    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Zigbee usb 3,0 Dongle plus mit EFR32MG 21 Chip
      Horst B @Thomas Braun last edited by Homoran
      zigbee.0
      2022-11-16 17:50:05.216 info Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      2022-11-16 17:50:05.190 error Error herdsman start
      zigbee.0
      2022-11-16 17:50:05.188 error Failed to start Zigbee
      zigbee.0
      2022-11-16 17:50:05.185 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812133736-if00'"
      zigbee.0
      2022-11-16 17:50:05.166 info Starting Zigbee npm ...
      zigbee.0
      2022-11-16 17:50:05.163 info Try to reconnect. 1 attempts left
      admin.0
      2022-11-16 17:49:59.604 info <== Disconnect system.user.admin from ::ffff:192.168.xxx.xxx
      zigbee.0
      2022-11-16 17:49:55.634 info Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      2022-11-16 17:49:55.152 error Error herdsman start
      zigbee.0
      2022-11-16 17:49:55.150 error Failed to start Zigbee
      zigbee.0
      2022-11-16 17:49:55.148 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812133736-if00'"
      zigbee.0
      2022-11-16 17:49:54.308 info Starting Zigbee npm ...
      zigbee.0
      2022-11-16 17:49:54.300 info delete old Backup files. keep only last 10
      zigbee.0
      2022-11-16 17:49:53.979 info starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.23
        Thomas Braun Most Active @Horst B last edited by
        @horst-b
        ls -lA /dev/serial/by-id/
          Horst B @Thomas Braun last edited by Horst B
          @thomas-braun said in Zigbee usb 3,0 Dongle plus mit EFR32MG 21 Chip:
          lrwxrwxrwx 1 root root 13 Nov 15 17:04 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Pl                                      us_V2_20220812133736-if00 -> ../../ttyACM0
            Horst B @Horst B last edited by
            @horst-b ```
            usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812133736-if00 -> ../../ttyACM0
              @horst-b
              Vollständig posten.
                pi@192.168.178.38's password:
                Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aar       ch64
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Wed Nov 16 22:40:37 2022 from 192.168.178.20
                pi@raspberrypi:~ $ lsusb
                Bus 001 Device 005: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongl       e Plus V2
                Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC       9512/9514 Fast Ethernet Adapter
                Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9       514 Hub
                Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                pi@raspberrypi:~ $ ls -lA /dev/serial/by-id/
                total 0
                pi@raspberrypi:~ $
                  Hallo Thomas. Konntest du etwas damit anfangen?
                    @horst-b
                    Hast du auch genau diesen Link in den Adapter kopiert?
                      @thomas-braun Hallo Thomas...Ja habe es gerade nochmal gemacht und passt so..Habe es auch so im Adapter bei Einstellungen eingegeben
                        @ThomasBraun
                        • Z
                          zgadgeter last edited by
                          Mein alter 2531 zigbee scheint kaputt zu sein. Er verliert ständig die Verbindung zu den Iobroker, und wenn er sich verbindet ist das Licht nur Rot, bzw. zeigt er lsusb immer andere Verbindungseinstellungen. Oftmals leuchtet das licht überhaupt nicht, scheint irgendwie auch ein Wackelkontakt zu haben. Andere USB ports machen kein Unterschied.
                          So, also suche ich einen neuen zigbee stick. Momentan gibt es ein Angebot bei Amazon für einen mit diesem Chip (https://www.amazon.de/gp/product/B0B6P22YJC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
                          Kann mir jemand von dem Stick berichten? Gut, stark, muss der noch geflasht werden, etct.
                          Sorry, einfache Fragen....aber vielleicht kann mir jemand helfen? danke
                            Thomas Braun Most Active @zgadgeter last edited by
                            @zgadgeter
                            Der Chipsatz wird als zur Zeit als experimentel bezeichnet:
                            https://www.zigbee2mqtt.io/guide/adapters/#not-recommended
                            Ob und wann das mal als stabil deklariert werden wird...
                            • Z
                              zgadgeter @Thomas Braun last edited by zgadgeter
                              @thomas-braun Hmm, danke der schnellen Antwort. Stellst sich die Frage, welchen neuen sollte mann jetzt nehmen? Ist für eine relative kleine Zweitwohnung. Für unser haus habe ich den TI CC26X2R1, und dieser funktioniert jetzt richtig gut.
                              Was gibt es sonst neues?
                                @zgadgeter
                                Auf der gleichen Seite gibt es noch eine Kategorie 'recommended'.
                                • Z
                                  @thomas-braun Ok, danke. Und hast Du einen Favorit?
                                    @zgadgeter
                                    Ich selber habe den Stick von slaesh im Einsatz. Hier im Forum wird aber im Marktplatz auch immer entsprechendes angeboten. Ich glaube @dimaiv hat da immer was im Portfolio.
                                    • Z
                                      @thomas-braun Ok, danke. bin bei dem @dimaiv fündig geworden.
                                      2440
