    4. Adapter "smartmeter"
      Jautze last edited by
      super danke es funktioniert.
      Viele Grüße
      Marcel Jaud
        apollon77 last edited by
        Könnten die anderen User bitte auch mal auf die Github Version updaten und schauen ob noch alles tut wie bisher?
        Danke!
          Bei mir läuft alles nach dem Update! 😄
          Enrico
            schneidy76 last edited by
            Hy,
            $ ./iobroker add smartmeter
            npm install iobroker.smartmeter --production --prefix "/opt/iobroker" (System call)
            npm
            WARN
            addRemoteGit Error: not found: gitnpm
            WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
            npm
            WARN
            addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
            npm
            WARN
            addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
            npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
            npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
            npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
            npm WARN
             addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2 because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
            npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
            npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
            npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
            npm
             ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2: undefined
            npm
             WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
            npm
            WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN
            addRemoteGit
            npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52 because of error: { Error: not found: git
                 at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
            npm
             ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefined
            npm
             addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
            npm
             WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
            npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac because of error: { Error: not found: git
                 at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
            npm
             ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefined
            npm
             ERR! Linux 4.9.24-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.smartmeter" "--production" "--prefix" "/opt/iobroker"
            npm ERR! node v6.10.3
            npm
             ERR! npm  v3.10.10npm
             ERR! code ENOGIT
            npm
            ERR! not found: gitnpm ERR!
            npm ERR! Failed using git.
            npm ERR! This is most likely not a problem with npm itself.
            npm ERR! Please check if you have git installed and in your PATH.
            npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
            host.ioBroker-RasPi install adapter smartmeter
            npm
            npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
            npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2 because of error: { Error: not found: git
            npm WARN
            npm WARN
             addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
            npm
            npm
            npm
            npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefined
            npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
            npm WARN
            npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefined
            npm
            npm ERR! npm  v3.10.10
            npm ERR! code ENOGIT
            npm ERR! not found: git
            npm ERR!
            npm
             WARN
             addRemoteGit
             WARN
             WARN
             WARN
            npm
            npm
            npm
            WARN
             addRemoteGit
            npm WARN
             addRemoteGit
            npm
            npm
            npm
             WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac because of error: { Error: not found: git
                 at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
            npm
            npm
            npm
             ERR!
            npm ERR!
             node v6.10.3
            npm
             ERR! npm  v3.10.10npm ERR! code ENOGIT
            npm
            ERROR: host.ioBroker-RasPi Cannot install smartmeter
            ERROR: process exited with code 13
            Ich bekomme den Adapter nicht installiert.
            Woran kann das liegen?
              … addRemoteGit Error: not found: git
              apt-get install git
                ChristianF last edited by
                Info: Udo verkauft keine Smartmeter Leseköpfe mehr.
                Alle Infos hier: https://wiki.volkszaehler.org/hardware/ … sb-ausgang
                  :?: @apollon77:
                  apt-get install git `
                  Das heißt???
                    Du musst git installiert haben. Der Adapter installiert eine Library direkt aus git. Mit Linux geht das per " apt-get install git"
                      Dankeschön, werde ich heute direkt mal testen …
                      Off Topic: Ich kann mich nicht mehr per putty mit root einloggen. Bekomme" Access denied" zurück. Direkt am pi mit Tastatur geht es????
                      • wendy2702
                        wendy2702 last edited by
                        @schneidy76:
                        Off Topic: Ich kann mich nicht mehr per putty mit root einloggen. Bekomme" Access denied" zurück. Direkt am pi mit Tastatur geht es???? `
                        Und wenn du per Putty versuchst dich als User "Pi" einzuloggen ?
                          Das geht ohne Probleme. Das ist es ja…
                          • a200
                            a200 last edited by
                            @schneidy76:
                            Das geht ohne Probleme. Das ist es ja… `
                            Der root Zugang ist von Außen gesperrt. Du kannst entweder dich als pi einloggen und dann:
                            su -
                            ausführen. Oder laut Installationsanleitung für ioBroker für Raspberry:
                            4. Über Putty am Raspberry anmelden. Login: pi, Kennwort: raspberry
                            5. mit sudo raspi-config die nötige Grundkonfiguration durchführen
                            6. Root Zugang freischalten
                            1. sudo nano /etc/ssh/sshd_config
                            2. Datei anpassen: PermitRootLogin without-password in PermitRootLogin yes ändern und speichern
                            3. SSH neu starten: sudo /etc/init.d/ssh restart
                            4. sudo su (jetzt ist der Root Modus gestartet)
                            5. mit passwd ein Passwort vergeben
                            6. Ausloggen und als Root über Putty anmelden
                              @apollon77:
                              Du musst git installiert haben. Der Adapter installiert eine Library direkt aus git. Mit Linux geht das per " apt-get install git" `
                              perfekt, super DANKE funktioniert!
                              Welche Abfrageintervalle hältst du für sinnvoll? 60s?
                              VG Torsten
                                An das kann ich mich irgendwie erinnern. Warum auch immer… Lol
                                  ich würde mich hier auch gern einklinken, da ich nicht weiß was ich falsch mache.
                                  Der Zähler den ich gern auswerten würde ich von der Deutschen Zählergesellschaft Oranienburg, Modell DWSE 20.244 (Hersteller: https://www.dzg.de/ , Anleitung hier: http://www.stadtwerke-kaltenkirchen.de/ … %20DSG.pdf 😞
                                  Als Equipment nutze ich den vielfach angesprochenen Auslesekopf von den Volkszähler-Kollegen (auf dem Bild ist noch der nicht funktionierende ELV Kopf zu sehen, da er das genutzte Protokoll leider nicht unterstützt).
                                  Nach allem was ich herausgefunden habe, "spricht" mein Zähler SML. Soweit ich das beurteilen kann erhalte ich auch Daten, aber wohl keine mit denen man was anfangen könnte:
                                  smartmeter.0	2017-07-31 02:29:11.433	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f2128" -> null
                                  smartmeter.0	2017-07-31 02:29:11.406	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f21" -> null
                                  smartmeter.0	2017-07-31 02:29:11.377	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f" -> null
                                  smartmeter.0	2017-07-31 02:29:11.347	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c08" -> null
                                  smartmeter.0	2017-07-31 02:29:11.318	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c" -> null
                                  smartmeter.0	2017-07-31 02:29:11.288	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c78" -> null
                                  smartmeter.0	2017-07-31 02:29:11.258	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c" -> null
                                  smartmeter.0	2017-07-31 02:29:11.229	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e" -> null
                                  smartmeter.0	2017-07-31 02:29:11.202	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b" -> null
                                  smartmeter.0	2017-07-31 02:29:11.170	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c" -> null
                                  smartmeter.0	2017-07-31 02:29:11.139	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c50" -> null
                                  smartmeter.0	2017-07-31 02:29:11.110	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c" -> null
                                  smartmeter.0	2017-07-31 02:29:11.081	debug	MATCH-RESULT MESSAGE: "08780a0d0a" -> null
                                  smartmeter.0	2017-07-31 02:29:11.052	debug	MATCH-RESULT MESSAGE: "08780a0d" -> null
                                  smartmeter.0	2017-07-31 02:29:11.022	debug	MATCH-RESULT MESSAGE: "08780a" -> null
                                  smartmeter.0	2017-07-31 02:29:10.990	debug	MATCH-RESULT MESSAGE: "0878" -> null
                                  smartmeter.0	2017-07-31 02:29:10.976	debug	MATCH-RESULT MESSAGE: "08" -> null
                                  smartmeter.0	2017-07-31 02:29:10.643	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                  smartmeter.0	2017-07-31 02:29:10.642	debug	DONE SEND 0
                                  smartmeter.0	2017-07-31 02:29:10.642	debug	INITIAL MESSAGES TO SEND: 0
                                  smartmeter.0	2017-07-31 02:29:10.642	debug	SERIALPORT RESET BAUDRATE TO 300
                                  smartmeter.0	2017-07-31 02:29:10.642	debug	SERIALPORT OPEN
                                  smartmeter.0	2017-07-31 02:29:10.641	debug	CREATE SERIALPORT: 300 7 1 even
                                  smartmeter.0	2017-07-31 02:29:10.640	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialRequestResponseTransport","requestInterval":"60","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"tra
                                  smartmeter.0	2017-07-31 02:29:10.637	info	starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.4
                                  Diese Daten schießen im Millisekundentakt nach oben. Innerhalb von einer Sekunde ist eine komplette Logseite voll, und die Zahl wird nach obigem Muster immer länger.
                                  EDIT: den unter https://wiki.volkszaehler.org/hardware/ … sb-ausgang ganz unten beschriebenen Test habe ich ebenfalls durchgeführt, und auch die entsprechenden Daten bekommen
                                  0000000 1b 1b 1b 1b 01 01 01 01 76 07 00 0a 00 6f 31 74
                                  0000020 62 00 62 00 72 63 01 01 76 01 01 07 00 0a 00 20
                                  0000040 10 7c 0b 06 45 4d 48 01 04 c5 6b 7d ce 01 01 63
                                  0000060 86 9d 00 76 07 00 0a 00 6f 31 75 62 00 62 00 72
                                  0000100 63 07 01 77 01 0b 06 45 4d 48 01 04 c5 6b 7d ce
                                  0000120 07 01 00 62 0a ff ff 72 62 01 65 00 20 79 be 7a
                                  Hat jemand einen Tipp für mich, was ich tun muss?
                                  Vielen Dank!
                                    Ich denke der Fehler liegt in der Einstellung.
                                    Dein Zähler scheint die Daten direkt zu senden ohne das man Sie anfragen müsste. Oder wie war das bei deinem Test - kam das alles von sich aus?
                                    Dann musst Du im Adapter "Seriell nur lesen" wählen. Dann sollte auch die Baudrate automatisch auf 9600 stehen und die EInstellungen wie beim test sein.
                                    Wenns noch nicht tut nochmal log bitte
                                    Ingo F
                                      Hallo Ingo,
                                      danke für Deine Hilfe. Habe Deinen Tipp probiert, leider ohne Erfolg:
                                      smartmeter.0	2017-07-31 19:53:56.815	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002fefe00fefefefefefefe02000000100600" -> null
                                      smartmeter.0	2017-07-31 19:53:56.810	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002fefe00fefefefefefefe" -> null
                                      smartmeter.0	2017-07-31 19:53:56.801	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002" -> null
                                      smartmeter.0	2017-07-31 19:53:56.790	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026" -> null
                                      smartmeter.0	2017-07-31 19:53:56.786	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220" -> null
                                      smartmeter.0	2017-07-31 19:53:56.782	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020" -> null
                                      smartmeter.0	2017-07-31 19:53:56.778	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000928266400040006042000064" -> null
                                      smartmeter.0	2017-07-31 19:53:56.774	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000928266400040006042" -> null
                                      smartmeter.0	2017-07-31 19:53:56.770	debug	MATCH-RESULT MESSAGE: "1212121200000000640000000000009282664000" -> null
                                      smartmeter.0	2017-07-31 19:53:56.765	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000" -> null
                                      smartmeter.0	2017-07-31 19:53:56.760	debug	MATCH-RESULT MESSAGE: "121212120000" -> null
                                      smartmeter.0	2017-07-31 19:53:56.144	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                      smartmeter.0	2017-07-31 19:53:56.144	debug	SERIALPORT OPEN
                                      smartmeter.0	2017-07-31 19:53:56.144	debug	CREATE SERIALPORT: 9600 8 1 none
                                      smartmeter.0	2017-07-31 19:53:56.143	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"60","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"transportS
                                      smartmeter.0	2017-07-31 19:53:56.142	info	starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.4
                                      Schade 😞
                                        Ich habe gerade nochmal gelesen was DU oben geschrieben hast: Du hast den Verbindungstest gemacht wie auf der Seite des Zählers beschrieben … und hast Dort Werte gepostet. Die entsprechen aber exakt denen von der volkszaehler-Seite. Also da passt was nicht.
                                        Wenn Du den test machst:Was genau kommt den da an wenn Du es ohne dem Adapter machst.
                                        Ansonsten ist das Log faktisch zu kurz.
                                        Wenn er lauscht und der Zähler sendet gerade dann kann es sein das die ersten Daten von einem "angefangenen Telegram" kommen. Also mal etwas warten und bitte dann nochmal langes log schicken.
                                          stimmt, weil ich nicht schnell genug war, um sie rauszukopieren, da hatte ich die Putty Session schon zu 😉
                                          Hier ein etwas längerer Log:
                                          root@raspi:~# cat /dev/ttyUSB0 | od -tx1
                                          0000000 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                          0000020 80 04 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                          0000040 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                          0000060 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                          0000100 20 40 00 64 00 00 00 00 00 00 92 80 06 40 00 40
                                          0000120 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                          0000140 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                          0000160 00 fe fe 60 40 00 40 00 04 0c 00 70 66 06 00 00
                                          0000200 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                          0000220 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                          0000240 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                          0000260 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 20
                                          0000300 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                          0000320 00 00 00 00 00 00 00 02 00 66 06 00 00 00 00 00
                                          0000340 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                          0000360 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                          0000400 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                          0000420 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                          0000440 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                          0000460 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                          0000500 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 20
                                          0000520 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                          0000540 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                          0000560 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                          0000600 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                          0000620 00 00 42 80 90 00 64 00 00 00 00 00 00 92 80 10
                                          0000640 40 00 40 00 60 42 00 00 60 00 42 80 00 00 00 00
                                          0000660 12 12 12 12 10 00 20 00 12 12 12 12 00 00 00 00
                                          0000700 64 00 00 00 00 00 00 92 80 10 40 00 40 00 60 42
                                          0000720 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
                                          0000740 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
                                          0000760 00 00 1e 62 82 00 00 42 06 06 00 64 00 00 00 00
                                          0001000 00 00 92 80 10 40 00 40 00 60 42 06 00 66 02 20
                                          0001020 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
                                          0001040 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
                                          0001060 04 0c 00 70 66 06 00 00 86 00 02 fe 00 00 00 00
                                          0001100 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
                                          0001120 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
                                          0001140 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
                                          0001160 00 00 00 00 00 00 00 24 00 66 06 00 00 00 00 00
                                          0001200 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 08
                                          0001220 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                          0001240 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
                                          0001260 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
                                          0001300 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
                                          0001320 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
                                          0001340 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                          0001360 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
                                          0001400 12 00 00 40 00 00 00 80 00 66 06 00 00 86 00 00
                                          0001420 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
                                          0001440 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
                                          0001460 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
                                          0001500 78 8e c2 04 20 00 00 00 00 00 42 e2 80 00 64 00
                                          0001520 00 00 00 00 00 92 80 12 40 00 40 00 60 42 00 00
                                          0001540 60 00 42 64 10 00 00 00 12 12 12 12 10 00 08 08
                                          0001560 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                          0001600 80 18 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                          0001620 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                          0001640 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                          0001660 12 00 00 64 00 00 00 00 00 00 92 80 18 40 00 40
                                          0001700 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                          0001720 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                          0001740 00 fe fe 60 40 00 40 00 04 0c 04 70 66 06 00 00
                                          0001760 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                          0002000 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                          0002020 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                          0002040 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 26
                                          0002060 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                          0002100 00 00 00 00 00 00 00 08 00 66 06 00 00 00 00 00
                                          0002120 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                          0002140 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                          0002160 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                          0002200 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                          0002220 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                          0002240 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                          0002260 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 84
                                          0002300 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                          0002320 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                          0002340 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                          0002360 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                          0002400 00 00 42 1c 60 00 64 00 00 00 00 00 00 92 80 1c
                                          0002420 40 00 40 00 60 42 00 00 60 00 42 20 00 00 00 00
                                          0002440 12 12 12 12 10 00 80 c0 12 12 12 12 00 00 00 00
                                          0002460 64 00 00 00 00 00 00 92 80 1e 40 00 40 00 60 42
                                          0002500 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
                                          0002520 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
                                          0002540 00 00 1e 62 82 00 00 42 00 38 00 64 00 00 00 00
                                          0002560 00 00 92 80 00 40 00 40 00 60 42 06 00 66 02 20
                                          0002600 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
                                          0002620 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
                                          0002640 04 0c 00 70 66 06 00 00 86 00 02 fe 00 00 00 00
                                          0002660 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
                                          0002700 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
                                          0002720 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
                                          0002740 00 00 00 00 00 00 00 30 00 66 06 00 00 00 00 00
                                          0002760 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 0c
                                          0003000 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                          0003020 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
                                          0003040 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
                                          0003060 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
                                          0003100 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
                                          0003120 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                          0003140 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
                                          0003160 12 00 00 40 00 00 00 88 00 66 06 00 00 86 00 00
                                          0003200 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
                                          0003220 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
                                          0003240 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
                                          0003260 78 8e c2 04 20 00 00 00 00 00 42 04 04 00 64 00
                                          0003300 00 00 00 00 00 92 80 00 40 00 40 00 60 42 00 00
                                          0003320 60 00 42 20 9c 00 00 00 12 12 12 12 10 00 30 1e
                                          0003340 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                          0003360 80 00 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                          0003400 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                          0003420 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                          0003440 00 04 00 64 00 00 00 00 00 00 92 80 02 40 00 40
                                          0003460 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                          0003500 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                          0003520 00 fe fe 60 40 00 40 00 04 0c 00 70 66 06 00 00
                                          0003540 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                          0003560 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                          0003600 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                          0003620 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 30
                                          0003640 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                          0003660 00 00 00 00 00 00 00 0e 00 66 06 00 00 00 00 00
                                          0003700 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                          0003720 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                          0003740 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                          0003760 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                          0004000 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                          0004020 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                          0004040 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 84
                                          0004060 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                          0004100 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                          0004120 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                          0004140 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                          0004160 00 00 42 00 04 00 64 00 00 00 00 00 00 92 80 00
                                          0004200 40 00 40 00 60 42 00 00 60 00 42 e0 80 00 00 00
                                          0004220 12 12 12 12 10 00 c6 00 12 12 12 12 00 00 00 00
                                          0004240 64 00 00 00 00 00 00 92 80 00 40 00 40 00 60 42
                                          0004260 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
                                          0004300 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
                                          0004320 00 00 1e 62 82 00 00 42 00 00 00 64 00 00 00 00
                                          0004340 00 00 92 80 04 40 00 40 00 60 42 06 00 66 02 20
                                          0004360 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
                                          0004400 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
                                          0004420 04 0c 02 70 66 06 00 00 86 00 02 fe 00 00 00 00
                                          0004440 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
                                          0004460 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
                                          0004500 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
                                          0004520 00 00 00 00 00 00 00 30 00 66 06 00 00 00 00 00
                                          0004540 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 00
                                          0004560 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                          0004600 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
                                          0004620 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
                                          0004640 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
                                          0004660 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
                                          0004700 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                          0004720 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
                                          0004740 12 00 00 40 00 00 00 90 00 66 06 00 00 86 00 00
                                          0004760 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
                                          0005000 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
                                          0005020 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
                                          0005040 78 8e c2 04 20 00 00 00 00 00 42 9c 30 00 64 00
                                          0005060 00 00 00 00 00 92 80 06 40 00 40 00 60 42 00 00
                                          0005100 60 00 42 04 02 00 00 00 12 12 12 12 10 00 00 10
                                          0005120 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                          0005140 80 00 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                          0005160 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                          0005200 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                          0005220 00 92 00 64 00 00 00 00 00 00 92 80 00 40 00 40
                                          0005240 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                          0005260 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                          0005300 00 fe fe 60 40 00 40 00 04 0c 08 70 66 06 00 00
                                          0005320 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                          0005340 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                          0005360 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                          0005400 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 32
                                          0005420 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                          0005440 00 00 00 00 00 00 00 00 00 66 06 00 00 00 00 00
                                          0005460 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                          0005500 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                          0005520 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                          0005540 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                          0005560 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                          0005600 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                          0005620 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 9e
                                          0005640 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                          0005660 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                          0005700 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                          0005720 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                          0005740 00 00 42 20 48 00 64 00 00 00 00 00 00 92 80 00
                                          0005760 40 00 40 00 60 42 00 00 60 00 42 00 18 00 00 00
                                          Viele Grüße
                                          Christian
                                            Ok, damit sind dei Daten so wie Sie auch der smartmeter entfernt. Also irgendwas stimmt nicht mit den Seriellen einstellungen. Die musst Du rausfinden.
                                            Die 9600 baud sollte stimmen, probier mal mit anderen EInstellungen die es sonst so gibt. Oder ruf bei deinem Energieunternehmen oder beim Hersteller an.
                                            Es müsste bei Dir pro Sekunde 1 Telegram kommen.
                                            81.1k
                                            3625
                                            2355256
