    4. Tuya Adapter 3.9.x
    Tuya Adapter 3.9.x
    • padrino
      padrino Most Active @apollon77 last edited by padrino
      @apollon77 sagte in Tuya Adapter 3.9.x:
      @padrino ok. Wie erstellt man Gruppen? Ich find das in meiner App nicht.
      Jo, das mit den Gruppen ist ein Graus.
      Keine Ahnung, wie man sowas verbrechen kann. 🤔
      Welche App nutzt Du?
      Nutze SmartLife.
      Evtl. ist ja eine andere Tuya App besser. 😌
      @padrino bitte mal noch das json des device objects (als text)
      Meinste das?
        "from": "system.adapter.tuya.0",
        "user": "system.user.admin",
        "ts": 1669194348590,
        "common": {
          "name": "Leinwand links",
          "read": true
        "native": {
          "lon": "7.0563",
          "uuid": "042257175002910f7b2f",
          "mac": "5002910f7b2f",
          "iconUrl": "https://images.tuyaeu.com/smart/icon/ay1519551146071pEnBd/5d6f0a2a653b884406bbe59a8de78159.png",
          "runtimeEnv": "prod",
          "lat": "49.2386",
          "devId": "042257175002910f7b2f",
          "devKey": "",
          "productId": "wnvviwswgzvwgnjj",
          "categoryCode": "wf_dj",
          "timezoneId": "Europe/Berlin",
          "category": "dj",
          "localKey": "94d19b043d9d8966",
          "productKey": "keycuag84ttsx3fm",
          "version": "3.3",
          "ip": "192.168.178.22",
          "gwId": "042257175002910f7b2f",
          "ownerId": "17527345",
          "gatewayVerCAD": "",
          "dpMaxTime": 1668168075282,
          "activeTime": 1668167245,
          "devAttribute": 3,
          "active": 2,
          "ability": 0,
          "mode": 0,
          "accessType": 0,
          "baseAttribute": 1024,
          "groudId": 17527345,
          "virtual": false,
          "encrypt": true,
          "cloudOnline": true,
          "dpName": {},
          "moduleMap": {
            "wifi": {
              "upgradeStatus": 3,
              "cdv": "1.0.0",
              "bv": "6.01",
              "pv": "2.2",
              "verSw": "5.1.0",
              "isOnline": true,
              "id": 40249817,
              "cadv": ""
            "mcu": {
              "upgradeStatus": 0,
              "cdv": "",
              "verSw": "5.1.0",
              "isOnline": true,
              "id": 40249818,
              "cadv": ""
          "schema": [
              "code": "switch_led",
              "defaultValue": "false",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "rw",
              "defaultRecommend": false,
              "name": "开关",
              "property": {
                "type": "bool"
              "id": 20,
              "editPermission": false
              "code": "work_mode",
              "defaultValue": "white",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "rw",
              "name": "模式",
              "property": {
                "range": [
                  "white",
                  "colour",
                  "scene",
                  "music"
                "type": "enum"
              "id": 21,
              "code": "bright_value",
              "defaultValue": "10",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "rw",
              "name": "亮度值",
              "property": {
                "unit": "",
                "min": 10,
                "max": 1000,
                "scale": 0,
                "step": 1,
                "type": "value"
              "id": 22,
              "code": "colour_data",
              "defaultValue": "",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "rw",
              "name": "彩光",
              "property": {
                "type": "string",
                "maxlen": 255
              "id": 24,
              "code": "scene_data",
              "defaultValue": "",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "rw",
              "name": "场景",
              "property": {
                "type": "string",
                "maxlen": 255
              "id": 25,
              "code": "countdown",
              "defaultValue": "0",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "rw",
              "name": "倒计时",
              "property": {
                "unit": "",
                "min": 0,
                "max": 86400,
                "scale": 0,
                "step": 1,
                "type": "value"
              "id": 26,
              "code": "music_data",
              "defaultValue": "",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "wr",
              "name": "音乐灯",
              "property": {
                "type": "string",
                "maxlen": 255
              "id": 27,
              "code": "control_data",
              "defaultValue": "",
              "canTrigger": true,
              "type": "obj",
              "executable": true,
              "mode": "wr",
              "name": "调节",
              "property": {
                "type": "string",
                "maxlen": 255
              "id": 28,
          "schemaExt": [
              "complexType": "",
              "inputStyle": "",
              "inputType": " ",
              "id": 20
              "complexType": "",
              "inputStyle": "",
              "inputType": " ",
              "id": 21
              "complexType": "",
              "inputStyle": "",
              "inputType": "percent1",
              "id": 22
              "complexType": "",
              "inputStyle": "",
              "inputType": "percent",
              "id": 23
              "complexType": "",
              "inputStyle": "",
              "inputType": "countdown1",
              "id": 26
          "otaInfo": {
            "supportAuto": true,
            "otaUpgradeModes": [
              0
            "otaModuleMap": {
              "wifi": {
                "upgradeStatus": 3,
                "cdv": "1.0.0",
                "bv": "6.01",
                "verSw": "5.1.0"
              "mcu": {
                "upgradeStatus": 0,
                "cdv": "",
                "verSw": "5.1.0"
          "communication": {
            "communicationNode": "042257175002910f7b2f",
            "communicationModes": [
                "pv": "",
                "type": 0
                "pv": "2.2",
                "type": 1
            "connectionStatus": 1
          "dataPointInfo": {
            "dpMaxTime": 1669081926878,
            "dpName": {},
            "dps": {
              "20": false,
              "21": 0,
              "22": 250,
              "24": "0025035500f5",
              "25": "000e0d0000000000000000c803e8",
              "26": 0,
              "27": "",
              "28": ""
            "dpsTime": {
              "20": 1669081926878,
              "21": 1669081858272,
              "22": 1669081858272,
              "24": 1669081794516,
              "25": 1668513054497,
              "26": 1668167250104,
              "27": 1668167245789,
              "28": 1668167245789
          "deviceTopo": {}
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
        "_id": "tuya.0.042257175002910f7b2f",
        "type": "device"
        A Former User @apollon77 last edited by
        @apollon77 mal fuer "die-noch-nicht-die-gruppe-gefunden-Leute" ... ich hab nur Szenen, ist es das, wo ich mehrere Devices ein/ausschalten kann... ? Ich such und google schon die ganze Zeit.. die Anleitung sagt was von Hauptseite, dann +, dann Gruppen... da hab ich aber nur Szenen ausser dem neuen Geraet... ( Smart Life App, iOs.. )
        padrino apollon77 2 Replies Last reply Reply Quote 0
        • padrino
          padrino Most Active @Guest last edited by padrino
          @ilovegym
          Du musst in ein Gerät gehen.
          Dann in dessen Konfig.
          Dort kannste "zu Gruppehinzufügen" auswählen. 🙄
            apollon77 @Guest last edited by
            @ilovegym Gruppen: Geht auf ein Gerät, auf den Stift und dann dort im "Menü des Geräts" quasi gibts "zu gruppe hinzufügen". so kannst du eine erstellen. Es gehen nur "Gleiche Gerätetypen" zusammen und dann kannst du nicht ur ein/ausschalten sondern wirklich werte machen - nicht alle aber einige ...
            padrino 2 Replies Last reply Reply Quote 0
            • padrino
              ...und dann kannst du nicht ur ein/ausschalten sondern wirklich werte machen - nicht alle aber einige ...
              Hmm, das sind doch Szenen? Also, mit Werten. 😌
              Gruppen sind nur für ein/aus, Szenen können mehr, oder? 😃
                apollon77 @padrino last edited by
                @padrino hehe , ja ok Fehler gefunden ... Fix in nächster Version
                  @padrino Wichtig;: Wir reden von Tuya, nicht "ioBroker Szenen!!".
                  Tuya: In meinenm Verständnis ists genau andersrum. Szenen (in der Tuya APP!!)) schalten "Eine gruppe von geräten in einem definierten Zustand". Gruppen erlauben mehrere "gleiche" Geräte zusammen zu steuern
                  • padrino
                    Jo, sag ich doch. 😉
                    Aber hier schreibst Du das anders...
                    Kein Stress. 🥰
                      A Former User @padrino last edited by
                      @padrino sagte in Tuya Adapter 3.9.x:
                      @ilovegym
                      Achjee.. ja, da isses.. richtig, DANKE!
                        @apollon77
                        wer hat noch ne LSC Doorbell? Seit der neuen Adapterversion 3.8.x funktioniert der Link fuer das Doorbell-Pic nicht mehr..
                        Seit dem 16.11.22 ist das anders, hier die History:
                        Bekommt man das wieder hin?
                        • padrino
                          @ilovegym
                          Evtl. mal das Gerät/Objekt löschen und dann denn Adapter neu starten (mit Cloud Abgleich)?
                          Hatte auch schon nach Updates, dass was nimmer lief, dann hat ein "neu anlegen" geholfen.
                            apollon77 @Guest last edited by apollon77
                            @ilovegym Ok, ich kann nochmal schauen. Das Problem ist das das "ein base64 encodetes etwas" ist was da von Tuya kommt. Bisher wurde immer "base64-decode gemacht". Damit war es da dann die URL. Problem ist aber das es ggf echte binäre Daten sind und die wurden dadurch zerstört.
                            Jetzt gibts zwei varianten:
                            1.) Ich baue im Adapter ein das er es dekodiert, irgendwie rausfindet ob es "text" ist und wenn ja so lässt und nur bei binärdaten es dann doch nicht dekodiert
                            2.) Du dir nen Alias definierst und dort als "read" funktion das base64 decode machst
                            Für 1.) wäre es ggf ein GitHub issue bitte
                              @apollon77 ah, gute Idee, ich teste mal rum.. muss halt jedesmal runter die Klingel druecken und wieder hoch rennen an den Rechner.. oder ich hol mir so ne Klingel nochmal.. mal schauen.. komm gerade vom Action.. 🙂
                              apollon77 padrino 2 Replies Last reply Reply Quote 0
                                @ilovegym sagte in Tuya Adapter 3.9.x:
                                wieder hoch rennen
                                Sport tut gut 🙂
                                  wieder hoch rennen
                                  Sport tut gut 🙂
                                  Gerade mal wieder koerperlich stark eingeschränkt.. 😞 da neige ich eher dazu, noch 23x bei Amazon einzeln zu bestellen, dann klappt das mit dem Klingel druecken.. ( es sei denn, es kommt per DHL, der wirft beim vorbeifahren ab..)
                                  • padrino
                                    Dann bestell doch was bei prime, am Besten über 'n Echo, dann haben wir alle was davon. 🤣
                                      @padrino schon passiert.. 😉
                                      • O
                                        Opa75+ last edited by
                                        @apollon77
                                        Bereits eine Anfrage gestellt. Datenpunkt nicht änderbar!
                                        Habe folgendes Problem:
                                        Infrarotheizung steuerbar mit der Tuya App, funktioniert gut.
                                        Alle DP in der Tuya App vorhanden und bis auf einen DP sind auch die DP,s steuerbar. Der DP "work_state" reagiert nicht- Im RAW war er schreibgeschützt, habe Schreibschutz auf nein gesetzt => keine Änderung. Ich kann zwar "Standby" oder "heating". wählen, aber es wird nichts ausgeführt. Der DP Wert ist rot!
                                        Ist das ein Cloud Problem oder ist dieser DP von der Tuya APP geschützt?
                                        apollon77 O 2 Replies Last reply Reply Quote 0
                                          apollon77 @Opa75+ last edited by
                                          @opa75 Also wenn das State Read only ist dann weil Tuya es so mitliefert und dann machts auch keinen Sinn es am Adapter vorbei zu ändern.
                                          Working state denke ich ist der Status des geräts. Am einfachsten ändere in der app und schaue was sich ändert in den States, dann weisst du was du ändern musst. Bei temo set 19 und aktuell 18 kann ggf sein das sie einfach nichts tut ... das musst du mal versuchen.
                                          • O
                                            Opa75+ @Opa75+ last edited by
                                            @opa75 Danke für die prompte Antwort.
                                            Die Steuerung über die App funktioniert. Wenn ich in der App auf work_state "smart" stelle funktioniert die Heizung laut Einstellung in der App. Problem ist nur, dass die Genauigkeit der Temperaturwerte sehr ungenau sind. Darum möchte ich im work_state "auto" die Heizplatte betreiben. Ich brauche diese nur in der Früh zum Aufheizen für 1 ca. Stunde.
                                            117
                                            14937
