    3. Einsteigerfragen
    4. Installation
    5. Installation Iobroker auf Debian 11
      liv-in-sky @Pass3de last edited by
      @pass3de
      bitte nutze die code tag function beim einstellen solcher meldungen
      https://forum.iobroker.net/post/394912
      • FredF
        FredF Most Active Forum Testing @Pass3de last edited by
        @pass3de
        Kenne VM Ware nicht, aber der Befehl zur Installation von ioBroker lautet:
        curl -sLf https://iobroker.net/install.sh | bash --
          Ah ja, Code habe ich nicht gefunden...
          deb@deb-iob-03:~$ curl -v -sLf https://iobroker.net/install.sh | bash --
          *   Trying 82.165.135.239:443...
          * Connected to iobroker.net (82.165.135.239) port 443 (#0)
          * ALPN, offering h2
          * ALPN, offering http/1.1
          * successfully set certificate verify locations:
          *  CAfile: /etc/ssl/certs/ca-certificates.crt
          *  CApath: /etc/ssl/certs
          } [5 bytes data]
          * TLSv1.3 (OUT), TLS handshake, Client hello (1):
          } [512 bytes data]
          * TLSv1.3 (IN), TLS handshake, Server hello (2):
          { [108 bytes data]
          * TLSv1.2 (IN), TLS handshake, Certificate (11):
          { [4016 bytes data]
          * TLSv1.2 (IN), TLS handshake, Server key exchange (12):
          { [365 bytes data]
          * TLSv1.2 (IN), TLS handshake, Server finished (14):
          { [4 bytes data]
          * TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
          } [102 bytes data]
          * TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
          } [1 bytes data]
          * TLSv1.2 (OUT), TLS handshake, Finished (20):
          } [16 bytes data]
          * TLSv1.2 (IN), TLS handshake, Finished (20):
          { [16 bytes data]
          * SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384
          * ALPN, server accepted to use http/1.1
          * Server certificate:
          *  subject: CN=iobroker.net
          *  start date: Sep 15 00:00:15 2022 GMT
          *  expire date: Dec 14 00:00:14 2022 GMT
          *  subjectAltName: host "iobroker.net" matched cert's "iobroker.net"
          *  issuer: C=US; O=Let's Encrypt; CN=R3
          *  SSL certificate verify ok.
          } [5 bytes data]
          > GET /install.sh HTTP/1.1
          > Host: iobroker.net
          > User-Agent: curl/7.74.0
          > Accept: */*
          { [5 bytes data]
          * Mark bundle as not supporting multiuse
          < HTTP/1.1 301 Moved Permanently
          < Server: nginx/1.10.3
          < Date: Sat, 12 Nov 2022 09:36:53 GMT
          < Content-Type: text/plain; charset=utf-8
          < Content-Length: 65
          < Connection: keep-alive
          < X-Powered-By: Express
          < Location: http://iobroker.live/install.sh
          < Vary: Accept
          * Ignoring the response-body
          { [65 bytes data]
          * Connection #0 to host iobroker.net left intact
          * Clear auth, redirects to port from 443 to 80Issue another request to this URL: 'http://iobroker.live/install.sh'
          *   Trying 217.160.0.211:80...
          * Connected to iobroker.live (217.160.0.211) port 80 (#1)
          > Host: iobroker.live
          > Accept: */*
          * Empty reply from server
          * Connection #1 to host iobroker.live left intact
          deb@deb-iob-03:~$
            Pass3de @FredF last edited by
            @fredf
            Hi fredf,
            das funktioniert leider auch nicht, dass hat mit ESX vorraussichtlich auch nichts zu tun.
            Trotzdem vielen Dank.
              Thomas Braun Most Active @Pass3de last edited by
              @pass3de
              Versuchs so:
              curl -L https://iobroker.net/install.sh | bash -
                Pass3de @Thomas Braun last edited by
                Hi Thomas,
                leider auch nicht.
                deb@deb-iob-03:~$ curl -L https://iobroker.net/install.sh | bash -
                  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                 Dload  Upload   Total   Spent    Left  Speed
                100    65  100    65    0     0    439      0 --:--:-- --:--:-- --:--:--   439
                  0     0    0     0    0     0      0      0 --:--:--  0:00:10 --:--:--     0
                curl: (52) Empty reply from server
                deb@deb-iob-03:~$
                  @pass3de sagte in Installation Iobroker auf Debian 11:
                  Das deutet auf eine Fehleinstellung im Server hin, bei mir wird das skript allerdings heruntergeladen, könnte also auch etwas bei dir im Netz sein.
                  Sowas wie PiHole oder ähnliches im Einsatz?
                  • itoss
                    itoss last edited by itoss
                    mhh ich habe heute morgen noch eine frische Debian 11 installation ( minimalinstall ) in VBOX installiert und dann einfach das Script geladen und ausgeführt.
                    Was für mich grad aber nicht ersichtlich ist : Ist der Accound unter dem du das Script ausführt in der gruppe sudo oder als root mit berechtigungen in /etc/sudoers eingetragen ?
                    Wenn nicht versuch die Zeile als root auszuführen :
                    sudo su
                      Homoran Global Moderator Administrators @itoss last edited by
                      @itoss sagte in Installation Iobroker auf Debian 11:
                      WARUM???
                      Sollen alle Rechte verbogen werden, damit der User iobroker da nicht mehr ran kann?
                        Thomas Braun Most Active @itoss last edited by
                        @itoss
                        Weder noch. Das Skript hat natürlich nur die Rechte vom ausführenden User. Wenn der keine sudo Rechte erwerben kann dann kann es das Skript auch nicht.
                        Direkt als root führt man das nicht aus, wozu auch?
                          danke für eure Ideen und Unterstützung.
                          Wartezimmer Wunderheilung.
                          Einfach mal ein paar Tage liegen lassen und schon geht´s...
                          Ich habe in der Tat eine ziemlich scharf eingestellte Sophos UTM laufen, habe aber über ein "anderes" GW den Weg frei nach draußen gelassen.
                          LG
                          Andre
                            guggu @Pass3de last edited by
                            @pass3de
                            ich hab's auf Oracle VirtualBox installiert. War schwierig.
                            Falls Du (noch) interessiert bist, schicke ich die Installationsanleitung.
                            CCS
                              Thomas Braun Most Active @guggu last edited by
                              @guggu sagte in Installation Iobroker auf Debian 11:
                              War schwierig.
                              Inwiefern? Sollte in einer VM überhaupt kein Problem sein, ist halt eine Standardinstallation.
                              1.2k
                              5809
