    • David G.
      David G. @ESP8266 last edited by
      @esp8266
      Anbei die config:
      [MakeImage]
      ;LogImageLocation = /log/source
      WaitBeforeTakingPicture = 5
      ;LogfileRetentionInDays = 15
      Brightness = 0
      Contrast = 0
      Saturation = 0
      LEDIntensity = 50
      ImageQuality = 12
      ImageSize = VGA
      FixedExposure = false
      [Alignment]
      InitialRotate = 12
      InitialMirror = false
      SearchFieldX = 20
      SearchFieldY = 20
      AlignmentAlgo = default
      FlipImageSize = false
      /config/ref0.jpg 320 320
      /config/ref1.jpg 423 190
      [Digits]
      Model = /config/dig-cont_0570_s3.tflite
      CNNGoodThreshold = 0.5
      ;LogImageLocation = /log/digit
      ;LogfileRetentionInDays = 3
      main.dig1 280 190 22 40 false
      main.dig2 311 191 22 40 false
      main.dig3 338 191 22 40 false
      main.dig4 365 191 22 40 0
      main.dig5 395 191 22 40 0
      [Analog]
      Model = /config/ana-cont_11.3.0_s2.tflite
      ;LogImageLocation = /log/analog
      main.ana1 402 295 75 75 false
      main.ana2 351 371 75 75 false
      main.ana3 259 381 75 75 false
      main.ana4 195 315 75 75 false
      [PostProcessing]
      ;main.DecimalShift = 0
      PreValueUse = true
      PreValueAgeStartup = 720
      AllowNegativeRates = false
      main.MaxRateValue = 0.05
      ;main.MaxRateType = AbsoluteChange
      ;main.ExtendedResolution = false
      ;main.IgnoreLeadingNaN = true
      ErrorMessage = true
      CheckDigitIncreaseConsistency = false
      [MQTT]
      Uri = mqtt://192.168.99.33:1884
      MainTopic = wasserzaehler
      ClientID = wasserzaehler
      user = iobroker
      password = dagrae
      SetRetainFlag = true
      ;[InfluxDB]
      ;Uri = undefined
      ;Database =
      ;Measurement = undefined
      ;user = undefined
      ;password = undefined
      ;[GPIO]
      ;IO0 = input disabled 10 false false
      ;IO1 = input disabled 10 false false
      ;IO3 = input disabled 10 false false
      ;IO4 = built-in-led disabled 10 false false
      ;IO12 = input-pullup disabled 10 false false
      ;IO13 = input-pullup disabled 10 false false
      LEDType = WS2812
      LEDNumbers = 2
      LEDColor = 150 150 150
      [AutoTimer]
      AutoStart = true
      Intervall = 10
      [Debug]
      ;Logfile = false
      [System]
      TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
      ;TimeServer = undefined
      ;AutoAdjustSummertime = false
      ;Hostname = undefined
      SetupMode = false
      Evtl hab ich das Bild von einer Stelle geholt wo es nicht hoch aufgelöst gespeichert ist.
      So sieht es aus, wenn ich die Zahlen justiere:
      Nachjustieren kann ich heute abend mal. Bin unterwegs.
      • ESP8266
        ESP8266 @David G. last edited by
        @david-g Ok, übernimm mal die Einstellungen:
        [PostProcessing]
        PreValueUse = true
        main.MaxRateValue = 1
        main.IgnoreLeadingNaN = false
        ErrorMessage = true
        CheckDigitIncreaseConsistency = true
        • Rene55
          Rene55 @jomjol last edited by
          @jomjol Jetzt hab ich die richtigen Dateien drauf 'master', vorher war 'rolling' (wobei mir in der Version das Ausrichten der digitalen ROIs sehr gut gefallen hat [nächstes Release?]). Es sieht jetzt deutlich besser aus, der o.g. Fehler tritt nicht mehr auf.
          Ich muss mich jetzt nur noch mit zwei Dingen beschäftigen: sauberes, scharfes Bild und stabiles WLAN. Sind aber zunächst meine Baustellen.
          Danke für die Hilfestellungen. Bei Fragen komme ich bestimmt wieder hierhin.
          • David G.
            David G. @ESP8266 last edited by David G.
            @esp8266
            Hab seien Settings mal übernommen. War ja eigentlich nur ein Parameter anders.
            Das Ding will mich aber ärgern.
            Passe den Stand an (Beispiel Kreis links):
            Reboot und dann kommt das raus:
            • Rene55
              Rene55 last edited by
              Ich habe einen Wasserzähler mit 5 Stellen vor dem Komma, und drei danach. Womit/wodurch wird denn das 'Komma' richtig gesetzt?
              • David G.
                David G. @Rene55 last edited by
                @rene55
                Dafür ist in den Serrings die Option DecimalShift (oder so ähnlich).
                ESP8266 Rene55 2 Replies Last reply Reply Quote 0
                • ESP8266
                  ESP8266 @David G. last edited by ESP8266
                  @david-g , es sind 2 Parameter anders.....und nach Rebooten mit dem Aktualisren etwas Zeit lassen, sonst kommt der ESP nicht hinterher.
                  • Rene55
                    Rene55 @David G. last edited by
                    @david-g sagte in Wasserzähler - Version 2 - all-in-device:
                    @rene55
                    Ok, Dann muss ich also den Parameter in [PostProcessing]
                    ";main.DecimalShift = 0" auf "main.DecimalShift = 3" ändern. Probiere ich nächste Woche aus. Danke.
                    • ESP8266
                      ESP8266 last edited by ESP8266
                      @esp8266
                      Weil deine Marker ungenau eingstellt sind, habe ich schon mal geschrieben. Warum hat der Marker soviel Luft nach oben. Warum sind die Buchstaben nicht richtig eingefasst?
                      Ich habe doch ein Beispiel gepostet.
                      Deine Digits genauso. Bei mir ist die Ebene gleich ausgerichtet.
                      Wenn man die Wiki richtig durch liesst, sollte alles schon beantwortet sein.
                      Und mal ein wenig ausprobieren schadet auch nichts, es geht deshalb nichts kaputt.
                      Ich bin raus hier....
                      • David G.
                        @esp8266
                        Das mit den Markern muss bei den über 2000 Posts wohl untergegangen sein.
                        Die digits haben unterschiedliche Höhen da dekse tatsächlich unterschiedlich sind.
                        Manche Zahlen stehen immer höher.
                        Hab gestern aber alles (bis auf die Marker) nochmal angepasst.
                        EDIT
                        Wenn ich die digits wirklich genau ausreichte passt der innere Rahmen nicht. Entweder steht außen über oder drinnen ist die Zahl abgeschnitten. Vermutlich weil ich den unteren weißen Bereich nicht mit erfassen möchte.
                        • ESP8266
                          @david-g, das ist bei mir genauso und juckt der Software überhaupt nicht. Was machste denn, wenn die Zahl dann mittig steht, wieder nach justieren?
                          So ganz doof ist die Sofware nicht
                          und das es 2 Parameter waren, muss wohl auch untergegangen sein.
                          2000 Posts finde ich ein bisschen übertrieben. Geschrieben wurde das alles in den letzten 10- 12 Posts.
                          Einen schönen 1. Advent noch.
                          • ESP8266
                            @david-g , noch mal zu deiner config.ini. Was mir im nachherein noch aufgefallen ist, das einiges anders ist wie nur die 2 Parameter. Genauer sind es sogar 3 Parameter die ins Auge fallen. Schau mal genauer hin.
                            Bei dir sind zudem fast alle Parameter mit Semikolons versehen, bei mir nicht. Das heißt, das die nicht angehakt wurden bzw. nicht Akiv sind.
                            David G. 2 Replies Last reply Reply Quote 0
                            • David G.
                              @esp8266
                              Stimmt. Da hast du recht.
                              Habe deine Settings per c&p eingefügt als du sie gepostst hast.
                              Gestern abend hatte ich noch einmal eine "Falschmeldung".
                              Hab dann die Digits alle im ganzen noch ein wenig verschoben.
                              Nach dem reboot hat er es dann richtig erkannt.
                              Denke, jetzt habe ich es.
                              Edit
                              Was mir aufgefallen ist. Auf dem Bild denkt man, dass um die Referenzmarken noch was Luft ist. In dem abgespeicherten Referenzbildern schneidet es auf den Pixel genau die Buchstaben an.
                              • David G.
                                @esp8266
                                Hey,
                                hab jetzt wieder, dass er einem qm zu viel ausliest.
                                Hast du noch einen Tip für mich?
                                Die Konfiguration ist wie oben, nur mit deinen Anpassungen.
                                Die Marker und Ausrichtung der Digits sehen wie folgt aus beim falsch eingelesen Zählerstand:
                                • ESP8266
                                  @david-g , spiel bitte noch mit den Einstellungen rum, die 4 wurde noch nicht erreicht, d.h. dann sollte normal noch die 3 zur Berechnung heran gezogen werden. Wenn dann dort irgendwann NaN steht, einfach ignorieren. Das berechnet dann die Software selbst. Der korrekte Wert sollte dann in der Value erscheinen. Das ist immer bei Zahlenwechsel.
                                  ...und ändere mal dein Model in folgendes:
                                  btw. das C hat noch Luft nach unten 1-2 Pixel nach oben 1 Pixel. Das einfassen der Marker ist besonders wichtig sonst verschiebt sich das Bild evtl. 2 Pixel nach unten oder 1 Pixel nach oben und wird Schief. Die Erfahrung habe ich selber schon gemacht
                                  • David G.
                                    @esp8266
                                    Die Digits habe ich umgestellt und das C was angepasst.
                                    Für die analogen Zeiger habe ich den entsprechenden Eintrag nicht gefunden.
                                    Nach dem reboot hat er die 3 richtig erkannt.
                                    Ich beobachte es weiter.
                                    P. S.
                                    Was macht die Referenz?
                                    Falls das Bild was verwackelt zum nachjustieren?
                                    • ESP8266
                                      @david-g , verstehe dein letzten Absatz nicht. Wenn man das Gehäuse verdreht oder gegen kommt, sodas es sich verschiebt, passt die Referenz nicht mehr (logisch). Darum sollte es so fest wie möglich montiert werden. Nicht das jeder mit dem Arxxxx gegen kommt und verschiebt.
                                      Das ist nicht Sinn der Sache. Oder du machst die Referenz öfters neu, soll welche geben dié Spaß dran haben....😊
                                      btw...wenn deine Analogen passen, dann kannst du das so belassen.
                                      • David G.
                                        @esp8266
                                        Die Frage mit der Referenz war eher aus Interesse warum man die braucht.
                                        Die Koordinaten wo die Software welche Zahl findet gibt man ja genau ein. Und die bleiben ja auch gleich, wenn man nicht an der Kamera wackelt.
                                        Deshalb dachte ich die Referenz wären so eine Art Fixpunkt zum nachkorrigieren, da sich die Zahlen logischerweise regelmäßig ändern.
                                        Aber das ist ja alles so ausgefuchst (und cool 😎), da hat es schon einen Sinn 😀
                                        • felix fre
                                          felix fre @BananaJoe last edited by
                                          @bananajoe said in Wasserzähler - Version 2 - all-in-device:
                                          RFID Platine
                                          welche hast du da genau vorliegen?
                                          • ESP8266
                                            @esp8266
                                            Die Referenz dient als Vergleich für die aufgenommenen Folgebilder. Wichtig ist dabei, das die Zahlen in den ausgerichteten ROI`s in den vorgegebenen Bereichen richtig erkannt werden können. Auch dient die Referenz für die Helligkeit und Kontrast Einstellung nur so kann alles Optimal zusammen arbeiten.
                                            238
                                            3411
                                            2022886
