    3. Entwicklung
    4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
      Diamand2k22 last edited by
      @patrick-kenzler
      06b9e9de-716c-4a03-95a1-94f34a45ccf6-avatto_me167.js
      Hab's angepasst für dein ME167 Thermostat.
      Probiers mal aus.
      Du weißt ja wo die Datei hin muss oder?
        Patrick Kenzler @Diamand2k22 last edited by
        @diamand2k22 Danke aber leider bekomme ich Fehler ausgeworfen und der Adapter startet nicht mehr. Naja ich packe den Pfad unter Einstellungen der jeweiligen Zigbee Instanz und die Datei in "/opt/iobroker/iobroker-data/zigbee_2"?!
        anbei das protokoll
        2022-11-22 07:57:47.563 - error: zigbee.2 (22077) Exception-Code: MODULE_NOT_FOUND: Cannot find module '../lib/exposes'
        Require stack:
        - /opt/iobroker/node_modules/iobroker.zigbee/main.js
        2022-11-22 07:57:47.641 - info: zigbee.2 (22077) cleaned everything up...
        2022-11-22 07:57:47.645 - info: zigbee.2 (22077) terminating
        2022-11-22 07:57:47.648 - warn: zigbee.2 (22077) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2022-11-22 07:57:48.285 - error: host.SmartHome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2022-11-22 07:57:48.286 - error: host.SmartHome Caught by controller[1]: node:internal/modules/cjs/loader:936
        2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: throw err;
        2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: ^
        2022-11-22 07:57:48.287 - error: host.SmartHome Caught by controller[1]: Error: Cannot find module '../lib/exposes'
        2022-11-22 07:57:48.288 - error: host.SmartHome Caught by controller[1]: Require stack:
        2022-11-22 07:57:48.288 - error: host.SmartHome Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
        2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        2022-11-22 07:57:48.289 - error: host.SmartHome Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1005:19)
        2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at require (node:internal/modules/cjs/helpers:102:18)
        2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at evalmachine.:1:17
        2022-11-22 07:57:48.290 - error: host.SmartHome Caught by controller[1]: at Script.runInContext (node:vm:139:12)
        2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Script.runInNewContext (node:vm:144:17)
        2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Object.runInNewContext (node:vm:298:38)
        2022-11-22 07:57:48.291 - error: host.SmartHome Caught by controller[1]: at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:222:16)
        2022-11-22 07:57:48.292 - error: host.SmartHome Caught by controller[1]: at getExternalDefinition.next ()
        2022-11-22 07:57:48.292 - error: host.SmartHome instance system.adapter.zigbee.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
          Diamand2k22 @Patrick Kenzler last edited by
          @patrick-kenzler
          kopiere das file nach
          /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/
          und mach den Eintrag bei externe Adapter raus.
          Dann Zigbee Adapter neu starten.
            @diamand2k22 habs probiert er schmeißt immernoch Fehler 😕 hast du noch eine Idee?
            2022-11-22 23:28:11.087	error	instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2022-11-22 23:28:11.087	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
            2022-11-22 23:28:11.087	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js:118:30)
            2022-11-22 23:28:11.086	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
            2022-11-22 23:28:11.086	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
            2022-11-22 23:28:11.086	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
            2022-11-22 23:28:11.085	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
            2022-11-22 23:28:11.085	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
            2022-11-22 23:28:11.084	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1069:27)
            2022-11-22 23:28:11.084	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1033:15)
            2022-11-22 23:28:11.083	error	Caught by controller[0]: at Object.compileFunction (node:vm:352:18)
            2022-11-22 23:28:11.083	error	Caught by controller[0]: SyntaxError: Unexpected identifier
            2022-11-22 23:28:11.083	error	Caught by controller[0]: ^^^^^^^^
            2022-11-22 23:28:11.083	error	Caught by controller[0]: konstantes Ergebnis = {};
            2022-11-22 23:28:11.082	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/06b9e9de-716c-4a03-95a1-94f34a45ccf6-avatto_me167.js:36
              Patrick Kenzler @Patrick Kenzler last edited by
              Habs in den Griff bekommen, neu installiert, Konverter in den Pfad verschoben - Adapter läuft aber erkennt jetzt das Thermostat nicht -.-
              2022-11-23 07:58:07.595 – Fehler : zigbee.2 (1887) Gerät 0x84ba20fffee088ee „TS0601“ nicht beschrieben in statesMapping.
                Thomas Braun Most Active @Patrick Kenzler last edited by
                Ich hab übrigens gesehen, dass in der aktuellen Alpha-Version vom GitHub die herdsman-Module angepackt wurden.
                P M 2 Replies Last reply Reply Quote 0
                  Patrick Kenzler @Thomas Braun last edited by
                  @thomas-braun okay dann spart es wahrscheinlich einfach Zeit und Nerven wenn ich abwarte und hoffe das das Thermostat aufgenommen wird? 😄
                    mucke1985 @Thomas Braun last edited by
                    Hallo hab auch das selbe Problem das der Converter nicht richtig funktioniert ich verwende den converter von hier ->https://github.com/twhittock/avatto_me167 und hab diesen über die externen converter eingetragen, ansteuern kann ich die Thermostate aber die reinkommenden Datenpunkte werden nicht in die Objektdaten geschriben bin schon mehrere Tage auf der suche nach einer Lösung leider hab ich keine ahnung an was es liegen könnte.
                    Kannst du mir ev. bei der fehlersuch helfen
                    mfg Michael
                      Thomas Braun Most Active last edited by
                      @mucke1985 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                      Ich nicht.
                        Ok
                          Diamand2k22 @mucke1985 last edited by
                          @mucke1985
                          ac9923ff-88a8-40b2-80a8-fdb4741ba2f0-avatto_me167.js
                          M P 2 Replies Last reply Reply Quote 0
                            mucke1985 @Diamand2k22 last edited by mucke1985
                            @diamand2k22
                            Hallo danke für deine Antwort das hab ich gemacht, hab mit nano unter devices eine datei erstellt (me167.js) und den verlinkten Inhalt rein kopiert.
                            Super Danke jetzt hats funktioniert !!!!!!!!!!!!!!!!!!!!!!!!
                            Würde gerne verstehen was jetzt anders ist das es funktioniert, liegts an dem umgang mit externenConvertern in IoBroker
                            oder wo lag das Problem an der me167.js datei die ich verwendet habe.
                            Wo muss ich die img/ME167.png reinkopieren.
                            Danke nochmal
                              Patrick Kenzler @Diamand2k22 last edited by Patrick Kenzler
                              @diamand2k22 jetzt funktioniert es, vielen Dank! Ich habe nen Node.js Update gemacht und anschließend das Thermostat nochmal neu angelernt 🙂
                                @Thomas-Braun
                                Hallo Thomas, ich bin's mal wieder 😄 wieso bekomm ich jetzt den Fehler wenn ich den zigbee herdsmann adapter aus dem Github aktualisieren will?
                                Brauch das update aufgrund neuer device.js updates.
                                $ iobroker url ioBroker/ioBroker.zigbee --host pi4b --debug
                                install ioBroker/ioBroker.zigbee
                                NPM version: 8.19.2Installing ioBroker/ioBroker.zigbee... (System call)
                                npm ERR! code ENOTEMPTY
                                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-11-24T21_59_38_118Z-debug-0.log
                                host.pi4b Cannot install ioBroker/ioBroker.zigbee: 217
                                ERROR: Process exited with code 25
                                  Thomas Braun Most Active @Diamand2k22 last edited by
                                  @diamand2k22
                                  https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                                    Diamand2k22 @Thomas Braun last edited by
                                    danke, hat funktioniert, hab ich vorhin auch gerade zufällig gesehen!
                                    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                      ReverZ @Diamand2k22 last edited by
                                      Einen Datenpunkt für den Batteriestand für den Avatto me167 gibt ´s momentan nicht, oder?
                                      Und muss man lediglich die ME167.png in die entsprechenden Ordner kopieren oder sind weitere Schritte nötig, um das passende Bild zu dem Gerät angezeigt zu bekommen?
                                        arteck Developer Most Active @ReverZ last edited by
                                        @reverz ???????????????????????
                                          @diamand2k22 said in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                          kann sein Thomas, hab ich aber wieder hingebogen bekommen.
                                          @Asgothian
                                          hab mir jetzt ne eigene ketotek.js für mein Heizkörperthermostat gebastelt.
                                          Jetzt funktioniert es wunderbar und ich hab keine Unrecognized DP's mehr und kann es steuern und empfange Temperaturen.
                                          Was mich nur interessieren würde, wie bekomme ich da ein vernünftiges Bild rein?
                                          Kannst du das Thermostat aufnehmen?
                                          @arteck
                                          Könnt ihr das Heizkörperthermostat bei zigbee2mqtt mit aufnehmen.
                                          Es handelt sich um Heizkörperthermostat der Firma Kenotek.
                                            @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                            zigbee2mqtt
                                            dann musst du den issue auch da einstellen.. das macht iobroker nicht..anderes Projekt
                                            herdsman zigbee
                                            13
                                            129
                                            23945
