    3. Einsteigerfragen
    4. Probleme beim Updaten von iobroker!
    • otti
      otti last edited by
      pi@raspberrypi:/opt/iobroker $ iobroker upgrade admin --debug
      This upgrade of "admin" will at least introduce the following changes:
      -> 6.2.23:
      Prepare for future js-controller versions
      Corrected deletion of objects
      -> 6.2.22:
      Corrected admin4 adapter settings
      -> 6.2.21:
      Corrected small JSON config issue
      -> 6.2.20:
      Corrected GUI issues
      -> 6.2.19:
      Corrected some issues
      -> 6.2.18:
      Corrected GUI bugs on custom settings
      -> 6.2.17:
      Corrected GUI bug on intro tab
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade admin from @5.2.3 to @6.2.23 now? [(y)es, (n)o]: y
      Update admin from @5.2.3 to @6.2.23
      host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
      NPM version: 6.14.16
      Installing iobroker.admin@6.2.23... (System call)
      npm ERR! code ENOTSUP
      npm ERR! notsup Unsupported engine for homebridge-ewelink@8.15.0: wanted: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"} (current: {"node":"14.19.0","npm":"6.14.16"})
      npm ERR! notsup Not compatible with your version of node/npm: homebridge-ewelink@8.15.0
      npm ERR! notsup Required: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"}
      npm ERR! notsup Actual:   {"npm":"6.14.16","node":"14.19.0"}
      npm ERR!     /home/iobroker/.npm/_logs/2022-11-19T17_27_11_829Z-debug.log
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      host.raspberrypi Adapter "system.adapter.admin.0" is started
        Homoran Global Moderator Administrators @otti last edited by Homoran
        @otti sagte in Probleme beim Updaten von iobroker!:
        da steht's ja
        otti 1 Reply Last reply Reply Quote 0
        • otti
          otti @Homoran last edited by
          welche Befehle mus ich jetzt eintippen?
            @otti was sagt denn jetzt iobroker update -i ?
              Thomas Braun Most Active @otti last edited by
              @otti
              Du möchtest deine nodeJS-Installation auf die aktuelle Empfehlung v16 heben.
              Siehe meine Signatur.
              • otti
                otti last edited by
                @homoran said in Probleme beim Updaten von iobroker!:
                iobroker update -i
                code_text
                ``pi@raspberrypi:/opt/iobroker $ iobroker update -i
                Used repository: stable
                Adapter    "admin"        : 6.2.23   , installed 5.2.3  [Updatable]
                Adapter    "alexa2"       : 3.21.0   , installed 3.11.2 [Updatable]
                Adapter    "backitup"     : 2.5.4    , installed 2.2.3  [Updatable]
                Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                Adapter    "cloud"        : 4.2.2    , installed 4.1.0  [Updatable]
                Adapter    "discovery"    : 3.0.5    , installed 2.7.3  [Updatable]
                Adapter    "ham"          : 5.3.0    , installed 4.0.2  [Updatable]
                Adapter    "history"      : 2.2.0    , installed 1.10.5 [Updatable]
                Adapter    "hue"          : 3.7.1    , installed 3.5.31 [Updatable]
                Adapter    "iot"          : 1.11.9   , installed 1.8.24 [Updatable]
                Adapter    "javascript"   : 6.0.3    , installed 5.2.13 [Updatable]
                Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
                Adapter    "mihome"       : 1.4.0    , installed 1.3.7  [Updatable]
                Adapter    "mihome-vacuum": 3.8.6    , installed 3.3.1  [Updatable]
                Adapter    "tuya"         : 3.9.4    , installed 3.6.15 [Updatable]
                Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
                  @otti soll das heißen dass bei dir homebridge-ewelink, das du anscheinend gar nicht installiert hast, alle updates blockiert?
                  @Thomas-Braun ??
                    Thomas Braun Most Active @Homoran last edited by Thomas Braun
                    Dafür ist der ham-Adapter installiert. Der wird den homebridge-ewelink im Bauch haben.
                      @otti
                      Bei node14 ist übrigens 14.21.1 der letzte Stand.
                      Also Betriebssytem auf Stand halten, am besten in dem Zug gleich auf nodeJS@16 springen.
                      • otti
                        otti last edited by
                        soll ich den ham-Adapter weglöschen,
                        geht aber nicht,hab da ein paar Geräte drüber laufen,
                        sorry Leute ,bekomme gerade von meiner Frau signalisiert das ich Schluss machen soll,wir haben noch Besuch.......
                        trotzdem erstmal vielen Dank an alle die geholfen haben,
                        eventuell ist ja morgen wieder jemand im Forum...
                        mfg otti
                          wir wohnen hier!
                            Thomas Braun Most Active last edited by
                            Nein, du sollst dein Betriebs-System aktuell halten.
                              @homoran sagte in Probleme beim Updaten von iobroker!:
                              wir wohnen hier!
                              Aber die Nachbarschaft ist seltsam hier... 🙂
                              • otti
                                otti last edited by
                                Guten Morgen,
                                der Dummi ist wieder da,
                                sollte ich den ham-Adapter erstmal weglöschen?
                                • otti
                                  otti @Thomas Braun last edited by
                                  ja das weis ich jetzt auch,
                                  ich gelobe Besserung,kannst Du mir nochmal verzeihen?
                                  mfg otti
                                    Guten Morgen,
                                    Nein. Hast du dein Betriebssystem auf Stand gebracht?
                                    • otti
                                      otti last edited by
                                      moin,
                                      habe mich mal durchgelesen bei den Links die Du unter deinem Post hast,
                                      jetzt kam diese Fehlermeldung.
                                      E: Failed to fetch http://mirror.netzwerge.de/raspbian/raspbian/pool/main/a/avahi/avahi-daemon_0.8-5+deb11u1_armhf.deb  Error reading from server - read (104: Connection reset by peer) [IP: 185.41.106.155 80]
                                      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                                      • otti
                                        otti last edited by
                                        jetzt versuche ich den Js zu updaten,nach der Anleitung,
                                        dies war die Fehlermeldung
                                        pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                                        │   │   ├── github-from-package@0.0.0 deduped
                                        │ │ │ ├── github-from-package@0.0.0
                                        npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                        npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                        npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                        npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                        npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
                                        npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
                                        npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
                                        npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                        npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                        npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                        npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                        npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
                                        npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
                                        npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
                                        npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                        npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                        npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                        npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
                                        npm ERR! extraneous: eslint@8.9.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
                                        npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
                                        npm ERR! extraneous: eslint-plugin-jest@26.1.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
                                        npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
                                        npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                        npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                        npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                        npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                        npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
                                        npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
                                        npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
                                        npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                        npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                        npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                        npm ERR! extraneous: @typescript-eslint/experimental-utils@5.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/experimental-utils
                                        npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                        npm ERR! extraneous: enquirer@2.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/enquirer
                                        npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
                                        npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
                                        npm ERR! extraneous: node-modules-regexp@1.0.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/node-modules-regexp
                                        npm ERR! extraneous: onigasm@2.2.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/onigasm
                                        npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/progress
                                        npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
                                        npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                        npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                        npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                        npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
                                        • otti
                                          otti last edited by
                                          Moin,
                                          wir können den tread schließen,
                                          Ich kann jetzt tatsächlich meine Adapter updaten,
                                          vielen Dank für eure Hilfe!!!
                                          mfg Thomas
                                          1944
