    4. Ring Adapter Problem
    • planetkeane
      planetkeane last edited by
      seit einigen Tagen funktioniert mein Ring-Adapter nicht mehr. Am System habe ich nichts verändert, jedoch den Adapter auf die neuste Version hochgezogen. Hat jemand eine Idee?
      host.ioBroker2
      	2022-11-20 13:20:30.468	info	Restart adapter system.adapter.ring.0 because enabled
      host.ioBroker2
      	2022-11-20 13:20:30.468	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.ioBroker2
      	2022-11-20 13:20:30.468	error	Caught by controller[0]: }
      host.ioBroker2
      	2022-11-20 13:20:30.468	error	Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
      host.ioBroker2
      	2022-11-20 13:20:30.468	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ring/build/lib/ringApiClient.js:7:15) {
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:533:31)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:493:36)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:748:3)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:464:9)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/api/api' is not defined by "exports" in /opt/iobroker/node_modules/ring-client-api/package.json
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: ^
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: throw e;
      host.ioBroker2
      	2022-11-20 13:20:30.467	error	Caught by controller[0]: node:internal/modules/cjs/loader:499
      host.ioBroker2
      	2022-11-20 13:20:30.044	info	instance system.adapter.ring.0 started with pid 312201
        Thomas Braun Most Active @planetkeane last edited by
        @planetkeane
        Welche nodeJS-Version? Ist diese senkrecht installiert?
        • planetkeane
          Ich nutze ioBroker als Docker.
          Die Node Version ist 16.17.1
          Was du mit "senkrecht" meinst, weiß ich leider nicht. Auch aus deiner Signatur konnte ich diesbezüglich nichts finden
          userB@ioBroker2:/opt/iobroker# npm ls | grep -E 'github|ERR'
          ├── iobroker.habpanel@0.5.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.habpanel.git#2b7acb607d832a9450bec5409ff219469eff4b50)
          ├── iobroker.mqtt@2.7.3 (git+ssh://git@github.com/ioBroker/ioBroker.mqtt.git#43438675241701d45ecf95f20e2d5ffa35e0af29)
            @planetkeane sagte in Ring Adapter Problem:
            Dann lies nochmal. Gibt da einen Punkt der sich Check nennt.
              @planetkeane
              https://github.com/iobroker-community-adapters/ioBroker.ring/issues/395
              Xcecc created this issue in iobroker-community-adapters/ioBroker.ring
              closed Paket Pfad kann nicht exportiert werden #395
              • planetkeane
                Danke für den Link. Er beschreibt zwar das Problem, jedoch keine Lösung mit der neusten Version von Ring. So wie im Forum beschrieben, habe ich die 2.0.0-beta.3 installiert. Diese funktioniert tatsächlich auf anhieb.
                  @planetkeane
                  Da muss dem Mainrainer ran, denke ich.
                  • planetkeane
                    Ich lasse es mit dem Adapter erst einmal bleiben. Auch hier bekomme ich Fehlermeldungen im Log. Ich habe ihn nur nutzen wollen, um den Batteriestatus der Kameras zu überwachen. Scheint aber sehr unausgereift der Adapter
