    3. Entwicklung
    4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
      Diamand2k22 @Thomas Braun last edited by
      @david-jung said in Hama Smartes Heizkörper-Thermostat:
      @david-jung
      so, ich habe folgendes gemacht:
      die Datei: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js
      etwas erweitert, jetzt kann ich die Ist-Temperatur ablesen, so wie die Soll-Temperatur setzen/lesen.
      Den Modus (heizen/auto/aus) lesen, setzen.
      Ventil Status ablesen.
      Und Offset für Temperatur setzen/lesen.
      const exposes = require('../lib/exposes');
      const fz = {...require('../converters/fromZigbee'), legacy: require('../lib/legacy').fromZigbee};
      const tz = require('../converters/toZigbee');
      const tuya = require('../lib/tuya');
      const reporting = require('../lib/reporting');
      const e = exposes.presets;
      const ea = exposes.access;
      module.exports = [
              fingerprint: [{modelID: 'GbxAXL2\u0000', manufacturerName: '_TYST11_KGbxAXL2'},
                  {modelID: 'uhszj9s\u0000', manufacturerName: '_TYST11_zuhszj9s'},
                  {modelID: '88teujp\u0000', manufacturerName: '_TYST11_c88teujp'},
                  {modelID: 'w7cahqs\u0000', manufacturerName: '_TYST11_yw7cahqs'},
                  {modelID: 'w7cahqs', manufacturerName: '_TYST11_yw7cahqs'},
                  {modelID: 'TS0601', manufacturerName: '_TZE200_c88teujp'},
                  {modelID: 'TS0601', manufacturerName: '_TZE200_yw7cahqs'},
                  {modelID: 'TS0601', manufacturerName: '_TZE200_azqp6ssj'},
                  {modelID: 'TS0601', manufacturerName: '_TZE200_bvu2wnxz'},
                  {modelID: 'TS0601', manufacturerName: '_TZE200_zuhszj9s'},
                  {modelID: 'TS0601', manufacturerName: '_TZE200_9gvruqf5'},
                  {modelID: 'TS0601', manufacturerName: '_TZE200_zr9c0day'},
              model: 'SEA801-Zigbee/SEA802-Zigbee',
              vendor: 'Saswell',
              description: 'Thermostatic radiator valve',
              whiteLabel: [{vendor: 'HiHome', model: 'WZB-TRVL'}, {vendor: 'Hama', model: '00176592'},
                  {vendor: 'RTX', model: 'ZB-RT1'}],
              fromZigbee: [fz.saswell_thermostat, fz.ignore_tuya_set_time, fz.ignore_basic_report, fz.legacy.tuya_thermostat_weekly_schedule],
              toZigbee: [tz.saswell_thermostat_current_heating_setpoint, tz.saswell_thermostat_mode, tz.saswell_thermostat_away,
                  tz.saswell_thermostat_child_lock, tz.saswell_thermostat_window_detection, tz.saswell_thermostat_frost_detection,
                  tz.saswell_thermostat_calibration, tz.saswell_thermostat_anti_scaling, tz.tuya_thermostat_weekly_schedule],
              onEvent: tuya.onEventSetTime,
              meta: {
                  thermostat: {
                      weeklyScheduleMaxTransitions: 4,
                      weeklyScheduleSupportedModes: [1], // bits: 0-heat present, 1-cool present (dec: 1-heat,2-cool,3-heat+cool)
                      weeklyScheduleConversion: 'saswell',
              configure: async (device, coordinatorEndpoint, logger) => {
                  const endpoint = device.getEndpoint(1);
                  await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
              exposes: [e.battery_low(), e.window_detection(), e.child_lock(),
                  exposes.binary('heating', ea.STATE, 'ON', 'OFF').withDescription('Device valve is open or closed (heating or not)'),
                  exposes.climate()
                      .withSetpoint('current_heating_setpoint', 5, 30, 0.5, ea.STATE_SET).withLocalTemperature(ea.STATE)
                      .withSystemMode(['off', 'heat', 'auto'], ea.STATE_SET)
                      // Range is -6 - 6 and step 1: https://github.com/Koenkk/zigbee2mqtt/issues/11777
                      .withLocalTemperatureCalibration(-6, 6, 1, ea.STATE_SET)
                      .withAwayMode()],
      		/*added by djung 10.11.2022*/
      	fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_h4cgnbzg'}],
              model: 'HZ',
              vendor: 'HAMA',
              whiteLabel: [{vendor: 'Hama', model: 'XXXxxxXXX'},],
              fromZigbee: [fz.saswell_thermostat],
                  tz.saswell_thermostat_calibration],
              exposes: [
      			e.battery_low(),
      			/*e.switch(),*/
      			/*e.lock(),*/
                  exposes.climate()
      soll man das irgendwo auf github oder so noch posten? Wenn ja, bitte zeigen wo 😃
      Grüße.
      David.
        Thomas Braun Most Active @Diamand2k22 last edited by
        @diamand2k22
        Alles? Das war nur als Denkansatz für dich gedacht.
        Ich hätte da erstmal nur die Manufacturer-ID hinzugefügt. Sind ja schon ein paar Varianten von dem Thermostat mit der Modellbezeichnung TS0601 vorhanden.
          hab die manufactor id eingefügt, jetzt erkennt er das thermostat, liefert aber keine werte!
          2022-11-15 21:35:02.182 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #2 with data {"dp":2,"datatype":4,"data":{"type":"Buffer","data":[2]}}
          2022-11-15 21:35:02.434 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #4 with data {"dp":4,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,50]}}
          2022-11-15 21:35:02.551 - info: dwd.0 (92835) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.18.1, js-controller: 4.0.23
          2022-11-15 21:35:02.555 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #5 with data {"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,200]}}
          2022-11-15 21:35:02.704 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #7 with data {"dp":7,"datatype":1,"data":{"type":"Buffer","data":[0]}}
          2022-11-15 21:35:02.789 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #28 with data {"dp":28,"datatype":0,"data":{"type":"Buffer","data":[1,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
          2022-11-15 21:35:02.906 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #29 with data {"dp":29,"datatype":0,"data":{"type":"Buffer","data":[2,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
          2022-11-15 21:35:03.032 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #30 with data {"dp":30,"datatype":0,"data":{"type":"Buffer","data":[3,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
          2022-11-15 21:35:03.144 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #31 with data {"dp":31,"datatype":0,"data":{"type":"Buffer","data":[4,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
          2022-11-15 21:35:03.264 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #32 with data {"dp":32,"datatype":0,"data":{"type":"Buffer","data":[5,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
          2022-11-15 21:35:03.380 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #33 with data {"dp":33,"datatype":0,"data":{"type":"Buffer","data":[6,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
          2022-11-15 21:35:03.502 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #34 with data {"dp":34,"datatype":0,"data":{"type":"Buffer","data":[7,6,0,0,120,8,0,0,160,18,0,0,220,20,0,0,200]}}
          2022-11-15 21:35:03.615 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #35 with data {"dp":35,"datatype":5,"data":{"type":"Buffer","data":[0]}}
          2022-11-15 21:35:03.731 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #36 with data {"dp":36,"datatype":1,"data":{"type":"Buffer","data":[0]}}
          2022-11-15 21:35:03.848 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #39 with data {"dp":39,"datatype":1,"data":{"type":"Buffer","data":[0]}}
          2022-11-15 21:35:03.968 - warn: zigbee.0 (92569) zigbee-herdsman-converters:SaswellThermostat: Unrecognized DP #47 with data {"dp":47,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}
            Thomas Braun Most Active @Diamand2k22 last edited by Thomas Braun
            @diamand2k22
            Ich kann dir da nicht weiterhelfen.
            Vielleicht weiß @david-jung ja noch was dazu.
              kann es sein, dass mit den Rechten was nicht stimmt?`
              $ iobroker url ioBroker/ioBroker.zigbee --host pi4b --debug
              install ioBroker/ioBroker.zigbee
              NPM version: 8.19.2
              Installing ioBroker/ioBroker.zigbee... (System call)
              npm WARN cleanup Failed to remove some directories [npm WARN cleanup [
              npm WARN cleanup '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV',npm WARN cleanup [Error: EACCES: permission denied, scandir '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'] {npm WARN cleanup errno: -13,npm WARN cleanup code: 'EACCES',npm WARN cleanup syscall: 'scandir',npm WARN cleanup path: '/opt/iobroker/node_modules/.zigbee-herdsman-converters-DzgWyYTV/devices'npm WARN cleanup }npm WARN cleanup ]npm WARN cleanup
                @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                iob stop
                iob fix
                iob start
                  danke dir für die schnelle Rückmeldung.
                  Hab's dann doch selber hinbekommen!
                  • DJMarc75
                    DJMarc75 @Diamand2k22 last edited by
                    Und des Rätsels Lösung war ?
                    Vll hilft das auch anderen Mitlesenden !
                      Diamand2k22 @DJMarc75 last edited by
                      @djmarc75
                      hat Thomas schon geschrieben.
                      iob stop
                      iob fix
                      iob start
                        @diamand2k22
                        Dann hast du da mal mit falschen Rechten hantiert.
                        root login?
                          Diamand2k22 last edited by Diamand2k22
                          kann sein Thomas, hab ich aber wieder hingebogen bekommen.
                          @Asgothian
                          hab mir jetzt ne eigene ketotek.js für mein Heizkörperthermostat gebastelt.
                          Jetzt funktioniert es wunderbar und ich hab keine Unrecognized DP's mehr und kann es steuern und empfange Temperaturen.
                          Was mich nur interessieren würde, wie bekomme ich da ein vernünftiges Bild rein?
                          Kannst du das Thermostat aufnehmen?
                            Patrick Kenzler @Thomas Braun last edited by
                            @thomas-braun könntest du deinen externen Konverter zur Verfügung stellen? Sitze schon seit Tagen und komme nicht weiter.
                              Thomas Braun Most Active @Patrick Kenzler last edited by
                              @patrick-kenzler
                              Meinen was? Wüsste nicht das ich sowas im Einsatz hätte.
                                @thomas-braun sorry, die Frage sollte eigentlich an @Diamand2k22 gehen habe mich verklickt^^
                                  Diamand2k22 @Patrick Kenzler last edited by
                                  @patrick-kenzler
                                  Hast du auch so ein ketotek Teil von Amaz**?
                                    Patrick Kenzler @Diamand2k22 last edited by
                                    @diamand2k22 said in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                    @patrick-kenzler
                                    nein, aber Avatto ME167 das wird auch unter _TZE200_bvu2wnxz geführt.
                                      @patrick-kenzler
                                      06b9e9de-716c-4a03-95a1-94f34a45ccf6-avatto_me167.js
                                      Hab's angepasst für dein ME167 Thermostat.
                                      Probiers mal aus.
                                      Du weißt ja wo die Datei hin muss oder?
                                        @diamand2k22 Danke aber leider bekomme ich Fehler ausgeworfen und der Adapter startet nicht mehr. Naja ich packe den Pfad unter Einstellungen der jeweiligen Zigbee Instanz und die Datei in "/opt/iobroker/iobroker-data/zigbee_2"?!
                                        anbei das protokoll
                                        2022-11-22 07:57:47.563 - error: zigbee.2 (22077) Exception-Code: MODULE_NOT_FOUND: Cannot find module '../lib/exposes'
                                        Require stack:
                                        - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                        2022-11-22 07:57:47.641 - info: zigbee.2 (22077) cleaned everything up...
                                        2022-11-22 07:57:47.645 - info: zigbee.2 (22077) terminating
                                        2022-11-22 07:57:47.648 - warn: zigbee.2 (22077) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2022-11-22 07:57:48.285 - error: host.SmartHome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                        2022-11-22 07:57:48.286 - error: host.SmartHome Caught by controller[1]: node:internal/modules/cjs/loader:936
                                        2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: throw err;
                                        2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: ^
                                        2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: Error: Cannot find module '../lib/exposes'
                                        2022-11-22 07:57:48.288 - error: host.SmartHome Caught by controller[1]: Require stack:
                                        2022-11-22 07:57:48.288 - error: host.SmartHome Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                        2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                        2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                        2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1005:19)
                                        2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at require (node:internal/modules/cjs/helpers:102:18)
                                        2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at evalmachine.:1:17
                                        2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at Script.runInContext (node:vm:139:12)
                                        2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Script.runInNewContext (node:vm:144:17)
                                        2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Object.runInNewContext (node:vm:298:38)
                                        2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:222:16)
                                        2022-11-22 07:57:48.292 - error: host.SmartHome Caught by controller[1]: at getExternalDefinition.next ()
                                        2022-11-22 07:57:48.292 - error: host.SmartHome instance system.adapter.zigbee.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          @patrick-kenzler
                                          kopiere das file nach
                                          und mach den Eintrag bei externe Adapter raus.
                                          Dann Zigbee Adapter neu starten.
                                            @diamand2k22 habs probiert er schmeißt immernoch Fehler 😕 hast du noch eine Idee?
                                            2022-11-22 23:28:11.087	error	instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2022-11-22 23:28:11.087	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                            2022-11-22 23:28:11.087	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js:118:30)
                                            2022-11-22 23:28:11.086	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                                            2022-11-22 23:28:11.086	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
                                            2022-11-22 23:28:11.086	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                            2022-11-22 23:28:11.085	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
                                            2022-11-22 23:28:11.085	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
                                            2022-11-22 23:28:11.084	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1069:27)
                                            2022-11-22 23:28:11.084	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1033:15)
                                            2022-11-22 23:28:11.083	error	Caught by controller[0]: at Object.compileFunction (node:vm:352:18)
                                            2022-11-22 23:28:11.083	error	Caught by controller[0]: SyntaxError: Unexpected identifier
                                            2022-11-22 23:28:11.083	error	Caught by controller[0]: ^^^^^^^^
                                            2022-11-22 23:28:11.083	error	Caught by controller[0]: konstantes Ergebnis = {};
                                            2022-11-22 23:28:11.082	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/06b9e9de-716c-4a03-95a1-94f34a45ccf6-avatto_me167.js:36
                                            herdsman zigbee
                                            13
                                            129
                                            23950
