    4. Fehlermeldungen bei Installation mac
      Addendum:
      Hier die Dateistruktur:
      Rainer
      • BuZZy
        BuZZy last edited by
        Funktioniert denn auch die Adapterinstallation bei dir Rainer?
        Von unterwegs gesendet
          Discovery und Admin hatte er ja schon während der Grundinstallation installiert,
          im Moment versuche ich den RPi2-Adapter zu installieren…
          ...und NEIN, Exit mit Code 1
          $ ./iobroker add rpi2
          npm install iobroker.rpi2 --production --prefix "/opt/iobroker" (System call)
          ERROR: module.js:487    throw err;
          Error: Cannot find module 'mime'
              at Function.Module._resolveFilename (module.js:485:15)
              at Function.Module._load (module.js:437:25)
              at Module.require (module.js:513:17)
              at require (internal/module.js:11:18)
              at Install.createInstance (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:584:27)
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:741:41
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:157:39
              at enableAdapters (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:47:21)
              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:156:21
              at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:325:31)
          ERROR: process exited with code 1</anonymous>
          Ich teste noch mal welche
          EDIT1:
          $ ./iobroker add hm-rpc
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module.runMain (module.js:605:10)
              at startup (bootstrap_node.js:158:16)
              at bootstrap_node.js:575:3
          EDIT2:
          $ ./iobroker add hm-rega
          Rainer
          • BuZZy
            Wie sieht es denn aus wenn du es unter node 6.x.x versuchst?
              Jetzt lief gar nichts mehr, kein iobroker update, kein drüberinstallieren - da kam auch ENOSELF
              npm ERR! code ENOSELF
              npm ERR! Refusing to install package with name "iobroker" under a package
              npm ERR! also called "iobroker". Did you name your project the same
              npm ERR! as the dependency you're installing?
              npm ERR!
              npm ERR! For more information, see:
              npm ERR!     <https: docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm="">npm ERR! A complete log of this run can be found in:
              npm ERR!     /root/.npm/_logs/2017-07-27T19_02_55_498Z-debug.log</https:>
              Hab nochmal komplett gelöscht und Installiere nochmal unter Nodejs 8
              Wenn das wieder schiefgeht lösch ich node8 und mach es unter node 6
              Rainer
                Zweiter Anlauf mit Node8 hat auch nicht geklappt.
                Erster Versuch mit Node6 brachte auch einen ENOSELF. Da das nicht sein konnte/durfte einen reboot gefahren.
                Dann ordentlich mit Ähnlichen Warnungen durchgefahren:
                root@OPi:/opt/iobroker# sudo npm install iobroker --unsafe-perm
                ! > iobroker@1.0.0 install /opt/iobroker/node_modules/iobroker
                node lib/setup.js
                ! npm install iobroker.discovery --production --prefix /opt/iobroker
                node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
                node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.1 (node-v48 ABI) (falling back to source compile with node-gyp)
                ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Localv8::object, std::string)’:
                ../src/serialport.cpp:90:52: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                return getValueFromObject(options, key)->ToInt32()->Int32Value();
                ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Localv8::object, std::string)’:
                ../src/serialport.cpp:102:53: warning: ‘v8::Local v8::numberv8::Value::ToNumber() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8173): Use maybe version [-Wdeprecated-declarations]
                return getValueFromObject(options, key)->ToNumber()->NumberValue();
                ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                ../src/serialport.cpp:174:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                int fd = argv[1]->ToInt32()->Int32Value();
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:193:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                int fd = info[0]->ToInt32()->Int32Value();
                ../src/serialport.cpp:217:116: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                baton->baudRate = Nan::Get(options, Nan::Newv8::string("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:252:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:369:32: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                baton->fd = info[0]->ToInt32()->Int32Value();
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:480:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:528:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport.cpp:585:29: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatformOptions(const v8::Localv8::object&)’:
                ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                result->vmin = Nan::Get(options, Nan::Newv8::string("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                result->vtime = Nan::Get(options, Nan::Newv8::string("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                ../src/serialport_poller.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE SerialportPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
                ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local v8::int32v8::Value::ToInt32() const’ is deprecated (declared at /root/.node-gyp/6.11.1/include/node/v8.h:8209): Use maybe version [-Wdeprecated-declarations]
                obj->fd_ = info[0]->ToInt32()->Int32Value();
                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                npm WARN iobroker No description
                npm WARN iobroker No repository field.
                npm WARN iobroker No README data
                npm WARN iobroker No license field.
                npm install iobroker.admin --production --prefix /opt/iobroker
                npm install iobroker.js-controller --production --prefix /opt/iobroker
                Write "./iobroker start" to start the ioBroker
                : No such file or directory
                Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
                iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
                /opt/iobroker
                └─┬ iobroker@1.0.0
                └─┬ yargs@7.1.0
                ├── camelcase@3.0.0
                ├─┬ cliui@3.2.0
                │ ├─┬ strip-ansi@3.0.1
                │ │ └── ansi-regex@2.1.1
                │ └── wrap-ansi@2.1.0
                ├── decamelize@1.2.0
                ├── get-caller-file@1.0.2
                ├─┬ os-locale@1.4.0
                │ └─┬ lcid@1.0.0
                │ └── invert-kv@1.0.0
                ├─┬ read-pkg-up@1.0.1
                │ ├─┬ find-up@1.1.2
                │ │ ├── path-exists@2.1.0
                │ │ └─┬ pinkie-promise@2.0.1
                │ │ └── pinkie@2.0.4
                │ └─┬ read-pkg@1.1.0
                │ ├─┬ load-json-file@1.1.0
                │ │ ├── graceful-fs@4.1.11
                │ │ ├─┬ parse-json@2.2.0
                │ │ │ └─┬ error-ex@1.3.1
                │ │ │ └── is-arrayish@0.2.1
                │ │ ├── pify@2.3.0
                │ │ └─┬ strip-bom@2.0.0
                │ │ └── is-utf8@0.2.1
                │ ├─┬ normalize-package-data@2.4.0
                │ │ ├── hosted-git-info@2.5.0
                │ │ ├─┬ is-builtin-module@1.0.0
                │ │ │ └── builtin-modules@1.1.1
                │ │ ├── semver@5.4.1
                │ │ └─┬ validate-npm-package-license@3.0.1
                │ │ ├─┬ spdx-correct@1.0.2
                │ │ │ └── spdx-license-ids@1.2.2
                │ │ └── spdx-expression-parse@1.0.4
                │ └── path-type@1.1.0
                ├── require-directory@2.1.1
                ├── require-main-filename@1.0.1
                ├── set-blocking@2.0.0
                ├─┬ string-width@1.0.2
                │ ├── code-point-at@1.1.0
                │ └─┬ is-fullwidth-code-point@1.0.0
                │ └── number-is-nan@1.0.1
                ├── which-module@1.0.0
                ├── y18n@3.2.1
                └── yargs-parser@5.0.0
                ! npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
                root@OPi:/opt/iobroker# iobroker restart
                iobroker controller daemon is not running
                Starting iobroker controller daemon...
                iobroker controller daemon started. PID: 1580</v8::int32></v8::string></v8::int32></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
                und zum Schluss auch nicht selber gestartet.
                Installation von rpi2 hat geklappt. HM-rpc auc und hm-rega läuft gerade (zu dem Zeitpunkt war es unter node8 bereits beendet)
                Jetzt weiß ich nur nicht ob es unter node8 vielleicht nach einem reboot zu irgendeinem Zeitpunkt dann ebenfalls geklappt hätte???
                Rainer
                  tesso last edited by
                  Mein opi2e läuft seit Wochen mit node 8.0.0 und das stabil.
                  die node 8.2.1 kann ich heute abend testen.
                    Welches BS nutzst du?
                    ich habe das aktuelle Armbian (Jessie), das hat gestern noch schnell bei apt-get update && apt-get upgrade ein Kernel Update gefahren.
                    Die Versionen kann ich dir jetzt jedoch nicht sagen, da ich keinen Zugriff darauf habe.
                    Rainer
                      thoduh last edited by
                      @supernova1963:
                      Also, wenn ich dich recht verstehe, willst du den Ordner ioBroker unbedingt im root Verzeichnis deiner Systemplatte platzieren und mit sudo chmod -R 777 /iobroker jedem alle Rechte auf diesen Verzeichnisbaum geben.
                      Kann ich dich irgendwie davon abbringen?
                      Ich würde den Ordner unter /User/MacMini/Documents/ioBrokerMac angelegen (ohne sudo!!!) und es funktioniert trotzdem (bzw. gerade deswegen). `
                      Ich wollte ja garnicht ins root Verzeichnis, deinen Speicherort hatte ich ganz am Anfang schon probiert (siehe oben). hatte aber nicht funktioniert, deshalb jetzt im root…
                      Nachdem ich iobroker nochmals neu installiert habe, läuft es auch bei mir. Auch das installieren von div. Adaptern funktioniert problemlos.
                      ABER: ich kann per````
                      MacMini-LAN:iobroker.js-controller MacMini$ ./ioBroker stop
                        Im iobroker verzeichnis ausführen
                        sudo iobroker stop
                        Rainer
                          Auch schon probiert…
                          MacMini-LAN:iobroker MacMini$ sudo iobroker stop
                          sudo: iobroker: command not found
                            pix last edited by
                            @thoduh:
                            ABER: ich kann perMacMini-LAN:iobroker.js-controller MacMini$ ./ioBroker stopnicht stoppen ? `
                            @thoduh:
                            Welcher Ordner ist es denn nun? ioBroker oder iobroker?
                            Wenn ich das richtig sehe, sollte aus dem OrdnerMacMini-LAN:iobroker MacMini$der Befehl````
                            ./iobroker stop
                            Pix
                              Da ich verzweifelt bin, hab ich verschiedene ausprobiert :lol:
                              Der Ordner "iobroker" ist eigentlich richtig…
                              MacMini-LAN:/ MacMini$ cd iobroker
                              MacMini-LAN:iobroker MacMini$ ./iobroker stop
                              -bash: ./iobroker: No such file or directory
                              Gibt es keine andere Möglichkeit den iobroker zu stoppen?
                                @thoduh:
                                Der Ordner "iobroker" ist eigentlich richtig… `
                                Aber der Befehl wars nicht. Einmal hattest du ioBroker statt iobroker grschrieben.
                                Außerdem musst du immer ein sudo voranstellen wenn du nicht root/Administrator bist.
                                Rainer
                                  Also ich hab jetzt wirklich so ziemlich alle Kombinationsmöglichkeiten Versucht. Auch das mit sudo ist bekannt.
                                  Immerhin suche ich schon seit 2 Stunden nach einer Lösung zum stoppen 😞
                                  MacMini-LAN:iobroker MacMini$ sudo ./iobroker stop
                                  Password:
                                  sudo: ./iobroker: command not found
                                  supernova1963 schreibt doch oben, dass es bei Ihm auch nicht funktioniert…
                                    pix last edited by
                                    Wenn es dir nur ums Stoppen geht, dann öffne die Aktivitätsanzeige
                                    Tippe Apfel+Space und schreibe "Aktivitä…." sollte dann schon kommen und RETURN
                                    Dann im Suchfeld oben rechts alle Prozesse mit "io." anzeigen lassen. Kannst du dann einzeln killen. natürlich auch den js-controller.
                                    Pix
                                    EDIT: Läuft deine iobroker Installation wirklich in diesem Ordner?
                                    EDIT: Natürlich "io." nicht ".io"
                                      Nachdem ich zum x-ten mal alles von ioBroker gelöscht habe (auch irgendwelche zerstreuten Dateien die ich irgendwo entdeckt hatte) und den Tip von supernova1963 etwas abgewandelt habe, läuft ioBroker jetzt auch bei mir 😄
                                      Warum das vorher schon nicht funktioniert hat weiß ich nicht und werde mich damit wahrscheinlich auch nicht mehr befassen wollen :!:
                                      So und NUR so hat die Installation endlich funktioniert:
                                      cd /Users/MacMini/Documents
                                      mkdir ioBrokerMac
                                      cd /Users/MacMini/Documents/ioBrokerMac
                                      sudo npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production --prefix /Users/MacMini/Documents/ioBrokerMac
                                      cd /Users/MacMini/Documents/ioBrokerMac/node_modules/iobroker.js-controller
                                      sudo chmod +x iobroker
                                      node controller.js
                                      Das einzige was ich geändert bzw. hinzugefügt habe ist das erste "sudo". NUR dann läuft die Installation auch fehlerfrei (!) durch.
                                      Anscheinend muß ioBroker auch in diesem Verzeichnis liegen, denn ich habe es auch in anderen Verzeichnissen versucht, hat nicht funktioniert.
                                      ioBroker läuft, Adapter lassen sich fehlerfrei (!) installieren und ich habe noch immer node v8.2.1 drauf.
                                      Nochmal Danke an die Helfer supernova1963, BuZZy, Homoran :!: :!: :!:
                                      Wie spät ist eigentlich? Oh schon 2:52 Uhr :shock:
                                      MacMini-LAN:node_modules MacMini$ sudo npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production --prefix /Users/MacMini/Documents/ioBrokerMac
                                      ! > unix-dgram@0.2.3 install /Users/MacMini/Documents/ioBrokerMac/node_modules/unix-dgram
                                      node-gyp rebuild
                                      ! CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                      SOLINK_MODULE(target) Release/unix_dgram.node
                                      ! > ursa@0.9.4 install /Users/MacMini/Documents/ioBrokerMac/node_modules/ursa
                                      node-gyp rebuild
                                      ! CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
                                      SOLINK_MODULE(target) Release/ursaNative.node
                                      ! > iobroker.js-controller@1.1.2 install /Users/MacMini/Documents/ioBrokerMac/node_modules/iobroker.js-controller
                                      node iobroker.js setup first
                                      ! + iobroker.js-controller@1.1.2
                                      added 509 packages in 25.632s
                                      • BuZZy
                                        Guten Morgen und herzlichen Glückwunsch! 😄
                                        Wir haben dir gerne geholfen! 🙂
                                        Gruß, Alex
                                          Schön, dass es jetzt bei dir läuft.
                                          und Update bei mir:
                                          ich habe es nochmal komplett deinstalliert und nodejs 6,xx wieder runtergeworfen, und nodejs 8.xx installiert.
                                          Die erneute Installation von ioBroker lief durch aber es ließen sich keine Adapter nachinstallieren.
                                          Und noch zur Vollständigkeit das Betriebssystem:
                                          ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
                                          Rainer
                                          • supernova1963
                                            supernova1963 last edited by
                                            Freut mich, thoduh, dass es läuft.
                                            Da ich zwischenzeitlich auch die node Version 8.x probiert habe, ist mir aufgefallen, dass, wenn ich das npm install mit sudo ausführe, der Ordner u.A. "/$HOME/Documents/ioBrockerMac/node_modules" den Eigentümer "root" erhält. Damit die Adapter Installationen in der Admin Oberfläche funktionieren habe ich noch den folgenden Befehl hinzugefügt ("$HOME" entspricht "~" das dem Homeverzeichnis des angemeldeten Benutzers entspricht; $USER ist der Kurzname des angemeldeten Benutzers)
                                            sudo chown $USER ~/Documents/ioBrokerMac/node_modules
                                            sudo chown $USER ~/Documents/ioBrokerMac/node_modules/.bin
                                            sudo chown $USER ~/Documents/ioBrokerMac/etc
                                            Noch offen war für mich der Start und das Beenden des/der ioBroker Prozesses bzw. Prozesse.
                                            • Das Starten mit "nohup … &" ermöglicht das Schliessen des Terminal-Fensters.
                                            • Das Beenden funktioniert mit "killall.sh", wenn man es ausführbar gemacht hat.
                                            Damit würde ein etwas variablere Befehlsfolge so aussehen:
                                            cd ~/Documents
                                            mkdir ioBrokerMac
                                            cd ~/Documents/ioBrokerMac
                                            sudo npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production --prefix ~/Documents/ioBrokerMac
                                            cd ~/Documents/ioBrokerMac/node_modules/iobroker.js-controller
                                            sudo chmod +x killall.sh
                                            nohup node controller.js &
                                            Dann sollte das Terminal-Fenster anderweitig verwendet werden können.
                                            Das Beenden der ioBroker Prozesse funktioniert dann mit:
                                            ~/Documents/ioBrokerMac/node_modules/iobroker.js-controller/killall.sh
                                            Könnte das ein Mac Benutzer mal testen und mir zurückmelden, ob es nicht nur bei mir funktioniert?
                                            Unsicher bin ich mir bei "sudo npm install https://github.com/ioBroker/ioBroker.js … all/master --production --prefix ~/Documents/ioBrokerMac". Ich weiß nicht, ob das npm den Parameter --prefix ~/Documents/ioBrokerMac richtig interpretiert.
                                            Danke,
                                            Gernot
                                            P.S.: Kennt sich einer mit launchd (ist sowas wie init.d von Linux) aus? Es wäre doch schön mit einem solchen "Profil" ioBroker auch ohne Benutzeranmeldung zu starten, oder?
                                            Die Einfachste aller Möglichkeiten des Autostartes über das Benutzeranmeldeobjekt:
                                            Eine Datei ioBrokerMac.sh mit folgendem Inhalt in ~/Documents/ioBrokerMac/node_modules/iobroker.js-controller/ erstellen:
                                            #!/bin/sh
                                            /$HOME/Documents/ioBrokerMac/node_modules/iobroker.js-controller/nohup node controller.js &
                                            und mit````
                                            sudo chmod +x ioBrokerMac.sh
                                            Dieses Script kann dann im Benutzer Anmeldeobjekt hinzugefügt werden.
                                            [3137_benutzer_anmeldeobjekt.png](/assets/uploads/files/3137_benutzer_anmeldeobjekt.png)
                                            13532
