    4. Adapter "smartmeter"
      Jautze last edited by
      ich habe es nochmal komplett deinstalliert und dann nochmal installiert.
      Aber es sieht nicht so aus als ob die Daten in node_modules/open-sml aktuell sind:
      ! pi@rasp_pv1_goke:/opt/iobroker $ sudo npm uninstall iobroker.smartmeter
      ! - smartmeter-obis@0.5.12 node_modules/iobroker.smartmeter/node_modules/smartmeter-obis
      ! - iobroker.smartmeter@0.5.12 node_modules/iobroker.smartmeter
      ! pi@rasp_pv1_goke:/opt/iobroker $ sudo npm cache clean
      ! pi@rasp_pv1_goke:/opt/iobroker $ sudo npm install https://github.com/Apollon77/ioBroker.smartmeter –production
      ! iobroker@1.0.0 /opt/iobroker
      ! └─┬ iobroker.smartmeter@0.5.12 (git+https://github.com/Apollon77/ioBroker.s ... f4003f6acd)
      ! └── smartmeter-obis@0.5.12
      ! pi@rasp_pv1_goke:/opt/iobroker $ ls -alh /opt/iobroker/node_modules/open-sml/
      ! insgesamt 56K
      ! drwxrwxrwx 4 root root 4,0K Jul 22 02:30 .
      ! drwxr-xr-x 337 root root 12K Jul 24 07:47 ..
      ! -rw-rw-rw- 1 root root 1,9K Jun 12 12:07 Gruntfile.js
      ! -rw-rw-rw- 1 root root 4,1K Jun 12 12:07 index.js
      ! drwxrwxrwx 3 root root 4,0K Jul 22 02:30 lib
      ! -rw-rw-rw- 1 root root 1,1K Jun 12 12:07 LICENSE
      ! -rw-rw-rw- 1 root root 102 Jun 12 12:07 .npmignore
      ! -rw-rw-rw- 1 root root 4,8K Jun 12 12:08 package.json
      ! -rw-rw-rw- 1 root root 1,7K Jun 12 12:07 README.md
      ! drwxrwxrwx 3 root root 4,0K Jul 22 02:30 test
      ! pi@rasp_pv1_goke:/opt/iobroker $ ls -alh /opt/iobroker/node_modules/open-sml/lib/
      ! insgesamt 60K
      ! drwxrwxrwx 3 root root 4,0K Jul 22 02:30 .
      ! drwxrwxrwx 4 root root 4,0K Jul 22 02:30 ..
      ! -rw-rw-rw- 1 root root 2,5K Jun 12 12:07 Constants.js
      ! drwxrwxrwx 3 root root 4,0K Jul 22 02:30 messages
      ! -rw-rw-rw- 1 root root 14K Jun 12 12:07 SmlBuffer.js
      ! -rw-rw-rw- 1 root root 3,0K Jun 12 12:07 SmlCRC.js
      ! -rw-rw-rw- 1 root root 4,3K Jun 12 12:07 SmlFile.js
      ! -rw-rw-rw- 1 root root 4,1K Jun 12 12:07 SmlMessageBody.js
      ! -rw-rw-rw- 1 root root 4,4K Jun 12 12:07 SmlMessage.js
      Viele Grüße
      Marcel Jaud
        apollon77 last edited by
        Interessant … versuch nochmal bitte.
        Falls nicht ersetze mal das File manuell:
        https://github.com/Apollon77/OpenSML/bl ... lBuffer.js
          habe jetzt manuell drüber kopiert.
          Jetzt bekomme ich nur noch:
          host.rasp_pv1_goke 2017-07-24 21:35:41.501 error instance system.adapter.smartmeter.0 terminated with code 1 ()
          host.rasp_pv1_goke 2017-07-24 21:35:40.719 info instance system.adapter.smartmeter.0 started with pid 11153
          host.rasp_pv1_goke 2017-07-24 21:35:35.334 info Restart adapter system.adapter.smartmeter.0 because enabled
          Auch wenn ich nochmal lösche und neu installiere das gleiche.
          Nach der Installation erneuert sich auch nicht das Datum der SmlBuffer.js Datei.
          Viele Grüße
          Marcel Jaud
            Komisch … Dann lösch mal den "open-sml" ordner und installiere dann den Adapter. Sollte dann wieder installiert werden. Falls nicht wirf auch smartmeter-obis weg (oder gleich beides)
              super danke es funktioniert.
              Viele Grüße
              Marcel Jaud
                Könnten die anderen User bitte auch mal auf die Github Version updaten und schauen ob noch alles tut wie bisher?
                Danke!
                  Bei mir läuft alles nach dem Update! 😄
                  Enrico
                    schneidy76 last edited by
                    Hy,
                    $ ./iobroker add smartmeter
                    npm install iobroker.smartmeter --production --prefix "/opt/iobroker" (System call)
                    npm
                    WARN
                    addRemoteGit Error: not found: gitnpm
                    WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                    npm
                    WARN
                    addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
                    npm
                    WARN
                    addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                    npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                    npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
                    npm WARN
                     addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2 because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                    npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
                    npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                    npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
                    npm
                     ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2: undefined
                    npm
                     WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                    npm
                    WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN
                    addRemoteGit
                    npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52 because of error: { Error: not found: git
                         at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
                    npm
                     ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefined
                    npm
                     addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
                    npm
                     WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                    npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac because of error: { Error: not found: git
                         at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                    npm
                     ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefined
                    npm
                     ERR! Linux 4.9.24-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.smartmeter" "--production" "--prefix" "/opt/iobroker"
                    npm ERR! node v6.10.3
                    npm
                     ERR! npm  v3.10.10npm
                     ERR! code ENOGIT
                    npm
                    ERR! not found: gitnpm ERR!
                    npm ERR! Failed using git.
                    npm ERR! This is most likely not a problem with npm itself.
                    npm ERR! Please check if you have git installed and in your PATH.
                    npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
                    host.ioBroker-RasPi install adapter smartmeter
                    npm
                    npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                    npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2 because of error: { Error: not found: git
                    npm WARN
                    npm WARN
                     addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
                    npm
                    npm
                    npm
                    npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefined
                    npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                    npm WARN
                    npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefined
                    npm
                    npm ERR! npm  v3.10.10
                    npm ERR! code ENOGIT
                    npm ERR! not found: git
                    npm ERR!
                    npm
                     WARN
                     addRemoteGit
                     WARN
                     WARN
                     WARN
                    npm
                    npm
                    npm
                    WARN
                     addRemoteGit
                    npm WARN
                     addRemoteGit
                    npm
                    npm
                    npm
                     WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac because of error: { Error: not found: git
                         at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                    npm
                    npm
                    npm
                     ERR!
                    npm ERR!
                     node v6.10.3
                    npm
                     ERR! npm  v3.10.10npm ERR! code ENOGIT
                    npm
                    ERROR: host.ioBroker-RasPi Cannot install smartmeter
                    ERROR: process exited with code 13
                    Ich bekomme den Adapter nicht installiert.
                    Woran kann das liegen?
                      … addRemoteGit Error: not found: git
                      apt-get install git
                        ChristianF last edited by
                        Info: Udo verkauft keine Smartmeter Leseköpfe mehr.
                        Alle Infos hier: https://wiki.volkszaehler.org/hardware/ … sb-ausgang
                          :?: @apollon77:
                          apt-get install git `
                          Das heißt???
                            Du musst git installiert haben. Der Adapter installiert eine Library direkt aus git. Mit Linux geht das per " apt-get install git"
                              Dankeschön, werde ich heute direkt mal testen …
                              Off Topic: Ich kann mich nicht mehr per putty mit root einloggen. Bekomme" Access denied" zurück. Direkt am pi mit Tastatur geht es????
                              • wendy2702
                                wendy2702 last edited by
                                @schneidy76:
                                Off Topic: Ich kann mich nicht mehr per putty mit root einloggen. Bekomme" Access denied" zurück. Direkt am pi mit Tastatur geht es???? `
                                Und wenn du per Putty versuchst dich als User "Pi" einzuloggen ?
                                  Das geht ohne Probleme. Das ist es ja…
                                  • a200
                                    a200 last edited by
                                    @schneidy76:
                                    Das geht ohne Probleme. Das ist es ja… `
                                    Der root Zugang ist von Außen gesperrt. Du kannst entweder dich als pi einloggen und dann:
                                    su -
                                    ausführen. Oder laut Installationsanleitung für ioBroker für Raspberry:
                                    4. Über Putty am Raspberry anmelden. Login: pi, Kennwort: raspberry
                                    5. mit sudo raspi-config die nötige Grundkonfiguration durchführen
                                    6. Root Zugang freischalten
                                    1. sudo nano /etc/ssh/sshd_config
                                    2. Datei anpassen: PermitRootLogin without-password in PermitRootLogin yes ändern und speichern
                                    3. SSH neu starten: sudo /etc/init.d/ssh restart
                                    4. sudo su (jetzt ist der Root Modus gestartet)
                                    5. mit passwd ein Passwort vergeben
                                    6. Ausloggen und als Root über Putty anmelden
                                      @apollon77:
                                      Du musst git installiert haben. Der Adapter installiert eine Library direkt aus git. Mit Linux geht das per " apt-get install git" `
                                      perfekt, super DANKE funktioniert!
                                      Welche Abfrageintervalle hältst du für sinnvoll? 60s?
                                      VG Torsten
                                        An das kann ich mich irgendwie erinnern. Warum auch immer… Lol
                                          ich würde mich hier auch gern einklinken, da ich nicht weiß was ich falsch mache.
                                          Der Zähler den ich gern auswerten würde ich von der Deutschen Zählergesellschaft Oranienburg, Modell DWSE 20.244 (Hersteller: https://www.dzg.de/ , Anleitung hier: http://www.stadtwerke-kaltenkirchen.de/ … %20DSG.pdf 😞
                                          Als Equipment nutze ich den vielfach angesprochenen Auslesekopf von den Volkszähler-Kollegen (auf dem Bild ist noch der nicht funktionierende ELV Kopf zu sehen, da er das genutzte Protokoll leider nicht unterstützt).
                                          Nach allem was ich herausgefunden habe, "spricht" mein Zähler SML. Soweit ich das beurteilen kann erhalte ich auch Daten, aber wohl keine mit denen man was anfangen könnte:
                                          smartmeter.0	2017-07-31 02:29:11.433	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f2128" -> null
                                          smartmeter.0	2017-07-31 02:29:11.406	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f21" -> null
                                          smartmeter.0	2017-07-31 02:29:11.377	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f" -> null
                                          smartmeter.0	2017-07-31 02:29:11.347	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c08" -> null
                                          smartmeter.0	2017-07-31 02:29:11.318	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c" -> null
                                          smartmeter.0	2017-07-31 02:29:11.288	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c78" -> null
                                          smartmeter.0	2017-07-31 02:29:11.258	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c" -> null
                                          smartmeter.0	2017-07-31 02:29:11.229	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e" -> null
                                          smartmeter.0	2017-07-31 02:29:11.202	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b" -> null
                                          smartmeter.0	2017-07-31 02:29:11.170	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c" -> null
                                          smartmeter.0	2017-07-31 02:29:11.139	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c50" -> null
                                          smartmeter.0	2017-07-31 02:29:11.110	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c" -> null
                                          smartmeter.0	2017-07-31 02:29:11.081	debug	MATCH-RESULT MESSAGE: "08780a0d0a" -> null
                                          smartmeter.0	2017-07-31 02:29:11.052	debug	MATCH-RESULT MESSAGE: "08780a0d" -> null
                                          smartmeter.0	2017-07-31 02:29:11.022	debug	MATCH-RESULT MESSAGE: "08780a" -> null
                                          smartmeter.0	2017-07-31 02:29:10.990	debug	MATCH-RESULT MESSAGE: "0878" -> null
                                          smartmeter.0	2017-07-31 02:29:10.976	debug	MATCH-RESULT MESSAGE: "08" -> null
                                          smartmeter.0	2017-07-31 02:29:10.643	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                          smartmeter.0	2017-07-31 02:29:10.642	debug	DONE SEND 0
                                          smartmeter.0	2017-07-31 02:29:10.642	debug	INITIAL MESSAGES TO SEND: 0
                                          smartmeter.0	2017-07-31 02:29:10.642	debug	SERIALPORT RESET BAUDRATE TO 300
                                          smartmeter.0	2017-07-31 02:29:10.642	debug	SERIALPORT OPEN
                                          smartmeter.0	2017-07-31 02:29:10.641	debug	CREATE SERIALPORT: 300 7 1 even
                                          smartmeter.0	2017-07-31 02:29:10.640	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialRequestResponseTransport","requestInterval":"60","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"tra
                                          smartmeter.0	2017-07-31 02:29:10.637	info	starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.4
                                          Diese Daten schießen im Millisekundentakt nach oben. Innerhalb von einer Sekunde ist eine komplette Logseite voll, und die Zahl wird nach obigem Muster immer länger.
                                          EDIT: den unter https://wiki.volkszaehler.org/hardware/ … sb-ausgang ganz unten beschriebenen Test habe ich ebenfalls durchgeführt, und auch die entsprechenden Daten bekommen
                                          0000000 1b 1b 1b 1b 01 01 01 01 76 07 00 0a 00 6f 31 74
                                          0000020 62 00 62 00 72 63 01 01 76 01 01 07 00 0a 00 20
                                          0000040 10 7c 0b 06 45 4d 48 01 04 c5 6b 7d ce 01 01 63
                                          0000060 86 9d 00 76 07 00 0a 00 6f 31 75 62 00 62 00 72
                                          0000100 63 07 01 77 01 0b 06 45 4d 48 01 04 c5 6b 7d ce
                                          0000120 07 01 00 62 0a ff ff 72 62 01 65 00 20 79 be 7a
                                          Hat jemand einen Tipp für mich, was ich tun muss?
                                          Vielen Dank!
                                            Ich denke der Fehler liegt in der Einstellung.
                                            Dein Zähler scheint die Daten direkt zu senden ohne das man Sie anfragen müsste. Oder wie war das bei deinem Test - kam das alles von sich aus?
                                            Dann musst Du im Adapter "Seriell nur lesen" wählen. Dann sollte auch die Baudrate automatisch auf 9600 stehen und die EInstellungen wie beim test sein.
                                            Wenns noch nicht tut nochmal log bitte
                                            Ingo F
                                            3625
                                            2194305
