    4. Test Adapter EnOcean v0.8.x
    • Jey Cee
      Jey Cee Developer @ares44 last edited by
      @ares44 mach mal ein upload.
      Expertenmodus einschalten -> Adapter Tab -> enocean Karte auf die 3 Punkte klicken -> rechts unten pfeil nach oben.
      Und nicht auf der Kommandozeile rum Hampeln, man kann alles nötig im Admin machen und der kümmert sich dann um das nötige.
        ares44 @Jey Cee last edited by
        @jey-cee Bitteschön:
        "nodeVersion": "v16.18.1",
        "serialDevices": [
        "/dev/ttyAMA0",
        "/dev/ttyUSB0",
        "/dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DB_FTO62XB-if00-port0"
        "instance": {
        "native": {
        "serialport": "/dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEGZ-if00-port0",
        "ser2net": false,
        "ser2net-ip": "",
        "ser2net-port": "",
        "esp2Switch": false,
        "gateway": "usb300",
        "device-id": "",
        "device-name": ""
        "version": "0.8.4"
        "devices": [
        "_id": "enocean.1.gateway",
        "native": {
        "BaseID": "ffcd6f80",
        "AppVersion": "2.11.1.0",
        "ApiVersion": "2.6.3.0",
        "ChipID": "01a69adf",
        "ChipVersion": "454f0103",
        "AppDescription": "GATEWAYCTRL",
        "senderIDs": {
        "ffcd6f81": "ffb9f981",
        "ffcd6f82": "ffb9f983",
        "ffcd6f83": "ffb9f984",
        "ffcd6f84": "ffb9f985",
        "ffcd6f85": "ffb9f986",
        "ffcd6f86": "ffb9f987",
        "ffcd6f87": "ffb9f988",
        "ffcd6f88": "041105bb",
        "ffcd6f89": "",
        "ffcd6f8a": "",
        "ffcd6f8b": "",
        "ffcd6f8c": "",
        "ffcd6f8d": "",
        "ffcd6f8e": "",
        "ffcd6f8f": "",
        "ffcd6f90": "",
        "ffcd6f91": "",
        "ffcd6f92": "",
        "ffcd6f93": "",
        "ffcd6f94": "",
        "ffcd6f95": "",
        "ffcd6f96": "",
        "ffcd6f97": "",
        "ffcd6f98": "",
        "ffcd6f99": "",
        "ffcd6f9a": "",
        "ffcd6f9b": "",
        "ffcd6f9c": "",
        "ffcd6f9d": "",
        "ffcd6f9e": "",
        "ffcd6f9f": "",
        "ffcd6fa0": "",
        "ffcd6fa1": "",
        "ffcd6fa2": "",
        "ffcd6fa3": "",
        "ffcd6fa4": "",
        "ffcd6fa5": "",
        "ffcd6fa6": "",
        "ffcd6fa7": "",
        "ffcd6fa8": "",
        "ffcd6fa9": "",
        "ffcd6faa": "",
        "ffcd6fab": "",
        "ffcd6fac": "",
        "ffcd6fad": "",
        "ffcd6fae": "",
        "ffcd6faf": "",
        "ffcd6fb0": "",
        "ffcd6fb1": "",
        "ffcd6fb2": "",
        "ffcd6fb3": "",
        "ffcd6fb4": "",
        "ffcd6fb5": "",
        "ffcd6fb6": "",
        "ffcd6fb7": "",
        "ffcd6fb8": "",
        "ffcd6fb9": "",
        "ffcd6fba": "",
        "ffcd6fbb": "",
        "ffcd6fbc": "",
        "ffcd6fbd": "",
        "ffcd6fbe": "",
        "ffcd6fbf": "",
        "ffcd6fc0": "",
        "ffcd6fc1": "",
        "ffcd6fc2": "",
        "ffcd6fc3": "",
        "ffcd6fc4": "",
        "ffcd6fc5": "",
        "ffcd6fc6": "",
        "ffcd6fc7": "",
        "ffcd6fc8": "",
        "ffcd6fc9": "",
        "ffcd6fca": "",
        "ffcd6fcb": "",
        "ffcd6fcc": "",
        "ffcd6fcd": "",
        "ffcd6fce": "",
        "ffcd6fcf": "",
        "ffcd6fd0": "",
        "ffcd6fd1": "",
        "ffcd6fd2": "",
        "ffcd6fd3": "",
        "ffcd6fd4": "",
        "ffcd6fd5": "",
        "ffcd6fd6": "",
        "ffcd6fd7": "",
        "ffcd6fd8": "",
        "ffcd6fd9": "",
        "ffcd6fda": "",
        "ffcd6fdb": "",
        "ffcd6fdc": "",
        "ffcd6fdd": "",
        "ffcd6fde": "",
        "ffcd6fdf": "",
        "ffcd6fe0": "",
        "ffcd6fe1": "",
        "ffcd6fe2": "",
        "ffcd6fe3": "",
        "ffcd6fe4": "",
        "ffcd6fe5": "",
        "ffcd6fe6": "",
        "ffcd6fe7": "",
        "ffcd6fe8": "",
        "ffcd6fe9": "",
        "ffcd6fea": "",
        "ffcd6feb": "",
        "ffcd6fec": "",
        "ffcd6fed": "",
        "ffcd6fee": "",
        "ffcd6fef": "",
        "ffcd6ff0": "",
        "ffcd6ff1": "",
        "ffcd6ff2": "",
        "ffcd6ff3": "",
        "ffcd6ff4": "",
        "ffcd6ff5": "",
        "ffcd6ff6": "",
        "ffcd6ff7": "",
        "ffcd6ff8": "",
        "ffcd6ff9": "",
        "ffcd6ffa": "",
        "ffcd6ffb": "",
        "ffcd6ffc": "",
        "ffcd6ffd": "",
        "ffcd6ffe": ""
        "BaseID_offset": 8
        "native": {
        "id": "ffb9f981",
        "eep": [
        "TF-14-04",
        "TF-13-04"
        "manufacturer": "ELTAKO",
        "Sender_ID": "ffcd6f81"
        "_id": "enocean.1.ffb9f981"
        "native": {
        "id": "ffb9f983",
        "eep": [
        "TF-13-07",
        "TF-13-06"
        "Sender_ID": "ffcd6f82",
        "baseIDoffset": 1
        "_id": "enocean.1.ffb9f983"
        "native": {
        "id": "ffb9f984",
        "eep": [
        "TF-13-07",
        "TF-13-06"
        "Sender_ID": "ffcd6f83",
        "baseIDoffset": 2
        "_id": "enocean.1.ffb9f984"
        "native": {
        "id": "ffb9f985",
        "eep": [
        "TF-14-01",
        "TF-14-02"
        "Sender_ID": "ffcd6f84",
        "baseIDoffset": 3
        "_id": "enocean.1.ffb9f985"
        "native": {
        "id": "ffb9f986",
        "eep": [
        "TF-14-01",
        "TF-14-02"
        "Sender_ID": "ffcd6f85",
        "baseIDoffset": 4
        "_id": "enocean.1.ffb9f986"
        "native": {
        "id": "ffb9f987",
        "eep": [
        "TF-14-01",
        "TF-14-02"
        "Sender_ID": "ffcd6f86",
        "baseIDoffset": 5
        "_id": "enocean.1.ffb9f987"
        "native": {
        "id": "ffb9f988",
        "eep": [
        "TF-14-01",
        "TF-14-02"
        "Sender_ID": "ffcd6f87",
        "baseIDoffset": 6
        "_id": "enocean.1.ffb9f988"
        "native": {
        "id": "0587b9ef",
        "eep": [
        "D2-05-00"
        "manufacturer": "ID_RF"
        "_id": "enocean.1.0587b9ef"
        "native": {
        "id": "041105bb",
        "eep": [
        "TF-13-03",
        "TF-13-04"
        "Sender_ID": "ffcd6f88",
        "baseIDoffset": 8
        "_id": "enocean.1.041105bb"
        • Jey Cee
          @ares44 also der Nodon hat keine Sender ID bekommen, das sollte er Eigentlich. Wobei ich mir nicht sicher bin ob er die Wirklich braucht.
          Aber was mich Stutzig macht, der in der Konfiguration eingetragene Stick passt nicht zu dem Verfügbaren Stick.
            @jey-cee Das ist interessant. Der USB-515 ist am Hauptrechner angeschlossen. Das ist die Instanz 0. USB300 ist an Instanz 1 angeschlossen, die auf dem Slave läuft.
              ares44 @ares44 last edited by
              @ares44 Ich glaube, da geht beim Sammeln der Info was schief. Sieh mal den Screenshot.
              iobroker-slave2 ist der korrekte raspi. Dort läuft die Instanz 1 mit USB300. Das angegebene Device gibt es da nicht.
              • Jey Cee
                @ares44 Ja schon gefunden er hat es immer von instanz 0 geholt.
                @ares44 sagte in Test Adapter EnOcean v0.8.x:
                Anlernen habe ich mich an die Doku gehalten Beim FJ62 die ID eintragen, Aktor in Lernmodus und dann teachin.
                Die Eltako Aktoren bestätigen normal den Erfolgreichen Anlernvorgang mit AB, Halt. Aber Achtung nach 2 Minuten wird der Anlernvorgang beendet und mit dem selben verhalten angezeigt.
                Hat der Aktor das vor ablauf der 2 Minuten getan?
                A 2 Replies Last reply Reply Quote 0
                  @jey-cee Der fj62 hat es meine ich nicht bestätigt. Beim nodon habe ich extra ein reset vorher durchgeführt um keine Altlasten zu haben.
                  • Jey Cee
                    Dann hängt es schon beim Anlernen.
                      @jey-cee Ok, reset am fj62, dann neu programmiert und diesmal kam die Bestätigung und nun geht es auch.
                      Darum versuche ich wo es geht auf die 14er Reihe zu gehen. Dann kann man wenigstens man nachschauen was er gespeichert hat.
                      Diese Bestätigung müsste doch auch zu einem Bestätigungstelegramm führen. Kann man das im Adapter nicht auswerten oder machst du das schon?
                      • Jey Cee
                        Ja, aber das ist einfach nur ein Telegram mit dem Aktuellen Zustand. Das ist für den Anlernvorgang nicht zu gebrauchen.
                        Auch bei den Automatischen Anlernvorgängen kommt es immer wieder vor das es nicht klappt. Das ganze ist, speziell bei Eltako, recht wackelig.
                        Ich glaub beim FJ62 hab ich es deswegen sogar auf manuell umgestellt.
                          Black-Raven last edited by
                          ich bin absoluter Neuling was den ioBroker angeht. Ich habe im Haus einen Eltako Bus verbaut und würde diesen gerne mit dem ioBroker ansprechen. Über ein FAM-USB-515 hab ich das auch hinbekommen, kann aber die FTS14EM Module nicht verwenden, weshalb ich gerne das FGW14-USB Gateway nutzen würde. Unter FHEM hat das jahrelang sehr gut funktioniert aber unter ioBroker bekomm ichs einfach nicht zum laufen. Ich kann zwar Protokolle in den Bus senden und Aktoren steuern aber ich bekomm keinerlei Rückmeldung über den Zustand der Aktoren oder der FTS14EM. Gibts hierfür ne DAUsichere Anleitung? In der Doku steht man müsse den ESP2-Modus in der Adapterkonfiguration aktivieren, um den FGW14 verwenden zu können, aber wie?
                          • Jey Cee
                            Jey Cee Developer @Black-Raven last edited by
                            @black-raven sagte in Test Adapter EnOcean v0.8.x:
                            Nö hat sich keiner die Mühe gemacht.
                            Ah das ist noch aus der Zeit wo man das selber machen musste. Geht jetzt alles Automatisch.
                            Normal kenn ich das nur anders herum, das steuern klappt nicht, aber Rückmeldungen kommen.
                            Zeig doch mal den Text aus dem Tab Support information aus der Adapterkonfiguration. Bitte in code Tags.
                              Black-Raven @Jey Cee last edited by
                              @jey-cee Erstmal Danke für die schnelle Antwort und die Mühe um den Adapter. So jetzt hab ich die beiden Gateways mal gegenübergestellt und jeweils den gleichen Aktor eingelernt.
                              FGW14:
                                "serialDevices": [
                                  "/dev/ttyUSB0",
                                  "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH05TOEX-if00-port0"
                                "instance": {
                                  "native": {
                                    "serialport": "/dev/ttyUSB0",
                                    "ser2net": false,
                                    "ser2net-ip": "",
                                    "ser2net-port": "",
                                    "gateway": "fgw14-usb",
                                    "device-id": "",
                                    "device-name": ""
                                  "version": "0.8.4",
                                  "installedFrom": "Jey-Cee/ioBroker.enocean#dd123fbf39b837136258b79d10117c49e4befb03"
                                "devices": [
                                    "_id": "enocean.0.gateway",
                                    "native": {
                                      "BaseID": "00010000",
                                      "Frequency": "868.3 Mhz",
                                      "Protocol": "ESP2",
                                      "AppVersion": "1.0.0.0",
                                      "ApiVersion": "1.0.0.0",
                                      "ChipID": "00000001",
                                      "ChipVersion": "00000001",
                                      "AppDescription": "Eltako RS485 Bus Gateway",
                                      "senderIDs": {
                                        "10001": "ffaf7291",
                                        "10002": "",
                                        "10003": "",
                                        "10004": "",
                                        "10005": "",
                                        "10006": "",
                                        "10007": "",
                                        "10008": "",
                                        "10009": "",
                                        "10010": "",
                                        "10011": "",
                                        "10012": "",
                                        "10013": "",
                                        "10014": "",
                                        "10015": "",
                                        "10016": "",
                                        "10017": "",
                                        "10018": "",
                                        "10019": "",
                                        "10020": "",
                                        "10021": "",
                                        "10022": "",
                                        "10023": "",
                                        "10024": "",
                                        "10025": "",
                                        "10026": "",
                                        "10027": "",
                                        "10028": "",
                                        "10029": "",
                                        "10030": "",
                                        "10031": "",
                                        "10032": "",
                                        "10033": "",
                                        "10034": "",
                                        "10035": "",
                                        "10036": "",
                                        "10037": "",
                                        "10038": "",
                                        "10039": "",
                                        "10040": "",
                                        "10041": "",
                                        "10042": "",
                                        "10043": "",
                                        "10044": "",
                                        "10045": "",
                                        "10046": "",
                                        "10047": "",
                                        "10048": "",
                                        "10049": "",
                                        "10050": "",
                                        "10051": "",
                                        "10052": "",
                                        "10053": "",
                                        "10054": "",
                                        "10055": "",
                                        "10056": "",
                                        "10057": "",
                                        "10058": "",
                                        "10059": "",
                                        "10060": "",
                                        "10061": "",
                                        "10062": "",
                                        "10063": "",
                                        "10064": "",
                                        "10065": "",
                                        "10066": "",
                                        "10067": "",
                                        "10068": "",
                                        "10069": "",
                                        "10070": "",
                                        "10071": "",
                                        "10072": "",
                                        "10073": "",
                                        "10074": "",
                                        "10075": "",
                                        "10076": "",
                                        "10077": "",
                                        "10078": "",
                                        "10079": "",
                                        "1000a": "",
                                        "1000b": "",
                                        "1000c": "",
                                        "1000d": "",
                                        "1000e": "",
                                        "1000f": "",
                                        "1001a": "",
                                        "1001b": "",
                                        "1001c": "",
                                        "1001d": "",
                                        "1001e": "",
                                        "1001f": "",
                                        "1002a": "",
                                        "1002b": "",
                                        "1002c": "",
                                        "1002d": "",
                                        "1002e": "",
                                        "1002f": "",
                                        "1003a": "",
                                        "1003b": "",
                                        "1003c": "",
                                        "1003d": "",
                                        "1003e": "",
                                        "1003f": "",
                                        "1004a": "",
                                        "1004b": "",
                                        "1004c": "",
                                        "1004d": "",
                                        "1004e": "",
                                        "1004f": "",
                                        "1005a": "",
                                        "1005b": "",
                                        "1005c": "",
                                        "1005d": "",
                                        "1005e": "",
                                        "1005f": "",
                                        "1006a": "",
                                        "1006b": "",
                                        "1006c": "",
                                        "1006d": "",
                                        "1006e": "",
                                        "1006f": "",
                                        "1007a": "",
                                        "1007b": "",
                                        "1007c": "",
                                        "1007d": "",
                                        "1007e": ""
                                      "BaseID_offset": 0
                                    "native": {
                                      "id": "ffaf7291",
                                      "eep": [
                                        "TF-14-01",
                                        "TF-14-02"
                                      "Sender_ID": "10001"
                                    "_id": "enocean.0.ffaf7291"
                              FAM USB 515:
                                "serialDevices": [
                                  "/dev/ttyUSB0",
                                  "/dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEG7-if00-port0"
                                "instance": {
                                  "native": {
                                    "ser2net": false,
                                    "ser2net-ip": "",
                                    "ser2net-port": "",
                                    "device-id": "",
                                    "device-name": ""
                                  "version": "0.8.4",
                                "devices": [
                                    "native": {
                                      "BaseID": "ffa6b180",
                                      "Protocol": "ERP1",
                                      "AppVersion": "1.6.1.0",
                                      "ApiVersion": "1.5.1.231",
                                      "ChipID": "04224d63",
                                      "AppDescription": "TCM515",
                                      "senderIDs": {
                                        "ffa6b181": "ffaf7291",
                                        "ffa6b182": "",
                                        "ffa6b183": "",
                                        "ffa6b184": "",
                                        "ffa6b185": "",
                                        "ffa6b186": "",
                                        "ffa6b187": "",
                                        "ffa6b188": "",
                                        "ffa6b189": "",
                                        "ffa6b18a": "",
                                        "ffa6b18b": "",
                                        "ffa6b18c": "",
                                        "ffa6b18d": "",
                                        "ffa6b18e": "",
                                        "ffa6b18f": "",
                                        "ffa6b190": "",
                                        "ffa6b191": "",
                                        "ffa6b192": "",
                                        "ffa6b193": "",
                                        "ffa6b194": "",
                                        "ffa6b195": "",
                                        "ffa6b196": "",
                                        "ffa6b197": "",
                                        "ffa6b198": "",
                                        "ffa6b199": "",
                                        "ffa6b19a": "",
                                        "ffa6b19b": "",
                                        "ffa6b19c": "",
                                        "ffa6b19d": "",
                                        "ffa6b19e": "",
                                        "ffa6b19f": "",
                                        "ffa6b1a0": "",
                                        "ffa6b1a1": "",
                                        "ffa6b1a2": "",
                                        "ffa6b1a3": "",
                                        "ffa6b1a4": "",
                                        "ffa6b1a5": "",
                                        "ffa6b1a6": "",
                                        "ffa6b1a7": "",
                                        "ffa6b1a8": "",
                                        "ffa6b1a9": "",
                                        "ffa6b1aa": "",
                                        "ffa6b1ab": "",
                                        "ffa6b1ac": "",
                                        "ffa6b1ad": "",
                                        "ffa6b1ae": "",
                                        "ffa6b1af": "",
                                        "ffa6b1b0": "",
                                        "ffa6b1b1": "",
                                        "ffa6b1b2": "",
                                        "ffa6b1b3": "",
                                        "ffa6b1b4": "",
                                        "ffa6b1b5": "",
                                        "ffa6b1b6": "",
                                        "ffa6b1b7": "",
                                        "ffa6b1b8": "",
                                        "ffa6b1b9": "",
                                        "ffa6b1ba": "",
                                        "ffa6b1bb": "",
                                        "ffa6b1bc": "",
                                        "ffa6b1bd": "",
                                        "ffa6b1be": "",
                                        "ffa6b1bf": "",
                                        "ffa6b1c0": "",
                                        "ffa6b1c1": "",
                                        "ffa6b1c2": "",
                                        "ffa6b1c3": "",
                                        "ffa6b1c4": "",
                                        "ffa6b1c5": "",
                                        "ffa6b1c6": "",
                                        "ffa6b1c7": "",
                                        "ffa6b1c8": "",
                                        "ffa6b1c9": "",
                                        "ffa6b1ca": "",
                                        "ffa6b1cb": "",
                                        "ffa6b1cc": "",
                                        "ffa6b1cd": "",
                                        "ffa6b1ce": "",
                                        "ffa6b1cf": "",
                                        "ffa6b1d0": "",
                                        "ffa6b1d1": "",
                                        "ffa6b1d2": "",
                                        "ffa6b1d3": "",
                                        "ffa6b1d4": "",
                                        "ffa6b1d5": "",
                                        "ffa6b1d6": "",
                                        "ffa6b1d7": "",
                                        "ffa6b1d8": "",
                                        "ffa6b1d9": "",
                                        "ffa6b1da": "",
                                        "ffa6b1db": "",
                                        "ffa6b1dc": "",
                                        "ffa6b1dd": "",
                                        "ffa6b1de": "",
                                        "ffa6b1df": "",
                                        "ffa6b1e0": "",
                                        "ffa6b1e1": "",
                                        "ffa6b1e2": "",
                                        "ffa6b1e3": "",
                                        "ffa6b1e4": "",
                                        "ffa6b1e5": "",
                                        "ffa6b1e6": "",
                                        "ffa6b1e7": "",
                                        "ffa6b1e8": "",
                                        "ffa6b1e9": "",
                                        "ffa6b1ea": "",
                                        "ffa6b1eb": "",
                                        "ffa6b1ec": "",
                                        "ffa6b1ed": "",
                                        "ffa6b1ee": "",
                                        "ffa6b1ef": "",
                                        "ffa6b1f0": "",
                                        "ffa6b1f1": "",
                                        "ffa6b1f2": "",
                                        "ffa6b1f3": "",
                                        "ffa6b1f4": "",
                                        "ffa6b1f5": "",
                                        "ffa6b1f6": "",
                                        "ffa6b1f7": "",
                                        "ffa6b1f8": "",
                                        "ffa6b1f9": "",
                                        "ffa6b1fa": "",
                                        "ffa6b1fb": "",
                                        "ffa6b1fc": "",
                                        "ffa6b1fd": "",
                                        "ffa6b1fe": ""
                                      "BaseID_offset": 0
                                    "native": {
                                      "id": "ffaf7291",
                                      "eep": [
                                        "TF-14-01",
                                        "TF-14-02"
                                      "Sender_ID": "ffa6b181"
                              Gruß Martin
                              • Jey Cee
                                @black-raven ich Zitieren mich mal selbst:
                                Die Bus Geräte melden sich mit ihrer Bus Adresse, das heist es fängt bei 00 00 00 01 an.
                                Für den Anlernprozess bedeutet dass, das man einfach nur die Bus Adresse angibt. Sonst ist soweit alles gleich wie bisher auch.
                                Du verwendest hier beim FGW14 jedoch die ID die der FAM14 benutzt für das Gerät.
                                Mich Überrascht das du das Gerät so Steuern kannst, aber vielleicht interpretiert der FAM14 das richtig und gibt das an den Aktor weiter.
                                  @jey-cee Habs jetzt mal mit der Busadresse in dezimal und hexadezimal ausprobiert, das Ergebnis bleibt jedoch das gleiche. Was mir aufgefallen ist, der Datenpunkt enocean.0.gateway.lastID zeigt wenn ich über das FAM USB 515 fahre schön brav an wenn sich einer der Aktoren zu Wort meldet. Über das FGW14 bleibt dieser Datenpunkt dauerhaft auf "(null)".
                                  • Jey Cee
                                    @black-raven hat jetzt etwas gedauert den Fehler zu beheben, da gab es zwei Problemstellen. Bitte installiere mal von Github neu und gib mir Rückmeldung.
                                      @jey-cee Jetzt siehts besser aus. Heute morgen hab ichs mal ausprobiert und siehe da die FTS14EM haben auf einmal wieder eine Reaktion gezeigt und liesen sich einlernen. Mit den F4SR14-LED hatte ich noch eine Kampf auszufechten aber nachdem ich das FAM14 richtig eingestellt habe gings. Ich hatte am Wochenende noch mal verschiedene Einstellungen des FAM14 ausprobiert und dann wohl irgendwie auch den Überblick verloren 😩 . Als ich dann gerade noch mal alles zurückgestzt habe und einen erneuten Versuch durchgeführt hab kamen auch gleich die LastID Daten am entsprechenden Datenpunkt an. So wie es gerade aussieht hab ich morgen Früh Sturmfrei dann werd ich mal versuchen das ganze System einzulernen.
                                      • Jey Cee
                                        @black-raven sehr gut, danke fürs Feedback.
                                          mustang last edited by
                                          @Jey-Cee
                                          Hallo Jey-Cee, bis Adapter Version 0.8.3 haben meine Eltako Rollladenaktoren noch einwandfrei funktioniert. Seit Version 0.8.4 werden die Datenpunkte TT und TTT beschrieben, sobald der Rollladen vor erreichen der Endposition ein Stopkommando per Adapter erhält. Die Werte bleiben dann unveränderlich bestehen und der jeweilige Rollladen fährt dann nicht mehr bis zur Endposition, wenn ein Auf- oder Ab-Kommando gesendet wird.
                                          Erst nach manuellem überschreiben der Werte mit null in den Objekten ist wieder eine komplette Auf- bzw. Abfahrt möglich.
                                          Soll das so sein? Wenn ja muß ich meine Scripte anpassen.
                                          Gruß mustang
                                          Jey Cee 1 Reply Last reply Reply Quote -1
                                          • Jey Cee
                                            Jey Cee Developer @mustang last edited by
                                            @mustang sagte in Test Adapter EnOcean v0.8.x:
                                            Soll das so sein?
                                            Nein das ist so nicht richtig und wurde mir bisher auch von keinem anderen so geschildert.
                                            Gib mir bitte mal den Inhalt aus dem "Support information" Tab.
                                            enocean
                                            25
                                            248
                                            45005
