      hertob81 last edited by
      komischerweise hat der Rolladen gersde ein eingeben. Obwohl ich beim Helligkeitssenor einen Schwellwert von "2" eingeben habe, fahren die Rolladen alle runter, obwohl der Wert 5-stellig ist.
      Wo versteckt sich der DP "brightness state down"???
      Mit freundlichen Grüßen
      rcontrol.0
      30501	2022-11-20 13:32:28.885	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.284	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.280	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.269	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.264	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.250	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.247	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.240	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.237	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.226	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.220	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.211	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.207	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.153	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.147	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.131	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:19.123	debug	Brightness State Down is: true
      shuttercontrol.0
      30501	2022-11-20 13:32:18.884	debug	Brightness sensor value: 18810
      shuttercontrol.0
      30501	2022-11-20 13:32:18.883	debug	Brightness sensor value: 18810
      shuttercontrol.0
      30501	2022-11-20 13:32:13.092	debug	Brightness State Down is: true
      • XBiT
        XBiT last edited by
        Gute Abend,
        ich habe das Problem, dass meine Rollos trotz aktiven Frostschutz fahren.
        kann mir jemand sagen was ich anpassen muss?
        Rollo Einstellung:
        Extra Einstellungen:
        Datenpunkt:
        Log wo die Rollos geöffnet werden:
        2022-11-21 08:13:00.095  - info: shuttercontrol.0 (3757) Sleep up #22 Set ID: Rollo DG Strasse value: 100%
        2022-11-21 08:13:00.805  - info: shuttercontrol.0 (3757) Sleep up #22 Set ID: Rollo DG Hofseite value: 100%
        Besten Dank
        XBiT 1 Reply Last reply Reply Quote 0
        • XBiT
          XBiT @XBiT last edited by XBiT
          Es scheint ja keiner den Frostschutz zu nutzen und kann mir einen Tipp geben…
          Habe zwar in meinen Notifications stehen das @Homoran mir geantwortet hat aber der Post ist nicht da.
          Aber vielleicht nutzt jemand den Feueralarm bei diesen erwarte ich, dass bei Änderung vom Datenpunkt auf „true“ die Rollos (welche in den Einstellungen den Feueralarm berücksichtigen) auf das eingestellte Level fahren in meinen Fall auf 0 bzw. auf.
          Leider passiert hier auch genau nichts.
          Hoffe mal sonst jemand nutzt diesen Datenpunkt, macht ja auch Sinn bei einen Brand nicht vor dem geschlossenen Rollo zu stehen, eventuell könnte mal jemand bei sich den Datenpunkt auf „true“ stellen und mir sagen ob die Rollos fahren dann müsste es an meiner Konfiguration liegen.
          Kann mir dazu jemand einen Tipp geben?
          Edit: Zur Info Adapterversion v1.4.18
          crunchip F 2 Replies Last reply Reply Quote 0
            crunchip Forum Testing Most Active @XBiT last edited by crunchip
            @xbit ich nutze dad bisher nicht, aber grad mal in der Beschreibung gelesen
            Prioritäten der einzelnen Alarme: Prio 1 -- Feuer- / Einbruchalarm: Höchste Priorität hat der Feuer / Einbruch Alarm. Wird dieser ausgelöst, fahren die dafür konfigurierten Rollo in jedem Fall auf die eingestellte Höhe. Die Rollos sind danach blockiert und schliessen NICHT mehr automatisch, auch nicht wenn der Feueralarm zurück gesetzt wird (false). Die Rollos müssen in diesem Fall nach der Rücknahme des Feueralarms zwingend mittels Buttons "openAll" / "closeAll" neu initialisiert werden
            Der Frost Alarm wirkt sich nur dann direkt aus, wenn die aktivierten Rollos bereits geschlossen sind (Gefahr von Festfrieren des Rollos). Wenn der Frostalarm bei noch offenem Rollo ausgelöst wird, fährt der Rollo beim Schliessen automatisch nur auf die für Frostalarm eingestelle Höhe.
            liegt dann vllt an deiner 0 bei Frostalarm oder ist 0 ganz offen bei dir?
              FoxRo @XBiT last edited by
              @xbit
              Hi, ich nutze den Windalarm2, welchen ich auch manuell auslösen kann. Soeben getestet und tut bei mir einwandfrei.
              Fürchte, dass bei deiner Config oder an den vom Aktor zurück gemeldeten Höhen evtl was nicht korrekt ist.
              Stelle sonst mal die Config als exporiertes File und ein debug log hier rein, dann kann Dir sicher jemand helfen.
              • XBiT
                XBiT @crunchip last edited by XBiT
                @crunchip
                Danke für deinen Post.
                Vorweg bei mir ist 0% die Rollos sind geschlossen.
                Bei mir war der Datenpunkt (für Frost) 2 Tage lang auf "true" und die Rollos sind 2 Tage lang munter früh auf und abends ab gefahren. (abends ab ist ja OK wie in der Beschreibung)
                Laut Beschreibung sollten sie geschlossen bleiben wegen der Gefahr des Festfrierens. (Welches sie auch waren und mit lauten Knallen aufgefahren sind)
                Beim Feueralarm war mein Fehler (0% ist bei mir "geschlossen" und nicht wie im Post oben gesagt "auf" Sorry), da Fahren die Rollos wie angegeben.
                @FoxRo
                Auch danke an dich, Wind2 habe ich getestet da fahren die Rollos auch wie erwartet.
                Scheint also nur ein Frostproblem zu sein???
                  @xbit
                  Hi, in deinem Screenshot oben hast du alle anderen Alarme auf 100 - also auf Offen. Der Frost ist aber auf 0 - also wenn ich dich jetzt richtig verstanden habe auf Zu. Besser wäre aber doch, wenn sie nicht ganz zu fahren, also zb. 90% zu was dann bei dir auf 10 wäre.
                  Hast da mal mit Werten geprüft, welche nicht Endanschlag sind?
                  • XBiT
                    XBiT @FoxRo last edited by
                    @foxro
                    ja im Screenshot sind alle auf 100% weil ich sie nicht genutzt habe nur jetzt zum testen habe ich einen Datenpunkt hinterlegt (bei Wind2 und Feuer).
                    Zwischenpositionen habe ich noch nicht getestet, weil es sich bei den Fenstern um Dachfenster handelt beine Frau möchte beim schlafen gern geschlossene Rollos. Sollte es jetzt in der Nacht sehr kalt sein mit Schnee und Eis friert das Rollo fest ob es da nun 10% auf fährt oder die kompletten 100% macht dann keinen Unterschied mehr. (meist ist am Anfang das schlimmste)
                    Sicher ist das nur ein Winterproblem, kann es aber mal mit 10 % Testen.
                    ich vermisse halt einen Log Eintrag wie beim Feuer oder Wind
                    2022-11-22 21:01:16.905  - info: shuttercontrol.0 (11783) #Shutter alarm fire Set ID: Rollo DG Hofseite value: 100%
                    2022-11-22 21:01:17.209  - info: shuttercontrol.0 (11783) #Shutter alarm fire Set ID: Rollo DG Strasse value: 100%
                    2022-11-22 21:01:17.451  - info: shuttercontrol.0 (11783) #Shutter alarm fire Set ID: Rollo Badezimmer value: 100%
                    2022-11-22 21:01:17.900  - info: shuttercontrol.0 (11783) #Shutter alarm fire Set ID: Rollo Ankleidezimmer value: 100%
                      @xbit sagte in Test Adapter shuttercontrol v1.4.x:
                      von der Logik her ja richtig, damit der Rollo nicht aufliegt um festzukleben, vllt ist es vom code her so hinterlegt, das der Wert kleiner 100(offen)/größer 0(geschlossen) sein muss, damit es greift.
                      @crunchip sagte in Test Adapter shuttercontrol v1.4.x:
                      Gegenargument, muss Frostschutz auf 99 stellen, sprich Rollo bleibt offen, oder möchtest du den nächsten bezahlen😁
                        @xbit
                        Oh, ich vermute da gibt’s ein Missverständnis.
                        Der Frostalarm ist nicht so konzipiert wie du ihn anwendest. Er verhindert das Fahren nicht, sondern ist dazu gedacht, dass bei Frostgefahr nicht ganz geschlossen wird, um ein Festfrieren der Rollos unten am Fensterbrett zu verhindern. Er fährt aber am Morgen normal hoch.
                        In deinem Fall würde ich eher empfehlen mittels script den AutoUP Datenpunkt bei Frost auf false zu setzen. Damit verhinderst, dass Shuttercontol am Morgen den Rollo überhaupt automatisch bewegt.
                        XBiT 1 Reply Last reply Reply Quote 1
                        • XBiT
                          Okay verstehe was du sagen willst ich teste es mal aus ob morgen früh bei 10% offen gstoppt wird.
                          Dann würde es bedeuten es muss eine Fahrt stattfinden auch wenn es nur 1% ist.
                          Das Gegenargument ist gut 🙂 ob ich das aber riskiere....
                            @foxro sagte in Test Adapter shuttercontrol v1.4.x:
                            • XBiT
                              XBiT @FoxRo last edited by XBiT
                              EDIT: es ist zu Spät ich mache erstmal 10% rein und schalte den Frost DP an mal sehen was morgen bei raus kommt 🙂
                                Homoran Global Moderator Administrators @XBiT last edited by
                                10% wird nicht reichen.
                                üblicherweise stößt der Rolladen bereits bei ca. 20% am Fensterbrett an.
                                Fahr doch zum Testen den Rollladen so weit runter, dass er gerade nicht das Fensterbrett berührt und lies die Position ab.
                                • XBiT
                                  XBiT @Homoran last edited by XBiT
                                  @homoran said in Test Adapter shuttercontrol v1.4.x:
                                  Sorry aber ich stehe auf dem Schlauch ....
                                  Mein Dachfenster hat kein Fensterbrett 🙂
                                  und die Beschreibung sagt doch
                                  Also zu 0% (man kann 0% raus sehen) also sollte er bei aktiven Alarm auch nicht fahren, und die Beschreibung weiter...
                                  bedeutet doch für mich wenn ich 10% einstelle fährt er abends 90% zu (ich kann 10% raussehen)..
                                  abgesehen davon das es mit 0% (also ganz zu) auch gehen sollte oder verstehe ich es ganz falsch?
                                  Homoran F crunchip 3 Replies Last reply Reply Quote 0
                                    Homoran Global Moderator Administrators @XBiT last edited by Homoran
                                    dann eben soweit dass sie die nicht näher bezeichnete Kontaktfläche nicht berühren, von der sie
                                    Ansonsten wäre die Frage ob bei dir der frost=true wirklich aktiviert wurde als die Rollläden bereits unten waren?
                                      @xbit
                                      Wie gesagt,
                                      Wenn der Rollo zu ist und dann der Frostalarm kommt, fährt Shuttercontol aktiv auf den Frost Level.
                                      Wenn Frostalarm aktiv ist und dann automatisch geschlossen wird, fährt er nur bis zum Frostlevel.
                                      Beachte auch, dass beim Auswerten der Temperatur genügend Hysterese gibst, damit er bei 0,1C „Flattern“ nicht dauernd auf und zu fährt.
                                      Der Frostalarm verhindert das Fahren vom Rollo nicht!
                                      • XBiT
                                        Sorry aber ich verstehe es leider nicht selbst wenn ich 50% einstellen würde ändert es doch nichts an der Sache wenn der Frostschutz aktiv ist und normalerweise das Rollo frühs auf geht dürfte genau gar nichts passieren, maximal auf die eingestellte % Zahl gefahren werden (wobei das nicht in der Beschreibung steht) sollte es Tagsüber zur Auslösung des Alarms kommen fährt das Rollo wenn es Abends normal zu geht auf die angegeben % Zahl vom Frostschutz.
                                        Das sagt mir die Beschreibung egal ab 10% 40% oder 80%
                                        zum Thema war der Datenpunkt wirklich true siehe oben die Screenshots und Logs da steht das Datum und die Uhrzeit wann der Datenpunkt geändert wurde und wann das Rollo gefahren wurde.
                                          geschlossen als Wort, er is halt zu, ob da jetz 5 Spalt offen sind, oder 8, fakto, der normale Rollo, je nach Länge, braucht ja einen gewissen Weg um die einzelnen Lamellen zu hebn, bis letztendlich das Endstück vom Brett gehoben wird.
                                          ja doch, weil er beim abends beim schliessen auf deinen vorgegeben Wert fährt, wenn du 0 einstellst, ist er ganz zu, somit die Frostfunktion ausser Betrieb
                                          Der Wert Frostschutz ist nichts anderes wie der Wert Rollo schliessen.
                                          üblich Rollo geht abend auf 0, Frostschutz aktiv mit Wert 20, somit fährt dein Rollo abends nict auf 0, sondern nur runter bis auf die 20, damit er nicht ganz geschlossen wird, am nächsten morgen fährt er wieder hoch
                                            @xbit siehe den Post vor deinem!
                                            die entscheidende Frage ist wann genau der Frost=true eintrat.
                                            solange du als höhe 0 eingetragen hattest, fährt der Rollo bei Eintreten des Events in diese Höhe
                                            332
                                            7411
                                            10603513
