Aktives Repository ist "default" - Was bedeutet die Meldung?
@thomas-braun sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
iob broker update
@homoran sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
iob broker update
Das sollte bestimmt ein Intelligenztest für mich sein
Tippgicht. -
iob update Used repository: Stable (default) hash changed or no sources cached => force download of new sources Cannot get any information of "_repoInfo". Ignored. update done Adapter "admin" : 6.2.23 , installed 6.2.23 Adapter "alexa2" : 3.21.0 , installed 3.11.2 [Updateable] Adapter "awattar" : 1.0.6 , installed 1.0.6 Adapter "backitup" : 2.5.4 , installed 2.5.4 Adapter "bluelink" : 2.2.3 , installed 2.2.3 Adapter "daswetter" : 3.1.4 , installed 3.1.4 Adapter "discovery" : 3.0.5 , installed 3.0.5 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "flot" : 1.11.0 , installed 1.11.0 Adapter "fritzdect" : 2.2.6 , installed 2.2.6 Adapter "history" : 2.2.0 , installed 1.11.1 [Updateable] Adapter "hs100" : 2.1.2 , installed 2.1.2 Adapter "ical" : 1.13.1 , installed 1.13.1 Adapter "icons-icons8" : 0.0.1 , installed 0.0.1 Adapter "icons-material-png": 0.1.0 , installed 0.1.0 Adapter "icons-mfd-png" : 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg" : 1.1.0 , installed 1.1.0 Adapter "icons-open-icon-library-png": 0.1.2 , installed 0.1.2 Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.9 , installed 1.11.9 Adapter "javascript" : 6.0.3 , installed 5.2.21 [Updateable] Controller "js-controller" : 4.0.23 , installed 3.3.22 [Updateable] Adapter "ping" : 1.5.3 , installed 1.5.3 Adapter "proxy" : 1.3.1 , installed 1.3.1 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "sayit" : 1.12.3 , installed 1.12.3 Adapter "shelly" : 6.0.0 , installed 4.0.7 [Updateable] Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "tahoma" : 0.7.1 , installed 0.7.1 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "tr-064" : 4.2.16 , installed 4.2.16 Adapter "tvspielfilm" : 2.0.4 , installed 2.0.4 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "vis-colorpicker": 1.2.0 , installed 1.2.0 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-map" : 1.0.4 , installed 1.0.4 Adapter "weatherunderground": 3.4.2 , installed 3.4.2 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 Adapter "zigbee" : 1.7.5 , installed 1.6.16 [Updateable]
ging heute ganz schnell
@klausiob sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
jepp, der hat's definitv nötig, aber erst mal mit upload versuchen
Da klemmt auch noch was im Repo-Setup.
iobroker repo list
iobroker repo list
Alle Adapter sind jetzt aktuell. iobroker repo list Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest): http://download.iobroker.net/sources-dist-latest.json Active repo: Stable (default)
Dann los.
Ich hab mal ein Update von der Doku für den Abschnitt "Auswahl des Repositorys vorbereitet"
https://github.com/Feuer-sturm/ioBroker.docs/blob/doc-repo-update/docs/de/basics/repositories.md#auswahl-des-repositorySchaut doch mal drüber ob noch was fehlt, dann kann ich es als Pullrequest zur Verfügung stellen.
Dann los.
mit upload? läuft und dauert wegen den icon-libraries ewig
Mit
iobroker update iobroker upgrade all iobroker upload all
ja ja ist noch beim letzten Befehl, dauerte schon gestern >10 min
Gib mal ein Link zu einem sicheren js-controller Update auf 4.xx
Hatte im Januar erst auf 3.2.22 upgedatet.Ist dies noch die empfohlene Variante zur Aktualisierung des js-controller, wenn ioBroker mittels "curl shell installation script" installiert wurde?
Bitte in einer SSH-Shell (Konsole) folgende Befehle ausführen:
iobroker stop iobroker update iobroker fix oder wenn das nicht funktioniert: curl -sL https://iobroker.net/fix.sh | bash - iobroker upgrade self iobroker start oder Server rebooten, danach sollte ioBroker neu starten und man kann sicher sein das alle alten Prozesse beendet waren.
js-controller:
iob stop iob update iob upgrade self iob start
Wie sieht es auf der nodejs-Seite aus?
sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
so jetzt erst fertignode und nodejs v14.18.1, kein Docker
ich habe ein Master-Slave-System. Welchen sollte ich zuerst updaten?
@klausiob Ich würd zuerst nodejs auf Stand bringen.
Achtung: MASTER-Systeme Reihenfolgen beachten!
Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.x läuft, ist es beim Update auf Version 4.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
@feuersturm sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
gefällt mir ziemlich gut, aber....
Zwei Dinge, die ich nicht wirklich weiß!
1.)
ist das Repo wirklich der Lagerort für Programme?
nicht eher eine Liste der Versionen?2.)
ist die Installation per Experte und npm wirklich (immer) die beta Version und nicht doch die github Version?wenn ja, bitte hier trotzdem noch die 3. Ebene erwähnen, dass github = Alpha sein kann.
js-controller:
iob upgrade self Update js-controller from @3.3.22 to @4.0.23 NPM version: 6.14.15 npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call) In file included from ../node_modules/nan/nan.h:60, from ../src/unix_dgram.cc:5: /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(unix_dgram, Initialize) ^~~~~~~~~~~ Server Objects 127.0.0.1:60770 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"] Server Objects 127.0.0.1:60770 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"] Server States 127.0.0.1:41382 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"] Server States 127.0.0.1:41384 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
Kein Problem.
