    4. Fehlermeldungen bei Installation mac
    • BuZZy
      BuZZy last edited by
      Momentan sehe ich keine Probleme außer
      ` > npm ERR! Refusing to install package with name "iobroker.js-controller" under a package
      npm ERR! also called "iobroker.js-controller". Did you name your project the same
      npm ERR! as the dependency you're installing? `
      npm macht manchmal Probleme wenn der Ordnername der gleiche ist wie der von dem Paket welches installiert werden soll. Deswegen bitte nochmal meine Tipps von http://forum.iobroker.net/viewtopic.php?f=17&t=7343#p76997 ausprobieren und dann nochmal hier berichten wie es aussieht - wobei es natürlich nie schadet die Rechte auf 777 zu setzen. 😄
        thoduh last edited by
        Erst mal Danke für deine Bemühungen 😉
        Ordner umbenannt in iobrokermac, installation mit sudo npm install iobroker –unsafe-perm
        MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker --unsafe-perm
        Password:
        > iobroker@1.0.0 install /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker
        > node lib/setup.js
        npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/ioBrokermac
        node-pre-gyp info it worked if it ends with ok
        node-pre-gyp verb cli [ '/usr/local/bin/node',
        node-pre-gyp verb cli   '/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/node_modules/.bin/node-pre-gyp',
        node-pre-gyp verb cli   'install',
        node-pre-gyp verb cli   '--fallback-to-build' ]
        node-pre-gyp info using node-pre-gyp@0.6.32
        node-pre-gyp info using node@8.2.1 | darwin | x64
        node-pre-gyp verb command install []
        node-pre-gyp info check checked for "/Users/MacMini/Documents/ioBrokermac/node_modules/serialport/build/Release/serialport.node" (not found)
        node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.2.1 (node-v57 ABI) (falling back to source compile with node-gyp)
        node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
        node-pre-gyp verb command build [ 'rebuild' ]
        ../src/serialport.cpp:90:44: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          return getValueFromObject(options, key)->ToInt32()->Int32Value();
        /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9336:21: note: 'ToInt32' has been explicitly marked deprecated here
        Local <int32>Value::ToInt32() const {
        ../src/serialport.cpp:102:44: warning: 'ToNumber' is deprecated [-Wdeprecated-declarations]
          return getValueFromObject(options, key)->ToNumber()->NumberValue();
        /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9300:22: note: 'ToNumber' has been explicitly marked deprecated here
        Local <number>Value::ToNumber() const {
        ../src/serialport.cpp:174:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
            int fd = argv[1]->ToInt32()->Int32Value();
        ../src/serialport.cpp:193:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          int fd = info[0]->ToInt32()->Int32Value();
        ../src/serialport.cpp:217:108: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        ../src/serialport.cpp:252:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:369:24: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          baton->fd = info[0]->ToInt32()->Int32Value();
        ../src/serialport.cpp:480:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:528:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp:585:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
        10 warnings generated.
        ../src/serialport_unix.cpp:44:101: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        ../src/serialport_unix.cpp:45:103: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
        2 warnings generated.
        ../src/serialport_poller.cpp:86:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
          obj->fd_ = info[0]->ToInt32()->Int32Value();
        1 warning generated.
        node-pre-gyp info ok
        npm install iobroker.admin --production --prefix /Users/MacMini/Documents/ioBrokermac
        npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
        npm ERR! code ENOSELF
        npm ERR!
        npm ERR! For more information, see:
        npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_40_371Z-debug.log
        Cannot install as normal user. Try sudo...
        sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
        npm ERR!
        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T13_59_42_345Z-debug.log
        Could not find "/Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/lib/../../iobroker.js-controller/conf/iobroker-dist.json". Possible iobroker.js-controller was not installed
        Write "./iobroker start" to start the ioBroker
        Cannot set permissions of /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker.js-controller/iobroker
        You can still manually copy
        Cannot create file /usr/bin/iobroker!. Non critical
        You can manually copy file into /usr/bin/. Just write:
            sudo cp /Users/MacMini/Documents/ioBrokermac/node_modules/iobroker/install/iobroker /usr/bin/
            sudo chmod 777 /usr/bin/iobroker
        + iobroker@1.0.0
        removed 329 packages and updated 1 package in 86.429s
        MacMini-LAN:ioBrokermac MacMini$</https:></https:></int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
        installation mit sudo npm install iobrokermac.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac
        MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobrokermac.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
        npm ERR! code E404
        npm ERR! 404 Not Found: iobrokermac.js-controller@latest
        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_02_24_890Z-debug.log
        installation mit sudo npm install iobroker.js-controller –production
        MacMini-LAN:ioBrokermac MacMini$ sudo npm install iobroker.js-controller --production
        npm ERR!
        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_03_43_461Z-debug.log
        npm ERR! code E404
        npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T14_05_40_972Z-debug.log
        • BuZZy
          Dann benenne den Ordner iobroker.js-controller um in iobrokermac.js-controller dann in den Ordner iobrokermac.js-controller rein gehen
          und versuchen zu installieren mit
          sudo npm install iobroker.js-controller –production (ohne das Mac im Namen)
          Welche Ausgabe bekommst du dann? Ich denke wir nähern uns bald dem Ziel.. Eine paar Ideen hätte ich noch wenn das auch nicht klappt. 😄
          Von unterwegs gesendet
            Also jetzt hast du mich abgehängt, den Ordner iobroker.js-controller gibt es doch eben gar nicht :?:
            • BuZZy
              Existiert der Ordner /Users/MacMini/Documents/ioBrokermac/node_modules/ ??
              Eventuell befindet sich der Ordner node_modules auch in irgend einem von den übergeordneten Ordnern?
                ja, den Ordner gibt es.
                • BuZZy
                  und welche Ordner sind in diesem node_modules Ordner enthalten?
                    welches nodejs hast du eigentlich installiert?
                    Rainer
                      @BuZZy:
                      und welche Ordner sind in diesem node_modules Ordner enthalten? `
                      • BuZZy
                        https://github.com/ioBroker/ioBroker.js … master.zip runterladen, in den Ordner rein und dann in dem Ordner
                        npm install iobroker.js-controller –production --prefix /Users/MacMini/Documents/ioBrokermac
                          Die gezippte Datei in den nodes_modules Ordner?
                          • BuZZy
                            Die Zip Datei in den Ordner ioBrokermac dann rein in den Zip Ordner und da dann
                              Wenn die Zipdatei angeklickt wird, öffnet sich der Download-Ordner…
                              Last login: Wed Jul 26 18:33:21 on ttys001
                              MacMini-LAN:~ MacMini$ cd /Users/MacMini/Downloads/ioBroker.js-controller-master\ 2
                              MacMini-LAN:ioBroker.js-controller-master 2 MacMini$ npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                              npm ERR!
                              npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_16_46_223Z-debug.log
                              MacMini-LAN:ioBroker.js-controller-master 2 MacMini$ sudo npm install iobroker.js-controller --production --prefix /Users/MacMini/Documents/ioBrokermac
                              Password:
                              npm ERR!
                              npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_17_01_883Z-debug.log
                              MacMini-LAN:ioBroker.js-controller-master 2 MacMini$</https:></https:>
                              Der Inhalt des iobrokermac-Ordners entspricht doch dem Inhalt der Zipdatei :?:
                              • BuZZy
                                Bald raste ich aus.. 😄
                                Nächster Versuch:
                                npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
                                  @BuZZy:
                                  Bald raste ich aus.. 😄 `
                                  Frag mich mal 😉
                                  MacMini-LAN:~ MacMini$ cd /Users/MacMini/Documents/iobrokermac
                                  MacMini-LAN:iobrokermac MacMini$ sudo npm install https://github.com/ioBroker/ioBroker/tarball/master
                                  > iobroker@1.0.0 install /Users/MacMini/Documents/iobrokermac/node_modules/iobroker
                                  > node lib/setup.js
                                  npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
                                  npm ERR! path /Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs
                                  npm ERR! code EACCES
                                  npm ERR! errno -13
                                  npm ERR! syscall rmdir
                                  npm ERR! Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
                                  npm ERR!  { Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
                                  npm ERR!   cause:
                                  npm ERR!      errno: -13,
                                  npm ERR!      code: 'EACCES',
                                  npm ERR!      syscall: 'rmdir',
                                  npm ERR!      path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs' },
                                  npm ERR!   stack: 'Error: EACCES: permission denied, rmdir \'/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs\'',
                                  npm ERR!   path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs',
                                  npm ERR!   parent: 'iobroker.js-controller' }
                                  npm ERR!
                                  npm ERR! Please try running this command again as root/Administrator.
                                  npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_40_08_563Z-debug.log
                                  sudo npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
                                  • BuZZy
                                    Lösche den kompletten inhalt von dem ioBrokermac ordner.
                                    Dann versuch es mit````
                                    sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
                                    Dann nochmal den Log posten.
                                    EDIT: Hab gesehen du hast es schon mit sudo probiert..
                                    Gib dem Ordner ioBrokermac mal (nachdem du den Inhalt komplett gelöscht hast) die Rechte 777 - dann nochmal versuchen mit dem oben genannten Befehl!
                                      Jetzt hats gekappt !!!
                                      Habe den iobroker-Ordner direkt auf Macintosh/ erstellt. per sudo npm install https://github.com/ioBroker/ioBroker/tarball/master –unsafe-perm installiert.
                                      Anschließend den Ordner an meinen gewünschten Platz verschoben und es läuft 😄 😄 😄 😄
                                      Vielen Dank für deine Hilfe !!!!
                                      Aber jetzt hab ich was anderes:
                                      Muss ich die Pfade noch anpassen ??
                                      Oder hätte ich es nicht verschieben dürfen ??
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:12:16.220 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:11:46.212 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:11:16.205 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:10:46.204 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:10:16.193 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:09:46.187 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:09:16.176 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:08:46.166 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:08:16.156 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:07:46.151 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
                                      iobroker 2017-07-26 20:07:29.113 info exit 1
                                      iobroker 2017-07-26 20:07:29.108 error at bootstrap_node.js:575:3
                                      iobroker 2017-07-26 20:07:29.108 error at startup (bootstrap_node.js:158:16)
                                      iobroker 2017-07-26 20:07:29.108 error at Function.Module.runMain (module.js:605:10)
                                      iobroker 2017-07-26 20:07:29.108 error at Function.Module._load (module.js:437:25)
                                      iobroker 2017-07-26 20:07:29.108 error at Function.Module._resolveFilename (module.js:485:15)
                                      iobroker 2017-07-26 20:07:29.108 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      iobroker 2017-07-26 20:07:29.108 error ^
                                      iobroker 2017-07-26 20:07:29.108 error module.js:487 throw err;
                                      iobroker 2017-07-26 20:07:28.844 info install hm-rega
                                      iobroker 2017-07-26 20:07:28.811 info exit 1
                                      iobroker 2017-07-26 20:07:28.807 error at bootstrap_node.js:575:3
                                      iobroker 2017-07-26 20:07:28.807 error at startup (bootstrap_node.js:158:16)
                                      iobroker 2017-07-26 20:07:28.807 error at Function.Module.runMain (module.js:605:10)
                                      iobroker 2017-07-26 20:07:28.807 error at Function.Module._load (module.js:437:25)
                                      iobroker 2017-07-26 20:07:28.807 error at Function.Module._resolveFilename (module.js:485:15)
                                      iobroker 2017-07-26 20:07:28.807 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      iobroker 2017-07-26 20:07:28.807 error ^
                                      iobroker 2017-07-26 20:07:28.807 error module.js:487 throw err;
                                      iobroker 2017-07-26 20:07:28.543 info install hm-rpc
                                      iobroker 2017-07-26 20:07:28.515 info exit 1
                                      iobroker 2017-07-26 20:07:28.511 error at bootstrap_node.js:575:3
                                      iobroker 2017-07-26 20:07:28.511 error at startup (bootstrap_node.js:158:16)
                                      iobroker 2017-07-26 20:07:28.511 error at Function.Module.runMain (module.js:605:10)
                                      iobroker 2017-07-26 20:07:28.511 error at Function.Module._load (module.js:437:25)
                                      iobroker 2017-07-26 20:07:28.511 error at Function.Module._resolveFilename (module.js:485:15)
                                      iobroker 2017-07-26 20:07:28.511 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      iobroker 2017-07-26 20:07:28.511 error ^
                                      iobroker 2017-07-26 20:07:28.511 error module.js:487 throw err;
                                      iobroker 2017-07-26 20:07:28.245 info install hm-rpc
                                      iobroker 2017-07-26 20:07:28.230 info exit 1
                                      iobroker 2017-07-26 20:07:28.226 error at bootstrap_node.js:575:3
                                      iobroker 2017-07-26 20:07:28.226 error at startup (bootstrap_node.js:158:16)
                                      iobroker 2017-07-26 20:07:28.226 error at Function.Module.runMain (module.js:605:10)
                                      iobroker 2017-07-26 20:07:28.226 error at Function.Module._load (module.js:437:25)
                                      iobroker 2017-07-26 20:07:28.226 error at Function.Module._resolveFilename (module.js:485:15)
                                      iobroker 2017-07-26 20:07:28.226 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      iobroker 2017-07-26 20:07:28.226 error ^
                                      iobroker 2017-07-26 20:07:28.226 error module.js:487 throw err;
                                      iobroker 2017-07-26 20:07:27.964 info install web
                                      iobroker 2017-07-26 20:07:27.935 info exit 1
                                      iobroker 2017-07-26 20:07:27.931 error at bootstrap_node.js:575:3
                                      iobroker 2017-07-26 20:07:27.931 error at startup (bootstrap_node.js:158:16)
                                      iobroker 2017-07-26 20:07:27.931 error at Function.Module.runMain (module.js:605:10)
                                      iobroker 2017-07-26 20:07:27.931 error at Function.Module._load (module.js:437:25)
                                      iobroker 2017-07-26 20:07:27.931 error at Function.Module._resolveFilename (module.js:485:15)
                                      iobroker 2017-07-26 20:07:27.931 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      iobroker 2017-07-26 20:07:27.931 error ^
                                      iobroker 2017-07-26 20:07:27.931 error module.js:487 throw err;
                                      iobroker 2017-07-26 20:07:27.663 info install hue
                                      iobroker 2017-07-26 20:07:27.643 info exit 1
                                      iobroker 2017-07-26 20:07:27.632 error at enableAdapters (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:47:21)
                                      iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:157:39
                                      iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup.js:753:41
                                      iobroker 2017-07-26 20:07:27.632 error at Install.uploadStaticObjects (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:339:17)
                                      iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup.js:754:44
                                      iobroker 2017-07-26 20:07:27.632 error at Upload.uploadAdapter (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:254:27)
                                      iobroker 2017-07-26 20:07:27.632 error at require (internal/module.js:11:18)
                                      iobroker 2017-07-26 20:07:27.632 error at Module.require (module.js:513:17)
                                      iobroker 2017-07-26 20:07:27.632 error at Function.Module._load (module.js:437:25)
                                      iobroker 2017-07-26 20:07:27.632 error at Function.Module._resolveFilename (module.js:485:15)
                                      iobroker 2017-07-26 20:07:27.632 error Error: Cannot find module 'mime'
                                      iobroker 2017-07-26 20:07:27.632 error ^
                                      iobroker 2017-07-26 20:07:27.632 error module.js:487 throw err;
                                      iobroker 2017-07-26 20:07:27.630 error host.MacMini-LAN.fritz.box Adapter directory "/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/adapter/tr-064" does not exists
                                      iobroker 2017-07-26 20:07:15.025 info npm install iobroker.tr-064 --production --prefix "/usr/local/lib/node_modules/iobroker" (System call)
                                      iobroker 2017-07-26 20:07:14.282 info install tr-064
                                      discovery.0 2017-07-26 20:05:54.558 info Discovery finished
                                      discovery.0 2017-07-26 20:05:54.549 info Discovery finished. Found new or modified 14 instances
                                      discovery.0 2017-07-26 20:05:54.545 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:54.045 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:53.545 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:52.532 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:52.031 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:51.531 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:51.024 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:50.525 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:50.023 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:49.515 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:49.017 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:48.514 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:47.504 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:47.009 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:46.508 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:45.500 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:45.000 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:44.500 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:43.991 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:43.493 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:42.990 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:42.484 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:41.987 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:41.487 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:40.480 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:39.980 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:39.480 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:38.971 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:38.474 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:37.972 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:36.965 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:36.464 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:35.965 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:34.954 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:34.457 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:33.954 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:32.952 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:32.450 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:31.951 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:31.445 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:30.940 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:30.446 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:29.440 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:28.936 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:28.439 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:27.933 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:27.432 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:26.931 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:25.921 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:25.419 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:24.920 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:24.415 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:23.915 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:23.414 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:22.908 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:22.409 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:21.907 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:21.402 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:20.903 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:20.405 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:19.896 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:19.397 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:18.896 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:17.887 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:17.389 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:16.885 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:16.382 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:15.884 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:15.383 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:14.875 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:14.375 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:13.875 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:12.863 warn LG TV ERR: timeout
                                      discovery.0 2017-07-26 20:05:12.361 warn MAX! Cube err: timeout
                                      discovery.0 2017-07-26 20:05:11.863 warn Mihome err: timeout
                                      discovery.0 2017-07-26 20:05:11.312 info Found 25 addresses
                                      discovery.0 2017-07-26 20:05:11.244 info Done discovering ping devices. 15 packages received
                                      discovery.0 2017-07-26 20:05:01.130 info Done discovering upnp devices. 10 packages received
                                      discovery.0 2017-07-26 20:05:00.972 info Done discovering mdns devices. 0 packages received
                                      discovery.0 2017-07-26 20:04:55.137 info Done discovering wifi-mi-light devices. 0 packages received
                                      discovery.0 2017-07-26 20:04:46.142 info Done discovering tr064 devices. 0 packages received
                                      discovery.0 2017-07-26 20:04:46.142 warn tr-064.0 not installed
                                      discovery.0 2017-07-26 20:04:46.129 info Discovering wifi-mi-light devices...
                                      discovery.0 2017-07-26 20:04:46.128 info Discovering UPnP devices...
                                      discovery.0 2017-07-26 20:04:45.970 info Discovering ping devices...
                                      discovery.0 2017-07-26 20:04:45.967 info Discovering mDNS devices...
                                      discovery.0 2017-07-26 20:04:00.125 info system.adapter.admin.0: logging true
                                      admin.0 2017-07-26 20:04:00.124 info system.adapter.admin.0: logging true
                                      admin.0 2017-07-26 20:04:00.122 info Change log subscriber state: true
                                      discovery.0 2017-07-26 20:03:50.592 info starting. Version 0.4.4 in /usr/local/lib/node_modules/iobroker/node_modules/iobroker.discovery, node: v8.2.1
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:50.089 info instance system.adapter.discovery.0 started with pid 2568
                                      admin.0 2017-07-26 20:03:48.314 info Repository received successfully.
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:47.538 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                                      admin.0 2017-07-26 20:03:47.483 info Use link "http://localhost:8081" to configure.
                                      admin.0 2017-07-26 20:03:47.483 info http server listening on port 8081
                                      admin.0 2017-07-26 20:03:47.475 info received all states
                                      admin.0 2017-07-26 20:03:47.473 info Request actual repository...
                                      admin.0 2017-07-26 20:03:47.473 warn Repository cannot be read
                                      admin.0 2017-07-26 20:03:47.471 info received all objects
                                      admin.0 2017-07-26 20:03:47.461 info requesting all objects
                                      admin.0 2017-07-26 20:03:47.461 info requesting all states
                                      admin.0 2017-07-26 20:03:47.453 info starting. Version 1.8.1 in /usr/local/lib/node_modules/iobroker/node_modules/iobroker.admin, node: v8.2.1
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.111 info instance system.adapter.admin.0 started with pid 2567
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.085 info starting 2 instances
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.083 info 2 instances found
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.080 info InMemoryDB connected
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.076 info inMem-objects listening on port 9001
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.052 info inMem-states listening on port 9000
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info ip addresses: fe80::ca9:c83e:4baf:8132 192.168.178.55 fe80::108f:d048:a985:98f1 192.168.178.51 fe80::d000:a1ff:feb1:f8bf fe80::3806:31be:1f46:2f80
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info hostname: MacMini-LAN.fritz.box, node: v8.2.1
                                      host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info Copyright (c) 2014-2017 bluefox, hobbyquaker
                                      • BuZZy
                                        In welchem Ordner hast du installiert? Direkt auf "/"? Also auf der obersten Ebene?
                                        Von wo nach wo hast du verschoben?
                                          Wenn ich es direkt an einen anderen Ort installieren will, geht es aber wieder nicht. Deshalb wollte ich verschieben.
                                          iobroker liegt jetzt hier: /usr/local/lib/node_modules/iobroker weil meine Homebridge auch schon da lag 😄
                                          iobroker läuft ja jetzt, kann es noch an Rechten liegen?
                                          • BuZZy
                                            Du kannst mal versuchen dem Ordner /usr/local/lib/node_modules/iobroker/ die Rechte 777 zuzuweisen.
                                            Aber: Existiert der Ordner /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller überhaupt?
                                            13532
