    4. flot gibt Werte abweichend wieder
      MiPl @Homoran last edited by
        Homoran Global Moderator Administrators @MiPl last edited by Homoran
        @mipl und die Konfiguration des charts?
        was ist das für eine Darstellung?
        so sieht flot bei mir nicht aus
          MiPl @Homoran last edited by MiPl
          hier die Einstellung in Flot für die Tagesansicht
          http://192.168.1.50:8083/flot/index.html?l%5B0%5D%5Bid%5D=modbus.0.holdingRegisters.226.789_PV_power&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23fff300&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=W&l%5B0%5D%5Bname%5D=Solarleistung+W&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5Bsmoothing%5D=20&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B1%5D%5Bid%5D=modbus.0.holdingRegisters.100.843_Battery_State_of_Charge_(System)&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%230600ff&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=%25&l%5B1%5D%5Bname%5D=Batterieladezustand+SOC&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5BafterComma%5D=1&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5Bsmoothing%5D=20&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bxaxe%5D=off&timeType=relative&relativeEnd=now&range=1440&aggregateType=count&aggregateSpan=300&title=Solareinstrahlung+Tag&titlePos=top%3A35%3Bleft%3A50&titleColor=%23ffffff&titleSize=10&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=300&legend=sw&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m.&noBorder=noborder&x_labels_color=%23ffffff&y_labels_color=%23ffffff&border_color=%23ffffff
          und hier für die Monatsansicht:
          http://192.168.1.50:8083/flot/index.html?l%5B0%5D%5Bid%5D=modbus.0.holdingRegisters.226.789_PV_power&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23fff300&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=W&l%5B0%5D%5Bname%5D=Solarleistung+W&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5Bsmoothing%5D=20&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B1%5D%5Bid%5D=modbus.0.holdingRegisters.100.843_Battery_State_of_Charge_(System)&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%230600ff&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=%25&l%5B1%5D%5Bname%5D=Batterieladezustand+SOC&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5BafterComma%5D=1&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5Bsmoothing%5D=20&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bxaxe%5D=off&timeType=relative&relativeEnd=now&range=1m&aggregateType=count&aggregateSpan=300&title=Solareinstrahlung+Tag&titlePos=top%3A35%3Bleft%3A50&titleColor=%23ffffff&titleSize=10&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=300&legend=sw&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m.&noBorder=noborder&x_labels_color=%23ffffff&y_labels_color=%23ffffff&border_color=%23ffffff
          Du hast Recht, dass die Darstellung aus VIS kommt.
          Homoran bahnuhr 2 Replies Last reply Reply Quote 0
            @mipl sagte in flot gibt Werte abweichend wieder:
            also weiter Einflüsse durch Browsercache, Rendering usw! 😞
            bitte immer alle relevanten Informationen von Anfang an mitliefern.
            diesmal wäre ein Screenshot besser. da wühl ich mich am Handy nicht durch den Bandwurm-URL
            also zwei verschiedene Einstellungen/flots?
            nicht nur das Zeitintervall geändert?
              hier zwei Screenshots aus Flot
              Tagesansicht und Monatsansicht. Ich habe nur die Zeit geändert und die Voransicht aktualisiert. Die Y-Achse (hier leider in weiß nur schwer zu sehen) ist unterschiedlich.
              Randnotiz: Die höhe der Kurven ändert sich auch, wenn man bei Aggregation die Werte ändert. Das habe ich jetzt aber nicht gemacht.
              • bahnuhr
                bahnuhr Forum Testing Most Active @MiPl last edited by
                @mipl
                Dann leg doch, wie oben schon geschrieben einen Max wert fest. dann ist y immer gleich.
                Und so wird auch die im Verhältnis gleich aussehen.
                  MiPl @bahnuhr last edited by
                  @bahnuhr
                  klar, könnte ich machen. Aber im Wiki steht ja, dass die Anzeige dynamisch ist, wenn man keinen Wert eingibt. Und gerade bei unterschiedlichen Umgebungsbedingungen ist dies gerade gewünscht, damit man mit den Graphen noch was anfangen kann.
                    das ist genau das was ich meinte mit
                    @homoran sagte in flot gibt Werte abweichend wieder:
                    @bahnuhr sagte in flot gibt Werte abweichend wieder:
                    Das hört sich alles richtig an.
                    eher nicht, aber... wenn....
                    ich gehe mal davon aus, dass...
                    die Zeitspanne auf 1 Monat
                    auch die
                    Zeitspanne 1 Tag
                    enthält.
                    aber,....
                    und,.....
                    kann man erst was zu sagen wenn man alles weiß
                    das ist die Ursache, mit anderer Aggregation wird anders geglättet
                      wie ich schrieb habe ich die Werte nicht geändert bei den beiden übermittelten Darstellungen. Sieht man ja auch auf den Screenshots.
                        geglättet kann ich ja verstehen, aber Maximum von ca. 150 W auf ca. 40 W verändert!?
                        • bahnuhr
                          @mipl
                          Ich hör jetzt hier auf; habe solche Probleme nicht.
                          Und ehrlich gesagt, ich versteh das Problem auch nicht.
                          Bei mir wird flot immer so angezeigt wie ich es gerne hätte.
                            ja, wenn nur kurze Peaks auf eine große Zeit geglättet werden fallen die hohen Werte weg.
                            beim Zoomen kommen sie wieder.
                            Also vorsichtig mit den Aggregationseinstellungen
                              ich möchte ja nicht nerven, aber sieh mal hier:
                              Verändert sich irgendwie. Habe nichts gemacht, außer gewartet.
                                klar, die Werte pro Zeiteinheit (Integral) ändern sich im Laufcder Kurvenerstellung und damit auch die der Aggregation zugrunde Liegende Datenbasis.
                                Jetzt ist der Peak vollständig und beteits eine längere Zeit "fertig"
                                  die Werte an der y-achse und auch die Kurven selbst ändern sich:
                                  zuerst:
                                  nach einer Wartezeit:
                                  Ist das vielleicht Berechnungszeit, die benötigt wird?
                                    ich kann das sehr schlecht sehen. ostfriesische Kriegsflagge mit weißem Adler auf weißem Grund ist besser zu erkennen
                                      ok, hier nochmal mit schwarzer Schrift:
                                      Monatsansicht direkt nach Aktualisierung der Ansicht in Flot:
                                      und hier nochmal nach Wartezeit:
                                      Aber es handelt sich ja um die Monatsansicht = mehr Daten = längere Berechnung? Bei Tagesansicht geht daher vielleicht schneller? Ich werde es mal mit einem noch längeren Zeitraumm testen und die Zeit messen.
                                        eher nicht. Muss mit der Aggregation zu tun haben.
                                        du hast nur 300 Datenpunkte, stell die mal höher.
                                        oder nur schwaches Frontend? schlechte Datenübertragung?
                                          hier mit Anzahl = 1000
                                          mit Anzahl = 2000
                                          Die Ausschläge steigen, sind aber nicht bei dem eigentlichen Wert.
                                          Und mit Wartezeit:
                                          Was meinst Du mit schwachem Frontend? Der Pi3?
                                            der sollte nur das Backend sein (hoffentlich)
                                            Das Tablet auf dem du es darstellst muss das rechnen.
                                            1571
