    3. Entwicklung
    4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
      Thomas Braun Most Active @Diamand2k22 last edited by
      @diamand2k22
      Und das Gerät ist auch drin?
        Diamand2k22 @Thomas Braun last edited by
        scheint nicht zu klappen 😕
          @diamand2k22
          Hier mal geschaut?
          https://forum.iobroker.net/topic/59852/hama-smartes-heizkörper-thermostat?_=1668467039158
            Hallo Thomas,
            hab das mal reinkopiert aber dann startet der zigbee adapter nicht mehr 😕
            2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52
            2022-11-15 21:15:17.734 - error: host.pi4b Caught by controller[0]: .withAwayMode()],
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: ^
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: TypeError: exposes.climate(...).withSetpoint(...).withLocalTemperature(...).withSystemMode(...).withLocalTemperatureCalibration(...).withAwayMode is not a function
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js:52:18)
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32)
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:868:12)
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
            2022-11-15 21:15:17.735 - error: host.pi4b Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
            2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js:118:30)
            2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
            2022-11-15 21:15:17.736 - error: host.pi4b Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
            2022-11-15 21:15:17.736 - error: host.pi4b instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
              Was wo reinkopiert?
                @david-jung said in Hama Smartes Heizkörper-Thermostat:
                @david-jung
                so, ich habe folgendes gemacht:
                die Datei: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js
                etwas erweitert, jetzt kann ich die Ist-Temperatur ablesen, so wie die Soll-Temperatur setzen/lesen.
                Den Modus (heizen/auto/aus) lesen, setzen.
                Ventil Status ablesen.
                Und Offset für Temperatur setzen/lesen.
                const exposes = require('../lib/exposes');
                const fz = {...require('../converters/fromZigbee'), legacy: require('../lib/legacy').fromZigbee};
                const tz = require('../converters/toZigbee');
                const tuya = require('../lib/tuya');
                const reporting = require('../lib/reporting');
                const e = exposes.presets;
                const ea = exposes.access;
                module.exports = [
                        fingerprint: [{modelID: 'GbxAXL2\u0000', manufacturerName: '_TYST11_KGbxAXL2'},
                            {modelID: 'uhszj9s\u0000', manufacturerName: '_TYST11_zuhszj9s'},
                            {modelID: '88teujp\u0000', manufacturerName: '_TYST11_c88teujp'},
                            {modelID: 'w7cahqs\u0000', manufacturerName: '_TYST11_yw7cahqs'},
                            {modelID: 'w7cahqs', manufacturerName: '_TYST11_yw7cahqs'},
                            {modelID: 'TS0601', manufacturerName: '_TZE200_c88teujp'},
                            {modelID: 'TS0601', manufacturerName: '_TZE200_yw7cahqs'},
                            {modelID: 'TS0601', manufacturerName: '_TZE200_azqp6ssj'},
                            {modelID: 'TS0601', manufacturerName: '_TZE200_bvu2wnxz'},
                            {modelID: 'TS0601', manufacturerName: '_TZE200_zuhszj9s'},
                            {modelID: 'TS0601', manufacturerName: '_TZE200_9gvruqf5'},
                            {modelID: 'TS0601', manufacturerName: '_TZE200_zr9c0day'},
                        model: 'SEA801-Zigbee/SEA802-Zigbee',
                        vendor: 'Saswell',
                        description: 'Thermostatic radiator valve',
                        whiteLabel: [{vendor: 'HiHome', model: 'WZB-TRVL'}, {vendor: 'Hama', model: '00176592'},
                            {vendor: 'RTX', model: 'ZB-RT1'}],
                        fromZigbee: [fz.saswell_thermostat, fz.ignore_tuya_set_time, fz.ignore_basic_report, fz.legacy.tuya_thermostat_weekly_schedule],
                        toZigbee: [tz.saswell_thermostat_current_heating_setpoint, tz.saswell_thermostat_mode, tz.saswell_thermostat_away,
                            tz.saswell_thermostat_child_lock, tz.saswell_thermostat_window_detection, tz.saswell_thermostat_frost_detection,
                            tz.saswell_thermostat_calibration, tz.saswell_thermostat_anti_scaling, tz.tuya_thermostat_weekly_schedule],
                        onEvent: tuya.onEventSetTime,
                        meta: {
                            thermostat: {
                                weeklyScheduleMaxTransitions: 4,
                                weeklyScheduleSupportedModes: [1], // bits: 0-heat present, 1-cool present (dec: 1-heat,2-cool,3-heat+cool)
                                weeklyScheduleConversion: 'saswell',
                        configure: async (device, coordinatorEndpoint, logger) => {
                            const endpoint = device.getEndpoint(1);
                            await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
                        exposes: [e.battery_low(), e.window_detection(), e.child_lock(),
                            exposes.binary('heating', ea.STATE, 'ON', 'OFF').withDescription('Device valve is open or closed (heating or not)'),
                            exposes.climate()
                                .withSetpoint('current_heating_setpoint', 5, 30, 0.5, ea.STATE_SET).withLocalTemperature(ea.STATE)
                                .withSystemMode(['off', 'heat', 'auto'], ea.STATE_SET)
                                // Range is -6 - 6 and step 1: https://github.com/Koenkk/zigbee2mqtt/issues/11777
                                .withLocalTemperatureCalibration(-6, 6, 1, ea.STATE_SET)
                                .withAwayMode()],
                		/*added by djung 10.11.2022*/
                	fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_h4cgnbzg'}],
                        model: 'HZ',
                        vendor: 'HAMA',
                        whiteLabel: [{vendor: 'Hama', model: 'XXXxxxXXX'},],
                        fromZigbee: [fz.saswell_thermostat],
                            tz.saswell_thermostat_calibration],
                        exposes: [
                			e.battery_low(),
                			/*e.switch(),*/
                			/*e.lock(),*/
                            exposes.climate()
                soll man das irgendwo auf github oder so noch posten? Wenn ja, bitte zeigen wo 😃
                Grüße.
                David.
                  @diamand2k22
                  Alles? Das war nur als Denkansatz für dich gedacht.
                  Ich hätte da erstmal nur die Manufacturer-ID hinzugefügt. Sind ja schon ein paar Varianten von dem Thermostat mit der Modellbezeichnung TS0601 vorhanden.
                    hab die manufactor id eingefügt, jetzt erkennt er das thermostat, liefert aber keine werte!
                    2022-11-15 21:35:02.182 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #2 with data {"dp":2,"datatype":4,"data":{"type":"Buffer","data":[2]}}
                    2022-11-15 21:35:02.434 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #4 with data {"dp":4,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,50]}}
                    2022-11-15 21:35:02.551 - info: dwd.0 (92835) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.1, js-controller: 4.0.23
                    2022-11-15 21:35:02.555 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #5 with data {"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,200]}}
                    2022-11-15 21:35:02.704 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #7 with data {"dp":7,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                    2022-11-15 21:35:02.789 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #28 with data {"dp":28,"datatype":0,"data":{"type":"Buffer","data":[1,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                    2022-11-15 21:35:02.906 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #29 with data {"dp":29,"datatype":0,"data":{"type":"Buffer","data":[2,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                    2022-11-15 21:35:03.032 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #30 with data {"dp":30,"datatype":0,"data":{"type":"Buffer","data":[3,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                    2022-11-15 21:35:03.144 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #31 with data {"dp":31,"datatype":0,"data":{"type":"Buffer","data":[4,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                    2022-11-15 21:35:03.264 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #32 with data {"dp":32,"datatype":0,"data":{"type":"Buffer","data":[5,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                    2022-11-15 21:35:03.380 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #33 with data {"dp":33,"datatype":0,"data":{"type":"Buffer","data":[6,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                    2022-11-15 21:35:03.502 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #34 with data {"dp":34,"datatype":0,"data":{"type":"Buffer","data":[7,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
                    2022-11-15 21:35:03.615 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #35 with data {"dp":35,"datatype":5,"data":{"type":"Buffer","data":[0]}}
                    2022-11-15 21:35:03.731 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #36 with data {"dp":36,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                    2022-11-15 21:35:03.848 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #39 with data {"dp":39,"datatype":1,"data":{"type":"Buffer","data":[0]}}
                    2022-11-15 21:35:03.968 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #47 with data {"dp":47,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}
                      Thomas Braun Most Active @Diamand2k22 last edited by Thomas Braun
                      @diamand2k22
                      Ich kann dir da nicht weiterhelfen.
                      Vielleicht weiß @david-jung ja noch was dazu.
                        kann es sein, dass mit den Rechten was nicht stimmt?`
                        $ iobroker url ioBroker/ioBroker.zigbee --host pi4b --debug
                        install ioBroker/ioBroker.zigbee
                        NPM version: 8.19.2
                        Installing ioBroker/ioBroker.zigbee... (System call)
                        npm WARN cleanup Failed to remove some directories [npm WARN cleanup [
                        npm WARN cleanup '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV',npm WARN cleanup [Error: EACCES: permission denied, scandir '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'] {npm WARN cleanup errno: -13,npm WARN cleanup code: 'EACCES',npm WARN cleanup syscall: 'scandir',npm WARN cleanup path: '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'npm WARN cleanup }npm WARN cleanup ]npm WARN cleanup
                          iob stop
                          iob fix
                          iob start
                            danke dir für die schnelle Rückmeldung.
                            Hab's dann doch selber hinbekommen!
                            • DJMarc75
                              DJMarc75 @Diamand2k22 last edited by
                              Und des Rätsels Lösung war ?
                              Vll hilft das auch anderen Mitlesenden !
                                Diamand2k22 @DJMarc75 last edited by
                                @djmarc75
                                hat Thomas schon geschrieben.
                                iob stop
                                iob fix
                                iob start
                                  @diamand2k22
                                  Dann hast du da mal mit falschen Rechten hantiert.
                                  root login?
                                    Diamand2k22 last edited by Diamand2k22
                                    kann sein Thomas, hab ich aber wieder hingebogen bekommen.
                                    @Asgothian
                                    hab mir jetzt ne eigene ketotek.js für mein Heizkörperthermostat gebastelt.
                                    Jetzt funktioniert es wunderbar und ich hab keine Unrecognized DP's mehr und kann es steuern und empfange Temperaturen.
                                    Was mich nur interessieren würde, wie bekomme ich da ein vernünftiges Bild rein?
                                    Kannst du das Thermostat aufnehmen?
                                      Patrick Kenzler @Thomas Braun last edited by
                                      @thomas-braun könntest du deinen externen Konverter zur Verfügung stellen? Sitze schon seit Tagen und komme nicht weiter.
                                        Thomas Braun Most Active @Patrick Kenzler last edited by
                                        @patrick-kenzler
                                        Meinen was? Wüsste nicht das ich sowas im Einsatz hätte.
                                          @thomas-braun sorry, die Frage sollte eigentlich an @Diamand2k22 gehen habe mich verklickt^^
                                            Diamand2k22 @Patrick Kenzler last edited by
                                            @patrick-kenzler
                                            Hast du auch so ein ketotek Teil von Amaz**?
                                            herdsman zigbee
                                            13
                                            129
                                            23958
