    4. Test Adapter TP-Link Tapo
      pfahlenbauer @tombox last edited by
      @tombox Ich habe ähnliche Probleme mit meinen Kamera's. Ich würde gerne die Strahler der Kameras (C320WS) ein- und ausschalten. Aber mir scheint auch es gibt Verbindungsprobleme. Auch wenn ich in der Tapo App Änderungen vornehme (z.B. Leuchtstärke), so ändert sich das iobroker Object "set brightness" nicht.
      Hier aus meinem Log:
      tapo.0
      2022-11-22 17:01:42.209	info	Wait for connections
      tapo.0
      2022-11-22 17:01:42.163	error	52 - Get Device Info failed
      tapo.0
      2022-11-22 17:01:42.162	info	Initialized 80217D4F5XXXXXXXXXXXX
      tapo.0
      2022-11-22 17:01:42.161	error	111 Error: connect ECONNREFUSED 192.168.178.110:80
      tapo.0
      2022-11-22 17:01:41.946	info	Unknown device type C320WS init as P100
      tapo.0
      2022-11-22 17:01:41.945	info	Init device 80217D4F5XXXXXXXXXXXXXXX type C320WS with ip 192.168.178.110
      tapo.0
      2022-11-22 17:01:41.744	error	52 - Get Device Info failed
      tapo.0
      2022-11-22 17:01:41.743	info	Initialized 8021AE79E9XXXXXXXXXXXXXXX
      tapo.0
      2022-11-22 17:01:41.742	error	111 Error: connect ECONNREFUSED 192.168.178.113:80
      tapo.0
      2022-11-22 17:01:41.542	info	Unknown device type C320WS init as P100
      tapo.0
      2022-11-22 17:01:41.541	info	Init device 8021AE79XXXXXXXXXXXXXXXXX type C320WS with ip 192.168.178.113
      tapo.0
      2022-11-22 17:01:41.366	error	52 - Get Device Info failed
      tapo.0
      2022-11-22 17:01:41.366	info	Initialized 80214550BEEXXXXXXXXXXXXXXXX
      tapo.0
      2022-11-22 17:01:41.363	error	111 Error: connect ECONNREFUSED 192.168.178.109:80
      tapo.0
      2022-11-22 17:01:41.238	info	Unknown device type C210 init as P100
      tapo.0
      2022-11-22 17:01:41.237	info	Init device 80214550BEEXXXXXXXXXXXXXXXX type C210 with ip 192.168.178.109
      tapo.0
      2022-11-22 17:01:41.011	info	Found 3 devices
      tapo.0
      2022-11-22 17:01:40.797	info	Login succesfull
      tapo.0
      2022-11-22 17:01:40.214	info	Login tp TAPO App
      tapo.0
      2022-11-22 17:01:40.153	info	starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.tapo, node: v14.20.0, js-controller: 4.0.23
        tombox @pfahlenbauer last edited by
        @pfahlenbauer du musst die GitHub version installieren das man die strahler schalten kann habe ich noch nicht gesehen
          @tombox Habe nun von GitHub installiert und bekomme den gleichen ONVIV SOAP faultwie @Gabe
          tapo.0
          2022-11-22 19:57:44.080	info	Wait for connections
          tapo.0
          2022-11-22 19:57:44.050	error	Error: ONVIF SOAP Fault: Authority failure
          tapo.0
          2022-11-22 19:57:43.952	info	Init device 80217D4F53XXXXXXXXXXXXXXXXXXXXXXXX type C320WS with ip 192.168.178.110
          tapo.0
          2022-11-22 19:57:43.687	error	Error: ONVIF SOAP Fault: Authority failure
          tapo.0
          2022-11-22 19:57:43.574	info	Init device 8021AE79E9CC0XXXXXXXXXXXXXXXX type C320WS with ip 192.168.178.113
          tapo.0
          2022-11-22 19:57:43.336	error	Error: ONVIF SOAP Fault: Authority failure
          tapo.0
          2022-11-22 19:57:43.189	info	Init device 80214550BEEXXXXXXXXXXXXXXXXXXXXX type C210 with ip 192.168.178.109
          tapo.0
          2022-11-22 19:57:42.921	info	Found 3 devices
          tapo.0
          2022-11-22 19:57:42.718	info	Login succesfull
          tapo.0
          2022-11-22 19:57:42.260	info	Login tp TAPO App
          tapo.0
          2022-11-22 19:57:42.196	info	starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#99bdbd2e2ba1bed5a907e1569e293924d49aef97) in /opt/iobroker/node_modules/iobroker.tapo, node: v14.20.0, js-controller: 4.0.23
            @pfahlenbauer ich habe noch eine version gebaut bei dem man den stream user eintragen kann was man anscheinend für die motion detection benötigt. für den strahler bräuchte ich Zugang zu einer Kamera um zu sehen welcher Befehl genau abgesetzt wird
              @tombox Danke. Zugang zu meiner Kamera kann ich Dir geben. Schicke ich Dir per PN
              pfahlenbauer
              • mrbungle64
                mrbungle64 Developer @tombox last edited by
                @tombox
                ich erreiche inzwischen recht schnell das "API rate limit".
                2022-11-23 21:30:14.067  - error: tapo.0 (480412) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
                2022-11-23 21:42:14.014  - error: tapo.0 (480804) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
                2022-11-23 21:59:28.199  - error: tapo.0 (481091) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
                Frage 1) Habt Ihr das auch schon gehabt?
                Frage 2) Welches Update-Intervall habt Ihr eingestellt?
                Ich hatte zuerst 10 Sekunden eingestellt - bis heute dann 15 Sekunden (bei 3 Tapo P115 Schaltsteckdosen)
                  tombox @mrbungle64 last edited by
                  @mrbungle64 Eigenartig das sind ja lokale api warum ist da ein rate limit drauf
                  mrbungle64 1 Reply Last reply Reply Quote 0
                  • mrbungle64
                    mrbungle64 Developer @tombox last edited by mrbungle64
                    @tombox sagte in Test Adapter TP-Link Tapo:
                    Ich denke, dass das im Zusammenhang mit diesen Fehlern auftritt:
                    2022-11-23 21:09:00.027  - info: tapo.0 (479641) Scheduled restart.
                    2022-11-23 21:09:00.053  - info: tapo.0 (479641) terminating
                    2022-11-23 21:09:00.056  - info: tapo.0 (479641) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-11-23 21:09:00.569  - warn: tapo.0 (479641) get state error: Connection is closed.
                    2022-11-23 21:09:00.581  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.04": DB closed
                    2022-11-23 21:09:00.583  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.03: DB closed
                    2022-11-23 21:09:00.584  - warn: tapo.0 (479641) get state error: Connection is closed.
                    2022-11-23 21:09:00.587  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.04: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.04": DB closed
                    2022-11-23 21:09:00.592  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.05": Connection is closed.
                    2022-11-23 21:09:00.595  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.04: DB closed
                    2022-11-23 21:09:00.597  - warn: tapo.0 (479641) get state error: Connection is closed.
                    2022-11-23 21:09:00.598  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.05: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.05": Connection is closed.
                    2022-11-23 21:09:00.602  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.06": Connection is closed.
                    2022-11-23 21:09:00.604  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.05: DB closed
                    2022-11-23 21:09:00.605  - warn: tapo.0 (479641) get state error: Connection is closed.
                    2022-11-23 21:09:00.606  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.06: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.06": Connection is closed.
                    2022-11-23 21:09:01.287  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
                    2022-11-23 21:09:01.290  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
                    2022-11-23 21:09:02.882  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 479711
                    2022-11-23 21:09:07.324  - info: tapo.0 (479711) starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#5869cef8f69a857a6c4970d13573d0a5edcba1d6) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                    2022-11-23 21:09:07.737  - info: tapo.0 (479711) Login tp TAPO App
                    2022-11-23 21:09:08.262  - info: tapo.0 (479711) Login succesfull
                    2022-11-23 21:09:08.492  - info: tapo.0 (479711) Found 3 devices
                    2022-11-23 21:09:08.861  - info: tapo.0 (479711) Init device 8022xxxCF04 type P115 with ip 192.168.0.115
                    2022-11-23 21:09:08.961  - info: tapo.0 (479711) Initialized 8022xxxCF04
                    2022-11-23 21:09:09.253  - info: tapo.0 (479711) Init device 8022xxxDD97 type P115 with ip 192.168.0.117
                    2022-11-23 21:09:09.355  - info: tapo.0 (479711) Initialized 8022xxxDD97
                    2022-11-23 21:09:09.716  - info: tapo.0 (479711) Init device 8022xxx4523 type P115 with ip 192.168.0.116
                    2022-11-23 21:09:09.818  - info: tapo.0 (479711) Initialized 8022xxx4523
                    2022-11-23 21:09:09.991  - info: tapo.0 (479711) Wait for connections
                    2022-11-23 21:10:00.052  - info: tapo.0 (479711) Scheduled restart.
                    2022-11-23 21:10:00.170  - info: tapo.0 (479711) terminating
                    2022-11-23 21:10:00.175  - info: tapo.0 (479711) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2022-11-23 21:10:00.702  - warn: tapo.0 (479711) get state error: Connection is closed.
                    2022-11-23 21:10:00.713  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.04": DB closed
                    2022-11-23 21:10:00.716  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.03: DB closed
                    2022-11-23 21:10:00.718  - warn: tapo.0 (479711) get state error: Connection is closed.
                    2022-11-23 21:10:00.720  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.04: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.04": DB closed
                    2022-11-23 21:10:00.726  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.05": Connection is closed.
                    2022-11-23 21:10:00.728  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.04: DB closed
                    2022-11-23 21:10:00.729  - warn: tapo.0 (479711) get state error: Connection is closed.
                    2022-11-23 21:10:00.730  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.05: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.05": Connection is closed.
                    2022-11-23 21:10:00.735  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.06": Connection is closed.
                    2022-11-23 21:10:00.737  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.05: DB closed
                    2022-11-23 21:10:00.738  - warn: tapo.0 (479711) get state error: Connection is closed.
                    2022-11-23 21:10:00.740  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.06: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.06": Connection is closed.
                    2022-11-23 21:10:01.408  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
                    2022-11-23 21:10:01.409  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
                    2022-11-23 21:10:03.445  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 479768
                    2022-11-23 21:10:08.789  - info: tapo.0 (479768) starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#5869cef8f69a857a6c4970d13573d0a5edcba1d6) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                    2022-11-23 21:10:09.164  - info: tapo.0 (479768) Login tp TAPO App
                    2022-11-23 21:10:09.565  - error: tapo.0 (479768) Login failed
                    2022-11-23 21:10:09.569  - error: tapo.0 (479768) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
                    Das tritt mehrmals am Tag auf und die Instanz startet dann immer neu.
                    Zur Info: das hier ist mit der GitHub Version. Die hatte ich installiert, weil genau das auch schon vorher mit der npm-Version aufgetreten ist.
                      @mrbungle64 Ja anscheinend wird der adapter jede minute neugestartet
                      • mrbungle64
                        Ich habe diese Datenpunkte jetzt mal gelöscht. Mal schauen wie es morgen läuft.
                        Muss ja jetzt erst mal mind. 30 Minuten warten 😉
                          @mrbungle64 Bitte auch den tapo.0 (479641) Scheduled restart rausnehmen
                            Gabe last edited by
                            Mit den Änderung die Tombox vorgenommen hat, funktioniert bei mir jetzt alles gut. Danke dir
                              tombox @Gabe last edited by
                              @gabe also motionDetection wird auch immer korrekt gesetzt bei Bewegung und es gibt die states
                              alert
                              lensMask
                              forceWhiteLamp
                              ra juha G 2 Replies Last reply Reply Quote 0
                              • ra juha
                                ra juha @tombox last edited by
                                @tombox: Wow. Sieht gut aus! Danke. Kann nun Alarm und Privatspäre toggeln. Super!!!
                                  Gabe @tombox last edited by
                                  @tombox
                                  also ich nutze hauptsächlich lensMask und AlertConfig und das funktioniert super.
                                  Aber auch motionEvent passt bei mir.
                                  Gruß und Danke!!!
                                  • mrbungle64
                                    Guter Hinweis - seitdem ich die raus genommen habe läuft es scheinbar fehlerfrei durch (bisher) 👍
                                    Aber warum wirken sich 3 Scheduled restarts am Tag so extrem negativ aus?
                                      @mrbungle64 Er war nicht auf 3 mal eingestellt sondern jede Minute
                                      • mrbungle64
                                        Ich verstehe, dass das in dem Log Auszug so aussieht - aber das war nicht so eingestellt.
                                        Es war auf 9 Uhr und 21 Uhr eingestellt + dass ich zusätzlich Nachts die Instanz per Skript gestoppt hatte.
                                        Die Probleme fingen um 9 Uhr (nach dem 1. Scheduled restart) an und dann hat sich die Instanz jede Minute aus irgendwelchen Gründen neu gestartet.
                                        Hier noch mal ein Auszug aus dem Log um 9 Uhr inkl. den letzten Einträgen davor. Die waren von 8:45 - und ab 9 Uhr hat sich die tapo Instanz dann jede Minute neu gestartet
                                        2022-11-23 08:45:06.257  - info: vanmoof-webapi.0 (465342) Terminated (NO_ERROR): Without reason
                                        2022-11-23 08:45:06.830  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 terminated with code 0 (NO_ERROR)
                                        2022-11-23 09:00:00.119  - info: tapo.0 (464412) Scheduled restart.
                                        2022-11-23 09:00:00.244  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 started with pid 465595
                                        2022-11-23 09:00:00.433  - info: tapo.0 (464412) terminating
                                        2022-11-23 09:00:00.437  - info: tapo.0 (464412) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-11-23 09:00:00.955  - warn: tapo.0 (464412) get state error: Connection is closed.
                                        2022-11-23 09:00:00.965  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.14": DB closed
                                        2022-11-23 09:00:00.968  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.13: DB closed
                                        2022-11-23 09:00:00.970  - warn: tapo.0 (464412) get state error: Connection is closed.
                                        2022-11-23 09:00:00.972  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.14: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.14": DB closed
                                        2022-11-23 09:00:00.978  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": Connection is closed.
                                        2022-11-23 09:00:00.981  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.14: DB closed
                                        2022-11-23 09:00:00.982  - warn: tapo.0 (464412) get state error: Connection is closed.
                                        2022-11-23 09:00:00.983  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.15: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": Connection is closed.
                                        2022-11-23 09:00:00.988  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
                                        2022-11-23 09:00:00.990  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.15: DB closed
                                        2022-11-23 09:00:00.991  - warn: tapo.0 (464412) get state error: Connection is closed.
                                        2022-11-23 09:00:00.992  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.16: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
                                        2022-11-23 09:00:02.442  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
                                        2022-11-23 09:00:02.444  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
                                        2022-11-23 09:00:04.337  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 465623
                                        2022-11-23 09:00:05.659  - info: vanmoof-webapi.0 (465595) starting. Version 0.0.1 (non-npm: mrbungle64/ioBroker.vanmoof-webapi#7191e9a468c074a159c4e8468d731016437e2128) in /opt/iobroker/node_modules/iobroker.vanmoof-webapi, node: v16.18.1, js-controller: 4.0.23
                                        2022-11-23 09:00:06.620  - info: vanmoof-webapi.0 (465595) Processing data for account: 'Sascha Hölzel'
                                        2022-11-23 09:00:06.795  - info: vanmoof-webapi.0 (465595) Number of bikes: 1
                                        2022-11-23 09:00:06.798  - info: vanmoof-webapi.0 (465595) Processing data for Bike #1 (id: 160905):
                                        2022-11-23 09:00:09.456  - info: vanmoof-webapi.0 (465595) Terminated (NO_ERROR): Without reason
                                        2022-11-23 09:00:10.100  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 terminated with code 0 (NO_ERROR)
                                        2022-11-23 09:00:13.557  - info: tapo.0 (465623) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                                        2022-11-23 09:00:13.986  - info: tapo.0 (465623) Login tp TAPO App
                                        2022-11-23 09:00:14.614  - info: tapo.0 (465623) Login succesfull
                                        2022-11-23 09:00:14.836  - info: tapo.0 (465623) Found 3 devices
                                        2022-11-23 09:00:15.154  - info: tapo.0 (465623) Init device 8022xxxCF04 type P115 with ip 192.168.0.115
                                        2022-11-23 09:00:15.473  - info: tapo.0 (465623) Initialized 8022xxxCF04
                                        2022-11-23 09:00:15.716  - info: tapo.0 (465623) Init device 8022xxxxDD97 type P115 with ip 192.168.0.117
                                        2022-11-23 09:00:15.933  - info: tapo.0 (465623) Initialized 8022xxxxDD97
                                        2022-11-23 09:00:16.187  - info: tapo.0 (465623) Init device 8022xxxx4523 type P115 with ip 192.168.0.116
                                        2022-11-23 09:00:16.318  - info: tapo.0 (465623) Initialized 8022xxxx4523
                                        2022-11-23 09:00:16.433  - info: tapo.0 (465623) Wait for connections
                                        2022-11-23 09:01:00.026  - info: tapo.0 (465623) Scheduled restart.
                                        Ergänzung:
                                        Ich vermute mal, dass der Scheduled Restart jede Minute nachgeholt wird, weil der Restart ja jeweils nicht erfolgreich ausgeführt werden konnte. Ist aber nur ein Gedanke was der Hintergrund von den minütlichen Neustarts sein könnte...
                                          helfi9999 @tombox last edited by
                                          Hi ich habe ein neuen Adapter für TP-Link die mit der Tapo App überwacht werden können, geschrieben.
                                          Der Adapter loggt sich über die Cloud ein um alle Geräte mit IP zu finden
                                          Wenn das Gerät nicht als online erkannt wird kann manuell die IP gesetzt wird.
                                          tapo.0.id.ip
                                          Dann versucht er sich lokal mit username und Password auf die Geräte zu verbinden und zu steuern.
                                          Aktuelle Werte:
                                          tapo.0.id
                                          Minimum Node v14 muss installiert sein, sonst bekommt man exit code 25 beim installieren
                                          Zum Installieren:
                                          https://github.com/TA2k/ioBroker.tapo
                                          Unter Adapter Experten Modus aktivieren:
                                          Unter Adapter das Github Icon klicken:
                                          Benutzerdefiniert auswählen und die Url einfügen.
                                          Dann unter Adapter den tapo Adapter suchen und ganz rechts auf das Plus klicken.
                                          Loginablauf:
                                          Die Tapo App Zugangsdaten eingeben
                                          Steuern
                                          tapo.0.id.remote auf true setzen steuert den jeweiligen Befehl
                                          Hallo habe es so wie deine Anleitung gemacht. Adapter wird nicht grün und folgende Log Meldung bekomme ich :
                                          tapo.0
                                          2022-11-26 14:42:53.750	info	Wait for connections
                                          tapo.0
                                          2022-11-26 14:42:53.736	warn	Login failed using cached device list
                                          tapo.0
                                          2022-11-26 14:42:53.735	error	Please set mfa in the instance settings
                                          tapo.0
                                          2022-11-26 14:42:53.723	info	Login tp TAPO App
                                          tapo.0
                                          2022-11-26 14:42:53.622	info	starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#8bb2e108a00246ade916287de7d71947043d3482) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                                          host.Iobroker
                                          2022-11-26 14:42:49.574	info	instance system.adapter.tapo.0 started with pid 40464
                                          host.Iobroker
                                          2022-11-26 14:42:47.060	info	instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          host.Iobroker
                                          2022-11-26 14:42:46.425	info	stopInstance system.adapter.tapo.0 send kill signal
                                          tapo.0
                                          2022-11-26 14:42:46.268	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          tapo.0
                                          2022-11-26 14:42:46.265	info	terminating
                                          tapo.0
                                          2022-11-26 14:42:46.262	info	Got terminate signal TERMINATE_YOURSELF
                                          Könntest du mir bitte sagen was ich verkehrt mache??
                                          Gruss helfi
                                            @helfi9999 Du hast sicher MFA aktiv. Ich habe das nur blind eingebaut und ist bisher ungerüstet und geht anscheinend nicht
                                            753
                                            189305
