    4. Test ioBroker Fixer mit JSONL-Compression
    • da_Woody
      da_Woody @apollon77 last edited by
      @apollon77
      woody@ioBroker:~$ npm -v
      8.19.2
      woody@ioBroker:~$ iob stop
      [sudo] Passwort für woody:
      woody@ioBroker:~$ ls -la /opt/iobroker/iobroker-data/*.jsonl
      -rw-rw-r--+ 1 iobroker iobroker 26161720 20. Nov 06:32 /opt/iobroker/iobroker-data/objects.jsonl
      -rw-rw-r--+ 1 iobroker iobroker 17136842 20. Nov 06:32 /opt/iobroker/iobroker-data/states.jsonl
          Database maintenance (3/4)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
      Latzi 1 Reply Last reply Reply Quote 0
      • Latzi
        Latzi @da_Woody last edited by
        @da_woody
        und wie war die Größe nach dem Fix?
        • da_Woody
          da_Woody @Latzi last edited by
          @latzi sorry, hab ich vergessen zu kopieren... lauft schon wieder...
            apollon77 @da_Woody last edited by
            @da_woody alles gut. Bei euren Größen seidige alle vom „große files“ problem nicht betroffen. Aber log sie ja gut aus. Danke
            • Kalle Blomquist
              Kalle Blomquist @apollon77 last edited by
              @apollon77
              kalle@iobrokerct:~$ npm -v
              8.19.2
              Vorher
              kalle@iobrokerct:~$ kalle@iobrokerct:~$ ls -la /opt/iobroker/iobroker-data/*.jsonl
              -rw-rw-r--+ 1 iobroker iobroker 20807087 20. Nov 09:17 /opt/iobroker/iobroker-data/objects.jsonl
              -rw-rw-r--+ 1 iobroker iobroker  4919960 20. Nov 09:18 /opt/iobroker/iobroker-data/states.jsonl
              Nacher
              -rw-rw-r--+ 1 iobroker iobroker 18449470 20. Nov 09:19 /opt/iobroker/iobroker-data/objects.jsonl
              -rw-rw-r--+ 1 iobroker iobroker  4181835 20. Nov 09:19 /opt/iobroker/iobroker-data/states.jsonl
              Gruß Kalle
                mrjeschke @apollon77 last edited by
                @apollon77
                Moin,
                Ich hoffe das ist groß genug.
                pi@iobroker:~$ ls -la /opt/iobroker/iobroker-data/*.jsonl
                -rw-rwxr--+ 1 iobroker iobroker 145665583 Nov 20 02:40 /opt/iobroker/iobroker-data/objects.jsonl
                -rw-rw-r--+ 1 iobroker iobroker    801992 Nov 20 09:25 /opt/iobroker/iobroker-data/states.jsonl
                pi@iobroker:~$
                -rw-rw-r--+ 1 iobroker iobroker 6821778 Nov 20 09:29 /opt/iobroker/iobroker-data/objects.jsonl
                -rw-rw-r--+ 1 iobroker iobroker  302548 Nov 20 09:29 /opt/iobroker/iobroker-data/states.jsonl
                pi@iobroker:~$
                  apollon77 @mrjeschke last edited by
                  @mrjeschke 145 mb auf 6 wenn ich grad aufm Handy nicht verzählt hab ;-)) aber ja cool. Tut. Dann kann das später raus.
                  • BananaJoe
                    BananaJoe Most Active @apollon77 last edited by
                    @apollon77
                    So aus technischer Neugier - *.jsonl ist doch im Prinzip eine schnöde Textdatei.
                    Wie/was komprimiert er da - also wie schafft er es da Platz zu schaffen? Oder lässt er "nur die Luft raus" und entfernt ungenuztes?
                    WolfgangD apollon77 2 Replies Last reply Reply Quote 0
                    • WolfgangD
                      WolfgangD @BananaJoe last edited by
                      @apollon77 Ich habe nach Systemcrash und Neuaufbau und Rücksicherung der states und objects.jsonl auch gerade "Effekte", die nach kaputter Datenbankstruktur riechen. Objecte tauchen mehrfach auf, alte Werte kommen irgendwie immer wieder hervor. Da kommt mir ein Werkzeug zur Reparatur der Datenbank gerade recht!
                        apollon77 @BananaJoe last edited by
                        @bananajoe Das Konzept von der jsonl Datenbank ist das pro Zeile ein Objekt drin steht und zuerst mal neue Daten ans file angehängt werden. Die standard „Komprimierung“ (also einen stand komplett neu zu schreiben bei dem für jeden key der aktuellste Wert drin steht) passiert an sich mit unseren Einstellungen wenn doppelt so viele Zeilen wie unique Objekte sind.
                        Und ja die Komprimierung räumt da auf. Vor allem da sich Objekte eher selten ändern halbes da Auswirkungen.
                        Der fixer kann so mit aufräumen und so Probleme beim iobroker start falls mal eine date groß wird und die sd Karte langsam ist zu vermeiden
                          apollon77 @WolfgangD last edited by
                          @wolfgangd wobei sowas an sich damit weniger was zu tun haben kann. Aber ja „Schaden kann’s auch nicht“ 😉 aber wenn die Probleme anhalten dann mal in eigenen thread „vorstellen“ 😉
                          • mcm1957
                            mcm1957 @apollon77 last edited by
                            @apollon77
                            Skript gestartet. Keine Probleme.
                            Werte
                            VORHER
                            pi@pi4:~ $ ls -la /opt/iobroker/iobroker-data/*.jsonl
                            -rw-r--r-- 1 iobroker iobroker 20202339 Nov 21 20:24 /opt/iobroker/iobroker-data/objects.jsonl
                            -rw-r--r-- 1 iobroker iobroker 3889023 Nov 21 20:24 /opt/iobroker/iobroker-data/states.jsonl
                            pi@pi4:~ $
                            NACHHER
                            -rw-rw-r--+ 1 iobroker iobroker 8740574 Nov 21 20:27 /opt/iobroker/iobroker-data/objects.jsonl
                            -rw-rw-r--+ 1 iobroker iobroker 956049 Nov 21 20:27 /opt/iobroker/iobroker-data/states.jsonl
                            pi@pi4:~ $
                              Hallo alle miteinander,
                              Für Linux
                              die Version des Fixers, die wir hier im Thread getestet hatten, ist seid gestern auch Live. Wäre cool wenn Ihr nochmal mit checken könntet das es auch mit einem "iob fix" immer noch tut.
                              Und wenn Ihr schon dabei seid wäre cool wenn Ihr auch (nachdem Ihr einmal iob fix gemacht habt!!) danach ein "iob diag" versuchen könntet. Geht das? Da ist bestimmt @Thomas-Braun interessiert ob es da noch Fehler gibt 🙂
                              Für Windows
                              Der Fixer ist jetzt auch unter Windows verfügbar! Wäre cool wenn ich da ggf auch Tester finden ...
                              Im ioBroker Verzeichnis wäre dies das Ausführen von npx @iobroker/fix ... (bei gestopptem ioBroker natürlich).
                              Danke für Euer Feedback
                              Ingo
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @apollon77 last edited by Dr. Bakterius
                                @apollon77 sagte in Test ioBroker Fixer mit JSONL-Compression:
                                iob fix
                                Funktioniert! objects.jsonl von 32751637 -> 20090424, states.jsonl von 20246420 -> 3260086
                                iob diag
                                Da bekomme ich folgenden Fehler:
                                bash: line 1: syntax error near unexpected token `<'
                                bash: line 1: `<!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="icon" href="/www/favicon.ico"/><meta name="viewport" content="width=device-width,initial-scale=1"/><meta name="theme-color" content="#2196F3"><meta name="description" content="Remote access to personal ioBroker server via ioBroker.cloud"/><link rel="apple-touch-icon" href="/www/logo192.png"/><link rel="manifest" href="/www/manifest.json"/><title>ioBroker Cloud</title><style>#root,body,html{height:100%;width:100%;display:flex;overflow:hidden}</style><script defer="defer" src="/www/static/js/main.ae982c84.js"></script><link href="/www/static/css/main.59da0ebb.css" rel="stylesheet"></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div></body></html>'
                                  apollon77 @Dr. Bakterius last edited by
                                  @dr-bakterius Danke, lasse es Bluefox nochmal prüfen
                                    bommel_030 @apollon77 last edited by
                                    @apollon77
                                    für iob diag wie @Dr-Bakterius
                                    bash: Zeile 1: Syntaxfehler beim unerwarteten Symbol »<«
                                    bash: Zeile 1: `<!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="icon" href="/www/favicon.ico"/><meta name="viewport" content="width=device-width,initial-scale=1"/><meta name="theme-color" content="#2196F3"><meta name="description" content="Remote access to personal ioBroker server via ioBroker.cloud"/><link rel="apple-touch-icon" href="/www/logo192.png"/><link rel="manifest" href="/www/manifest.json"/><title>ioBroker Cloud</title><style>#root,body,html{height:100%;width:100%;display:flex;overflow:hidden}</style><script defer="defer" src="/www/static/js/main.ae982c84.js"></script><link href="/www/static/css/main.59da0ebb.css" rel="stylesheet"></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div></body></html>'
                                    für iob fix auf meinem vermanschten System
                                    vorher:
                                    bommel@iobroker:~$ ls -lah /opt/iobroker/iobroker-data/*.jsonl
                                    -rw-rw-r--+ 1 iobroker iobroker  54M 13. Dez 10:52 /opt/iobroker/iobroker-data/objects.jsonl
                                    -rw-rw-r--+ 1 iobroker iobroker 218M 13. Dez 10:52 /opt/iobroker/iobroker-data/states.jsonl
                                    nachher:
                                    bommel@iobroker:/opt/iobroker$ ls -lah /opt/iobroker/iobroker-data/*.jsonl
                                    -rw-rw-r--+ 1 iobroker iobroker 31M 13. Dez 10:53 /opt/iobroker/iobroker-data/objects.jsonl
                                    -rw-rw-r--+ 1 iobroker iobroker 15M 13. Dez 10:53 /opt/iobroker/iobroker-data/states.jsonl
                                      So, "iob diag" sollte jetzt gefixt sein!!
                                      • Latzi
                                        Latzi @apollon77 last edited by Latzi
                                        jup, so ist es! 👏
                                        Edit: Leider wird alles vor der summary in meiner putty-session gelöscht (ich kann zumindest nicht mehr hochscrollen), ist das so gewollt?
                                          mrjeschke @Latzi last edited by
                                          @latzi
                                          Das Script soll beim Start und vor summary auf einen Tastendruck warten.
                                          Das macht es aber leider nicht.
                                            Thomas Braun Most Active @mrjeschke last edited by Thomas Braun
                                            @mrjeschke
                                            Richtig, sollte es.
                                            Tut es auf meiner lokalen Version auch. Muss ich mal buddeln was da jetzt auf dem Server gelandet ist.
                                            echad@chet:~/iob_diag $ diff iob_diag diag.sh
                                            8c8
                                            < SKRIPTV="0.0.8"; #version of this script
                                            > SKRIPTV="2022-12-09"; #version of this script
                                            Bis auf der angepasste Versionsnummer ist das gleich. Keine Ahnung warum das nicht wie vorgesehen funktioniert.
                                            84
                                            5646
