    3. Marktplatz
    4. [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P
    • qqolli
      qqolli @dimaiv last edited by qqolli
      @dimaiv
      Ok, sorry:
      zigbee.0
      2022-07-23 16:41:49.738	error	Error herdsman start
      zigbee.0
      2022-07-23 16:41:49.738	error	Failed to start Zigbee
      zigbee.0
      2022-07-23 16:41:49.737	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      zigbee.0
      2022-07-23 16:41:49.736	error	Re-commissioning your network will require re-pairing of all devices!
      zigbee.0
      2022-07-23 16:41:49.736	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      zigbee.0
      2022-07-23 16:41:49.736	error	Please update configuration to prevent further issues.
      zigbee.0
      2022-07-23 16:41:49.736	error	- Channel List: configured=11, adapter=11
      zigbee.0
      2022-07-23 16:41:49.736	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      zigbee.0
      2022-07-23 16:41:49.736	error	- Extended PAN ID: configured=4d1517db8593869a, adapter=00124b00257910df
      zigbee.0
      2022-07-23 16:41:49.735	error	- PAN ID: configured=6745, adapter=6754
      zigbee.0
      2022-07-23 16:41:49.735	error	Configuration is not consistent with adapter state/backup!
      zigbee.0
      2022-07-23 16:41:48.537	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      2022-07-23 16:41:48.535	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-07-23 16:41:48.535	info	Starting Zigbee npm ...
      zigbee.0
      2022-07-23 16:41:48.534	info	Try to reconnect.
      Wie gesagt, Hatte die erweiterte Pan ID und Pan ID geändert, Transportschlüssel erstmal so gelassen. Jetzt meckert er deswegen 🙂
      Edit: Oder soll ich mal, wie weiter oben empfohlen die unter /opt/iobroker/iobroker-data/zigbee_0 die vorhandenen Dateien (shepherd.db, nvbackup.json) löschen und Adapter neu starten?
      Dominik F. D 3 Replies Last reply Reply Quote 0
      • Dominik F.
        Dominik F. @qqolli last edited by Dominik F.
        @qqolli
        Trag mal das als erweiterte Pan-ID ein:00124b00257910df
        und das als Pan-ID: 6754
          dimaiv @qqolli last edited by
          @qqolli
          1. Stoppen Zigbee Adapter!!!
          2. Mach das was im Log steht "If you wish to...."
          3. Starte Zigbee Gateway neu.
          4. Starte Zigbee Adapter.
          qqolli 1 Reply Last reply Reply Quote 1
          • Dominik F.
            @qqolli
            Ich hatte auch folgende Unterschiede gehabt und hab das die genommen, die der Adapter hatte und dann hat es funktioniert:
            zigbee.0
            zigbee.0
            • qqolli
              @dimaiv
              Na super! Jetzt geht er. Und die Werte von @Dominik-F hatte ich auch noch eingetragen:
              Vielen Dank!
              • BananaJoe
                BananaJoe Most Active last edited by
                @qqolli eines von beiden hätte es getan 🙂 Aber so ist auch ok
                qqolli 1 Reply Last reply Reply Quote 0
                • qqolli
                  qqolli @BananaJoe last edited by
                  @bananajoe
                  Stimmt, aber du weißt ja: Viel hilft viel 😀
                  Jetzt graut es mir nur noch vor der Umstellung, da ich mein Produktivsystem immer noch auf Raspi mit ConBee 2 laufen habe. ioB auf Proxmox mit dem Gateway läuft super und die Umstellung wird interessant 🙂 Obwohl es eigentlich per BackitUp "einfach" gehen müsste; soweit die Theorie.
                    michihorn @dimaiv last edited by michihorn
                    @dimaiv Danke für die super schnelle Lieferung.
                    Installation war einfach, klappte auf Anhieb, dass Übertragen der Daten dauert zuerst ein paar Minuten.
                    Der Leistungsgewinn ist überragend.
                    Habe den Stick im übrigen im Ferienhaus installiert, das ist über VPN mit der Heimat verbunden ist. Ich habe eine zusätzliche Zigbee Instance aufgelegt. So entfällt die MQTT Übertragung. 👍
                      Rushmed Most Active last edited by Rushmed
                      @dimaiv Danke für die schnelle Lieferung. Stick läuft. Danke auch für die Anleitung.
                      Das Ding hat ja sogar WiFi.
                        Tobias 0 last edited by Tobias 0
                        @dimaiv Danke für die schnelle Lieferung und die Erklärung vorab per telegram. Es war schon fast zu einfach. Anstecken, IP-Eintragen und warten bis der Adapter Grün wurde. Alle geräte blieben erhalten beim Wechsel und die angezeigte Leistung hat sich beim schwächsten Empfänger um 50 verbessert. Also was soll man sagen einfach perfekt! 👍
                          liv-in-sky @dimaiv last edited by
                          @dimaiv
                          erstmal vielen dank für die schnelle lieferung 🙂
                          ich wollte das ganze nun mit zigbee2mqtt installieren
                          meine configuration.yaml sieht so aus:
                          homeassistant: false
                          permit_join: true
                          frontend:
                             port: 8080
                             host: 0.0.0.0
                          mqtt:
                             base_topic: zigbee2mqtt
                             server: mqtt://192.168.178.59:1890
                          serial:
                             port: 'tcp://192.168.178.141:6638'
                          advanced:
                             pan_id: 0x1A79
                             ext_pan_id: [0xDD, 0xDD, 0xDD, 0xDD, 0xAA, 0xAD, 0xDD, 0xDD]
                             channel: 14
                             network_key: [0x01, 0x03, 0x05, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A>
                             last_seen: ISO_8601_local
                             homeassistant_legacy_entity_attributes: false
                             legacy_api: false
                             legacy_availability_payload: false
                             output: json
                             transmit_power: 20
                             log_level: warn
                          device_options:
                             legacy: false
                          availability: true
                          beim aufruf des servers kommt aber:
                          $ npm start
                          > zigbee2mqtt@1.28.2 start
                          > node index.js
                          Zigbee2MQTT:info  2022-11-20 08:33:09: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-11-20.08-33-09' filename: log.txt
                          Zigbee2MQTT:info  2022-11-20 08:33:09: Starting Zigbee2MQTT version 1.28.2 (commit #e66fe85)
                          Zigbee2MQTT:info  2022-11-20 08:33:09: Starting zigbee-herdsman (0.14.68)
                          Zigbee2MQTT:error 2022-11-20 08:33:09: Error while starting zigbee-herdsman
                          Zigbee2MQTT:error 2022-11-20 08:33:09: Failed to start zigbee
                          Zigbee2MQTT:error 2022-11-20 08:33:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
                          Zigbee2MQTT:error 2022-11-20 08:33:09: Exiting...
                          Zigbee2MQTT:error 2022-11-20 08:33:09: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
                              at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
                              at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
                              at /opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
                          irgendwie will er /dev/ttyACM0 - ist aber anders konfiguriert - hättest du eine idee für mich
                          crunchip D 2 Replies Last reply Reply Quote 0
                            crunchip Forum Testing Most Active @liv-in-sky last edited by
                            @liv-in-sky hast du z2m auch neu gestartet?
                              liv-in-sky @crunchip last edited by
                              @crunchip ja - habe ich
                                @liv-in-sky sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                                bei mir ist das so eingetragen, vllt liegts daran
                                serial:
                                  port: tcp://10.1.20.7:20108
                                  @crunchip habe es lt: https://forum.iobroker.net/post/693392 gemacht
                                  aber habe auch mal deines getestet - kommt leider die selbe fehlermeldung
                                    crunchip Forum Testing Most Active @liv-in-sky last edited by crunchip
                                    @liv-in-sky na ich meine ohne die ' '
                                    stick ist erreichbar?
                                      @crunchip ohne und mit probiert - mit habe probiert, weil hier:
                                      aber ich denke da fehlt was anderes, weil im fehler immer auf den cannot open /dev/ttyACM0 hingewiesen wird
                                        @crunchip sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                                        wie stell ich das fest - weiß nur er ist im netzwerk mit ip
                                          @crunchip
                                          könnte es ein problem sein, weil proxmox lxc ??
                                            @liv-in-sky vllt passt der port nicht
                                            weil proxmox lxc
                                            hab ich auch
                                            hab von hier installiert
                                            236
                                            52647
