    4. Test Adapter LG ThinQ
      freak9882 @Lucky_ESA last edited by
      @lucky_esa DANKE, sehr nett von dir. 👍
        Lucky_ESA Developer Most Active @freak9882 last edited by Lucky_ESA
        @freak9882 Hier das Blockly. Ersetze die 3 xxx mit deiner Seriennummer. Dann kannst du die neuen DP in VIS darstellen.
        0_userdata.0.frigde
        0_userdata.0.freezer
         <variables>
           <variable id="Wi/oqgyp:,oi#%a0E$?O">SearchStr</variable>
           <variable id="*cZJ6NWMhBk*B}I|5EIs">SN</variable>
         </variables>
         <block type="procedures_defcustomreturn" id="{O*5V-23?}s?glAtjyra" x="38" y="-62">
           <mutation statements="false">
             <arg name="SearchStr" varid="Wi/oqgyp:,oi#%a0E$?O"></arg>
           </mutation>
           <field name="NAME">fridgeTemp</field>
           <field name="SCRIPT">Y29uc3QgVGhpbnFTdHJpbmcgPSB7DQogICAgLypmcmlkZ2VUZW1wKi8NCiAgICAnMSc6ICI3IiwNCiAgICAiMiI6ICI2IiwNCiAgICAiMyI6ICI1IiwNCiAgICAiNCI6ICI0IiwNCiAgICAiNSI6ICIzIiwNCiAgICAiNiI6ICIyIiwNCiAgICAiNyI6ICIxIg0KfTsNCg0KaWYgKFRoaW5xU3RyaW5nW1NlYXJjaFN0cl0pIHsNCiAgICByZXR1cm4gVGhpbnFTdHJpbmdbU2VhcmNoU3RyXTsNCn0gZWxzZSB7DQogICAgcmV0dXJuIFNlYXJjaFN0cjsNCn0NCg==</field>
         <block type="procedures_defcustomreturn" id="Z.%QtZGh}:Qs=O?JP0*3" x="38" y="-37">
           </mutation>
           <field name="NAME">freezerTemp</field>
           <field name="SCRIPT">Y29uc3QgVGhpbnFTdHJpbmcgPSB7DQogICAgLypmcmlkZ2VUZW1wKi8NCiAgICAnMSc6ICctMTQnLA0KICAgICcyJzogJy0xNScsDQogICAgJzMnOiAnLTE2JywNCiAgICAnNCc6ICctMTcnLA0KICAgICc1JzogJy0xOCcsDQogICAgJzYnOiAnLTE5JywNCiAgICAnNyc6ICctMjAnLA0KICAgICc4JzogJy0yMScsDQogICAgJzknOiAnLTIyJywNCiAgICAnMTAnOiAnLTIzJywNCiAgICAnMTEnOiAnLTI0JywNCiAgICAnMjU1JzogJzAnDQp9Ow0KDQppZiAoVGhpbnFTdHJpbmdbU2VhcmNoU3RyXSkgew0KICAgIHJldHVybiBUaGlucVN0cmluZ1tTZWFyY2hTdHJdOw0KfSBlbHNlIHsNCiAgICByZXR1cm4gU2VhcmNoU3RyOw0KfQ0K</field>
         <block type="variables_set" id="-vCvZ56ky{j9FAwwvwlQ" x="37" y="12">
           <field name="VAR" id="*cZJ6NWMhBk*B}I|5EIs">SN</field>
             <block type="text" id="B6|f,HT7InjG=.a(!0h6">
               <field name="TEXT">lg-thinq.0.xxx</field>
             <block type="create" id=")g:)EuZaOk51/}B#4c9:" collapsed="true">
               <field name="NAME">0_userdata.0.frigde</field>
               <value name="COMMON">
                 <block type="text" id="0=`9d57uRQCT^:7^tTAR">
                   <field name="TEXT">{"fridge":"Kühlschrank","type":"number"}</field>
                 <block type="create" id="`mtgnM-ZKQJNJ.fYpR2!" collapsed="true">
                   <field name="NAME">0_userdata.0.freezer</field>
                     <block type="text" id="61LT:XA])W#hrAI4)OIi">
                       <field name="TEXT">{"freezer":"Eisschrank","type":"number"}</field>
                     <block type="update" id="kMiQ|tyj;A*)kRH?/OC*" collapsed="true">
                       <field name="OID">0_userdata.0.freezer</field>
                         <block type="procedures_callcustomreturn" id="L{/k]HHzSr4Uc[qjtbW$">
                           <mutation name="freezerTemp">
                             <arg name="SearchStr"></arg>
                           </mutation>
                           <value name="ARG0">
                             <block type="get_value_var" id="*%zcB^84Ndd!-rg[r0Az">
                               <value name="OID">
                                 <shadow type="text">
                                   <field name="TEXT"></field>
                                 <block type="text_join" id="(HI7?cFg/SQX~Jp4c@7T">
                                   <value name="ADD0">
                                     <block type="variables_get" id="e[#}VE=B!X?t^H{QMa}4">
                                   <value name="ADD1">
                                     <block type="text" id="L!/!`y~SXkNF=rFO0!=4">
                                       <field name="TEXT">.snapshot.refState.freezerTemp_C</field>
                         <block type="update" id="EwM=a(`gu)XWC|ED!_vx" collapsed="true">
                           <field name="OID">0_userdata.0.frigde</field>
                             <block type="procedures_callcustomreturn" id="zQR?mTE,6]d9M,Lv7^^j">
                               <mutation name="fridgeTemp">
                               </mutation>
                               <value name="ARG0">
                                 <block type="get_value_var" id="AT=L!{j)Yvb{m*~=4]82">
                                   <value name="OID">
                                     <block type="text_join" id="vrL]dVVw8EeeC|8s|0{t">
                                       <value name="ADD0">
                                         <block type="variables_get" id="hsOi##osH6XHHWF}YGB4">
                                       <value name="ADD1">
                                         <block type="text" id="p^+dq~hyw(hg+=@}P^Xv">
                                           <field name="TEXT">.snapshot.refState.fridgeTemp_C</field>
                             <block type="on_ext" id="J/jj8:/t4~w*0}`3oJm1">
                               <value name="OID0">
                                 <shadow type="field_oid" id=")d~I5ZNj4HZ9^}ZgL}{m">
                                 <block type="text_join" id="M4pMW/v[_7s8*,`)oM@A">
                                   <value name="ADD0">
                                     <block type="variables_get" id="0v|nm+^LI7Ke!VWpMsmB">
                                   <value name="ADD1">
                                     <block type="text" id="*kBpQLtlf;TJZX%1@[?c">
                               <value name="OID1">
                                 <shadow type="field_oid" id="dO#WepI0Gp4k$iv!LA+d">
                                 <block type="text_join" id=":VzGJBji_19+80wWMxPQ">
                                   <value name="ADD0">
                                     <block type="variables_get" id="AW#;E:SvXfy=pv+~XN+u">
                                   <value name="ADD1">
                                     <block type="text" id="cQ[okqhlfABep8O8E1hI">
                                 <block type="update" id="@}jp@rcqew+6q(nw#8Or">
                                     <block type="procedures_callcustomreturn" id="*tsX@gclr8l8h%zFtf5Y">
                                       </mutation>
                                       <value name="ARG0">
                                         <block type="get_value_var" id="C9K^Y6t2-jdB7:A9p[#N">
                                           <value name="OID">
                                             <shadow type="text" id="FHNhUGVu6@#Gly;T$uj9">
                                             <block type="text_join" id=")M[dwfCYvR`FndjoL*f;">
                                               <value name="ADD0">
                                                 <block type="variables_get" id="f^E:ScQ$.aNtcbDyuU]^">
                                               <value name="ADD1">
                                                 <block type="text" id="$585HZPRVL,AaEA7i,YZ">
                                     <block type="update" id="$g}fx7axLQ@Ex+pRv-[G">
                                         <block type="procedures_callcustomreturn" id="HB5@@W/@nOyCoMVZuB|N">
                                           </mutation>
                                           <value name="ARG0">
                                             <block type="get_value_var" id="8*b1@*p,(q.Wgx`.22~v">
                                               <value name="OID">
                                                 <shadow type="text" id="^/d]p5xH#nNbB7-5=Nuw">
                                                 <block type="text_join" id="v0Kbipvp*#Wp_UlqU+UF">
                                                   <value name="ADD0">
                                                     <block type="variables_get" id="@{5x!)sSfK??gHX|pGq-">
                                                   <value name="ADD1">
                                                     <block type="text" id=",{taw@3hLkfV4+PpbMTR">
        Edit1: Nach dem Import vom Blockly solltest du den Javascript Adapter neu starten.
          mmaric @Lucky_ESA last edited by
          @lucky_esa sagte in Test Adapter LG ThinQ v0.0.1:
          @mmaric Kannst jetzt mal vom GIT laden und testen. Wie man vom GIT richtig lädt habe ich hierbeschrieben
          Holiday habe ich noch nicht hinzugefügt da dein Geräte Offline war. Es gibt einige Values die du nicht anwenden kannst. Es kommt im Prtokoll dann ein Error 400. Einige states sind auch nicht übersetzt...Wenn du heraus findest was dort stehen müsste, dann poste es hier.
          lg-thinq.1.xxx.remote.basicCtrl.operation = 0 für Aus
          lg-thinq.1.xxx.remote.basicCtrl.operation = 1 für Ein
          lg-thinq.1.xxx.remote.basicCtrl.target = Gewünschte Temperatur
          Viel Spaß beim testen.
          Gruß//Lucky
          was ist denn der Unterschied bei den einzelnen Werten ?
            Lucky_ESA Developer Most Active @mmaric last edited by
            @mmaric Dazu mal auf den Stift klicken. Leider wird mit dem Template aus langPackModelVer leider nicht alles übersetzt. Alle Werte in States kommen aus dem Template modelJsonUri. Die 0 und 1 hat @tombox ausgelesen, daher wissen wir 0 ist Aus und 1 ist An. Den Rest musst du ausprobieren. Kommt im Protokoll ein Error, ist dieser Value nicht für dein Geräte da dir wohl dann Features fehlen. Den Standard Urlaub habe ich fertig muss jetzt leider auch geräuscharm implementieren.
               "states": {
                 "0": "AUS",
                 "1": "AC_MAIN_OPERATION_RIGHT_ON_W",
                 "256": "AC_MAIN_OPERATION_LEFT_ON_W",
                 "257": "AC_MAIN_OPERATION_ALL_ON_W"
              @lucky_esa sorry, become folgende Fehlermeldung. Hast du eine Idee?
              22.11.2022, 17:03:07.567 [info ]: javascript.0 (26959) Stop script script.js.Kühlschrank
              22.11.2022, 17:03:07.578 [info ]: javascript.0 (26959) Start javascript script.js.Kühlschrank
              22.11.2022, 17:03:07.580 [error]: javascript.0 (26959) script.js.Kühlschrank compile failed:
              at script.js.Kühlschrank:1
              André
                @freak9882 sagte in Test Adapter LG ThinQ v0.0.1:
                Du hast alles ersetzt satt nur die 3 x.
                lg-thinq.0.xxx
                lg-thinq.0.7b9.....
                Gruß//Lucky
                  @lucky_esa ich bin da zu blöd zu. Das habe ich gemacht:
                  Bildschirmfoto 2022-11-22 um 19.39.55.png Bildschirmfoto 2022-11-22 um 19.39.11.png
                    @freak9882 Du musst ein Blockly erstellen und nicht ein Script. Im Blockly dann den Code von oben importieren.
                      freak9882 @Lucky_ESA last edited by freak9882
                      @lucky_esa Danke für deine Geduld, scheint jetzt zu laufen. Wo finde ich denn dann den richtigen Datenpunkt?
                      Sorry, absoluter Anfänger auf dem Gebiet.
                        @freak9882 Kein Problem.
                        Wie oben beschrieben unter:
                        0_userdata.0.frigde
                        Edit1: Nach dem Import bitte die Instanz javascript neu starten.
                        Gruß//Lucky
                          @lucky_esa Ich geb auf, bin da zu blöd für. Sehe da keine Werte.
                          Danke für deine Hilfe.
                            Lucky_ESA Developer Most Active last edited by Lucky_ESA
                            Mach mal diesen Screenshot.
                              hab nur die letzten 3 Ziffern gelöscht
                                Was steht bei dir hier? Deine SN ist zu kurz...
                                lg-thinq.0.xxx.platformType
                                M F 2 Replies Last reply Reply Quote 0
                                  @lucky_esa
                                  @tombox
                                  Danke für Eure unermüdliche Arbeit.
                                  Gibt es einen Weg sich bei Euch mit einem kleinen Obolus zu bedanken ?
                                  paypal oder so ?
                                  Mladen
                                    @lucky_esa DANKE, jetzt funktioniert es. Ich hatte anstatt auf copy einfache den hinteren Bereich der serial nur kopiert.Bildschirmfoto 2022-11-23 um 18.52.20.png
                                      @mmaric Habe die neue Version auf dem GIT. Du kannst jetzt gerne mal vom GIT laden. Wie das genau geht habe weiter oben per Bilder beschrieben.
                                      Wird bei dir irgendwo angezeigt wann dein Filter getauscht werden muss?
                                      remote.break.holiday_silent_update: Hiermit musst du immer die aktuellen Daten von der Cloud laden bevor du andere Änderungen vornimmst
                                      remote.break.holiday_silent_data: Hier wird der JSON von der Cloud dann gespeichert.
                                      remote.break.holiday_startdate: Hier das Startdatum für den Urlaubsmodus eintragen. Das Datum darf nicht in der Vergangenheit liegen (Format DD.MM.YY HH:MM)
                                      remote.break.holiday_enddate: Hier das Enddatum für den Urlaubsmodus eintragen. Das Datum darf nicht in der Vergangenheit liegen und muss größer sein als das Startdatum (Format DD.MM.YY HH:MM)
                                      remote.break.holiday_heating: Heizen An/Aus (wie in der APP)
                                      remote.break.holiday_water: Warmwasser An/Aus (wie in der APP)
                                      remote.break.holiday_onoff: Erst die o. g. Datenpunkte füllen und dann hier den Urlaubsmodus aktivieren/deaktivieren
                                      remote.break.silent_mode_starttime: Hier die Startzeit für den geräuscharmen Modus eintragen (Format HH:MM)
                                      remote.break.silent_mode_endtime: Hier die Endzeit für den geräuscharmen Modus eintragen. Sollte natürlich größer als das Startdatum sein. (Format HH:MM)
                                      remote.break.silent_mode_onoff: Geräuscharmen Modus aktivieren/deaktivieren
                                      remote.break.holiday_sendJSON: Nur für Experten gedacht. Der JSON hat einen Array der aus JSON Type 1, 2 und 3 besteht. 1 steht für die Laufzeiten, die 2 für den Urlaubsmodus und Type 3 für den geräuscharmen Modus. Man könnte nun bei Type 1 weitere JSON`s anhängen und damit generiert man mehr Schaltzeiten. Das wollte ich jetzt nicht per Datenpunkte darstellen.
                                      Danke für dein Angebot aber ich möchte nichts.
                                      Du kannst ja testen...Ich werde auch noch ein wenig testen und dann tombox darum bitten in latest zu gehen.
                                      Gruß//Lucky
                                        Freut mich...
                                        Gruß//Lucky
                                          Lars0815 last edited by
                                          Guten Morgen, leider habe ich noch dem Update auf die aktuellste Version nur noch diese Meldung. Neuinstallieren brachte auch kein Erfolg.
                                          lg-thinq.0
                                          Zeit
                                          debug
                                          Nachricht
                                          lg-thinq.0
                                          2022-12-01 06:35:15.249 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v16.18.0, js-controller: 4.0.23
                                          lg-thinq.0
                                          2022-12-01 06:35:19.326 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          lg-thinq.0
                                          2022-12-01 06:35:19.324 info terminating
                                          lg-thinq.0
                                          2022-12-01 06:35:19.316 error Cannot convert undefined or null to object
                                          lg-thinq.0
                                          2022-12-01 06:35:19.315 error TypeError: Cannot convert undefined or null to object at Function.keys (<anonymous>) at LgThinq.createAirRemoteStates (/opt/iobroker/node_modules/iobroker.lg-thinq/lib/air_conditioning.js:61:16) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async LgThinq.getDeviceModelInfo (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:668:17) at async LgThinq.onReady (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:154:57)
                                          lg-thinq.0
                                          2022-12-01 06:35:19.314 error unhandled promise rejection: Cannot convert undefined or null to object
                                          lg-thinq.0
                                          2022-12-01 06:35:19.313 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          lg-thinq.0
                                          2022-12-01 06:35:18.861 info createAirRemoteStates: Cannot found ControlDevice
                                          lg-thinq.0
                                          2022-12-01 06:35:18.530 info Found: 1 devices
                                          lg-thinq.0
                                          2022-12-01 06:35:17.342 info Login successful
                                          M T L 3 Replies Last reply Reply Quote 0
                                            mmaric @Lars0815 last edited by
                                            @lars0815
                                            hast Du die Objekte mal gelöscht und dann die Instanz wieder gestartet ?
                                            908
                                            283047
