    4. Fehlermeldungen bei Installation mac
      thoduh last edited by
      @BuZZy:
      Bald raste ich aus.. 😄 `
      Frag mich mal 😉
      MacMini-LAN:~ MacMini$ cd /Users/MacMini/Documents/iobrokermac
      MacMini-LAN:iobrokermac MacMini$ sudo npm install https://github.com/ioBroker/ioBroker/tarball/master
      > iobroker@1.0.0 install /Users/MacMini/Documents/iobrokermac/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
      npm ERR! path /Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs
      npm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall rmdir
      npm ERR! Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
      npm ERR!  { Error: EACCES: permission denied, rmdir '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs'
      npm ERR!   cause:
      npm ERR!      errno: -13,
      npm ERR!      code: 'EACCES',
      npm ERR!      syscall: 'rmdir',
      npm ERR!      path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs' },
      npm ERR!   stack: 'Error: EACCES: permission denied, rmdir \'/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs\'',
      npm ERR!   path: '/Users/MacMini/Documents/iobrokermac/node_modules/iobroker/node_modules/yargs',
      npm ERR!   parent: 'iobroker.js-controller' }
      npm ERR!
      npm ERR! Please try running this command again as root/Administrator.
      npm ERR!     /Users/MacMini/.npm/_logs/2017-07-26T17_40_08_563Z-debug.log
      Cannot install as normal user. Try sudo...
      sudo npm install iobroker.discovery --production --prefix /Users/MacMini/Documents/iobrokermac
      • BuZZy
        BuZZy last edited by
        Lösche den kompletten inhalt von dem ioBrokermac ordner.
        Dann versuch es mit````
        sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
        Dann nochmal den Log posten.
        EDIT: Hab gesehen du hast es schon mit sudo probiert..
        Gib dem Ordner ioBrokermac mal (nachdem du den Inhalt komplett gelöscht hast) die Rechte 777 - dann nochmal versuchen mit dem oben genannten Befehl!
          Jetzt hats gekappt !!!
          Habe den iobroker-Ordner direkt auf Macintosh/ erstellt. per sudo npm install https://github.com/ioBroker/ioBroker/tarball/master –unsafe-perm installiert.
          Anschließend den Ordner an meinen gewünschten Platz verschoben und es läuft 😄 😄 😄 😄
          Vielen Dank für deine Hilfe !!!!
          Aber jetzt hab ich was anderes:
          Muss ich die Pfade noch anpassen ??
          Oder hätte ich es nicht verschieben dürfen ??
          host.MacMini-LAN.fritz.box 2017-07-26 20:12:16.220 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
          host.MacMini-LAN.fritz.box 2017-07-26 20:11:46.212 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
          host.MacMini-LAN.fritz.box 2017-07-26 20:11:16.205 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
          host.MacMini-LAN.fritz.box 2017-07-26 20:10:46.204 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
          host.MacMini-LAN.fritz.box 2017-07-26 20:10:16.193 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
          host.MacMini-LAN.fritz.box 2017-07-26 20:09:46.187 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/no
          host.MacMini-LAN.fritz.box 2017-07-26 20:09:16.176 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
          host.MacMini-LAN.fritz.box 2017-07-26 20:08:46.166 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
          host.MacMini-LAN.fritz.box 2017-07-26 20:08:16.156 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
          host.MacMini-LAN.fritz.box 2017-07-26 20:07:46.151 error Cannot save /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/states.json: Error: ENOENT: no such file or directory, open '/usr/local/lib/n
          iobroker 2017-07-26 20:07:29.113 info exit 1
          iobroker 2017-07-26 20:07:29.108 error at bootstrap_node.js:575:3
          iobroker 2017-07-26 20:07:29.108 error at startup (bootstrap_node.js:158:16)
          iobroker 2017-07-26 20:07:29.108 error at Function.Module.runMain (module.js:605:10)
          iobroker 2017-07-26 20:07:29.108 error at Function.Module._load (module.js:437:25)
          iobroker 2017-07-26 20:07:29.108 error at Function.Module._resolveFilename (module.js:485:15)
          iobroker 2017-07-26 20:07:29.108 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          iobroker 2017-07-26 20:07:29.108 error ^
          iobroker 2017-07-26 20:07:29.108 error module.js:487 throw err;
          iobroker 2017-07-26 20:07:28.844 info install hm-rega
          iobroker 2017-07-26 20:07:28.811 info exit 1
          iobroker 2017-07-26 20:07:28.807 error at bootstrap_node.js:575:3
          iobroker 2017-07-26 20:07:28.807 error at startup (bootstrap_node.js:158:16)
          iobroker 2017-07-26 20:07:28.807 error at Function.Module.runMain (module.js:605:10)
          iobroker 2017-07-26 20:07:28.807 error at Function.Module._load (module.js:437:25)
          iobroker 2017-07-26 20:07:28.807 error at Function.Module._resolveFilename (module.js:485:15)
          iobroker 2017-07-26 20:07:28.807 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          iobroker 2017-07-26 20:07:28.807 error ^
          iobroker 2017-07-26 20:07:28.807 error module.js:487 throw err;
          iobroker 2017-07-26 20:07:28.543 info install hm-rpc
          iobroker 2017-07-26 20:07:28.515 info exit 1
          iobroker 2017-07-26 20:07:28.511 error at bootstrap_node.js:575:3
          iobroker 2017-07-26 20:07:28.511 error at startup (bootstrap_node.js:158:16)
          iobroker 2017-07-26 20:07:28.511 error at Function.Module.runMain (module.js:605:10)
          iobroker 2017-07-26 20:07:28.511 error at Function.Module._load (module.js:437:25)
          iobroker 2017-07-26 20:07:28.511 error at Function.Module._resolveFilename (module.js:485:15)
          iobroker 2017-07-26 20:07:28.511 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          iobroker 2017-07-26 20:07:28.511 error ^
          iobroker 2017-07-26 20:07:28.511 error module.js:487 throw err;
          iobroker 2017-07-26 20:07:28.245 info install hm-rpc
          iobroker 2017-07-26 20:07:28.230 info exit 1
          iobroker 2017-07-26 20:07:28.226 error at bootstrap_node.js:575:3
          iobroker 2017-07-26 20:07:28.226 error at startup (bootstrap_node.js:158:16)
          iobroker 2017-07-26 20:07:28.226 error at Function.Module.runMain (module.js:605:10)
          iobroker 2017-07-26 20:07:28.226 error at Function.Module._load (module.js:437:25)
          iobroker 2017-07-26 20:07:28.226 error at Function.Module._resolveFilename (module.js:485:15)
          iobroker 2017-07-26 20:07:28.226 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          iobroker 2017-07-26 20:07:28.226 error ^
          iobroker 2017-07-26 20:07:28.226 error module.js:487 throw err;
          iobroker 2017-07-26 20:07:27.964 info install web
          iobroker 2017-07-26 20:07:27.935 info exit 1
          iobroker 2017-07-26 20:07:27.931 error at bootstrap_node.js:575:3
          iobroker 2017-07-26 20:07:27.931 error at startup (bootstrap_node.js:158:16)
          iobroker 2017-07-26 20:07:27.931 error at Function.Module.runMain (module.js:605:10)
          iobroker 2017-07-26 20:07:27.931 error at Function.Module._load (module.js:437:25)
          iobroker 2017-07-26 20:07:27.931 error at Function.Module._resolveFilename (module.js:485:15)
          iobroker 2017-07-26 20:07:27.931 error Error: Cannot find module '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          iobroker 2017-07-26 20:07:27.931 error ^
          iobroker 2017-07-26 20:07:27.931 error module.js:487 throw err;
          iobroker 2017-07-26 20:07:27.663 info install hue
          iobroker 2017-07-26 20:07:27.643 info exit 1
          iobroker 2017-07-26 20:07:27.632 error at enableAdapters (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:47:21)
          iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:157:39
          iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup.js:753:41
          iobroker 2017-07-26 20:07:27.632 error at Install.uploadStaticObjects (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:339:17)
          iobroker 2017-07-26 20:07:27.632 error at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup.js:754:44
          iobroker 2017-07-26 20:07:27.632 error at Upload.uploadAdapter (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:254:27)
          iobroker 2017-07-26 20:07:27.632 error at require (internal/module.js:11:18)
          iobroker 2017-07-26 20:07:27.632 error at Module.require (module.js:513:17)
          iobroker 2017-07-26 20:07:27.632 error at Function.Module._load (module.js:437:25)
          iobroker 2017-07-26 20:07:27.632 error at Function.Module._resolveFilename (module.js:485:15)
          iobroker 2017-07-26 20:07:27.632 error Error: Cannot find module 'mime'
          iobroker 2017-07-26 20:07:27.632 error ^
          iobroker 2017-07-26 20:07:27.632 error module.js:487 throw err;
          iobroker 2017-07-26 20:07:27.630 error host.MacMini-LAN.fritz.box Adapter directory "/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/adapter/tr-064" does not exists
          iobroker 2017-07-26 20:07:15.025 info npm install iobroker.tr-064 --production --prefix "/usr/local/lib/node_modules/iobroker" (System call)
          iobroker 2017-07-26 20:07:14.282 info install tr-064
          discovery.0 2017-07-26 20:05:54.558 info Discovery finished
          discovery.0 2017-07-26 20:05:54.549 info Discovery finished. Found new or modified 14 instances
          discovery.0 2017-07-26 20:05:54.545 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:54.045 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:53.545 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:52.532 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:52.031 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:51.531 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:51.024 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:50.525 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:50.023 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:49.515 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:49.017 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:48.514 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:47.504 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:47.009 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:46.508 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:45.500 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:45.000 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:44.500 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:43.991 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:43.493 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:42.990 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:42.484 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:41.987 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:41.487 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:40.480 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:39.980 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:39.480 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:38.971 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:38.474 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:37.972 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:36.965 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:36.464 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:35.965 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:34.954 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:34.457 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:33.954 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:32.952 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:32.450 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:31.951 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:31.445 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:30.940 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:30.446 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:29.440 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:28.936 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:28.439 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:27.933 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:27.432 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:26.931 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:25.921 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:25.419 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:24.920 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:24.415 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:23.915 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:23.414 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:22.908 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:22.409 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:21.907 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:21.402 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:20.903 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:20.405 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:19.896 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:19.397 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:18.896 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:17.887 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:17.389 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:16.885 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:16.382 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:15.884 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:15.383 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:14.875 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:14.375 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:13.875 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:12.863 warn LG TV ERR: timeout
          discovery.0 2017-07-26 20:05:12.361 warn MAX! Cube err: timeout
          discovery.0 2017-07-26 20:05:11.863 warn Mihome err: timeout
          discovery.0 2017-07-26 20:05:11.312 info Found 25 addresses
          discovery.0 2017-07-26 20:05:11.244 info Done discovering ping devices. 15 packages received
          discovery.0 2017-07-26 20:05:01.130 info Done discovering upnp devices. 10 packages received
          discovery.0 2017-07-26 20:05:00.972 info Done discovering mdns devices. 0 packages received
          discovery.0 2017-07-26 20:04:55.137 info Done discovering wifi-mi-light devices. 0 packages received
          discovery.0 2017-07-26 20:04:46.142 info Done discovering tr064 devices. 0 packages received
          discovery.0 2017-07-26 20:04:46.142 warn tr-064.0 not installed
          discovery.0 2017-07-26 20:04:46.129 info Discovering wifi-mi-light devices...
          discovery.0 2017-07-26 20:04:46.128 info Discovering UPnP devices...
          discovery.0 2017-07-26 20:04:45.970 info Discovering ping devices...
          discovery.0 2017-07-26 20:04:45.967 info Discovering mDNS devices...
          discovery.0 2017-07-26 20:04:00.125 info system.adapter.admin.0: logging true
          admin.0 2017-07-26 20:04:00.124 info system.adapter.admin.0: logging true
          admin.0 2017-07-26 20:04:00.122 info Change log subscriber state: true
          discovery.0 2017-07-26 20:03:50.592 info starting. Version 0.4.4 in /usr/local/lib/node_modules/iobroker/node_modules/iobroker.discovery, node: v8.2.1
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:50.089 info instance system.adapter.discovery.0 started with pid 2568
          admin.0 2017-07-26 20:03:48.314 info Repository received successfully.
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:47.538 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
          admin.0 2017-07-26 20:03:47.483 info Use link "http://localhost:8081" to configure.
          admin.0 2017-07-26 20:03:47.483 info http server listening on port 8081
          admin.0 2017-07-26 20:03:47.475 info received all states
          admin.0 2017-07-26 20:03:47.473 info Request actual repository...
          admin.0 2017-07-26 20:03:47.473 warn Repository cannot be read
          admin.0 2017-07-26 20:03:47.471 info received all objects
          admin.0 2017-07-26 20:03:47.461 info requesting all objects
          admin.0 2017-07-26 20:03:47.461 info requesting all states
          admin.0 2017-07-26 20:03:47.453 info starting. Version 1.8.1 in /usr/local/lib/node_modules/iobroker/node_modules/iobroker.admin, node: v8.2.1
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.111 info instance system.adapter.admin.0 started with pid 2567
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.085 info starting 2 instances
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.083 info 2 instances found
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.080 info InMemoryDB connected
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.076 info inMem-objects listening on port 9001
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:46.052 info inMem-states listening on port 9000
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info ip addresses: fe80::ca9:c83e:4baf:8132 192.168.178.55 fe80::108f:d048:a985:98f1 192.168.178.51 fe80::d000:a1ff:feb1:f8bf fe80::3806:31be:1f46:2f80
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info hostname: MacMini-LAN.fritz.box, node: v8.2.1
          host.MacMini-LAN.fritz.box 2017-07-26 20:03:45.989 info Copyright (c) 2014-2017 bluefox, hobbyquaker
          • BuZZy
            In welchem Ordner hast du installiert? Direkt auf "/"? Also auf der obersten Ebene?
            Von wo nach wo hast du verschoben?
              Wenn ich es direkt an einen anderen Ort installieren will, geht es aber wieder nicht. Deshalb wollte ich verschieben.
              iobroker liegt jetzt hier: /usr/local/lib/node_modules/iobroker weil meine Homebridge auch schon da lag 😄
              iobroker läuft ja jetzt, kann es noch an Rechten liegen?
              • BuZZy
                Du kannst mal versuchen dem Ordner /usr/local/lib/node_modules/iobroker/ die Rechte 777 zuzuweisen.
                Aber: Existiert der Ordner /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller überhaupt?
                  Den Ordner: /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller gibt es doch nicht in meiner Kopie.
                  Muss morgen weiterschauen…
                  Danke nochmal !!
                  • BuZZy
                    Frage 1:
                    Existiert der Ordner?
                    Edit: hier stand Mist
                    Frage 2:
                    /usr/local/lib/node_modules/iobroker/iobroker-data/
                      @BuZZy:
                      Frage 2:
                      Ja den gibt es bei mir.
                      Den ersten nicht…
                      Wie war der Befehl nochmal um an einen bestimmten Platz zu installieren?
                      • BuZZy
                        Ich vermute dein Mac versuche auf den falschen Ordner zuzugreifen.
                        EDIT […...]
                          Kannst du mir nochmal den Befehl zum installieren an einem bestimmten Platz nennen?
                          Du hattest ihn vorhin mal irgendwo geschrieben, jetzt ist er leider weg.
                          • BuZZy
                            Ich bin mir nicht sicher ob iobroker bzw. npm das mag..
                            Aber du kannst es hiermit versuchen:
                            sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm --prefix /ort/wohin/es/soll
                            • BuZZy
                              Edit; hier stand Müll..
                                sudo npm install https://github.com/ioBroker/ioBroker/tarball/master –unsafe-perm --prefix /ort/wohin/es/soll
                                Leider nicht funktioniert:
                                MacMini-LAN:node_modules MacMini$ cd node_modules/iobroker.js-controller
                                -bash: cd: node_modules/iobroker.js-controller: No such file or directory
                                MacMini-LAN:node_modules MacMini$ cd iobroker
                                MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controlle
                                -bash: cd: node_modules/iobroker.js-controlle: No such file or directory
                                MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controller
                                MacMini-LAN:iobroker.js-controller MacMini$ chmod +x iobroker
                                MacMini-LAN:iobroker.js-controller MacMini$ node controller.js
                                host.MacMini-LAN.fritz.box check instance "system.adapter.admin.0" for host "MacMini-LAN.fritz.box"
                                host.MacMini-LAN.fritz.box check instance "system.adapter.discovery.0" for host "MacMini-LAN.fritz.box"
                                { Error: EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/log/iobroker.2017-07-26.log'
                                  errno: -13,
                                  code: 'EACCES',
                                  syscall: 'open',
                                  path: '/usr/local/lib/node_modules/iobroker/log/iobroker.2017-07-26.log' }
                                EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                                Error: EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                                    at Object.fs.openSync (fs.js:652:18)
                                    at Object.fs.writeFileSync (fs.js:1299:33)
                                    at saveConfig (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1749:16)
                                    at ObjectsInMemServer.destroy (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2677:26)
                                    at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/controller.js:2244:49
                                    at Timeout.waitForInstances [as _onTimeout] (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/controller.js:2197:49)
                                    at ontimeout (timers.js:469:11)
                                    at tryOnTimeout (timers.js:304:5)
                                    at Timer.listOnTimeout (timers.js:264:5)
                                Bis morgen dann :lol:
                                • BuZZy
                                  In welchem Ordner landest du wenn du den Befehl
                                  cd /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data
                                  eingibst?
                                    Hab ich noch nicht versucht, wollte es erneut aber diesmal an den richtigen Platz installieren. War ja nix 😉 Morgen teste ich mal deinen anderen Vorschlag…
                                    • BuZZy
                                      Also halten wir kurz fest:
                                      1. Ich kenne mich nicht mit Mac aus… 😄
                                      ````im Hauptverzeichnis "/" ausgeführt hat die Installation "korrekt" beendet. Die Versuche vorher in einem /User/ Ordner die Installation auszuführen hat nicht funktioniert.
                                      (Eventuell gibt es Probleme mit der Berechtigung wenn ein Script versucht in einen /User/ Ordner zu schreiben bzw. Dateien zu erstellen?!)
                                      3.
                                      Du hast den durch die Installation erstellen Ordner verschoben und jetzt gibts einen Haufen von Fehlern beim starten dass die Module nicht existieren bzw. nicht gefunden werden können.
                                      Dadurch dass du jetzt nochmal versucht hast ioBroker zu installieren bin ich mir nicht ganz sicher was passiert ist.
                                      Versuche nochmal ioBroker zu stoppen und dann wieder zu starten.
                                      Welche Ausgabe bekommst du dann im Log auf dem ioBroker Webinterface? Die gleiche die du vorhin schon gepostet hast?
                                      Bis Morgen. :D
                                      • BuZZy
                                        Habe über Nacht mal meine Gedanken neu sortiert..
                                        Als erstes setzt du jetzt die Rechte für den Ordner /usr/local/lib/node_modules/iobroker/ auf 777
                                        sudo chmod -R 777 /usr/local/lib/node_modules/iobroker/
                                        Jetzt versuch ioBroker aus diesem Ordner raus nochmal neu zu installieren..
                                        Also du befindest dich im Terminalfenster in dem Ordner /usr/local/lib/node_modules/iobroker/ und dort soll iobroker auch installiert werden ja?
                                        Hast du wirklich "sudo chmod -R 777 /usr/local/lib/node_modules/iobroker/" ausgeführt?
                                        Wenn ja, dann nochmal in diesem Ordner ioBroker installieren mit
                                        ioBroker wird in dem Ordner installiert in dem du den Befehl zum installieren gibst.
                                        Wenn du also das Terminal öffnest und eingibst
                                        befindest du dich logischerweise jetzt im Ordner /usr/local/lib/node_modules/iobroker/
                                        mit dem Befehl
                                        wird es in den aktuellen Ordner (also dann /usr/local/lib/node_modules/iobroker/) installiert.
                                        Wichtig ist, dass du vorher den befehl "chmod -R 777 /usr/local/lib/node_modules/iobroker/" ausführst um dem Ordner wo du installieren willst die Rechte 777 zu geben und erst dann installierst.
                                        • supernova1963
                                          supernova1963 last edited by
                                          Als absoluter Neuling und MAC Nutzer versuche ich mal zu unterstützen.
                                          Da meine erste Installation von ioBroker nicht so verlief, wie hier (http://www.iobroker.net/docu/?page_id=2293&lang=de) beschrieben, habe ich den weiteren Verlauf dieses Beitrages und vor Allem die tolle Unterstützung von BuZZy durchgelesen.
                                          Ich habe daraufhin meine zwar laufende aber "unsaubere" erste Installation gemäß Anleitung gelöscht.
                                          Bei der Neuinstallation habe ich mich an die Anleitung von BuZZy gehalten.
                                          Voraussetzung ist:
                                          raunet:~ Gernot$ node -v
                                          v6.11.1
                                          1. einen Ordner "ioBrokerMac" in "Documents" erstellt.
                                          (@thoduh: im Folgenden ersetzen: …/Gernot/… durch: .../MacMini/…):
                                          raunet:~ Gernot$ mkdir /Users/Gernot/Documents/ioBrokerMac
                                          2. die Datei https://codeload.github.com/ioBroker/io … zip/master heruntergeladen und in den neu erstellten Ordner ioBrokerMac kopiert
                                          cp /Users/Gernot/Downloads/ioBroker.js-controller-master.zip /Users/Gernot/Documents/ioBrokerMac
                                          3. die Installation gem. BuZZy mit Vorgabe Verzeichnis gestartet
                                          raunet:ioBrokerMac Gernot$ npm install iobroker.js-controller --production --prefix /Users/Gernot/Documents/ioBrokerMac
                                          4. in das Verzeichnis /Users/Gernot/Documents/ioBrokerMac/node_modules/iobroker.js-controller gewechselt un die Datei ioBroker ausführbar gemacht
                                          raunet:ioBrokerMac Gernot$ cd /Users/Gernot/Documents/ioBrokerMac/node_modules/iobroker.js-controller
                                          raunet:iobroker.js-controller Gernot$ chmod +x iobroker
                                          5. mit node controller.js gestartet
                                          raunet:iobroker.js-controller Gernot$ node controller.js
                                          host.raunet.private check instance "system.adapter.admin.0" for host "raunet.private"
                                          Cannot send diag info: ETIMEDOUT
                                          cmdExec on raunet.private(223091688): add fhem
                                          und es läuft im Browser http://127.0.0.1:8081/
                                          Vielleicht hilft's,
                                          Gernot
                                            Hallo Gernot,
                                            Danke für diese Anleitung und zwei Zwischenfragen:
                                            Hast du außer dem chmod +x auch noch irgendwo ein chmod 777 o.ä. gemacht?
                                            Hast du als normaler User oder als Admin installiert?
                                            Rainer
                                            13532
