script.js.Papa-Garagen.Garage_Audi","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668700336224}
                                  18:51:01.326	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, timerId=undefined) => {"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                                    Wuschl @Armilar last edited by
                                    @armilar
                                    18:51:01.330	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Audi.ACTUAL","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                    18:51:01.331	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getObject(id=alias.0.Garagen-Papa.Garage-Polo, enumName=undefined) => {"_id":"alias.0.Garagen-Papa.Garage-Polo","common":{"name":{"de":"Garage-Polo"},"role":"gate","icon":"","color":null},"native":{},"type":"channel","from":"system.adapter.admin.0","user":"system.user.admin","ts":1668611696389,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    18:51:01.332	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, timerId=undefined) => {"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                                    18:51:01.335	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Polo.ACTUAL","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                    18:51:01.335	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getObject(id=alias.0.Garagen-Papa.Garage-Fahrräder, enumName=undefined) => {"_id":"alias.0.Garagen-Papa.Garage-Fahrräder","common":{"name":{"de":"Garage-Fahrräder"},"role":"gate","icon":"","color":null},"native":{},"type":"channel","from":"system.adapter.admin.0","user":"system.user.admin","ts":1668612233532,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    18:51:01.335	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Garagen-Papa.Garage-Fahrräder.ACTUAL, timerId=undefined) => {"val":false,"ack":false,"ts":1668636385319,"q":0,"c":"script.js.Papa-Garagen.Garage_Fahrräder","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668636385319}
                                    18:51:01.336	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=0_userdata.0.NSPanel.Paps.NSPanel_locales_json, timerId=undefined) => {"val":"{\n \"lights\": {\n \"Brightness\": {\n \"en-US\": \"Brightness\",\n \"de-DE\": \"Helligkeit\",\n \"nl-NL\": \"Helderheid\",\n \"da-DK\": \"Lysstyrke\",\n \"es-ES\": \"Brillo\",\n \"fr-FR\": \"Luminosité\",\n \"it-IT\": \"Luminosità\",\n \"ru-RU\": \"Яркость\",\n \"nb-NO\": \"Lysstyrke\",\n \"nn-NO\": \"Lysstyrke\",\n \"pl-PL\": \"Jasność\",\n \"pt-PT\": \"Brilho\",\n \"af-ZA\": \"Helderheid\",\n \"ar-SY\": \"السطوع\",\n \"bg-BG\": \"Яркост\",\n \"ca-ES\": \"Brillantor\",\n \"cs-CZ\": \"Jas\",\n \"el-GR\": \"Φωτεινότητα\",\n \"et-EE\": \"Heledus\",\n \"fa-IR\": \"روشنایی\",\n \"fi-FI\": \"Kirkkaus\",\n \"he-IL\": \"בהירות\",\n \"hr-xx\": \"Svjetlina\",\n \"hu-HU\": \"Fényerő\",\n \"hy-AM\": \"Պայծառություն\",\n \"id-ID\": \"Kecerahan\",\n \"is-IS\": \"Birtustig\",\n \"lb-xx\": \"Hellegkeet\",\n \"lt-LT\": \"Ryškumas\",\n \"ro-RO\": \"Luminozitate\",\n \"sk-SK\": \"Jas\",\n \"sl-SI\": \"Svetlost\",\n \"sv-SE\": \"Ljusstyrka\",\n \"th-TH\": \"ความสว่าง\",\n \"tr-TR\": \"Parlaklık\",\n \"uk-UA\": \"Яскравість\",\n \"vi-VN\": \"Độ sáng\",\n \"zh-CN\": \"亮度\",\n \"zh-TW\": \"亮度\"\n },\n \"Temperature\": {\n \"en-US\": \"Color temperature\",\n \"de-DE\": \"Farbtemperatur\",\n \"nl-NL\": \"Kleurtemperatuur\",\n \"da-DK\": \"Farvetemperatur\",\n \"es-ES\": \"Temperatura del color\",\n \"fr-FR\": \"Température de couleur\",\n \"it-IT\": \"Temperatura colore\",\n \"ru-RU\": \"Цветовая температура\",\n \"nb-NO\": \"Fargetemperatur\",\n \"nn-NO\": \"Fargetemperatur\",\n \"pl-PL\": \"Temperatura barwy\",\n \"pt-PT\": \"Temperatura de cor\",\n \"af-ZA\": \"Kleur temperatuur\",\n \"ar-SY\": \"درجة حرارة اللون\",\n \"bg-BG\": \"Цветова температура\",\n \"ca-ES\": \"Temperatura de color\",\n \"cs-CZ\": \"Teplota barvy\",\n \"el-GR\": \"Θερμοκρασία χρώματος\",\n \"et-EE\": \"Värvustemperatuur\",\n \"fa-IR\": \"دمای رنگ\",\n \"fi-FI\": \"Värilämpötila\",\n \"he-IL\": \"טמפרטורת הצבע\",\n \"hr-xx\": \"Temperatura boje\",\n \"hu-HU\": \"Színhőmérséklet\",\n \"hy-AM\": \"Գունային ջերմաստիճան\",\n \"id-ID\": \"Temperatur warna\",\n \"is-IS\": \"Litastig\",\n \"lb-xx\": \"Faarf Temperatur\",\n \"lt-LT\": \"Spalvos temperatūra\",\n \"ro-RO\": \"Temperatură de culoare\",\n \"sk-SK\": \"Teplota farby\",\n \"sl-SI\": \"Temperatura barve\",\n \"sv-SE\": \"Färgtemperatur\",\n \"th-TH\": \"อุณหภูมิสี\",\n \"tr-TR\": \"Renk sıcaklığı\",\n \"uk-UA\": \"Кольорова температура\",\n \"vi-VN\": \"Nhiệt độ màu\",\n \"zh-CN\": \"色温\",\n \"zh-TW\": \"色溫\"\n }\n },\n \"window\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыто\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворен\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστό\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגור\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Loka\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängt\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинене\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыто\",\n \"nb-NO\": \"Åpent\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворен\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτό\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוח\",\n \"hr-xx\": \"Otvoreno\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opna\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppet\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинене\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"開啟\"\n }\n },\n \"door\": {\n \"closed\": {\n \"en-US\": \"Closed\",\n \"de-DE\": \"Geschlossen\",\n \"nl-NL\": \"Dicht\",\n \"da-DK\": \"Lukket\",\n \"es-ES\": \"Cerrada\",\n \"fr-FR\": \"Fermée\",\n \"it-IT\": \"Chiusa\",\n \"ru-RU\": \"Закрыта\",\n \"nb-NO\": \"Lukket\",\n \"nn-NO\": \"Lukka\",\n \"pl-PL\": \"zamknięte\",\n \"pt-PT\": \"Fechada\",\n \"af-ZA\": \"Toe\",\n \"ar-SY\": \"مغلق\",\n \"bg-BG\": \"Затворена\",\n \"ca-ES\": \"Tancada\",\n \"cs-CZ\": \"Zavřeno\",\n \"el-GR\": \"Κλειστή\",\n \"et-EE\": \"Suletud\",\n \"fa-IR\": \"بسته\",\n \"fi-FI\": \"Suljettu\",\n \"he-IL\": \"סגורה\",\n \"hr-xx\": \"Zatvoreno\",\n \"hu-HU\": \"Zárva\",\n \"hy-AM\": \"Փակված է\",\n \"id-ID\": \"Tertutup\",\n \"is-IS\": \"Lokuð\",\n \"lb-xx\": \"Zou\",\n \"lt-LT\": \"Uždaryta\",\n \"ro-RO\": \"Închis\",\n \"sk-SK\": \"Zatvorené\",\n \"sl-SI\": \"Zaprto\",\n \"sv-SE\": \"Stängd\",\n \"th-TH\": \"ปิดแล้ว\",\n \"tr-TR\": \"Kapalı\",\n \"uk-UA\": \"Зачинені\",\n \"vi-VN\": \"Đóng\",\n \"zh-CN\": \"关闭\",\n \"zh-TW\": \"已關閉\"\n },\n \"opened\": {\n \"en-US\": \"Open\",\n \"de-DE\": \"Offen\",\n \"nl-NL\": \"Open\",\n \"da-DK\": \"Åben\",\n \"es-ES\": \"Abierta\",\n \"fr-FR\": \"Ouverte\",\n \"it-IT\": \"Aperta\",\n \"ru-RU\": \"Открыта\",\n \"nb-NO\": \"Åpen\",\n \"nn-NO\": \"Open\",\n \"pl-PL\": \"otwarte\",\n \"pt-PT\": \"Aberta\",\n \"af-ZA\": \"Oop\",\n \"ar-SY\": \"مفتوح\",\n \"bg-BG\": \"Отворена\",\n \"ca-ES\": \"Oberta\",\n \"cs-CZ\": \"Otevřeno\",\n \"el-GR\": \"Ανοιχτή\",\n \"et-EE\": \"Avatud\",\n \"fa-IR\": \"باز\",\n \"fi-FI\": \"Auki\",\n \"he-IL\": \"פתוחה\",\n \"hr-xx\": \"Otvori\",\n \"hu-HU\": \"Nyitva\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Terbuka\",\n \"is-IS\": \"Opin\",\n \"lb-xx\": \"Op\",\n \"lt-LT\": \"Atidaryta\",\n \"ro-RO\": \"Deschis\",\n \"sk-SK\": \"Otvorené\",\n \"sl-SI\": \"Odprto\",\n \"sv-SE\": \"Öppen\",\n \"th-TH\": \"เปิด\",\n \"tr-TR\": \"Açık\",\n \"uk-UA\": \"Відчинені\",\n \"vi-VN\": \"Mở\",\n \"zh-CN\": \"开启\",\n \"zh-TW\": \"已開啟\"\n }\n },\n \"lock\": {\n \"LOCK\": {\n \"en-US\": \"Lock\",\n \"de-DE\": \"Verriegeln\",\n \"nl-NL\": \"Vergrendelen\",\n \"da-DK\": \"Lås\",\n \"es-ES\": \"Bloquear\",\n \"fr-FR\": \"Verrouiller\",\n \"it-IT\": \"Blocca\",\n \"ru-RU\": \"Закрыть\",\n \"nb-NO\": \"Lås\",\n \"nn-NO\": \"Lås\",\n \"pl-PL\": \"Zablokuj\",\n \"pt-PT\": \"Bloquear\",\n \"af-ZA\": \"Sluit toe\",\n \"ar-SY\": \"قفل\",\n \"bg-BG\": \"Заключване\",\n \"ca-ES\": \"Bloquejar\",\n \"cs-CZ\": \"Zamknout\",\n \"el-GR\": \"Κλείδωμα\",\n \"et-EE\": \"Lukusta\",\n \"fa-IR\": \"قفل\",\n \"fi-FI\": \"Lukitse\",\n \"he-IL\": \"נעילה\",\n \"hr-xx\": \"zaključati\",\n \"hu-HU\": \"Bezár\",\n \"hy-AM\": \"Կողպեք\",\n \"id-ID\": \"Kunci\",\n \"is-IS\": \"Læsa\",\n \"lb-xx\": \"Spären\",\n \"lt-LT\": \"Užrakinti\",\n \"ro-RO\": \"Blocat\",\n \"sk-SK\": \"Zamknúť\",\n \"sl-SI\": \"Zakleni\",\n \"sv-SE\": \"Lås\",\n \"th-TH\": \"ล็อค\",\n \"tr-TR\": \"Kilitle\",\n \"uk-UA\": \"Блокувати\",\n \"vi-VN\": \"Khóa\",\n \"zh-CN\": \"锁定\",\n \"zh-TW\": \"上鎖\"\n },\n \"UNLOCK\": {\n \"en-US\": \"Unlock\",\n \"de-DE\": \"Entriegeln\",\n \"nl-NL\": \"Ontgrendelen\",\n \"da-DK\": \"Lås op\",\n \"es-ES\": \"Desbloquear\",\n \"fr-FR\": \"Déverrouiller\",\n \"it-IT\": \"Sblocca\",\n \"ru-RU\": \"Открыть\",\n \"nb-NO\": \"Lås opp\",\n \"nn-NO\": \"Lås opp\",\n \"pl-PL\": \"Odblokuj\",\n \"pt-PT\": \"Desbloquear\",\n \"af-ZA\": \"Sluit oop\",\n \"ar-SY\": \"فتح\",\n \"bg-BG\": \"Отключване\",\n \"ca-ES\": \"Desbloquejar\",\n \"cs-CZ\": \"Odemknout\",\n \"el-GR\": \"Ξεκλείδωμα\",\n \"et-EE\": \"Ava\",\n \"fa-IR\": \"باز کردن\",\n \"fi-FI\": \"Avaa lukitus\",\n \"he-IL\": \"ביטול נעילה\",\n \"hr-xx\": \"Otključati\",\n \"hu-HU\": \"Kinyit\",\n \"hy-AM\": \"Բացել\",\n \"id-ID\": \"Buka\",\n \"is-IS\": \"Aflæsa\",\n \"lb-xx\": \"Entspären\",\n \"lt-LT\": \"Atrakinti\",\n \"ro-RO\": \"Deblocare\",\n \"sk-SK\": \"Odomknúť\",\n \"sl-SI\": \"Odkleni\",\n \"sv-SE\": \"Lås upp\",\n \"th-TH\": \"ปลดล็อค\",\n \"tr-TR\": \"Kilidi aç\",\n \"uk-UA\": \"Розблокувати\",\n \"vi-VN\": \"Mở khóa\",\n \"zh-CN\": \"解锁\",\n \"zh-TW\": \"解鎖\"\n }\n },\n \"blinds\": {\n \"Position\": {\n \"en-US\": \"Position\",\n \"de-DE\": \"Position\",\n \"nl-NL\": \"Positie\",\n \"da-DK\": \"Position\",\n \"es-ES\": \"Posición\",\n \"fr-FR\": \"Position\",\n \"it-IT\": \"Apertura\",\n \"ru-RU\": \"Положение\",\n \"nb-NO\": \"Posisjon\",\n \"nn-NO\": \"Posisjon\",\n \"pl-PL\": \"Pozycja\",\n \"pt-PT\": \"Posição\",\n \"af-ZA\": \"Posisie\",\n \"ar-SY\": \"موضع\",\n \"bg-BG\": \"Позиция\",\n \"ca-ES\": \"Posició\",\n \"cs-CZ\": \"Pozice\",\n \"el-GR\": \"Θέση\",\n \"et-EE\": \"Asend\",\n \"fa-IR\": \"موقعیت\",\n \"fi-FI\": \"Sijainti\",\n \"he-IL\": \"מיקום\",\n \"hr-xx\": \"Pozicija\",\n \"hu-HU\": \"Pozíció\",\n \"hy-AM\": \"Դիրք\",\n \"id-ID\": \"Posisi\",\n \"is-IS\": \"Staðsetning\",\n \"lb-xx\": \"Positioun\",\n \"lt-LT\": \"Padėtis\",\n \"ro-RO\": \"Poziţie\",\n \"sk-SK\": \"Poloha\",\n \"sl-SI\": \"Položaj\",\n \"sv-SE\": \"Position\",\n \"th-TH\": \"ตำแหน่ง\",\n \"tr-TR\": \"Pozisyon\",\n \"uk-UA\": \"Положення\",\n \"vi-VN\": \"Vị trí\",\n \"zh-CN\": \"位置\",\n \"zh-TW\": \"位置\"\n }\n },\n \"thermostat\": {\n \"Currently\": {\n \"en-US\": \"Currently\",\n \"de-DE\": \"Aktuell\",\n \"nl-NL\": \"Momenteel\",\n \"da-DK\": \"Aktuelt\",\n \"es-ES\": \"Actualmente\",\n \"fr-FR\": \"Actuellement\",\n \"it-IT\": \"Attualmente\",\n \"ru-RU\": \"Сейчас\",\n \"nb-NO\": \"Er nå\",\n \"nn-NO\": \"Akkurat no\",\n \"pl-PL\": \"Obecnie\",\n \"pt-PT\": \"Atualmente\",\n \"af-ZA\": \"Tans\",\n \"ar-SY\": \"حاليا\",\n \"bg-BG\": \"В момента\",\n \"ca-ES\": \"Actual\",\n \"cs-CZ\": \"Aktuálně\",\n \"el-GR\": \"Αυτή τη στιγμή\",\n \"et-EE\": \"Hetkel\",\n \"fa-IR\": \"در حال حاضر\",\n \"fi-FI\": \"Tällä hetkellä\",\n \"he-IL\": \"כעת\",\n \"hr-xx\": \"Trenutno\",\n \"hu-HU\": \"Jelenleg\",\n \"hy-AM\": \"Ներկայումս\",\n \"id-ID\": \"Saat ini\",\n \"is-IS\": \"Er núna\",\n \"lb-xx\": \"Momentan\",\n \"lt-LT\": \"Šiuo metu\",\n \"ro-RO\": \"În prezent\",\n \"sk-SK\": \"Aktuálne\",\n \"sl-SI\": \"Trenutno\",\n \"sv-SE\": \"Nuvarande\",\n \"th-TH\": \"ในขณะนี้\",\n \"tr-TR\": \"Şu an\",\n \"uk-UA\": \"В даний час\",\n \"vi-VN\": \"Hiện tại\",\n \"zh-CN\": \"当前\",\n \"zh-TW\": \"目前狀態\"\n },\n \"State\": {\n \"en-US\": \"State\",\n \"de-DE\": \"Zustand\",\n \"nl-NL\": \"Toestand\",\n \"da-DK\": \"Tilstand\",\n \"es-ES\": \"Estado\",\n \"fr-FR\": \"État\",\n \"it-IT\": \"Stato\",\n \"ru-RU\": \"Состояние\",\n \"nb-NO\": \"Tilstand\",\n \"nn-NO\": \"Tilstand\",\n \"pl-PL\": \"Stan\",\n \"pt-PT\": \"Estado\",\n \"af-ZA\": {\n \"add_entities_lovelace\": \"Voeg by Lovelace\",\n \"entities\": \"Entiteite\",\n \"none\": \"Hierdie toestel het geen entiteite nie\"\n },\n \"ar-SY\": {\n \"add_entities_lovelace\": \"أضف إلى Lovelace\",\n \"disabled_entities\": \"{count} {count, plural,\\n one {كيان}\\n other {كيانات}\\n}\",\n \"entities\": \"الكيانات\",\n \"hide_disabled\": \"إخفاء معطل\",\n \"none\": \"هذا الجهاز ليس له كيانات\"\n },\n \"bg-BG\": {\n \"add_entities_lovelace\": \"Добавете към Lovelace\",\n \"config\": \"Конфиг.\",\n \"control\": \"Контроли\",\n \"diagnostic\": \"Диагностика\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {деактивиран обект}\\n other {деактивирани обекта}\\n}\",\n \"entities\": \"Обекти\",\n \"hide_disabled\": \"Скриване на деактивираните\",\n \"none\": \"Това устройство няма обекти\",\n \"sensor\": \"Сензори\"\n },\n \"ca-ES\": \"Estat\",\n \"cs-CZ\": \"Stav\",\n \"el-GR\": \"Κατάσταση\",\n \"et-EE\": \"Olek\",\n \"fa-IR\": {\n \"add_entities_lovelace\": \"Adauga la Lovelace\",\n \"entities\": \"Entitati\",\n \"none\": \"Acest dispozitiv nu are nicio entitate\"\n },\n \"fi-FI\": \"Tila\",\n \"he-IL\": \"מצב\",\n \"hr-xx\": {\n \"automation\": {\n \"actions\": {\n \"caption\": \"Kada se nešto pokrene…\"\n },\n \"automations\": \"Automatizacije\",\n \"conditions\": {\n \"caption\": \"Učini nešto samo ako…\"\n },\n \"create\": \"Stvorite automatizaciju s uređajem\",\n \"no_automations\": \"Nema automatizacije\",\n \"no_device_automations\": \"Nema dostupnih automatizacija za ovaj uređaj.\",\n \"triggers\": {\n \"caption\": \"Učini nešto kad...\"\n }\n },\n \"cant_edit\": \"Možete uređivati samo stavke stvorene u korisničkom sučelju (UI).\",\n \"caption\": \"Uređaji\",\n \"confirm_rename_entity_ids\": \"Želite li također preimenovati ID entiteta svojih entiteta?\",\n \"data_table\": {\n \"area\": \"Područje\",\n \"battery\": \"Baterija\",\n \"device\": \"Uređaj\",\n \"integration\": \"Integracija\",\n \"manufacturer\": \"Proizvođač\",\n \"model\": \"Model\"\n },\n \"description\": \"Upravljanje povezanim uređajima\",\n \"device_not_found\": \"Uređaj nije pronađen.\",\n \"name\": \"Naziv\",\n \"scene\": {\n \"create\": \"Stvorite scenu s uređajem\",\n \"no_scenes\": \"Nema scena\",\n \"scenes\": \"Scene\"\n },\n \"scenes\": \"Scene\",\n \"script\": {\n \"create\": \"Stvorite skriptu s uređajem\",\n \"no_scripts\": \"Nema skripte\",\n \"scripts\": \"Skripte\"\n },\n \"scripts\": \"Skripte\",\n \"unknown_error\": \"Nepoznata pogreška\",\n \"unnamed_device\": \"Neimenovani uređaj\",\n \"update\": \"Ažuriraj\"\n },\n \"hu-HU\": \"Állapot\",\n \"hy-AM\": {\n \"automation\": {\n \"create_disable\": \"Հնարավոր չէ ստեղծել ավտոմատացում անջատված սարքով\"\n },\n \"disabled\": \"Անջատված\",\n \"disabled_by\": {\n \"config_entry\": \"Կարգավորման կետ\",\n \"integration\": \"Ինտեգրում\",\n \"user\": \"Օգտատեր\"\n },\n \"enabled_cause\": \"Անջատված է {cause}-ի կողմից\",\n \"enabled_label\": \"Միացնել սարքը\",\n \"picker\": {\n \"filter\": {\n \"filter\": \"Ֆիլտր\",\n \"show_all\": \"Ցույց տալ ամբողջը\",\n \"show_disabled\": \"Ցուցադրել ապաակտիվացված սարքերը\"\n },\n \"search\": \"Որոնել սարքեր\"\n },\n \"scene\": {\n \"create_disable\": \"Հնարավոր չէ սցենար ստեղծել անջատված սարքով\"\n },\n \"script\": {\n \"create_disable\": \"Անջատված սարքով հնարավոր չէ ստեղծել սկրիպտ\"\n }\n },\n \"id-ID\": \"Status\",\n \"is-IS\": \"Staða\",\n \"lb-xx\": {\n \"add_entities_lovelace\": \"Zu Lovelace bäisetzen\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {Déaktivéiert Entitéit}\\n other {Déaktivéiert Entitéiten}\\n}\",\n \"entities\": \"Entitéiten\",\n \"hide_disabled\": \"Deaktivéiert net uweisen\",\n \"none\": \"Dësen Appart huet keng Entitéiten.\"\n },\n \"lt-LT\": {\n \"add_entities_lovelace\": \"Pridėti į Lovelace\",\n \"config\": \"Konfigūracija\",\n \"control\": \"Valdikliai\",\n \"diagnostic\": \"Diagnostika\",\n \"entities\": \"Subjektai\",\n \"sensor\": \"Jutikliai\"\n },\n \"ro-RO\": {\n \"add_entities_lovelace\": \"Adăugați la Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {entitate dezactivată}\\n other {entități dezactivate}\\n}\",\n \"entities\": \"Entități\",\n \"hide_disabled\": \"Ascundeți dezactivate\",\n \"none\": \"Acest dispozitiv nu are entități\",\n \"sensor\": \"Senzori\"\n },\n \"sk-SK\": \"Stav\",\n \"sl-SI\": \"Stanje\",\n \"sv-SE\": \"Tillstånd\",\n \"th-TH\": \"สถานะ\",\n \"tr-TR\": \"Durum\",\n \"uk-UA\": \"Стан\",\n \"vi-VN\": {\n \"add_entities_lovelace\": \"Thêm vào Lovelace\",\n \"disabled_entities\": \"+{count} {count, plural,\\n one {thực thể bị vô hiệu hoá}\\n other {các thực thể bị vô hiệu hoá}\\n}\",\n \"entities\": \"Các thực thể\",\n \"hide_disabled\": \"Ẩn các thiết bị bị vô hiệu hoá\",\n \"none\": \"Thiết bị này không có thực thể nào\"\n },\n \"zh-CN\": \"状态\",\n \"zh-TW\": \"狀態\"\n },\n \"Action\": {\n \"en-US\": \"Operation\",\n \"de-DE\": \"Aktion\",\n \"nl-NL\": \"Werking\",\n \"da-DK\": \"Drifttype\",\n \"es-ES\": \"Modo\",\n \"fr-FR\": \"Opération\",\n \"it-IT\": \"Operazione\",\n \"ru-RU\": \"Режим работы\",\n \"nb-NO\": \"Operasjon\",\n \"nn-NO\": \"Operasjon\",\n \"pl-PL\": \"Tryb pracy\",\n \"pt-PT\": \"Operação\",\n \"af-ZA\": \"Operasie\",\n \"ar-SY\": \"الوضع\",\n \"bg-BG\": \"Режим\",\n \"ca-ES\": \"Funcionament\",\n \"cs-CZ\": \"Provoz\",\n \"el-GR\": \"Λειτουργία\",\n \"et-EE\": \"Töörežiim\",\n \"fa-IR\": \"عملیات\",\n \"fi-FI\": \"Toiminto\",\n \"he-IL\": \"פעולה\",\n \"hr-xx\": \"operacija\",\n \"hu-HU\": \"Működés\",\n \"hy-AM\": \"Գործողություն\",\n \"id-ID\": \"Operasi\",\n \"is-IS\": \"Aðgerð\",\n \"lb-xx\": \"Aktioun\",\n \"lt-LT\": \"Operacija\",\n \"ro-RO\": \"Operație\",\n \"sk-SK\": \"Prevádzka\",\n \"sl-SI\": \"Delovanje\",\n \"sv-SE\": \"Driftläge\",\n \"th-TH\": \"การทำงาน\",\n \"tr-TR\": \"İşlem\",\n \"uk-UA\": \"Режим\",\n \"vi-VN\": \"Chế độ hoạt động\",\n \"zh-CN\": \"运行模式\",\n \"zh-TW\": \"運轉模式\"\n }\n }\n}","ack":true,"ts":1668707461164,"q":0,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1668327324911}
                                    18:51:01.339	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: subscribe: {"pattern":{"id":"alias.0.Garagen-Papa.Garage-Fahrräder.ACTUAL","change":"any","q":0},"name":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"}
                                    18:51:01.339	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"pageType~cardEntities","ack":false,"ts":1668707461339,"q":0,"from":"system.adapter.javascript.0","lc":1668707461339,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    18:51:01.339	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"entityUpd~Garagen~1|1~text~alias.0.Garagen-Papa.Garage-Audi~~32495~Garage Audi~Geschlossen~text~alias.0.Garagen-Papa.Garage-Polo~~64332~Garage Polo~Offen~text~alias.0.Garagen-Papa.Garage-Fahrräder~~32495~Garage Fahrräder~Geschlossen","ack":false,"ts":1668707461339,"q":0,"from":"system.adapter.javascript.0","lc":1668707461339,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    18:51:01.348	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Hardware, state={"val":"ESP32-D0WD-V3 rev.3","ack":true,"ts":1668707461348,"q":0,"from":"system.adapter.javascript.0","lc":1668327326137,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    18:51:01.410	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Display_Firmware.currentVersion, state={"val":"43","ack":true,"ts":1668707461410,"q":0,"from":"system.adapter.javascript.0","lc":1668327325214,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    18:51:01.416	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.tele.NS-Panel-Paps_0BED20.INFO2, timerId=undefined) => {"val":"{\"Info2\":{\"WebServerMode\":\"Admin\",\"Hostname\":\"NS-Panel-Paps-0BED20-3360\",\"IPAddress\":\"192.168.178.244\"}}","ack":true,"ts":1668692778130,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668270172355}
                                    18:51:01.440	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.AP, state={"val":1,"ack":true,"ts":1668707461440,"q":0,"from":"system.adapter.javascript.0","lc":1668327326143,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    18:51:01.442	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.NSPanel_Version, state={"val":"eu","ack":true,"ts":1668707461442,"q":0,"from":"system.adapter.javascript.0","lc":1668327325303,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    18:51:01.451	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.SSId, state={"val":"Siggi&Bernd_2.4","ack":true,"ts":1668707461451,"q":0,"from":"system.adapter.javascript.0","lc":1668327326154,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    18:51:01.454	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Display.TFTVersion, obj={"type":"channel","common":{"role":"info","name":"Display.TFTVersion"},"native":{}})
                                    18:51:01.454	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Display.Model, obj={"type":"channel","common":{"role":"info","name":"Display.Model"},"native":{}})
                                    18:51:01.522	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.BSSId, state={"val":"2C:3A:FD:09:0B:6F","ack":true,"ts":1668707461522,"q":0,"from":"system.adapter.javascript.0","lc":1668327326162,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                    • Armilar
                                      Armilar Most Active Forum Testing @Wuschl last edited by
                                      @wuschl
                                      Wäre schon gut, wenn die Warnungen dazwischen wären 😉
                                        @armilar
                                        18:56:05.906	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.Mode, state={"val":"11n","ack":true,"ts":1668707765906,"q":0,"from":"system.adapter.javascript.0","lc":1668327326178,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:05.908	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Display_Firmware.onlineVersion, state={"val":"43","ack":true,"ts":1668707765908,"q":0,"from":"system.adapter.javascript.0","lc":1668327325591,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:05.957	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.RSSI, state={"val":64,"ack":true,"ts":1668707765957,"q":0,"from":"system.adapter.javascript.0","lc":1668707765957,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:06.006	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota.Wifi.Signal, state={"val":-68,"ack":true,"ts":1668707766006,"q":0,"from":"system.adapter.javascript.0","lc":1668707766006,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:06.058	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Uptime, obj={"type":"channel","common":{"role":"info","name":"Uptime"},"native":{}})
                                        18:56:06.058	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Version, obj={"type":"channel","common":{"role":"info","name":"Version"},"native":{}})
                                        18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Hardware, obj={"type":"channel","common":{"role":"info","name":"Hardware"},"native":{}})
                                        18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.AP, obj={"type":"channel","common":{"role":"info","name":"AP"},"native":{}})
                                        18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.SSId, obj={"type":"channel","common":{"role":"info","name":"SSId"},"native":{}})
                                        18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.BSSId, obj={"type":"channel","common":{"role":"info","name":"BSSId"},"native":{}})
                                        18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.Channel, obj={"type":"channel","common":{"role":"info","name":"Channel"},"native":{}})
                                        18:56:06.059	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.Mode, obj={"type":"channel","common":{"role":"info","name":"Mode"},"native":{}})
                                        18:56:06.060	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.RSSI, obj={"type":"channel","common":{"role":"info","name":"RSSI"},"native":{}})
                                        18:56:06.060	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Tasmota.Wifi.Signal, obj={"type":"channel","common":{"role":"info","name":"Signal"},"native":{}})
                                        18:56:06.213	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.TFT_Firmware.onlineVersion, state={"val":"3.5.0","ack":true,"ts":1668707766213,"q":0,"from":"system.adapter.javascript.0","lc":1668327325426,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:06.269	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Tasmota_Firmware.onlineVersion, state={"val":"12.2.0","ack":true,"ts":1668707766269,"q":0,"from":"system.adapter.javascript.0","lc":1668327325585,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:06.286	warn	javascript.0 (806) at script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:1293:46
                                        18:56:06.287	warn	javascript.0 (806) at step (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:33:23)
                                        18:56:06.287	warn	javascript.0 (806) at Object.next (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:14:53)
                                        18:56:06.287	warn	javascript.0 (806) at fulfilled (script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5:5:58)
                                        18:56:06.287	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Berry_Driver.currentVersion, state={"val":"4","ack":true,"ts":1668707766287,"q":0,"from":"system.adapter.javascript.0","lc":1668327325585,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:06.364	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Display.BerryDriver, obj={"type":"channel","common":{"role":"info","name":"Berry Driver"},"native":{}})
                                        18:56:22.397	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.Time, state={"val":"2022-11-17T18:56:22","ack":true,"ts":1668707782397,"q":0,"from":"system.adapter.javascript.0","lc":1668707782397,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:22.406	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.TempUnit, state={"val":"°C","ack":true,"ts":1668707782406,"q":0,"from":"system.adapter.javascript.0","lc":1668327395067,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:22.415	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.ANALOG.Temperature, state={"val":28.7,"ack":true,"ts":1668707782415,"q":0,"from":"system.adapter.javascript.0","lc":1668707782415,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:22.424	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=0_userdata.0.NSPanel.Paps.Sensor.ESP32.Temperature, state={"val":40,"ack":true,"ts":1668707782424,"q":0,"from":"system.adapter.javascript.0","lc":1668707782424,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:22.437	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Sensor.ANALOG.Temperature, obj={"type":"channel","common":{"role":"info","name":""},"native":{}})
                                        18:56:22.438	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setObject(id=alias.0.NSPanel.Paps.Sensor.ESP32.Temperature, obj={"type":"channel","common":{"role":"info","name":""},"native":{}})
                                        18:56:26.024	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"pageType~screensaver","ack":false,"ts":1668707786023,"q":0,"from":"system.adapter.javascript.0","lc":1668707786023,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:26.025	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: adapterUnsubscribe(id=[object Object])
                                        18:56:26.026	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: adapterUnsubscribe(id=[object Object])
                                        18:56:26.028	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Wetter.Gerät_1.ICON, timerId=undefined) => {"val":"7","ack":true,"ts":1668704678761,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678761}
                                        18:56:26.029	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=alias.0.Wetter.Gerät_1.TEMP, timerId=undefined) => {"val":7.4,"ack":true,"ts":1668707775192,"q":0,"from":"system.adapter.shelly.1","user":"system.user.admin","lc":1668707775192}
                                        18:56:26.030	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Hourly.h0.PrecipitationProbability, timerId=undefined) => {"val":11,"ack":true,"ts":1668704677777,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668683082200}
                                        18:56:26.030	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.WindSpeed, timerId=undefined) => {"val":3.7,"ack":true,"ts":1668704678763,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678763}
                                        18:56:26.030	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3, timerId=undefined) => {"val":6.4,"ack":true,"ts":1668706145132,"q":0,"from":"system.adapter.shelly.1","user":"system.user.admin","lc":1668706145132}
                                        18:56:26.031	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.RelativeHumidity, timerId=undefined) => {"val":93,"ack":true,"ts":1668704678762,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678762}
                                        18:56:26.031	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Hourly.h0.PrecipitationProbability, timerId=undefined) => {"val":11,"ack":true,"ts":1668704677777,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668683082200}
                                        18:56:26.031	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.WindSpeed, timerId=undefined) => {"val":3.7,"ack":true,"ts":1668704678763,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678763}
                                        18:56:26.032	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.WindSpeed, timerId=undefined) => {"val":3.7,"ack":true,"ts":1668704678763,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678763}
                                        18:56:26.032	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=shelly.1.SHSW-1#E098068D8BFC#1.ext.temperatureC3, timerId=undefined) => {"val":6.4,"ack":true,"ts":1668706145132,"q":0,"from":"system.adapter.shelly.1","user":"system.user.admin","lc":1668706145132}
                                        18:56:26.032	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=accuweather.0.Current.RelativeHumidity, timerId=undefined) => {"val":93,"ack":true,"ts":1668704678762,"q":0,"from":"system.adapter.accuweather.0","user":"system.user.admin","lc":1668704678762}
                                        18:56:26.033	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.stat.NS-Panel-Paps_0BED20.POWER1, timerId=undefined) => {"val":"OFF","ack":true,"ts":1668693148871,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668693148871}
                                        18:56:26.033	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: getState(id=mqtt.0.stat.NS-Panel-Paps_0BED20.POWER2, timerId=undefined) => {"val":"OFF","ack":true,"ts":1668693152067,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1668693152067}
                                        18:56:26.034	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"color~0~65535~65535~65535~19017~65535~65535~65535~65535~65535~34351~26095~42639~64750~65535~65535~65535~65535~65535~65535~65535~65535","ack":false,"ts":1668707786034,"q":0,"from":"system.adapter.javascript.0","lc":1668707786034,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:26.034	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"weatherUpdate~~7.4 °C~Regen~~11 %~Wind~~3.7 km/h~Pool~艹~6.4 °C~Luft~~93 %~~~~17299~~17299~","ack":false,"ts":1668707786034,"q":0,"from":"system.adapter.javascript.0","lc":1668707786034,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:26.035	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: setForeignState(id=mqtt.0.cmnd.NS-Panel-Paps_0BED20.CustomSend, state={"val":"color~0~65535~65535~65535~19017~65535~65535~65535~65535~65535~34351~26095~42639~64750~65535~65535~65535~65535~65535~65535~65535~65535","ack":false,"ts":1668707786035,"q":0,"from":"system.adapter.javascript.0","lc":1668707786035,"c":"script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5"})
                                        18:56:26.667	info	javascript.0 (806) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                                        18:56:26.726	info	javascript.1 (821) Stop script script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5
                                        18:56:26.903	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: compiling TypeScript source...
                                        18:56:27.906	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: source code did not change, using cached compilation result...
                                        18:56:27.972	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: Wetter-Alias existiert bereits
                                        18:56:28.014	info	javascript.0 (806) script.js.Papa-Garagen.NS-Panel-Paps-3_5_0_5: registered 13 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        • Armilar
                                          @wuschl
                                          Auf was steht der Datenpunkt?:
                                          0_userdata.0.NSPanel.1.NSPanel_autoUpdate
                                          Und zeige mal kurz die Datenpunkte wie in der Abb.
                                          Die Warnung dürfte in der mit den Updates laufen...
                                            Wuschl @Armilar last edited by Wuschl
                                            @armilar wo finde ich den Datenpunkt?
                                            Armilar 2 Replies Last reply Reply Quote 0
                                            lovelace ui nspanel sonoff
                                            271
                                            7747
                                            6671987
