    4. Sonos Lautstärke ohne Slider
      csamaggi last edited by
      Danke erstmal dafür hab ich gefunden doch ich bekomme nur plus aber nicht minus hin.
      MFG Maggi
      • Jey Cee
        Geht der Wert und ein minus davor nicht?
        Gesendet von meinem m8 mit Tapatalk
          Ja das dachte ich mir auch aber nein bei "-2" tut sich nix.
            tempestas last edited by
            sollte jqui ctrl icon increment sein
              Ja das habe ich gefunden jedoch bekomme ich keine Minuswerte hin plus geht.
              MFG Maggi
                pix last edited by
                probier mal so:
                ! 3 Widgets:````
                [{"tpl":"tplIconInc","data":{"oid":"sonos.0.root.192_168_178_51.volume","visibility-cond":"==","visibility-val":1,"step":"7","minmax":"100","text":"","repeat_delay":"800","repeat_interval":"800","name":"SONOS Lautstärke lauter","invert_icon":false,"src":"/icons-mfd-png/audio_volume_high.png","alt":"lauter","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"548px","top":"337px","width":"42px","height":"50px","background":"rgba(250,250,250,0)","z-index":"30","border-width":"1px","border-radius":"0px","border-color":"rgba(180,180,200,0.2)","cursor":"pointer"},"widgetSet":"jqui"},{"tpl":"tplValueFloat","data":{"oid":"sonos.0.root.192_168_178_51.volume","g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":"false","visibility-groups-action":"hide","is_comma":false,"is_tdp":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"digits":"0","html_prepend":"","name":"Lautstärke absolut Küche","visibility-oid":"192_168_178_51.muted","oid-quality":"sonos.0.root.192_168_178_51.muted","class_true":"muted","class_false":"notmuted","test_html":""},"style":{"left":"506px","top":"343px","z-index":"25","color":"rgba(250,250,250,1)","width":"35px","height":"38px","font-size":"35px","text-align":"center"},"widgetSet":"basic"},{"tpl":"tplIconInc","data":{"oid":"sonos.0.root.192_168_178_51.volume","visibility-cond":"==","visibility-val":1,"step":"-7","minmax":"0","text":"","repeat_delay":"800","repeat_interval":"800","name":"SONOS Lautstärke leiser","invert_icon":false,"src":"/icons-mfd-png/audio_volume_low.png","alt":"leiser","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide"},"style":{"left":"454px","top":"337px","width":"42px","height":"50px","background":"rgba(250,250,250,0)","z-index":"30","border-width":"1px","border-radius":"0px","border-color":"rgba(180,180,200,0.2)","cursor":"pointer"},"widgetSet":"jqui"}]
                Pix
                  Ah Danke daher kam ich ja auf die Idee dass umzustellen.
                  Hab den Fehler auch direkt gefunden.
                  Es lag an dem "minmax" beim Minus dort hatte ich 100 und nicht 0 stehen.
                  Danke Pix
                    Schnubbi last edited by
                    mit welchem widget habt ihr denn die Favoriten und das aktuelle Album dargestellzt?
                      Das aktuelle Album wird einfach mit einem "basic string image src" dargestellt und dann von SonosAdapter mittels "current_cover".
                      MFG Maggi
                        Die Favoriten sind ein Dropdown Menü, dazu musst du aber auch erst noch ein Skript zum laufen bringen. KORREKTUR: Du kannst die Favoriten auch einfach manuell eintragen, aber dann gibt es keine automatische Anpassung, sofern du welche hinzufügst oder löscht in Sonos. Dafür ist das Skript notwendig
                        Bei Pix Visualisierung ist glaube ich zudem noch eine alterantive Methode dabei, die hier mal von user "Night…?" gepostet wurde und dann von Pix mit CSS aufgehübscht wurde. Benötigt auch ein Skript.
                        Wenn du nur wenige Favoriten hast oder einige, die du immer sofort im Zugriff haben willst, kannst du auch ein entsprechendes Metro Widget nutzen und es dir schön machen. Dann einfach darüber set_favorites mit dem konkreten Favoritennamen (genaue Schreibweise beachten) setzen.
                          stephan last edited by
                          @tempestas:
                          Wenn du nur wenige Favoriten hast oder einige, die du immer sofort im Zugriff haben willst, kannst du auch ein entsprechendes Metro Widget nutzen und es dir schön machen. Dann einfach darüber set_favorites mit dem konkreten Favoritennamen (genaue Schreibweise beachten) setzen. `
                          wo könnte mann da denn wohl mehr drüber erfahren.
                          Gruss Stephan
                            Hier im Forum. Die Links habe ich mir auch nicht gespeichert und müsste sie ebenso raussuchen, wie du.
                            Abgesehen davon bleibt unklar, worüber genau du denn mehr erfahren willst, denn in dem zitierten Teil sind ja verschiedene Bereiche angesprochen.
                              Legoracer70 last edited by
                              ich versuche gerade auch so eine schöne Sonos-Bedienung nach zu bauen, aber scheitere schon an der Darstellung des Covers.
                              Ich habe versuche in einem "Basic string src" über den Sonosadapter das "current_cover" anzuzeigen.
                              In der Projektierung sieht es auch sehr gut aus, aber über die App wird auf meinen Tablets Nichts bzw. nur Symbol für wahrscheinlich nicht vorhanden dargestellt.
                              Gibt es da einen Trick ?
                              Gruß und danke,
                              Michael
                                Das Problem habe ich auf dem PC. Egal ob firefox, Chrome oder IE / Edge. Auf dem Tablet läuft es dagegen mit dem Fully Browser perfekt.
                                Was der Grund ist, keine Ahnung
                                  habe ich eventuell das gleiche Problem wie im folgenden Beitrag:
                                  http://forum.iobroker.net/viewtopic.php … 620#p76953
                                  Wenn ja, welches Widget kann ich in der App für die Darstellung des Covers benutzen ?
                                  Gruß,
                                  Michael
                                    Also ich frage mich wie ich die einzelnen Bilder zu den Sendern bekomme..
                                    Gibt es dazu eine Anleitung zum bsp. FFN..
                                    Wie bekomme ich es hin meinen Button mit diesem Bild zu füllen..
                                    Gruss Stephan
                                      pix last edited by
                                      Hier das Widget
                                      [{"tpl":"tplMetroTileState","data":{"visibility-cond":"==","visibility-val":1,"hover":false,"transform":"true","bg_class_false":"bg-transparent","bg_class_true":"bg-cyan","icon_class_false":"","icon_class_true":"","icon_badge_false":"","icon_badge_true":"","badge_bg_class_false":"","badge_bg_class_true":"","brand_bg_class_false":"","brand_bg_class_true":"","name":"Sonos Favorit 2","state_oid":"sonos.0.root.192_168_178_51.favorites_set","value":"1LIVE - Das junge Radio des WDR.","label_true":"Einslive","label_false":"Einslive","class":"","select_on_value":true,"badge_top":"0","badge_left":"0","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"icon_false":"http://static.radio.de/images/broadcasts/4e/0d/1382/1/c175.png","icon_left":"88","icon_width":"29","icon_height":"84","icon_top":"62","visibility-groups-action":"hide"},"style":{"left":"766px","top":"103px","z-index":"20","height":"50px","width":"137px","cursor":"pointer"},"widgetSet":"metro"}]
                                      Und hier der Screenshot,d er erklärt, wo das Logo verlinkt wird: 261_bildschirmfoto_2017-08-07_um_20.45.28.jpg
                                      Habe einfach die Logos von radio.de verlinkt. Kannst sie aber auch runterladen und offline speichern. Dann mit dem VIS Uploader ins System laden.
                                      http://static.radio.de/images/broadcast … 1/c175.png (EINSLIVE)
                                      Pix
                                        Super vielen Dank…
                                        Das hat mir sehr viel geholfen..
                                        Gruss Stephan
                                          Ein Dank an alle die hier so schnell helfen.
                                          Ich habe dank euch so einigen eingestellt und Dargestellt wie ich es möchte.
                                          Nun noch ein Frage Hilfe wie stelle ich es an das wenn ich mir ein Stop Button anlege das die Verbindung komplett abgebrochen wird, oder langt die Verbindung einfach zu Stoppen.
                                          Gruß Stephan
                                          4664
