    4. Fehlermeldungen bei Installation mac
    • BuZZy
      BuZZy last edited by
      Versuch eine Ebene höher zu wechseln "cd .." dann wieder rein in das Verzeichnis mit "cd iobroker"
      Dann nochmal die Installation versuchen (eventuell mit sudo)?
      Wie oben gesagt:
      Der Eintrag "error retrieving current directory: getcwd: cannot access parent directories: No such file or directory"
      sagt eigentlich dass das Script nicht weiß wo es gerade ist..
      Also raus aus dem Ordner und nochmal rein im gleichen Terminalfenster und dann nochmal die Installation versuchen.
        thoduh last edited by
        Leider auch nicht:
        MacMini-LAN:ioBroker MacMini$ cd ..
        MacMini-LAN:Documents MacMini$ cd iobroker
        MacMini-LAN:iobroker MacMini$ sudo npm install iobroker --unsafe-perm
        Password:
        > iobroker@1.0.0 install /Users/MacMini/Documents/ioBroker/node_modules/iobroker
        > node lib/setup.js
        npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/ioBroker
        node-pre-gyp info it worked if it ends with ok
        node-pre-gyp verb cli [ '/usr/local/bin/node',
        node-pre-gyp verb cli   '/Users/MacMini/Documents/ioBroker/node_modules/serialport/node_modules/.bin/node-pre-gyp',
        node-pre-gyp verb cli   'install',
        node-pre-gyp verb cli   '--fallback-to-build' ]
        node-pre-gyp info using node-pre-gyp@0.6.32
        node-pre-gyp info using node@8.2.1 | darwin | x64
        node-pre-gyp verb command install []
        node-pre-gyp info check checked for "/Users/MacMini/Documents/ioBroker/node_modules/serialport/build/Release/serialport.node" (not found)
        node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.2.1 (node-v57 ABI) (falling back to source compile with node-gyp)
        node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp verb command build [ 'rebuild' ]
        ../src/serialport.cpp:90:44: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          return getValueFromObject(options, key)->ToInt32()->Int32Value();
        /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9336:21: note: 'ToInt32' has been explicitly marked deprecated here
        Local <int32>Value::ToInt32() const {
        ../src/serialport.cpp:102:44: warning: 'ToNumber' is deprecated [-Wdeprecated-declarations]
          return getValueFromObject(options, key)->ToNumber()->NumberValue();
        /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9300:22: note: 'ToNumber' has been explicitly marked deprecated here
        Local <number>Value::ToNumber() const {
        ../src/serialport.cpp:174:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
            int fd = argv[1]->ToInt32()->Int32Value();
        ../src/serialport.cpp:193:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          int fd = info[0]->ToInt32()->Int32Value();
        ../src/serialport.cpp:217:108: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        ../src/serialport.cpp:252:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:369:24: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          baton->fd = info[0]->ToInt32()->Int32Value();
        ../src/serialport.cpp:480:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:528:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:585:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        10 warnings generated.
        ../src/serialport_unix.cpp:44:101: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        ../src/serialport_unix.cpp:45:103: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        2 warnings generated.
        ../src/serialport_poller.cpp:86:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          obj->fd_ = info[0]->ToInt32()->Int32Value();
        1 warning generated.
        node-pre-gyp info ok
        npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBroker
        npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBroker
        npm ERR! code ENOSELF
        npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
        npm ERR! also called "iobroker.js-controller". Did you name your project the same
        npm ERR! as the dependency you're installing?
        npm ERR!
        npm ERR! For more information, see:
        npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-25T17_31_42_595Z-debug.log
        Cannot install as normal user. Try sudo...
        sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBroker
        npm ERR!
        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-25T17_31_45_952Z-debug.log
        Could not find "/Users/MacMini/Documents/ioBroker/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
        Write "./iobroker start" to start the ioBroker
        Cannot set permissions of /Users/MacMini/Documents/ioBroker/node_modules/iobroker.js-controller/iobroker
        You can still manually copy
        Cannot create file /usr/bin/iobroker!. Non critical
        You can manually copy file into /usr/bin/. Just write:
            sudo cp /Users/MacMini/Documents/ioBroker/node_modules/iobroker/install/iobroker /usr/bin/
            sudo chmod 777 /usr/bin/iobroker
        + iobroker@1.0.0
        added 46 packages and removed 167 packages in 92.075s
        MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controller
        -bash: cd: node_modules/iobroker.js-controller: No such file or directory
        MacMini-LAN:iobroker MacMini$</https:></https:></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
        • BuZZy
          Okay, ändere mal den Ordnernamen "/Users/MacMini/Documents/ioBroker/" in "/Users/MacMini/Documents/ioBrokermac/" also den ioBroker ordner in ioBrokermac umbennen.
          Dann die installation nochmal versuchen. Gibts wieder einen Fehler?
          Dann:
          Existiert der Ordner iobroker.js-controller in dem neu umbenannten ioBrokermac Ordner?
          Wenn ja, diesen auch umbenennen in iobrokermac.js-controller, dann in diesen Ordner reinwechseln und dort "sudo npm install iobroker.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac"
          oder eventuell
          "sudo npm install iobrokermac.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac"
          oder eventuell
          "sudo npm install iobroker.js-controller --production"
          oder eventuell
          "sudo npm install iobrokermac.js-controller --production" ... 😄 Versuch macht kluch.. Oder wie heißt es so schön? 😄
            Es kann sich hier auch um Zugriffsrechte handeln.
            Bei der ioBroker Installation auf Linux muss der Ordner iobroker ALLE Rechte (777) haben.
            Rainer
            • BuZZy
              Momentan sehe ich keine Probleme außer
              ` > npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
              npm ERR! as the dependency you're installing? `
              npm macht manchmal Probleme wenn der Ordnername der gleiche ist wie der von dem Paket welches installiert werden soll. Deswegen bitte nochmal meine Tipps von http://forum.iobroker.net/viewtopic.php?f=17&t=7343#p76997 ausprobieren und dann nochmal hier berichten wie es aussieht - wobei es natürlich nie schadet die Rechte auf 777 zu setzen. 😄
                Erst mal Danke für deine Bemühungen 😉
                Ordner umbenannt in iobrokermac, installation mit sudo npm install iobroker –unsafe-perm
                MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker --unsafe-perm
                Password:
                > iobroker@1.0.0 install /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker
                > node lib/setup.js
                npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/ioBrokermac
                node-pre-gyp verb cli   '/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/node_modules/.bin/node-pre-gyp',
                node-pre-gyp info check checked for "/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/build/Release/serialport.node" (not found)
                npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBrokermac
                npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                npm ERR!
                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_40_371Z-debug.log
                sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                npm ERR!
                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_42_345Z-debug.log
                Could not find "/Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
                Cannot set permissions of /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker.js-controller/iobroker
                    sudo cp /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/install/iobroker /usr/bin/
                + iobroker@1.0.0
                removed 329 packages and updated 1 package in 86.429s
                MacMini-LAN:ioBrokermac MacMini$</https:></https:></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
                installation mit sudo npm install iobrokermac.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac
                MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobrokermac.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                npm ERR! code E404
                npm ERR! 404 Not Found: iobrokermac.js-controller@latest
                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_02_24_890Z-debug.log
                installation mit sudo npm install iobroker.js-controller –production
                MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker.js-controller --production
                npm ERR!
                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_03_43_461Z-debug.log
                npm ERR! code E404
                npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_05_40_972Z-debug.log
                • BuZZy
                  Dann benenne den Ordner iobroker.js-controller um in iobrokermac.js-controller dann in den Ordner iobrokermac.js-controller rein gehen
                  und versuchen zu installieren mit
                  sudo npm install iobroker.js-controller –production (ohne das Mac im Namen)
                  Welche Ausgabe bekommst du dann? Ich denke wir nähern uns bald dem Ziel.. Eine paar Ideen hätte ich noch wenn das auch nicht klappt. 😄
                  Von unterwegs gesendet
                    Also jetzt hast du mich abgehängt, den Ordner iobroker.js-controller gibt es doch eben gar nicht :?:
                    • BuZZy
                      Existiert der Ordner /Users/MacMini/Documents/ioBrokermac/node_modules/ ??
                      Eventuell befindet sich der Ordner node_modules auch in irgend einem von den übergeordneten Ordnern?
                        ja, den Ordner gibt es.
                        • BuZZy
                          und welche Ordner sind in diesem node_modules Ordner enthalten?
                            welches nodejs hast du eigentlich installiert?
                            Rainer
                              @BuZZy:
                              und welche Ordner sind in diesem node_modules Ordner enthalten? `
                              • BuZZy
                                https://github.com/ioBroker/ioBroker.js … master.zip runterladen, in den Ordner rein und dann in dem Ordner
                                  Die gezippte Datei in den nodes_modules Ordner?
                                  • BuZZy
                                    Die Zip Datei in den Ordner ioBrokermac dann rein in den Zip Ordner und da dann
                                      Wenn die Zipdatei angeklickt wird, öffnet sich der Download-Ordner…
                                      Last login: Wed Jul 26 18:33:21 on ttys001
                                      MacMini-LAN:~ MacMini$ cd /Users/MacMini/Downloads/ioBroker.js-controller-master\ 2
                                      MacMini-LAN:ioBroker.js-controller-master 2 MacMini$ npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                                      npm ERR!
                                      npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_16_46_223Z-debug.log
                                      MacMini-LAN:ioBroker.js-controller-master 2 MacMini$ sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                                      Password:
                                      npm ERR!
                                      npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_17_01_883Z-debug.log
                                      MacMini-LAN:ioBroker.js-controller-master 2 MacMini$</https:></https:>
                                      Der Inhalt des iobrokermac-Ordners entspricht doch dem Inhalt der Zipdatei :?:
                                      • BuZZy
                                        Bald raste ich aus.. 😄
                                        Nächster Versuch:
                                        npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
                                          @BuZZy:
                                          Bald raste ich aus.. 😄 `
                                          Frag mich mal 😉
                                          MacMini-LAN:~ MacMini$ cd /Users/MacMini/Documents/iobrokermac
                                          MacMini-LAN:iobrokermac MacMini$ sudo npm install https://github.com/ioBroker/ioBroker/tarball/master
                                          > iobroker@1.0.0 install /Users/MacMini/Documents/iobrokermac/node_modules/iobroker
                                          > node lib/setup.js
                                          npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
                                          npm ERR! path /Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs
                                          npm ERR! code EACCES
                                          npm ERR! errno -13
                                          npm ERR! syscall rmdir
                                          npm ERR! Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
                                          npm ERR!  { Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
                                          npm ERR!   cause:
                                          npm ERR!      errno: -13,
                                          npm ERR!      code: 'EACCES',
                                          npm ERR!      syscall: 'rmdir',
                                          npm ERR!      path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs' },
                                          npm ERR!   stack: 'Error: EACCES: permission denied, rmdir \'/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs\'',
                                          npm ERR!   path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs',
                                          npm ERR!   parent: 'iobroker.js-controller' }
                                          npm ERR!
                                          npm ERR! Please try running this command again as root/Administrator.
                                          npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_40_08_563Z-debug.log
                                          sudo npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
                                          • BuZZy
                                            Lösche den kompletten inhalt von dem ioBrokermac ordner.
                                            Dann versuch es mit````
                                            sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
                                            Dann nochmal den Log posten.
                                            EDIT: Hab gesehen du hast es schon mit sudo probiert..
                                            Gib dem Ordner ioBrokermac mal (nachdem du den Inhalt komplett gelöscht hast) die Rechte 777 - dann nochmal versuchen mit dem oben genannten Befehl!
                                            13534
