    4. Test Adapter ice Road
      liv-in-sky @David G. last edited by
      @david-g
      hast du vorher die alte version gestartet ? dann würde ich mal den iob server neustarten
        apollon77 @David G. last edited by
        @david-g Bitte vollständiges Log senden sodass auch die meldungen vom "Host" drin sind, Da sollte man sehen was passiert
          apollon77 @xmace last edited by
          @xmace Oder ein kleines JavaScript was setObject machen darf und das instanz objekt aktualisieren.
          • David G.
            @Thomas-Braun
            Hab ich bisher noch nie gemacht.
            Hab das System aber grad reboot, kein Unterschied.
            @liv-in-sky
            Anbei ein ungefiltertes Log:
            2022-10-03 20:04:49.646	info	instance system.adapter.iceroad.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            host.pi
            2022-10-03 20:04:49.256	info	stopInstance system.adapter.iceroad.0 send kill signal
            iceroad.0
            2022-10-03 20:04:48.930	info	response.data: {"success":true,"message":"Request successful!","code":200,"callsLeft":34,"callsDailyLimit":50,"callsResetInSeconds":14112,"result":{"requestDate":"2022-10-03 20:04:48","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}}
            iceroad.0
            2022-10-03 20:04:48.929	info	response.data.result: {"requestDate":"2022-10-03 20:04:48","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}
            iceroad.0
            2022-10-03 20:04:48.791	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            iceroad.0
            2022-10-03 20:04:48.788	info	terminating
            iceroad.0
            2022-10-03 20:04:48.786	info	Got terminate signal TERMINATE_YOURSELF
            host.pi
            2022-10-03 20:04:48.776	info	stopInstance system.adapter.iceroad.0 (force=false, process=true)
            host.pi
            2022-10-03 20:04:48.774	info	"system.adapter.iceroad.0" disabled
            iceroad.0
            2022-10-03 20:04:48.204	info	starting. Version 0.1.1 (non-npm: iobroker-community-adapters/ioBroker.iceroad#99c619ea3f1ebd3544a22fe33518a2d98b97a3f0) in /opt/iobroker/node_modules/iobroker.iceroad, node: v16.17.1, js-controller: 4.0.23
            host.pi
            2022-10-03 20:04:44.514	info	instance system.adapter.iceroad.0 started with pid 22006
            host.pi
            2022-10-03 20:04:43.208	info	Restart adapter system.adapter.iceroad.0 because enabled
            host.pi
            2022-10-03 20:04:43.208	info	instance system.adapter.iceroad.0 terminated with code 0 (NO_ERROR)
            iceroad.0
            2022-10-03 20:04:42.478	info	Terminated (NO_ERROR): Without reason
            iceroad.0
            2022-10-03 20:04:42.471	info	terminating
            iceroad.0
            2022-10-03 20:04:42.014	info	response.data: {"success":true,"message":"Request successful!","code":200,"callsLeft":35,"callsDailyLimit":50,"callsResetInSeconds":14119,"result":{"requestDate":"2022-10-03 20:04:41","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}}
            iceroad.0
            2022-10-03 20:04:42.013	info	response.data.result: {"requestDate":"2022-10-03 20:04:41","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}
            iceroad.0
            2022-10-03 20:04:41.417	info	starting. Version 0.1.1 (non-npm: iobroker-community-adapters/ioBroker.iceroad#99c619ea3f1ebd3544a22fe33518a2d98b97a3f0) in /opt/iobroker/node_modules/iobroker.iceroad, node: v16.17.1, js-controller: 4.0.23
            host.pi
            2022-10-03 20:04:38.195	info	instance system.adapter.iceroad.0 started with pid 21771
            host.pi
            2022-10-03 20:04:36.858	info	Restart adapter system.adapter.iceroad.0 because enabled
            host.pi
            2022-10-03 20:04:36.858	info	instance system.adapter.iceroad.0 terminated with code 0 (NO_ERROR)
            iceroad.0
            2022-10-03 20:04:36.127	info	Terminated (NO_ERROR): Without reason
            iceroad.0
            2022-10-03 20:04:36.125	info	terminating
            iceroad.0
            2022-10-03 20:04:36.020	info	response.data: {"success":true,"message":"Request successful!","code":200,"callsLeft":36,"callsDailyLimit":50,"callsResetInSeconds":14125,"result":{"requestDate":"2022-10-03 20:04:35","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}}
            iceroad.0
            2022-10-03 20:04:36.019	info	response.data.result: {"requestDate":"2022-10-03 20:04:35","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}
            iceroad.0
            2022-10-03 20:04:35.293	info	starting. Version 0.1.1 (non-npm: iobroker-community-adapters/ioBroker.iceroad#99c619ea3f1ebd3544a22fe33518a2d98b97a3f0) in /opt/iobroker/node_modules/iobroker.iceroad, node: v16.17.1, js-controller: 4.0.23
            host.pi
            2022-10-03 20:04:31.761	info	instance system.adapter.iceroad.0 started with pid 21752
            host.pi
            2022-10-03 20:04:30.492	info	Restart adapter system.adapter.iceroad.0 because enabled
            host.pi
            2022-10-03 20:04:30.491	info	instance system.adapter.iceroad.0 terminated with code 0 (NO_ERROR)
            iceroad.0
            2022-10-03 20:04:29.709	info	Terminated (NO_ERROR): Without reason
            iceroad.0
            2022-10-03 20:04:29.707	info	terminating
            iceroad.0
            2022-10-03 20:04:29.636	info	response.data: {"success":true,"message":"Request successful!","code":200,"callsLeft":37,"callsDailyLimit":50,"callsResetInSeconds":14131,"result":{"requestDate":"2022-10-03 20:04:29","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}}
            iceroad.0
            2022-10-03 20:04:29.635	info	response.data.result: {"requestDate":"2022-10-03 20:04:29","forecastId":0,"forecastText":"Kein Eis.","forecastCity":"Hilchenbach","forecastDate":"2022-10-04"}
            iceroad.0
            2022-10-03 20:04:29.028	info	starting. Version 0.1.1 (non-npm: iobroker-community-adapters/ioBroker.iceroad#99c619ea3f1ebd3544a22fe33518a2d98b97a3f0) in /opt/iobroker/node_modules/iobroker.iceroad, node: v16.17.1, js-controller: 4.0.23
            host.pi
            2022-10-03 20:04:25.531	info	instance system.adapter.iceroad.0 started with pid 21732
            host.pi
            2022-10-03 20:04:24.570	info	"system.adapter.iceroad.0" enabled
              apollon77 last edited by
              Ok, also bei dir denkt das System es ist ein normaler Adaper und kein Schedule Adapter was es ist.
              Am besten:
              • Adapter (nicht nur instanz) deinstallieren
              • iobroker neu starten
              • Adapter neu von GitHub installieren
              David G. 1 Reply Last reply Reply Quote 1
              • David G.
                David G. @apollon77 last edited by
                @apollon77
                Danke, jetzt klappt es.
                Jetzt wo du es sagst, sehe ich es auch. Am Screenshot ist ist nicht die kleine gelbe Uhr sondern der farbige Punkt.
                  bommel_030 @PatrickWalther last edited by
                  @patrickwalther
                  Soweit läuft der Adapter eigentlich stabil. Allerdings klappt das mit der Benachrichtigung bei mir nicht. Egal ob Pushover oder Telegram, es kommt immer die Meldung
                  Error from Pushover: message cannot be blank
                  Cannot send message [chatId - XXXXXXX]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  S ? 2 Replies Last reply Reply Quote 0
                    Siggi0904 @bommel_030 last edited by
                    @bommel_030 mach bitte ein issue auf github auf.
                    @apollon77 kümmert sich jetzt um den Adapter.
                    apollon77 B 2 Replies Last reply Reply Quote 0
                      apollon77 @Siggi0904 last edited by
                      @siggi0904 sagte in Test Adapter ice Road:
                      Hhm ..., sagt wer? ;-)) Die Community Developer kümmern sich drum ... In einer idealen Welt sind das ein paar mehr als nur ich 😉 ber ja ohne Issue ist es für keinen sichtbar
                        Siggi0904 @apollon77 last edited by
                        @apollon77 Man sieht nur dich 🙂
                          @siggi0904 🙈
                            bommel_030 @Siggi0904 last edited by
                            @siggi0904
                            Soweit so klar, die Frage war eher ob es bei anderen funktioniert oder nicht.
                              @bommel_030 Ich nutze den Adapter nicht. Ich nutze das Blockly-Script von hier und hab die Erinnerung in eine extra Abfrage gepackt.
                                A Former User @bommel_030 last edited by
                                @bommel_030 bin gerade dabei mich mit dem Adapter ein wenig auseinander zu setzen. Finde die Idee eigentlich ganz nett. Der Fehler mit der Benachrichtigung sollte nun behoben sein. Wenn nicht dann bitte im Issue #15 melden.
                                  bommel_030 @Guest last edited by
                                  @ciddi89
                                  Sauber, Test Messages kommen an und auch wenn man den Adapter startet. Im Log auch keine Fehler.
                                  Als weitere Optimierung könnte man den Inhalt von "forecastText" in die Nachricht mit reinpacken?!?
                                  sigi234 ? 2 Replies Last reply Reply Quote 0
                                    sigi234 Forum Testing Most Active @bommel_030 last edited by sigi234
                                    @bommel_030 sagte in Test Adapter ice Road:
                                    Und ein Icon bei true or false als DP?
                                    Hmm...., kann man ja selber machen wenn es einen DP mit true/false gäbe.
                                    ? B 3 Replies Last reply Reply Quote 0
                                      @bommel_030 Super. Ist ja schon mal ein Anfang. 👍🏻
                                      Ja eigentlich hatte ich beim ersten benutzen damit gerechnet das der Text gesendet wird. Aber es wird nur der Text genutzt den man selbst eingibt in den Instanz Einstellungen. Bin am überlegen wie man es am besten umsetzt.
                                        A Former User @sigi234 last edited by
                                        @sigi234 dp true/false wird auf jeden Fall mit reingenommen. Icon denke ist eher schwieriger. Finde es sollte auch zu den passenden Design des eigenes Vis passen.
                                          @ciddi89
                                          Dachte ich ursprünglich auch. Ich weiß allerdings auch noch nicht wann der Adapter eine Message schicken will / soll.
                                          Keine Ahnung ob er nur eine Nachricht schicken soll wenn der Datenpunkt von "kein Eis" zu "Eis" wechselt, oder bei jedem Wechsel? Oder bei jedem Abruf? Momentan sieht es hier so aus das "Eis !" die nächsten Tage erstmal bestehen bleibt :-S
                                          Auf jeden danke schonmal!
                                            @bommel_030 den Gedanke hatte ich auch. Nun ist er k auf 60min eingestellt wo man auch jedes Mal eine Nachricht bekommt. Finde das nervt ein bisschen auf Dauer. Mir persönlich würde es reichen wenn es nur bei Status Änderungen eine Nachricht gesendet wird.
                                            103
                                            8283
