    3. Marktplatz
    4. [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P
      liv-in-sky @dimaiv last edited by
      @dimaiv
      erstmal vielen dank für die schnelle lieferung 🙂
      ich wollte das ganze nun mit zigbee2mqtt installieren
      meine configuration.yaml sieht so aus:
      homeassistant: false
      permit_join: true
      frontend:
         port: 8080
         host: 0.0.0.0
      mqtt:
         base_topic: zigbee2mqtt
         server: mqtt://192.168.178.59:1890
      serial:
         port: 'tcp://192.168.178.141:6638'
      advanced:
         pan_id: 0x1A79
         ext_pan_id: [0xDD, 0xDD, 0xDD, 0xDD, 0xAA, 0xAD, 0xDD, 0xDD]
         channel: 14
         network_key: [0x01, 0x03, 0x05, 0x07, 0x09, 0x0B, 0x0D, 0x0F, 0x00, 0x02, 0x04, 0x06, 0x08, 0x0A>
         last_seen: ISO_8601_local
         homeassistant_legacy_entity_attributes: false
         legacy_api: false
         legacy_availability_payload: false
         output: json
         transmit_power: 20
         log_level: warn
      device_options:
         legacy: false
      availability: true
      beim aufruf des servers kommt aber:
      $ npm start
      > zigbee2mqtt@1.28.2 start
      > node index.js
      Zigbee2MQTT:info  2022-11-20 08:33:09: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-11-20.08-33-09' filename: log.txt
      Zigbee2MQTT:info  2022-11-20 08:33:09: Starting Zigbee2MQTT version 1.28.2 (commit #e66fe85)
      Zigbee2MQTT:info  2022-11-20 08:33:09: Starting zigbee-herdsman (0.14.68)
      Zigbee2MQTT:error 2022-11-20 08:33:09: Error while starting zigbee-herdsman
      Zigbee2MQTT:error 2022-11-20 08:33:09: Failed to start zigbee
      Zigbee2MQTT:error 2022-11-20 08:33:09: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
      Zigbee2MQTT:error 2022-11-20 08:33:09: Exiting...
      Zigbee2MQTT:error 2022-11-20 08:33:09: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
          at SerialPort.<anonymous> (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
          at SerialPort._error (/opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:198:14)
          at /opt/zigbee2mqtt/node_modules/@serialport/stream/lib/index.js:242:12
      irgendwie will er /dev/ttyACM0 - ist aber anders konfiguriert - hättest du eine idee für mich
      crunchip D 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @liv-in-sky last edited by
        @liv-in-sky hast du z2m auch neu gestartet?
          liv-in-sky @crunchip last edited by
          @crunchip ja - habe ich
            @liv-in-sky sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
            bei mir ist das so eingetragen, vllt liegts daran
            serial:
              port: tcp://10.1.20.7:20108
              @crunchip habe es lt: https://forum.iobroker.net/post/693392 gemacht
              aber habe auch mal deines getestet - kommt leider die selbe fehlermeldung
                crunchip Forum Testing Most Active @liv-in-sky last edited by crunchip
                @liv-in-sky na ich meine ohne die ' '
                stick ist erreichbar?
                  @crunchip ohne und mit probiert - mit habe probiert, weil hier:
                  aber ich denke da fehlt was anderes, weil im fehler immer auf den cannot open /dev/ttyACM0 hingewiesen wird
                    @crunchip sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                    wie stell ich das fest - weiß nur er ist im netzwerk mit ip
                      @crunchip
                      könnte es ein problem sein, weil proxmox lxc ??
                        @liv-in-sky vllt passt der port nicht
                        weil proxmox lxc
                        hab ich auch
                        hab von hier installiert
                          dimaiv @liv-in-sky last edited by
                          @liv-in-sky
                          Hier werden nur Verkaufsfragen beantwortet.
                          Bitte für Z2M ein eigenen Thread auf machen.
                          Danke.
                          liv-in-sky Codierknecht 2 Replies Last reply Reply Quote 1
                            @crunchip hast du die anleitung auf der zigbee2mqtt anleitung für linux gemacht ?
                              @dimaiv sorry - mach ich
                                toralt last edited by toralt
                                @dimaiv said in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                                CC1352P2_CC2652P_launchpad_coordinator_xxxxxxxx
                                @dimaiv nachdem ich gestern ein FW update gemacht hatte mir der o.g. Datei ging bei mir leider gar nichts mehr. Alles war langsam, keine Geräte wurden mehr gefunden. Es hat eine Weile gedauert, bis ich darauf gekommen bin, dass ich die falsche FW Datei hatte.
                                Laut https://zig-star.com/radio-docs/quick-start/#1plug-your-device-in konnte ich dann feststellen, dass der Ebyte E72 Chip, welcher bei mir verbaut ist, die CC1352P2_CC2652P_other_coordinator_xxxxxxxxx FW benötigt. Die Erkenntnis hat eine Weile gebraucht. Nochmal neu geflasht und alles ging wieder. Hast Du zwischenzeitlich den Chip gewechselt?
                                Die CC1352P2_CC2652P_launchpad_coordinator_xxxxxxxx FW ist laut Zigstar nur für den RF-STAR Chip. Oder müssten beide gehen und ich hab da was falsch verstanden? Will nur anderen evtl Kummer ersparen 🤘
                                • Kusselin
                                  Kusselin last edited by Kusselin
                                  Hallo Zusammen, ich habe mir jetzt auch solch ein Stick bei Dimaiv bestellt da mein CC2531 langsam abschmiert.
                                  Nun meine Fragen:
                                  1. wenn der Stick kommt, schließe ich den direkt per lAN an dien Unifi switch an... lasse ich da meinen jetzigen CC2531 noch dran und richte parallel den neuen ein.. und ziehe erst dann den CC2531 ab, oder ziehe ich gleich den CC2531 ab?
                                  2. kann ich den neuen Stick jetzt auch mit POE versorgen..langt das?
                                  3. Wenn nicht kann ich mit usb zb Strom vom usb der Fritzbox 7590 holen? Hab keine Steckdosen mehr 🙈
                                  4. Der Port 6638 ist immer gleich oder muss ich den selbst konfigurieren und einstellen?
                                  5. Muss ich zwingend was vor dem Anschließen des neuen Sticks was an der PAN ID ändern oder so?
                                  6. Muss der Adapter zwingend erst ausgeschaltet werden beim anstecken des neuen Sticks?
                                  Sorry für die vielen Fragen..will halt nix falsch machen.
                                  Über die Beantwortung herzlichen Dank.
                                  Gruss
                                  Asgothian BananaJoe 2 Replies Last reply Reply Quote 0
                                  • Asgothian
                                    Asgothian Developer @Kusselin last edited by
                                    @kusselin sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
                                    Nun meine Fragen:
                                    Du kannst ihn direkt anschliessen und die Einrichtung des Sticks selber durchführen (IP herausfinden, sicherstellen das er strom hat etc.
                                    1. kann ich den neuen Stick jetzt auch mit POE versorgen..langt das?
                                    soweit ich weiss nicht.
                                    1. Wenn nicht kann ich mit usb zb Strom vom usb der Fritzbox 7590 holen? Hab keine Steckdosen mehr 🙈
                                    Das müsste eigentlich gehen.
                                    1. Der Port 6638 ist immer gleich oder muss ich den selbst konfigurieren und einstellen?
                                    2. Muss ich zwingend was vor dem Anschließen des neuen Sticks was an der PAN ID ändern oder so?
                                    Nein - das sind alles Parameter des Adapters. Die werden erst interessant wenn du dem Adapter den neuen Stick bekannt machst.
                                    1. Muss der Adapter zwingend erst ausgeschaltet werden beim anstecken des neuen Sticks?
                                    Beim Anstecken - nein. Allerdings macht es Sinn den Adapter anzuhalten wenn du den bestehenden CC2531 abziehst, dann etwas warten und dann erst den Adapter mit den Parametern für den neuen Stick starten (TCP Verbindung, etc.)
                                    Gruss
                                    • BananaJoe
                                      BananaJoe Most Active @Kusselin last edited by
                                      kannst du, siehe Beiträge weiter oben. Du brauchst einen Adapter der aus dem PoE die 5V auf USB-C raushoolt und das Netzwerk durchreicht, z.B. https://www.amazon.de/gp/product/B08HS6NDM2
                                      Ein USB-Kabel von der FritzBox und deren USB Port sollte auch gehen
                                      Wenn du die IP rausbekommen hast - das Ding hat auch eine Weboberfläche wo man dann z.B. auch eine feste IP-Adresse einstellen kann
                                      Kusselin 1 Reply Last reply Reply Quote 0
                                      • Kusselin
                                        Kusselin @BananaJoe last edited by
                                        @bananajoe hi danke dir...ich habe von ubiquiti den poe 24 layer 2 switch.....
                                        Also so direkt über den LAN Port dann gehts nicht?
                                        • BananaJoe
                                          @kusselin nein, nur mit dem Adapter dazwischen. Da ist keine PoE Logik in diesem Gateway. Da passiert dann einfach nichts. Erst wenn du dann extern mit Strom versorgst
                                          Kusselin 1 Reply Last reply Reply Quote 1
                                          • Kusselin
                                            Kusselin @BananaJoe last edited by Kusselin
                                            @bananajoe ok danke Dir dann mach ich’s über die usb Buchse der nebenstehenden fritz7590 die ich für die Telefonie verwende👍
                                            236
                                            52582
