    4. Adapter "smartmeter"
      apollon77 last edited by
      Könnten die anderen User bitte auch mal auf die Github Version updaten und schauen ob noch alles tut wie bisher?
      Danke!
        Bei mir läuft alles nach dem Update! 😄
        Enrico
          schneidy76 last edited by
          Hy,
          $ ./iobroker add smartmeter
          npm install iobroker.smartmeter --production --prefix "/opt/iobroker" (System call)
          npm
          WARN
          addRemoteGit Error: not found: gitnpm
          WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
          npm
          WARN
          addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
          npm
          WARN
          addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
          npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
          npm WARN
           addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2 because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
          npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
          npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
          npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
          npm
           ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2: undefined
          npm
           WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
          npm
          WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN
          addRemoteGit
          npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52 because of error: { Error: not found: git
               at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
          npm
           ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefined
          npm
           addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
          npm
           WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
          npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac because of error: { Error: not found: git
               at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
          npm
           ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefined
          npm
           ERR! Linux 4.9.24-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.smartmeter" "--production" "--prefix" "/opt/iobroker"
          npm ERR! node v6.10.3
          npm
           ERR! npm  v3.10.10npm
           ERR! code ENOGIT
          npm
          ERR! not found: gitnpm ERR!
          npm ERR! Failed using git.
          npm ERR! This is most likely not a problem with npm itself.
          npm ERR! Please check if you have git installed and in your PATH.
          npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
          host.ioBroker-RasPi install adapter smartmeter
          npm
          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
          npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-f43458a2 because of error: { Error: not found: git
          npm WARN
          npm WARN
           addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
          npm
          npm
          npm
          npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/apollon77/OpenSML.git /root/.npm/_git-remotes/git-https-github-com-apollon77-OpenSML-git-28622d52: undefined
          npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
          npm WARN
          npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git@github.com:apollon77/OpenSML.git /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac: undefined
          npm
          npm ERR! npm  v3.10.10
          npm ERR! code ENOGIT
          npm ERR! not found: git
          npm ERR!
          npm
           WARN
           addRemoteGit
           WARN
           WARN
           WARN
          npm
          npm
          npm
          WARN
           addRemoteGit
          npm WARN
           addRemoteGit
          npm
          npm
          npm
           WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)npm WARN addRemoteGit  apollon77/OpenSML resetting remote /root/.npm/_git-remotes/git-github-com-apollon77-OpenSML-git-6ff02cac because of error: { Error: not found: git
               at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
          npm
          npm
          npm
           ERR!
          npm ERR!
           node v6.10.3
          npm
           ERR! npm  v3.10.10npm ERR! code ENOGIT
          npm
          ERROR: host.ioBroker-RasPi Cannot install smartmeter
          ERROR: process exited with code 13
          Ich bekomme den Adapter nicht installiert.
          Woran kann das liegen?
            … addRemoteGit Error: not found: git
            apt-get install git
              ChristianF last edited by
              Info: Udo verkauft keine Smartmeter Leseköpfe mehr.
              Alle Infos hier: https://wiki.volkszaehler.org/hardware/ … sb-ausgang
                :?: @apollon77:
                apt-get install git `
                Das heißt???
                  Du musst git installiert haben. Der Adapter installiert eine Library direkt aus git. Mit Linux geht das per " apt-get install git"
                    Dankeschön, werde ich heute direkt mal testen …
                    Off Topic: Ich kann mich nicht mehr per putty mit root einloggen. Bekomme" Access denied" zurück. Direkt am pi mit Tastatur geht es????
                    • wendy2702
                      wendy2702 last edited by
                      @schneidy76:
                      Off Topic: Ich kann mich nicht mehr per putty mit root einloggen. Bekomme" Access denied" zurück. Direkt am pi mit Tastatur geht es???? `
                      Und wenn du per Putty versuchst dich als User "Pi" einzuloggen ?
                        Das geht ohne Probleme. Das ist es ja…
                        • a200
                          a200 last edited by
                          @schneidy76:
                          Das geht ohne Probleme. Das ist es ja… `
                          Der root Zugang ist von Außen gesperrt. Du kannst entweder dich als pi einloggen und dann:
                          su -
                          ausführen. Oder laut Installationsanleitung für ioBroker für Raspberry:
                          4. Über Putty am Raspberry anmelden. Login: pi, Kennwort: raspberry
                          5. mit sudo raspi-config die nötige Grundkonfiguration durchführen
                          6. Root Zugang freischalten
                          1. sudo nano /etc/ssh/sshd_config
                          2. Datei anpassen: PermitRootLogin without-password in PermitRootLogin yes ändern und speichern
                          3. SSH neu starten: sudo /etc/init.d/ssh restart
                          4. sudo su (jetzt ist der Root Modus gestartet)
                          5. mit passwd ein Passwort vergeben
                          6. Ausloggen und als Root über Putty anmelden
                            @apollon77:
                            Du musst git installiert haben. Der Adapter installiert eine Library direkt aus git. Mit Linux geht das per " apt-get install git" `
                            perfekt, super DANKE funktioniert!
                            Welche Abfrageintervalle hältst du für sinnvoll? 60s?
                            VG Torsten
                              An das kann ich mich irgendwie erinnern. Warum auch immer… Lol
                                ich würde mich hier auch gern einklinken, da ich nicht weiß was ich falsch mache.
                                Der Zähler den ich gern auswerten würde ich von der Deutschen Zählergesellschaft Oranienburg, Modell DWSE 20.244 (Hersteller: https://www.dzg.de/ , Anleitung hier: http://www.stadtwerke-kaltenkirchen.de/ … %20DSG.pdf 😞
                                Als Equipment nutze ich den vielfach angesprochenen Auslesekopf von den Volkszähler-Kollegen (auf dem Bild ist noch der nicht funktionierende ELV Kopf zu sehen, da er das genutzte Protokoll leider nicht unterstützt).
                                Nach allem was ich herausgefunden habe, "spricht" mein Zähler SML. Soweit ich das beurteilen kann erhalte ich auch Daten, aber wohl keine mit denen man was anfangen könnte:
                                smartmeter.0	2017-07-31 02:29:11.433	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f2128" -> null
                                smartmeter.0	2017-07-31 02:29:11.406	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f21" -> null
                                smartmeter.0	2017-07-31 02:29:11.377	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c084f" -> null
                                smartmeter.0	2017-07-31 02:29:11.347	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c08" -> null
                                smartmeter.0	2017-07-31 02:29:11.318	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c780c" -> null
                                smartmeter.0	2017-07-31 02:29:11.288	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c78" -> null
                                smartmeter.0	2017-07-31 02:29:11.258	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e4c" -> null
                                smartmeter.0	2017-07-31 02:29:11.229	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b0e" -> null
                                smartmeter.0	2017-07-31 02:29:11.202	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c5b" -> null
                                smartmeter.0	2017-07-31 02:29:11.170	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c504c" -> null
                                smartmeter.0	2017-07-31 02:29:11.139	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c50" -> null
                                smartmeter.0	2017-07-31 02:29:11.110	debug	MATCH-RESULT MESSAGE: "08780a0d0a0c" -> null
                                smartmeter.0	2017-07-31 02:29:11.081	debug	MATCH-RESULT MESSAGE: "08780a0d0a" -> null
                                smartmeter.0	2017-07-31 02:29:11.052	debug	MATCH-RESULT MESSAGE: "08780a0d" -> null
                                smartmeter.0	2017-07-31 02:29:11.022	debug	MATCH-RESULT MESSAGE: "08780a" -> null
                                smartmeter.0	2017-07-31 02:29:10.990	debug	MATCH-RESULT MESSAGE: "0878" -> null
                                smartmeter.0	2017-07-31 02:29:10.976	debug	MATCH-RESULT MESSAGE: "08" -> null
                                smartmeter.0	2017-07-31 02:29:10.643	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                smartmeter.0	2017-07-31 02:29:10.642	debug	DONE SEND 0
                                smartmeter.0	2017-07-31 02:29:10.642	debug	INITIAL MESSAGES TO SEND: 0
                                smartmeter.0	2017-07-31 02:29:10.642	debug	SERIALPORT RESET BAUDRATE TO 300
                                smartmeter.0	2017-07-31 02:29:10.642	debug	SERIALPORT OPEN
                                smartmeter.0	2017-07-31 02:29:10.641	debug	CREATE SERIALPORT: 300 7 1 even
                                smartmeter.0	2017-07-31 02:29:10.640	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialRequestResponseTransport","requestInterval":"60","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"tra
                                smartmeter.0	2017-07-31 02:29:10.637	info	starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.4
                                Diese Daten schießen im Millisekundentakt nach oben. Innerhalb von einer Sekunde ist eine komplette Logseite voll, und die Zahl wird nach obigem Muster immer länger.
                                EDIT: den unter https://wiki.volkszaehler.org/hardware/ … sb-ausgang ganz unten beschriebenen Test habe ich ebenfalls durchgeführt, und auch die entsprechenden Daten bekommen
                                0000000 1b 1b 1b 1b 01 01 01 01 76 07 00 0a 00 6f 31 74
                                0000020 62 00 62 00 72 63 01 01 76 01 01 07 00 0a 00 20
                                0000040 10 7c 0b 06 45 4d 48 01 04 c5 6b 7d ce 01 01 63
                                0000060 86 9d 00 76 07 00 0a 00 6f 31 75 62 00 62 00 72
                                0000100 63 07 01 77 01 0b 06 45 4d 48 01 04 c5 6b 7d ce
                                0000120 07 01 00 62 0a ff ff 72 62 01 65 00 20 79 be 7a
                                Hat jemand einen Tipp für mich, was ich tun muss?
                                Vielen Dank!
                                  Ich denke der Fehler liegt in der Einstellung.
                                  Dein Zähler scheint die Daten direkt zu senden ohne das man Sie anfragen müsste. Oder wie war das bei deinem Test - kam das alles von sich aus?
                                  Dann musst Du im Adapter "Seriell nur lesen" wählen. Dann sollte auch die Baudrate automatisch auf 9600 stehen und die EInstellungen wie beim test sein.
                                  Wenns noch nicht tut nochmal log bitte
                                  Ingo F
                                    Hallo Ingo,
                                    danke für Deine Hilfe. Habe Deinen Tipp probiert, leider ohne Erfolg:
                                    smartmeter.0	2017-07-31 19:53:56.815	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002fefe00fefefefefefefe02000000100600" -> null
                                    smartmeter.0	2017-07-31 19:53:56.810	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002fefe00fefefefefefefe" -> null
                                    smartmeter.0	2017-07-31 19:53:56.801	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026262002" -> null
                                    smartmeter.0	2017-07-31 19:53:56.790	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220222026" -> null
                                    smartmeter.0	2017-07-31 19:53:56.786	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020202220" -> null
                                    smartmeter.0	2017-07-31 19:53:56.782	debug	MATCH-RESULT MESSAGE: "12121212000000006400000000000092826640004000604200006400022020" -> null
                                    smartmeter.0	2017-07-31 19:53:56.778	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000928266400040006042000064" -> null
                                    smartmeter.0	2017-07-31 19:53:56.774	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000928266400040006042" -> null
                                    smartmeter.0	2017-07-31 19:53:56.770	debug	MATCH-RESULT MESSAGE: "1212121200000000640000000000009282664000" -> null
                                    smartmeter.0	2017-07-31 19:53:56.765	debug	MATCH-RESULT MESSAGE: "121212120000000064000000000000" -> null
                                    smartmeter.0	2017-07-31 19:53:56.760	debug	MATCH-RESULT MESSAGE: "121212120000" -> null
                                    smartmeter.0	2017-07-31 19:53:56.144	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                    smartmeter.0	2017-07-31 19:53:56.144	debug	SERIALPORT OPEN
                                    smartmeter.0	2017-07-31 19:53:56.144	debug	CREATE SERIALPORT: 9600 8 1 none
                                    smartmeter.0	2017-07-31 19:53:56.143	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"60","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"transportS
                                    smartmeter.0	2017-07-31 19:53:56.142	info	starting. Version 0.5.12 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.8.4
                                    Schade 😞
                                      Ich habe gerade nochmal gelesen was DU oben geschrieben hast: Du hast den Verbindungstest gemacht wie auf der Seite des Zählers beschrieben … und hast Dort Werte gepostet. Die entsprechen aber exakt denen von der volkszaehler-Seite. Also da passt was nicht.
                                      Wenn Du den test machst:Was genau kommt den da an wenn Du es ohne dem Adapter machst.
                                      Ansonsten ist das Log faktisch zu kurz.
                                      Wenn er lauscht und der Zähler sendet gerade dann kann es sein das die ersten Daten von einem "angefangenen Telegram" kommen. Also mal etwas warten und bitte dann nochmal langes log schicken.
                                        stimmt, weil ich nicht schnell genug war, um sie rauszukopieren, da hatte ich die Putty Session schon zu 😉
                                        Hier ein etwas längerer Log:
                                        root@raspi:~# cat /dev/ttyUSB0 | od -tx1
                                        0000000 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                        0000020 80 04 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                        0000040 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                        0000060 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                        0000100 20 40 00 64 00 00 00 00 00 00 92 80 06 40 00 40
                                        0000120 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                        0000140 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                        0000160 00 fe fe 60 40 00 40 00 04 0c 00 70 66 06 00 00
                                        0000200 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                        0000220 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                        0000240 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                        0000260 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 20
                                        0000300 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                        0000320 00 00 00 00 00 00 00 02 00 66 06 00 00 00 00 00
                                        0000340 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                        0000360 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                        0000400 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                        0000420 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                        0000440 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                        0000460 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                        0000500 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 20
                                        0000520 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                        0000540 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                        0000560 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                        0000600 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                        0000620 00 00 42 80 90 00 64 00 00 00 00 00 00 92 80 10
                                        0000640 40 00 40 00 60 42 00 00 60 00 42 80 00 00 00 00
                                        0000660 12 12 12 12 10 00 20 00 12 12 12 12 00 00 00 00
                                        0000700 64 00 00 00 00 00 00 92 80 10 40 00 40 00 60 42
                                        0000720 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
                                        0000740 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
                                        0000760 00 00 1e 62 82 00 00 42 06 06 00 64 00 00 00 00
                                        0001000 00 00 92 80 10 40 00 40 00 60 42 06 00 66 02 20
                                        0001020 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
                                        0001040 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
                                        0001060 04 0c 00 70 66 06 00 00 86 00 02 fe 00 00 00 00
                                        0001100 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
                                        0001120 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
                                        0001140 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
                                        0001160 00 00 00 00 00 00 00 24 00 66 06 00 00 00 00 00
                                        0001200 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 08
                                        0001220 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                        0001240 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
                                        0001260 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
                                        0001300 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
                                        0001320 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
                                        0001340 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                        0001360 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
                                        0001400 12 00 00 40 00 00 00 80 00 66 06 00 00 86 00 00
                                        0001420 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
                                        0001440 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
                                        0001460 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
                                        0001500 78 8e c2 04 20 00 00 00 00 00 42 e2 80 00 64 00
                                        0001520 00 00 00 00 00 92 80 12 40 00 40 00 60 42 00 00
                                        0001540 60 00 42 64 10 00 00 00 12 12 12 12 10 00 08 08
                                        0001560 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                        0001600 80 18 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                        0001620 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                        0001640 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                        0001660 12 00 00 64 00 00 00 00 00 00 92 80 18 40 00 40
                                        0001700 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                        0001720 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                        0001740 00 fe fe 60 40 00 40 00 04 0c 04 70 66 06 00 00
                                        0001760 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                        0002000 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                        0002020 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                        0002040 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 26
                                        0002060 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                        0002100 00 00 00 00 00 00 00 08 00 66 06 00 00 00 00 00
                                        0002120 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                        0002140 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                        0002160 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                        0002200 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                        0002220 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                        0002240 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                        0002260 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 84
                                        0002300 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                        0002320 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                        0002340 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                        0002360 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                        0002400 00 00 42 1c 60 00 64 00 00 00 00 00 00 92 80 1c
                                        0002420 40 00 40 00 60 42 00 00 60 00 42 20 00 00 00 00
                                        0002440 12 12 12 12 10 00 80 c0 12 12 12 12 00 00 00 00
                                        0002460 64 00 00 00 00 00 00 92 80 1e 40 00 40 00 60 42
                                        0002500 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
                                        0002520 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
                                        0002540 00 00 1e 62 82 00 00 42 00 38 00 64 00 00 00 00
                                        0002560 00 00 92 80 00 40 00 40 00 60 42 06 00 66 02 20
                                        0002600 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
                                        0002620 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
                                        0002640 04 0c 00 70 66 06 00 00 86 00 02 fe 00 00 00 00
                                        0002660 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
                                        0002700 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
                                        0002720 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
                                        0002740 00 00 00 00 00 00 00 30 00 66 06 00 00 00 00 00
                                        0002760 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 0c
                                        0003000 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                        0003020 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
                                        0003040 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
                                        0003060 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
                                        0003100 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
                                        0003120 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                        0003140 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
                                        0003160 12 00 00 40 00 00 00 88 00 66 06 00 00 86 00 00
                                        0003200 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
                                        0003220 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
                                        0003240 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
                                        0003260 78 8e c2 04 20 00 00 00 00 00 42 04 04 00 64 00
                                        0003300 00 00 00 00 00 92 80 00 40 00 40 00 60 42 00 00
                                        0003320 60 00 42 20 9c 00 00 00 12 12 12 12 10 00 30 1e
                                        0003340 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                        0003360 80 00 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                        0003400 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                        0003420 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                        0003440 00 04 00 64 00 00 00 00 00 00 92 80 02 40 00 40
                                        0003460 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                        0003500 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                        0003520 00 fe fe 60 40 00 40 00 04 0c 00 70 66 06 00 00
                                        0003540 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                        0003560 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                        0003600 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                        0003620 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 30
                                        0003640 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                        0003660 00 00 00 00 00 00 00 0e 00 66 06 00 00 00 00 00
                                        0003700 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                        0003720 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                        0003740 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                        0003760 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                        0004000 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                        0004020 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                        0004040 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 84
                                        0004060 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                        0004100 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                        0004120 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                        0004140 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                        0004160 00 00 42 00 04 00 64 00 00 00 00 00 00 92 80 00
                                        0004200 40 00 40 00 60 42 00 00 60 00 42 e0 80 00 00 00
                                        0004220 12 12 12 12 10 00 c6 00 12 12 12 12 00 00 00 00
                                        0004240 64 00 00 00 00 00 00 92 80 00 40 00 40 00 60 42
                                        0004260 00 00 64 00 02 20 20 20 22 20 22 20 26 26 20 02
                                        0004300 fe fe fe fe fe fe fe fe fe fe 02 00 00 00 10 06
                                        0004320 00 00 1e 62 82 00 00 42 00 00 00 64 00 00 00 00
                                        0004340 00 00 92 80 04 40 00 40 00 60 42 06 00 66 02 20
                                        0004360 20 20 22 20 22 20 26 26 20 02 00 00 00 10 06 00
                                        0004400 00 1e 62 82 06 00 00 40 00 fe fe 60 40 00 40 00
                                        0004420 04 0c 02 70 66 06 00 00 86 00 02 fe 00 00 00 00
                                        0004440 00 00 10 06 00 66 06 00 00 00 00 00 fe 00 00 00
                                        0004460 00 02 00 00 00 10 06 00 00 1e 62 82 00 66 06 00
                                        0004500 00 00 00 00 fe 40 00 00 00 00 00 40 1c 00 fe 10
                                        0004520 00 00 00 00 00 00 00 30 00 66 06 00 00 00 00 00
                                        0004540 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 00
                                        0004560 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                        0004600 00 00 00 00 00 00 10 e0 00 66 06 00 00 00 00 00
                                        0004620 fe 40 00 00 00 00 00 40 1c 00 fe 10 00 00 00 00
                                        0004640 00 40 18 00 00 66 06 00 00 00 00 00 fe 00 00 40
                                        0004660 1c 00 fe 10 00 00 00 00 00 40 30 62 00 66 06 00
                                        0004700 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                        0004720 00 00 02 e6 00 66 06 00 00 0e 06 00 fe 00 00 40
                                        0004740 12 00 00 40 00 00 00 90 00 66 06 00 00 86 00 00
                                        0004760 fe 00 00 00 00 02 00 30 70 ce 40 20 00 04 00 08
                                        0005000 18 80 86 00 10 3e 06 44 06 0e 32 26 02 00 12 20
                                        0005020 00 20 90 10 06 08 10 00 00 00 0c 90 06 18 04 30
                                        0005040 78 8e c2 04 20 00 00 00 00 00 42 9c 30 00 64 00
                                        0005060 00 00 00 00 00 92 80 06 40 00 40 00 60 42 00 00
                                        0005100 60 00 42 04 02 00 00 00 12 12 12 12 10 00 00 10
                                        0005120 12 12 12 12 00 00 00 00 64 00 00 00 00 00 00 92
                                        0005140 80 00 40 00 40 00 60 42 00 00 64 00 02 20 20 20
                                        0005160 22 20 22 20 26 26 20 02 fe fe fe fe fe fe fe fe
                                        0005200 fe fe 02 00 00 00 10 06 00 00 1e 62 82 00 00 42
                                        0005220 00 92 00 64 00 00 00 00 00 00 92 80 00 40 00 40
                                        0005240 00 60 42 06 00 66 02 20 20 20 22 20 22 20 26 26
                                        0005260 20 02 00 00 00 10 06 00 00 1e 62 82 06 00 00 40
                                        0005300 00 fe fe 60 40 00 40 00 04 0c 08 70 66 06 00 00
                                        0005320 86 00 02 fe 00 00 00 00 00 00 10 06 00 66 06 00
                                        0005340 00 00 00 00 fe 00 00 00 00 02 00 00 00 10 06 00
                                        0005360 00 1e 62 82 00 66 06 00 00 00 00 00 fe 40 00 00
                                        0005400 00 00 00 40 1c 00 fe 10 00 00 00 00 00 00 00 32
                                        0005420 00 66 06 00 00 00 00 00 fe 00 00 40 1c 00 fe 10
                                        0005440 00 00 00 00 00 00 00 00 00 66 06 00 00 00 00 00
                                        0005460 fe 00 00 40 1c 00 fe 10 00 00 00 00 00 00 10 e0
                                        0005500 00 66 06 00 00 00 00 00 fe 40 00 00 00 00 00 40
                                        0005520 1c 00 fe 10 00 00 00 00 00 40 18 00 00 66 06 00
                                        0005540 00 00 00 00 fe 00 00 40 1c 00 fe 10 00 00 00 00
                                        0005560 00 40 30 62 00 66 06 00 00 00 00 00 fe 00 00 40
                                        0005600 1c 00 fe 10 00 00 00 00 00 00 02 e6 00 66 06 00
                                        0005620 00 0e 06 00 fe 00 00 40 12 00 00 40 00 00 00 9e
                                        0005640 00 66 06 00 00 86 00 00 fe 00 00 00 00 02 00 30
                                        0005660 70 ce 40 20 00 04 00 08 18 80 86 00 10 3e 06 44
                                        0005700 06 0e 32 26 02 00 12 20 00 20 90 10 06 08 10 00
                                        0005720 00 00 0c 90 06 18 04 30 78 8e c2 04 20 00 00 00
                                        0005740 00 00 42 20 48 00 64 00 00 00 00 00 00 92 80 00
                                        0005760 40 00 40 00 60 42 00 00 60 00 42 00 18 00 00 00
                                        Viele Grüße
                                        Christian
                                          Ok, damit sind dei Daten so wie Sie auch der smartmeter entfernt. Also irgendwas stimmt nicht mit den Seriellen einstellungen. Die musst Du rausfinden.
                                          Die 9600 baud sollte stimmen, probier mal mit anderen EInstellungen die es sonst so gibt. Oder ruf bei deinem Energieunternehmen oder beim Hersteller an.
                                          Es müsste bei Dir pro Sekunde 1 Telegram kommen.
                                            @apollon77:
                                            Es müsste bei Dir pro Sekunde 1 Telegram kommen. `
                                            Naja, unsere Stadtwerke vertreten die Einstellung "Am Zähler haben Sie nix zu suchen, Finger weg!".. Da ist wohl wenig Hilfe zu erwarten.. Ich werde mal ein bisschen Einstellungen fummeln, mal sehen was passiert…
                                            Übrigens, ist es richtig dass sich in den Objekten noch kein smartmeter.0 Ordner gebildet hat? Es gibt nur ein Systemobjekt smartmeter.0, aber mehr auch nicht...
                                            1.2k
                                            3625
                                            2372324
