    4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
      A Former User @Malz1902 last edited by A Former User
      @malz1902 hm okay komisch. Werde es heut Abend selbst mal testen. Eigentlich ist es aber nicht mehr möglich da es intern eine eigene Liste ist. 🙈
      //EDIT: @Malz1902 habs mir mal angeguckt. Könntest du mal die Github Version testen. Nun müsste es definitiv korrekt funktionieren. 🙂
      M Axel Koeneke 3 Replies Last reply Reply Quote 0
        Malz1902 @Guest last edited by
        @ciddi89 alles klar teste ich 🙂 Danke
          @ciddi89 said in Test Adapter Device-Watcher v1.x.x GitHub/Latest:
          Scheint zu klappen, vielen Dank 🙂
          • Axel Koeneke
            Axel Koeneke @Guest last edited by
            @ciddi89 Hallo Ciddi,
            habe jetzt erst bemerkt, dass die RPC's nicht aufgelistet werden:
            Links aus dem bekannten Skript - rechts aus Device-Watcher
            Bei den Datenpunkten wird zwar die Anzahl erkannt, aber die Tabelle wird nicht komplett aufgefüllt.
            [{"Device":"Base Station","Adapter":"Ham","Battery":"100%","Status":"Online"},{"Device":"EG Bewegungsmelder WZ","Adapter":"Ham","Battery":"100%","Status":"Online"},{"Device":"Fensterkontakt","Adapter":"Ham","Battery":"100%","Status":"Online"},{"Device":"KG Fitness","Adapter":"Ham","Battery":"100%","Status":"Online"},{"Device":"Keypad","Adapter":"Ham","Battery":"100%","Status":"Online"},{"Device":"Schalt-Mess-Steckdose","Adapter":"Homematic IP","Battery":"low","Status":"Online"},{"Device":"HOME_CONTROL_ACCESS_POINT","Adapter":"Homematic IP","Battery":"low","Status":"Online"},{"Device":"roborock.vacuum.s5","Adapter":"MiHome Vacuum","Battery":"100%","Status":"Online"},{"Device":"Fibargroup FGMS001","Adapter":"Z-wave 2","Battery":"low","Status":"Online"},{"Device":"AEON Labs ZW100 Badezimmer","Adapter":"Z-wave 2","Battery":"100%","Status":"Online"},{"Device":"Fibargroup FGMS001","Adapter":"Z-wave 2","Battery":"low","Status":"Offline"},{"Device":"AEON Labs ZW100 Gartenhaus","Adapter":"Z-wave 2","Battery":"100%","Status":"Online"},{"Device":"Popp & Co 004001 Garage Rauchmelder","Adapter":"Z-wave 2","Battery":"100%","Status":"Online"}]
            Liegt das evtl. daran das bei mir die RPC-Instanz die ".2" ist?
            VG
            Axel
              A Former User @Axel Koeneke last edited by
              @axel-koeneke Ääähm ja das ist merkwürdig. Die Instanz Nummer ist egal. Adapter Version ist aktuell?
              Das komische ist, die Anzahl basiert auf den Listen. Also theoretisch müssten die da drin stehen. Was für Geräte sind es speziell? Ältere Homematic Geräte?
              Axel Koeneke 1 Reply Last reply Reply Quote 0
              • Axel Koeneke
                Axel Koeneke @Guest last edited by Axel Koeneke
                @ciddi89 Moin, es sind alles Homematic-IP Geräte an einer Rasberrymatic, also ohne cloud.
                Ist halt seltsam das sie gezäklt werden, aber nicht in die Tabelle eingetragen werden. Weder in JSON noch in HTML Format.
                VG
                Axel
                Habe das noch im LOG:
                device-watcher.0
                2022-11-18 09:35:40.659	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
                device-watcher.0
                2022-11-18 09:35:37.397	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
                  @axel-koeneke okay, kannst du im Objektbaum bei einem Hauptordner eines Gerätes auf das Stift Symbol klicken und mir die JSON mal zeigen? Es müsste dort der Name definiert sein für das Gerät
                  • Axel Koeneke
                    @ciddi89 Meinst du das hier:
                      "_id": "hm-rpc.2.000E9A498E8046",
                      "type": "device",
                      "common": {
                        "name": "Hz-Regler-Bad",
                        "icon": "/icons/147_hmip-sthd_thumb.png"
                      "native": {
                        "TYPE": "HmIP-STHD",
                        "SUBTYPE": "STHD",
                        "ADDRESS": "000E9A498E8046",
                        "RF_ADDRESS": 3773934,
                        "CHILDREN": [
                          "000E9A498E8046:0",
                          "000E9A498E8046:1",
                          "000E9A498E8046:2",
                          "000E9A498E8046:3",
                          "000E9A498E8046:4",
                          "000E9A498E8046:5",
                          "000E9A498E8046:6",
                          "000E9A498E8046:7"
                        "PARENT": "",
                        "PARENT_TYPE": "",
                        "INDEX": 0,
                        "AES_ACTIVE": 1,
                        "PARAMSETS": [
                          "MASTER",
                          "SERVICE"
                        "FIRMWARE": "2.8.2",
                        "AVAILABLE_FIRMWARE": "2.8.2",
                        "UPDATABLE": true,
                        "FIRMWARE_UPDATE_STATE": "UP_TO_DATE",
                        "VERSION": 5,
                        "FLAGS": 1,
                        "LINK_SOURCE_ROLES": "",
                        "LINK_TARGET_ROLES": "",
                        "DIRECTION": 0,
                        "GROUP": "",
                        "TEAM": "",
                        "TEAM_TAG": "",
                        "TEAM_CHANNELS": [],
                        "INTERFACE": "",
                        "ROAMING": 0,
                        "RX_MODE": 3
                      "from": "system.adapter.hm-rega.0",
                      "user": "system.user.admin",
                      "ts": 1662625014918,
                      "acl": {
                        "object": 1636,
                        "owner": "system.user.admin",
                      @axel-koeneke ja okay, ich denke das problem liegt woanders. Das kannst du aber testen indem du alle adapter deaktiviert im device-watcher deaktivierst und nur hm-rpc aktivierst.
                      Du hast mir aber noch nicht gesagt welche Version du nutzt?
                      Sagt das log noch etwas anderes?
                      Vielleicht kannst du, wenn du Zeit hast, mal alle ausgewählten Adapter deaktivieren im device-watcher und dann jeden Adapter für sich aktivieren. Kann leider so mit dem Fehler nichts anfangen und daher müssen wir mal suchen welches Gerät da Probleme macht. Wenn du bei Github angemeldet bist, wäre es cool da ein Issue aufzumachen damit wir das Problem dort bearbeiten, um hier nicht den Rahmen zu sprengen. Aber nur wenn du da angemeldet bist.
                      da_Woody Axel Koeneke 2 Replies Last reply Reply Quote 0
                      • da_Woody
                        da_Woody @Guest last edited by
                        @ciddi89 sagte in Test Adapter Device-Watcher v1.x.x GitHub/Latest:
                        das sollte da kleinste prob sein... 😉
                        interessante geschichte ist das...
                          A Former User @da_Woody last edited by
                          @da_woody naja möchte niemanden dazu drängen. Hält die Sache aber übersichtlicher
                          da_Woody 1 Reply Last reply Reply Quote 1
                          • da_Woody
                            @ciddi89 klar, aber wenn man mit neuen adaptern rumprobieren will, hat's sinn. 😉 auch wegen issues.
                              @da_woody das stimmt.
                              Naja mal bisschen zum Fehler:
                              diesen Fehler mit localcompare gibt es schon ewig. Betrifft aber nur 1-2 User. Ich denke da liegt irgendwo eine Geräte Leiche rum oder so. Leider haben sich diese User noch nie bei mir gemeldet geschweige denn den Adapter mal aktualisiert. Die krebsen alle noch bei 0.3 rum usw. Ich sehe es nur in sentry kann aber nicht genau ausmachen was den Fehler produziert. Und diese 1-2 User spamen mit diesen Fehler auch extrem das sentry voll so das das Kontingent immer schnell ausgeschöpft ist. Ich hoffe ich kann nun mit Hilfe von dem Axel mal heraus finden warum und eine korrekte Behandlung mit einbauen damit das nicht mehr vorkommt.
                              • Axel Koeneke
                                @ciddi89 Moin, sorry habe die Version 2.0.2
                                Leider bin ich im Github nicht so bewandert...
                                Folgendes habe ich probiert und festgestellt:
                                Alle anderen Abfragen funktionieren fehlerfrei, außer HM-RPC. Habe jetzt LOG auf DEBUG gestellt:
                                device-watcher.0
                                2022-11-19 09:51:25.841	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
                                device-watcher.0
                                2022-11-19 09:51:25.788	debug	Start the function: writeDatapoints
                                device-watcher.0
                                2022-11-19 09:51:25.323	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                device-watcher.0
                                2022-11-19 09:51:25.259	debug	Function finished: resetVars
                                device-watcher.0
                                2022-11-19 09:51:25.259	debug	Function started: resetVars
                                device-watcher.0
                                2022-11-19 09:51:25.258	debug	Function started: createDataOfAllAdapter
                                device-watcher.0
                                2022-11-19 09:51:25.258	debug	Created and filled data for Hmrpc
                                device-watcher.0
                                2022-11-19 09:51:25.257	debug	Function finished: createDataForEachAdapter
                                device-watcher.0
                                2022-11-19 09:51:25.257	debug	Function finished: writeDatapoints
                                device-watcher.0
                                2022-11-19 09:51:25.223	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
                                device-watcher.0
                                2022-11-19 09:51:25.033	debug	Start the function: writeDatapoints
                                device-watcher.0
                                2022-11-19 09:51:24.578	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                device-watcher.0
                                2022-11-19 09:51:24.569	debug	Function finished: resetVars
                                device-watcher.0
                                2022-11-19 09:51:24.569	debug	Function started: resetVars
                                device-watcher.0
                                2022-11-19 09:51:24.568	debug	Function started: createDataForEachAdapter
                                device-watcher.0
                                2022-11-19 09:51:24.567	debug	Function started: main
                                device-watcher.0
                                2022-11-19 09:51:24.560	debug	Created datapoints for Hmrpc
                                device-watcher.0
                                2022-11-19 09:51:24.479	debug	Function finished: createBlacklist
                                device-watcher.0
                                2022-11-19 09:51:24.478	debug	Function started: createBlacklist
                                device-watcher.0
                                2022-11-19 09:51:24.476	info	Number of selected adapters: 1. Loading data from: Hmrpc ...
                                device-watcher.0
                                2022-11-19 09:51:24.475	debug	[{"Selektor":"hm-rpc.*.UNREACH","adapterID":"hmrpc","adapter":"Homematic RPC","rssiState":".RSSI_DEVICE","rssiPeerState":".RSSI_PEER","battery":".OPERATING_VOLTAGE","reach":".UNREACH","isLowBat":".LOW_BAT","isLowBat2":".LOWBAT","stateValue":".1.STATE"}]
                                device-watcher.0
                                2022-11-19 09:51:24.471	debug	Adapter device-watcher was started
                                device-watcher.0
                                2022-11-19 09:51:24.430	info	starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v16.15.1, js-controller: 4.0.23
                                device-watcher.0
                                2022-11-19 09:51:23.671	debug	Plugin sentry Initialize Plugin (enabled=true)
                                Zeile 63 sieht für mich interessant aus:
                                "Selektor":"hm-rpc.*.UNREACH"........
                                Datenpunkt:
                                hm-rpc.2.000E9A498DFC2D.0.UNREACH
                                Kann es sein das hier zwei Platzhalter fehlen?
                                Also wenn der erste für die Instanz ist, dann müssten doch noch die Geräte ID und dann der Kanal kommen. und anschließend die Abfrage (UNREACH).
                                VG
                                Axel
                                ? 2 Replies Last reply Reply Quote 0
                                  A Former User @Axel Koeneke last edited by A Former User
                                  @axel-koeneke danke für deine Informationen. Werde nachher mal versuchen das zu reproduzieren. Irgendwie… 😰
                                  Kannst du mir evtl noch ein screenshot von allen Datenpunkte senden von einem gerät? Die json vom datenpunkt unreach wäre auch ganz gut.
                                  Nee an den Selektor liegt das nicht. Das ist schon richtig so. Ausser du hast pro gerät zweimal den Datenpunkt unreach. Dann könnte es vielleicht ein bisschen durcheinander kommen. Hast du nur eine Instanz von hm-rpc oder mehrere?
                                  //EDIT: Ich glaube ich konnte es etwas eingrenzen. Lässt du dir auch die HTML listen erstellen?
                                    @axel-koeneke ok ich denke ich habe den Fehler gefunden und habe ein Fix eingebaut. Kannst du dann bitte mal die GitHub Version testen? Aber ich denke du wirst Irgendwo im HM-RPC Adapter ein Gerät haben wo er den Namen nicht korrekt ausgibt oder eine Datenleiche versteckt ist. Vielleicht kannst du mal schauen ob da irgendwo was auffälliges zu sehen ist.
                                    • da_Woody
                                      möglicherweise sonderzeichen, oder sowas?
                                        @da_woody Sonderzeichen kann natürlich auch sein. Wollte mal ein Filter dafür einbauen, denke mittlerweile wird es Zeit dafür 🫣 ich vergesse immer das nicht alle wissen das es nicht gesund ist bestimmte Zeichensätze in Namen zu setzen 🙇
                                        da_Woody Axel Koeneke Scrounger 3 Replies Last reply Reply Quote 0
                                        • da_Woody
                                          • Axel Koeneke
                                            @ciddi89 Huhu, was auch immer du gemacht hast, es hat funtioniert ! 🙂
                                            Super !!!
                                            VG
                                            Axel
                                            1464
                                            503786
