    3. Einsteigerfragen
    4. Probleme beim Updaten von iobroker!
      Homoran Global Moderator Administrators @otti last edited by
      @otti sagte in Probleme beim Updaten von iobroker!:
      This upgrade of "admin" will at least introduce the following changes
      das ist leider alles was ich zu dem admin update finde
      was kommt denn bei iobroker upgrade admin --debug ?
      • otti
        otti last edited by
        pi@raspberrypi:/opt/iobroker $ iobroker upgrade admin --debug
        This upgrade of "admin" will at least introduce the following changes:
        -> 6.2.23:
        Prepare for future js-controller versions
        Corrected deletion of objects
        -> 6.2.22:
        Corrected admin4 adapter settings
        -> 6.2.21:
        Corrected small JSON config issue
        -> 6.2.20:
        Corrected GUI issues
        -> 6.2.19:
        Corrected some issues
        -> 6.2.18:
        Corrected GUI bugs on custom settings
        -> 6.2.17:
        Corrected GUI bug on intro tab
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade admin from @5.2.3 to @6.2.23 now? [(y)es, (n)o]: y
        Update admin from @5.2.3 to @6.2.23
        host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
        NPM version: 6.14.16
        Installing iobroker.admin@6.2.23... (System call)
        npm ERR! code ENOTSUP
        npm ERR! notsup Unsupported engine for homebridge-ewelink@8.15.0: wanted: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"} (current: {"node":"14.19.0","npm":"6.14.16"})
        npm ERR! notsup Not compatible with your version of node/npm: homebridge-ewelink@8.15.0
        npm ERR! notsup Required: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"}
        npm ERR! notsup Actual:   {"npm":"6.14.16","node":"14.19.0"}
        npm ERR!     /home/iobroker/.npm/_logs/2022-11-19T17_27_11_829Z-debug.log
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
        host.raspberrypi Adapter "system.adapter.admin.0" is started
          Homoran Global Moderator Administrators @otti last edited by Homoran
          da steht's ja
          otti 1 Reply Last reply Reply Quote 0
          • otti
            otti @Homoran last edited by
            welche Befehle mus ich jetzt eintippen?
              @otti was sagt denn jetzt iobroker update -i ?
                Thomas Braun Most Active @otti last edited by
                @otti
                Du möchtest deine nodeJS-Installation auf die aktuelle Empfehlung v16 heben.
                Siehe meine Signatur.
                • otti
                  otti last edited by
                  @homoran said in Probleme beim Updaten von iobroker!:
                  iobroker update -i
                  code_text
                  ``pi@raspberrypi:/opt/iobroker $ iobroker update -i
                  Used repository: stable
                  Adapter    "admin"        : 6.2.23   , installed 5.2.3  [Updatable]
                  Adapter    "alexa2"       : 3.21.0   , installed 3.11.2 [Updatable]
                  Adapter    "backitup"     : 2.5.4    , installed 2.2.3  [Updatable]
                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                  Adapter    "cloud"        : 4.2.2    , installed 4.1.0  [Updatable]
                  Adapter    "discovery"    : 3.0.5    , installed 2.7.3  [Updatable]
                  Adapter    "ham"          : 5.3.0    , installed 4.0.2  [Updatable]
                  Adapter    "history"      : 2.2.0    , installed 1.10.5 [Updatable]
                  Adapter    "hue"          : 3.7.1    , installed 3.5.31 [Updatable]
                  Adapter    "iot"          : 1.11.9   , installed 1.8.24 [Updatable]
                  Adapter    "javascript"   : 6.0.3    , installed 5.2.13 [Updatable]
                  Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
                  Adapter    "mihome"       : 1.4.0    , installed 1.3.7  [Updatable]
                  Adapter    "mihome-vacuum": 3.8.6    , installed 3.3.1  [Updatable]
                  Adapter    "tuya"         : 3.9.4    , installed 3.6.15 [Updatable]
                  Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
                    @otti soll das heißen dass bei dir homebridge-ewelink, das du anscheinend gar nicht installiert hast, alle updates blockiert?
                    @Thomas-Braun ??
                      Thomas Braun Most Active @Homoran last edited by Thomas Braun
                      Dafür ist der ham-Adapter installiert. Der wird den homebridge-ewelink im Bauch haben.
                        @otti
                        Bei node14 ist übrigens 14.21.1 der letzte Stand.
                        Also Betriebssytem auf Stand halten, am besten in dem Zug gleich auf nodeJS@16 springen.
                        • otti
                          otti last edited by
                          soll ich den ham-Adapter weglöschen,
                          geht aber nicht,hab da ein paar Geräte drüber laufen,
                          sorry Leute ,bekomme gerade von meiner Frau signalisiert das ich Schluss machen soll,wir haben noch Besuch.......
                          trotzdem erstmal vielen Dank an alle die geholfen haben,
                          eventuell ist ja morgen wieder jemand im Forum...
                          mfg otti
                            wir wohnen hier!
                              Thomas Braun Most Active last edited by
                              Nein, du sollst dein Betriebs-System aktuell halten.
                                @homoran sagte in Probleme beim Updaten von iobroker!:
                                wir wohnen hier!
                                Aber die Nachbarschaft ist seltsam hier... 🙂
                                • otti
                                  otti last edited by
                                  Guten Morgen,
                                  der Dummi ist wieder da,
                                  sollte ich den ham-Adapter erstmal weglöschen?
                                  • otti
                                    otti @Thomas Braun last edited by
                                    ja das weis ich jetzt auch,
                                    ich gelobe Besserung,kannst Du mir nochmal verzeihen?
                                    mfg otti
                                      Guten Morgen,
                                      Nein. Hast du dein Betriebssystem auf Stand gebracht?
                                      • otti
                                        otti last edited by
                                        moin,
                                        habe mich mal durchgelesen bei den Links die Du unter deinem Post hast,
                                        jetzt kam diese Fehlermeldung.
                                        E: Failed to fetch http://mirror.netzwerge.de/raspbian/raspbian/pool/main/a/avahi/avahi-daemon_0.8-5+deb11u1_armhf.deb  Error reading from server - read (104: Connection reset by peer) [IP: 185.41.106.155 80]
                                        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                                        • otti
                                          otti last edited by
                                          jetzt versuche ich den Js zu updaten,nach der Anleitung,
                                          dies war die Fehlermeldung
                                          pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                                          │   │   ├── github-from-package@0.0.0 deduped
                                          │ │ │ ├── github-from-package@0.0.0
                                          npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                          npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                          npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                          npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                          npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
                                          npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
                                          npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
                                          npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                          npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                          npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                          npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                          npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
                                          npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
                                          npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
                                          npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                          npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                          npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                          npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
                                          npm ERR! extraneous: eslint@8.9.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
                                          npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
                                          npm ERR! extraneous: eslint-plugin-jest@26.1.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
                                          npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
                                          npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                          npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                          npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                          npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                          npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
                                          npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
                                          npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
                                          npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                          npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                          npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                          npm ERR! extraneous: @typescript-eslint/experimental-utils@5.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/experimental-utils
                                          npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                          npm ERR! extraneous: enquirer@2.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/enquirer
                                          npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
                                          npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
                                          npm ERR! extraneous: node-modules-regexp@1.0.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/node-modules-regexp
                                          npm ERR! extraneous: onigasm@2.2.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/onigasm
                                          npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/progress
                                          npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
                                          npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                          npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                          npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                          npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
                                          • otti
                                            otti last edited by
                                            Moin,
                                            wir können den tread schließen,
                                            Ich kann jetzt tatsächlich meine Adapter updaten,
                                            vielen Dank für eure Hilfe!!!
                                            mfg Thomas
                                            1944
